  4. gelöst - Was bedeudet diese Fehlermeldung?
    6.8k
update error
15 Beiträge 5 Kommentatoren 2.8k Aufrufe 5 Beobachtet
  • MaufloM Offline
    MaufloM Offline
    Mauflo
    schrieb am zuletzt editiert von Mauflo
    In letzter Zeit erhalte ich folgende Fehlermeldungen in den Update Prozessen. Der Updateprozess funktioniert allerdings . Nur macht mich die Meldung nervös. Kann mir bitte jemand sagen, wass die ERR Meldungen in der Zeile mit: "Package pixman-1 was not found in the pkg-config search path." bedeuten?
    $ ./iobroker upgrade iot
    Update iot from @1.4.2 to @1.4.4
    host.iobrokerP4 Adapter "system.adapter.iot.0" is stopped.
    NPM version: 6.14.2npm install iobroker.iot@1.4.4 --loglevel error --prefix "/opt/iobroker" (System call)
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' foundgyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gypgyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.93-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)node-pre-gyp ERR! System Linux 4.19.93-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.19.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok info sharp Downloading https://github.com/lovell/sharp-libvips/releases/download/v8.9.1/libvips-8.9.1-linux-armv7.tar.gz
    Update "system.adapter.iot.0"
    upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.8b3eca34.js.map static/js/runtime-main.8b3eca34.js.map application/json
    upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.8b3eca34.js static/js/runtime-main.8b3eca34.js application/javascript
    upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.721d1c42.chunk.js.map static/js/main.721d1c42.chunk.js.map application/json
    upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.721d1c42.chunk.js static/js/main.721d1c42.chunk.js application/javascript
    upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.faa62e98.chunk.js.map static/js/2.faa62e98.chunk.js.map application/json
    upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.faa62e98.chunk.js.LICENSE.txt static/js/2.faa62e98.chunk.js.LICENSE.txt text/plain
    upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.faa62e98.chunk.js static/js/2.faa62e98.chunk.js application/javascript
    upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css.map static/css/main.d4bed9c6.chunk.css.map application/json
    upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css static/css/main.d4bed9c6.chunk.css text/css
    upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.b1b16afe.chunk.css.map static/css/2.b1b16afe.chunk.css.map application/json
    upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.b1b16afe.chunk.css static/css/2.b1b16afe.chunk.css text/css
    upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
    upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.b5249c907f3acd0903d8c4d182d1dce1.js precache-manifest.b5249c907f3acd0903d8c4d182d1dce1.js application/javascript
    upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
    upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
    upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
    upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
    upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
    upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
    upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
    Adapter "iot" updatedhost.iobrokerP4 Adapter "system.adapter.iot.0" is started
    process exited with code 0
    RaspberryPi 4 4 GB - Raspbian light Buster - ARMv7 Processor rev 3 (v7l) - Node.js v12.18.0 - NPM 6.14.4 - Aktive Instanzen 18 (admin, alexa2, backitup, broadlink2, ham-wemo, harmony, history, hs100, hue, info, iot, javascript, radar2, scenes, tr-064, web [2x], wifilight) all latest and updated
    • MaufloM Mauflo
      wendy2702W Online
      wendy2702W Online
      wendy2702
      @Mauflo sagte in Was bedeudet diese Fehlermeldung?:
      Z.B.
      https://forum.iobroker.net/topic/26900/hinzufuegen-von-roomba-adapter-wirft-fehler
      Oder hier noch mehr
      https://forum.iobroker.net/search?term=Package pixman-1 was not found&in=titlesposts
      • MaufloM Offline
        MaufloM Offline
        Mauflo
        Danke, aber das hat leider nicht geholfen. Die Installation ist schiefgegangen. Ich bekomme beim installieren am RaspberryPi4 jetzt folgendes:
        sudo npm install canvas --unsafe-perm=true
        > canvas@2.6.1 install /home/pi/node_modules/canvas
        > node-pre-gyp install --fallback-to-build
        node-pre-gyp WARN Using needle for node-pre-gyp https download
        node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v64-linux-glibc-arm.tar.gz
        node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@10.20.1 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/node_modules/canvas/build/Release/canvas.n                                           ode" "--module_name=canvas" "--module_path=/home/pi/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
        gyp ERR! cwd /home/pi/node_modules/canvas
        gyp ERR! node -v v10.20.1
        gyp ERR! not ok
        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/node_modules/canva                                           s/build/Release/canvas.node --module_name=canvas --module_path=/home/pi/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64'                                            (1)
        node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
        node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
        node-pre-gyp ERR! cwd /home/pi/node_modules/canvas
        node-pre-gyp ERR! node -v v10.20.1
        Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/node_modules/canvas/build/Release/canvas.node --m                                           odule_name=canvas --module_path=/home/pi/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm WARN pi No description
        npm WARN pi No repository field.
        npm WARN pi No README data
        npm WARN pi No license field.
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the canvas@2.6.1 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /root/.npm/_logs/2020-04-16T19_06_29_983Z-debug.log
        • MaufloM Mauflo
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          wendy2702W Online
          wendy2702W Online
          wendy2702
          Kannst du kurz erklären was genau du gerade von wo gemacht hast und versuchst?
          MaufloM 1 Antwort Letzte Antwort
          • wendy2702W wendy2702
            MaufloM Offline
            MaufloM Offline
            Mauflo
            @wendy2702 ich habe versucht via npm folgendes zu installieren:
            sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
            • wendy2702W Online
              wendy2702W Online
              wendy2702
              Hm,
              ist das ein fertiges Image gewesen oder manuell installiert?
              Hast du mal den Fixer laufen lassen?
              • MaufloM Offline
                MaufloM Offline
                Mauflo
                Es war das buster image. Ich habe aber gestern ein update und upgrade gefahren. trotzdem noch immer der Fehler. Wie lasse ich den fixer drüber laufen?
                Interessanterweise installiert er mir trotzdem die Adapter ohne Fehler. nur diesen canvas Fehler bringe ich nicht weg!
                  Hm,
                  MaufloM Offline
                  MaufloM Offline
                  Mauflo
                  @wendy2702 Ich erhalte ja auch diese Zeile:
                  Nur weiß ich nicht wie ich das mache und in welchem Verzeichnis oder in welchem Config File bzw. wo das liegt?
                  • MaufloM Offline
                    MaufloM Offline
                    Mauflo
                    @wendy2702 Seit den heutigen Updates tritt diese Fehlermeldung nicht mehr auf! Offensichtlich wurde im Updateprozess der Adapter dieser Fehler behoben! Wer immer es war - Ihr macht einen tollen Job! Danke dafür!
                    • KeyronicsK Offline
                      KeyronicsK Offline
                      Keyronics
                      $ ./iobroker upgrade backitup
                      Update backitup from @1.4.2 to @1.4.5
                      host.iobroker Adapter "system.adapter.backitup.0" is stopped.
                      NPM version: 6.14.4
                      npm install iobroker.backitup@1.4.5 --loglevel error --prefix "/opt/iobroker" (System call)
                      gyp
                      gyp ERR! System Linux 4.19.97-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.20.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                      node-pre-gyp ERR! System Linux 4.19.97-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.20.1node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
                      upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                      Update "system.adapter.backitup.0"
                      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                      Adapter "backitup" updated
                      host.iobroker Adapter "system.adapter.backitup.0" is started
                      Also ich hab auch immer noch den Fehler mit Package pixman-1. Wofür wird dieses denn benötigt?
                      • wendy2702W Online
                        wendy2702W Online
                        wendy2702
                        Kann es sein das dieses pixman Problem nach einem Update von Node zum ersten mal aufgetreten ist?
                        L 1 Antwort Letzte Antwort
                          KeyronicsK Offline
                          Keyronics
                          schrieb am zuletzt editiert von Keyronics
                          Das kann sehr gut sein. Ich hab letztens den Node geupdated.
                          EDIT: Also laut Infoseite habe ich schon nicht mehr die aktuellste Version. Laut Apt gibt es aber auch keine neuere.
                          Node.js
                          v10.19.0 (Es gibt eine neuere Version: v10.20.1)
                            LJSven
                            @wendy2702 sagte in gelöst - Was bedeudet diese Fehlermeldung?:
                            Ja, würde ich auch sagen - bei meinem Raspberry funktioniert es ohne Fehlermelderung. Auf meinem Tinkerboard kommt die Meldung. Node Version ist 10.20.1 - der Fehler bleibt aber.
                              KeyronicsK Offline
                              Keyronics
                              Ich habe eine Lösung gefunden 😊
                              Nachdem ich den Fehler weiter gegoogelt habe,
                              wurde mir auf Github folgende info angezeigt:
                              Es hat aber nicht geholfen, es hat sogar alles schlimmer gemacht, also habe ich wieder alles gelöscht
                              sudo apt-get remove build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                              danach war es weg und meine Updates funktionieren wieder ohne Fehler!
                              • ? Offline
                                mit dieser Vorgehensweise hatte ich auch Erfolg. Pixman Error ist abgetaucht 👍
