  4. gelöst - Was bedeudet diese Fehlermeldung?
    6.8k
update error
15 Beiträge 5 Kommentatoren 2.8k Aufrufe 5 Beobachtet
  • MaufloM Mauflo
    Danke, aber das hat leider nicht geholfen. Die Installation ist schiefgegangen. Ich bekomme beim installieren am RaspberryPi4 jetzt folgendes:
    sudo npm install canvas --unsafe-perm=true
    > canvas@2.6.1 install /home/pi/node_modules/canvas
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Using needle for node-pre-gyp https download
    node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v64-linux-glibc-arm.tar.gz
    node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@10.20.1 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
    Package pixman-1 was not found in the pkg-config search path.
    Perhaps you should add the directory containing `pixman-1.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.19.93-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/node_modules/canvas/build/Release/canvas.n                                           ode" "--module_name=canvas" "--module_path=/home/pi/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
    gyp ERR! cwd /home/pi/node_modules/canvas
    gyp ERR! node -v v10.20.1
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/node_modules/canva                                           s/build/Release/canvas.node --module_name=canvas --module_path=/home/pi/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64'                                            (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp ERR! System Linux 4.19.93-v7l+
    node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /home/pi/node_modules/canvas
    node-pre-gyp ERR! node -v v10.20.1
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/node_modules/canvas/build/Release/canvas.node --m                                           odule_name=canvas --module_path=/home/pi/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    npm WARN pi No description
    npm WARN pi No repository field.
    npm WARN pi No README data
    npm WARN pi No license field.
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the canvas@2.6.1 install script.
    npm ERR!     /root/.npm/_logs/2020-04-16T19_06_29_983Z-debug.log
    wendy2702W Online
    wendy2702W Online
    @Mauflo sagte in Was bedeudet diese Fehlermeldung?:
    Kannst du kurz erklären was genau du gerade von wo gemacht hast und versuchst?
    MaufloM 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      MaufloM Offline
      MaufloM Offline
      Mauflo
      @wendy2702 ich habe versucht via npm folgendes zu installieren:
      sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
      RaspberryPi 4 4 GB - Raspbian light Buster - ARMv7 Processor rev 3 (v7l) - Node.js v12.18.0 - NPM 6.14.4 - Aktive Instanzen 18 (admin, alexa2, backitup, broadlink2, ham-wemo, harmony, history, hs100, hue, info, iot, javascript, radar2, scenes, tr-064, web [2x], wifilight) all latest and updated
      • wendy2702W Online
        wendy2702W Online
        Hm,
        ist das ein fertiges Image gewesen oder manuell installiert?
        Hast du mal den Fixer laufen lassen?
        • MaufloM Offline
          MaufloM Offline
          Mauflo
          schrieb am zuletzt editiert von Mauflo
          Es war das buster image. Ich habe aber gestern ein update und upgrade gefahren. trotzdem noch immer der Fehler. Wie lasse ich den fixer drüber laufen?
          Interessanterweise installiert er mir trotzdem die Adapter ohne Fehler. nur diesen canvas Fehler bringe ich nicht weg!
            Hm,
            MaufloM Offline
            MaufloM Offline
            Mauflo
            @wendy2702 Ich erhalte ja auch diese Zeile:
            Nur weiß ich nicht wie ich das mache und in welchem Verzeichnis oder in welchem Config File bzw. wo das liegt?
            • MaufloM Offline
              MaufloM Offline
              Mauflo
              @wendy2702 Seit den heutigen Updates tritt diese Fehlermeldung nicht mehr auf! Offensichtlich wurde im Updateprozess der Adapter dieser Fehler behoben! Wer immer es war - Ihr macht einen tollen Job! Danke dafür!
              • KeyronicsK Offline
                KeyronicsK Offline
                Keyronics
                $ ./iobroker upgrade backitup
                Update backitup from @1.4.2 to @1.4.5
                host.iobroker Adapter "system.adapter.backitup.0" is stopped.
                NPM version: 6.14.4
                npm install iobroker.backitup@1.4.5 --loglevel error --prefix "/opt/iobroker" (System call)
                Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
                gyp
                gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                gyp ERR! System Linux 4.19.97-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.20.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                node-pre-gyp ERR! System Linux 4.19.97-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.20.1node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
                upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                Update "system.adapter.backitup.0"
                upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                Adapter "backitup" updated
                host.iobroker Adapter "system.adapter.backitup.0" is started
                process exited with code 0
                Also ich hab auch immer noch den Fehler mit Package pixman-1. Wofür wird dieses denn benötigt?
                • wendy2702W Online
                  wendy2702W Online
                  Kann es sein das dieses pixman Problem nach einem Update von Node zum ersten mal aufgetreten ist?
                  L 1 Antwort Letzte Antwort
                    KeyronicsK Offline
                    Keyronics
                    schrieb am zuletzt editiert von Keyronics
                    Das kann sehr gut sein. Ich hab letztens den Node geupdated.
                    EDIT: Also laut Infoseite habe ich schon nicht mehr die aktuellste Version. Laut Apt gibt es aber auch keine neuere.
                    Node.js
                    v10.19.0 (Es gibt eine neuere Version: v10.20.1)
                      LJSven
                      @wendy2702 sagte in gelöst - Was bedeudet diese Fehlermeldung?:
                      Ja, würde ich auch sagen - bei meinem Raspberry funktioniert es ohne Fehlermelderung. Auf meinem Tinkerboard kommt die Meldung. Node Version ist 10.20.1 - der Fehler bleibt aber.
                        KeyronicsK Offline
                        Keyronics
                        Ich habe eine Lösung gefunden 😊
                        Nachdem ich den Fehler weiter gegoogelt habe,
                        wurde mir auf Github folgende info angezeigt:
                        Es hat aber nicht geholfen, es hat sogar alles schlimmer gemacht, also habe ich wieder alles gelöscht
                        sudo apt-get remove build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                        danach war es weg und meine Updates funktionieren wieder ohne Fehler!
                        • ? Offline
                          mit dieser Vorgehensweise hatte ich auch Erfolg. Pixman Error ist abgetaucht 👍
