  4. (Gelöst) Problem Gosund WB3 (LED Birne) Tasmota Flashen
    5.7k
tuyatasmota ota flashprobleme
16 Beiträge 5 Kommentatoren 4.6k Aufrufe 4 Beobachtet
  • W Offline
    W Offline
    wannabe
    schrieb am zuletzt editiert von wannabe
    habe 2 Gosund WB3 Lampen bekommen. Auf einer ist bereits Tasmota aufgespielt und funktioniert problemlos.
    Nun wollte ich die 2te auch flashen, aber aktuell lässt sie sich nichtmehr einschalten.
    Hier ist die Terminal-Ausgabe, interessant ist wahrscheinlich nur der Bereich ab Zeile 49.
    pi@raspberrypi:~ $ cd tuya-convert
    pi@raspberrypi:~/tuya-convert $ dir
    backups     docker      files              LICENSE    scripts
    config.txt  Dockerfile  install_prereq.sh  README.md  start_flash.sh
    pi@raspberrypi:~/tuya-convert $ ./start_flash.sh
    tuya-convert v2.4.3
    Checking for network interface wlan0... Found.
    Checking UDP port 53... Occupied by dnsmasq with PID 552.
    Port 53 is needed to resolve DNS queries
    Do you wish to terminate dnsmasq? [y/N] y
    Attempting to stop dnsmasq.service
    Checking UDP port 67... Available.
    Checking TCP port 80... Available.
    Checking TCP port 443... Available.
    Checking UDP port 6666... Available.
    Checking UDP port 6667... Available.
    Checking TCP port 1883... Occupied by mosquitto with PID 538.
    Port 1883 is needed to run MQTT
    Do you wish to terminate mosquitto? [y/N] y
    Attempting to stop mosquitto.service
    Checking TCP port 8886... Available.
    sudo: ufw: command not found
      Starting AP in a screen.
      Starting web server in a screen
      Starting Mosquitto in a screen
      Starting PSK frontend in a screen
      Starting Tuya Discovery in a screen
    IMPORTANT
    1. Connect any other device (a smartphone or something) to the WIFI vtrust-flash
       This step is IMPORTANT otherwise the smartconfig may not work!
    2. Put your IoT device in autoconfig/smartconfig/pairing mode (LED will blink fast). This is usually done by pressing and holding the primary button of the device
       Make sure nothing else is plugged into your IoT device while attempting to flash.
    3. Press ENTER to continue
    Starting smart config pairing procedure
    Waiting for the device to install the intermediate firmware
    Put device in EZ config mode (blinking fast)
    Sending SSID                  vtrust-flash
    Sending wifiPassword
    Sending token                 00000000
    Sending secret                0101
    SmartConfig complete.
    Resending SmartConfig Packets
    IoT-device is online with ip 10.42.42.42
    Fetching firmware backup
    mkdir: cannot create directory ‘../backups/20200410_225516’: Permission denied
    ./start_flash.sh: line 96: pushd: ../backups/20200410_225516: No such file or directory
    Cleaning up...
    Closing AP
    Exiting...
    Was ich komisch finde, der Flashvorgang ansich scheint ja gar nicht angefangen zu haben. Scheint ja am Erstellen des Backups gescheitert zu sein.
    Ist da noch was zu retten oder ist die LED hinüber?
    Vielen Dank
    • W wannabe
      tuya-convert v2.4.3
      IMPORTANT
      Sending secret                0101
      Cleaning up...
      Closing AP
      Exiting...
      Vielen Dank
      smarthome2020
      schrieb am zuletzt editiert von smarthome2020
      @wannabe
      Findest du ein WLAN Netzwerk? Vllt auch ein Vtrust-Recovery-Netzwerk?
      Zur Not kannst du sie per Kabel noch flashen, ganz zerstören wird also schwer.
      Es scheint ja so als könne er den Ordner zum Speichern des Backups nicht erstellen. Dann will er flashen und will aufs Backup zugreifen, das ja nicht gespeichert wurde und bricht dann ab.
      Ich hatte bei OTA-Flash auch ähnliche Probleme. Hab eine Gosund-Steckdose OTA geflasht und dabei ist der Strom ausgefallen. Die Dose ging nicht mehr an. Sie war funktionell tot. Sie hat jedoch ein WLAN-Netzwerk ausgespuckt, in das ich mich mitm Handy einloggen konnte. Flashvorgang nochmal drüberlaufen lassen und sie ging.
        Desastro
        Hi
        Da steht was von "Permission denied".
        Versuch mal die start-flash.sh mit sudo aufzurufen.
        Gruß Thomas
        • W Offline
          W Offline
          wannabe
          sie gibt leider gar kein Lebenszeichen von sich. Das Vtrust Netzwerk hatte ich, war ich auch drin und hab das Backup gestartet. Die blinkt ja in dem Modus vor sich hin und sollte dann irgendwann an bleiben - wenn ich das noch richtig im Kopf habe.
          Diese LED wurde aber mit einem Blinken ziemlich hell und war dann aus, danach kein W-Lan mehr um erneut zu flashen und lässt sich auch nicht mehr schalten. Aber ist schonmal gut, dass es einen Plan B mit gutem altem Kabel gibt.
          So wie ich das verstanden habe, ist das Ding im jetzigen Zustand ein Backstein. Das Ding strebt von sich aus keine Kontaktaufnahme an und Antworten möchte es ja auch nicht.
          Als root hatte ich es danach versucht, aber da war das Kind wohl schon in den Brunnen gefallen.
          Bin ich der erste Esel der das script nicht mit root rechten oder als root direkt ausführt? 🙄
          Ich schau mir den Plan B mal genauer an. Vielen Dank.
          Kommando halb zurück. Habe einen D1 Mini zum W-Lan lauschangriff ausgelegt, bekomme das recovery netzwerk rein.
          Ich meine auch vorhin auf dem Smartphone das normale Vtrust gesehen zu haben, aber kann auch noch von vorheriger session gewesen sein, da bin ich nicht sicher. Zumindest "lebt" sie noch :)
          • W wannabe
            smarthome2020
            @wannabe Ja, keine Sorge. :D.
            Löten wäre nur aufwendiger. Ich hab bisher nur OTA geflasht bei den Birnen.
            • W Offline
              W Offline
              wannabe
              Aber irgendwie alles komisch, ich komme aktuell so gut wie immer in das recovery-netzwerk, weiß aber nicht so wirklich was ich da machen kann/soll.
              Hin und wieder taucht das richtige vtrust auf, komme nach vielen Anläufen meist auch rein.
              Aber Backup ziehen oder gar flashen. Nope!
              Also entweder stehe ich gewaltig auf dem Schlauch oder iwas stimmt da nicht.
              Ich hoffe zweiteres, so viele Gedanken über ne Glühbirne habe ich mir noch nie gemacht 🤕 :man-facepalming:
              Habe inzwischen Rat auf Github erfragt, mal schauen was dabei rauskommt.
              Dankeschön
              • W wannabe
                Dankeschön
                smarthome2020
                @wannabe In das WLAN einloggen mit dem Handy und mit dem Pi den Flash Befehl geben.
                So gings bei mir.
                W 1 Antwort Letzte Antwort
                • S smarthome2020
                  So gings bei mir.
                  W Offline
                  W Offline
                  wannabe
                  @smarthome2020
                  IMPORTANT
                  Stopping smart config
                    % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                   Dload  Upload   Total   Spent    Left  Speed
                    0     0    0     0    0     0      0      0 --:--:--  0:00:31 --:--:--     0curl: (7) Failed to connect to 10.42.42.42 port 80: Connection timed out
                  Could not fetch a complete backup
                  Do you want to continue anyway? [y/N] N
                  Cleaning up...
                  Closing AP
                  Exiting...
                  Im Grunde genommen klar, aber aus irgendeinem Grund bekomme ich keine Verbindung und folglich auch kein Backup.
                  Deshalb würd ich ungern mit Y bestätigen. Das könnte die Sache evtl noch komplizierter machen 👀
                    pampulea
                    schrieb am zuletzt editiert von pampulea
                    @wannabe
                    Darf ich fragen wie du gelöst hast?
                    Ich stehe nämlich auch da. Kann die LED Birne in pairing mode stellen aber so bald ich den Enter drücke und das Program startet ..... dann bleib die Lampe einfach an.
                    VG,
                    Valentin
                    • W wannabe
                      @smarthome2020
                      IMPORTANT
                      Cleaning up...
                      Closing AP
                      Exiting...
                      smarthome2020
                      @wannabe
                      Das Backup hat mich nicht interessiert, da der Chinaserver eh ein Ausschluss für den Gebrauch der Birne war. Hab aber auch noch nicht herausgefunden, wo dieses liegen soll :D.
                      Was soll denn passieren? Welche Alternative hast du? Selbst wenn es schief geht, sind es paar Euro Schaden. Dabei aber nicht vergessen, dass man sie mit Kabel ja noch zurückholen kann. Wurde mir damals jedenfalls mehrfach bestätigt.
                      Bei mir sah es damals aber anders aus. Wenn keine Verbindung zustande kam, dann war das durch zahlreiche Versuche dokumentiert. Also die Infos in der Konsole waren ganz andere. Ich würde es dennoch einfach mal wagen.
                      Kleine Anmerkung noch. Ich hatte damals beim ersten Versuch keine Probleme. Danach hab ich es paar Tage später wiederholen wollen für die restlichen Steckdosen. Es klappte jedoch einfach nicht. Hab danach die SD Karte neu aufgesetzt und danach klappte es auf einmal wieder.
                      • S smarthome2020
                        @wannabe
                        W Offline
                        W Offline
                        wannabe
                        @pampulea
                        Also vermutlich war es wohl ein Anwenderfehler. Erstens hab ich den flashvorgang und damit auch das Backup nicht als root oder mit rootrechten ausgeführt, dadurch konnte der Ordner oder dessen Inhalt nicht erstellt werden.
                        Dazu kam, dass die LED nach diesem Vorgang ohne rootrechte einfach dunkel blieb. So konnte ich nicht sehen, ob sie im korrekten "Blink-Modus" war. Man soll da mit 3x Ein/Aus reinkommen. Ich hab mich aber die ganze Zeit auf das VTrust Netzwerk konzentriert, welches immer mal wieder kurz auftauchte. Das scheint aber laut jemandem auf Github ab diesem Zeitpunkt schon komplett egal zu sein.
                        Irgendwann war ich so genervt, dass ich auf den Taster für den Lichtschalter 7 oder 10 mal Ein/Aus geschaltet habe und ein letztes mal den flashvorgang mit root zu probieren .... #lief ! :)
                        Hab jetzt 6 Geräte geflashed, aber 5 davon sind schon ein paar Wochen her, hab mich dann wohl nur halbherzig wieder eingelesen (root vergessen).
                        @smarthome2020
                        Stimmt eigentlich, hab ich gar nicht drüber nachgedacht, war so an die Anleitung gebunden und als pflichtbewusster Staatsbürger macht man ja brav seine backups ... 🙄
                        In der Terminal Ausgabe stand ja auch device ist online, aber anpingen war nicht, immer timeout. Daher dachte ich, dass das Online schon einfach n fester Ausdruck im Script ist. ( Wenn was nicht funktioniert - spinnt man sich manchmal komische Sachen zusammen :man-facepalming: )
                        Bin recht neu in Sachen Linux, keine Ahnung wie schnell da mal was am Dateisystem kaputt gehen kann.
                        SD-Karte neu aufsetzen wäre wohl der nächste Schritt gewesen. Aber zum Glück nicht nötig.
                        Danke jedenfalls für deine Denkanstöße :)
                          pampulea
                          Hallo zusammne,
                          kann bitte jemand helfen?
                          Ich versuche ein Gosund LED WB4 zu flashen:
                          [sudo] password for openhabian:
                          tuya-convert v2.4.3
                          Checking UDP port 53... Occupied by dnsmasq with PID 624.
                          Checking TCP port 1883... Occupied by mosquitto with PID 552.
                            Starting AP in a screen.........................
                          IMPORTANT
                          .........Put device in EZ config mode (blinking fast)
                          Sending secret                0101
                          Device did not appear with the intermediate firmware
                          Check the *.log files in the scripts folder
                          Do you want to try flashing another device? [y/N]
                          Meine Vorgehensweise:
                          1. alles bis zu Ziele 33 zuerst
                          2. dann die LED im "Pairing Mode" setzten (3 Mal ein und ausschalten - danach blinkt schnell)
                          3. auf Enter drücken
                          Ergebnis:
                          Led blinkt bis zu Mitte-Ende Zeile 44. Danach bleibt an!
                          Was soll ich noch tun?
                          VG,
                          Valentin
                          W S 2 Antworten Letzte Antwort
                          • P pampulea
                            Hallo zusammne,
                            tuya-convert v2.4.3
                            IMPORTANT
                            Sending secret                0101
                            Ergebnis:
                            VG,
                            Valentin
                            W Offline
                            W Offline
                            wannabe
                            @pampulea
                            ich glaube der Übersicht halber wäre es besser einen neuen Thread aufzumachen, weil anderes Problem und anderes Produkt. Du hänst wohl einen Schritt vorher fest als ich. Weil die intermediate firmware hatte ich schon drauf, als das Problem auftrat. Von der WB3 weiß ich, dass die sich mittels Tuya-Convert flashen lässt. Hast du nachgeschlagen, ob das mit der WB4 auch der Fall ist?
                            Bin weit davon entfernt Experte zu sein, aber welche Linux Version läuft auf dem Gerät, auf dem das Script ausgeführt wird?
                            Im Ordner tuya-convert/scripts findest du *.log files. Da steht so einiges drin, was weiterhelfen kann :)
                            Pack mal zusammen in nen neuen Thread, evtl findet sich da was.
                            mfg
                            • P pampulea
                              Hallo zusammne,
                              tuya-convert v2.4.3
                              IMPORTANT
                              Sending secret                0101
                              Ergebnis:
                              VG,
                              Valentin
                              smarthome2020
                              @pampulea
                              Schritt für Schritt Anleitung
                                pampulea
                                Alles klar!
                                Veruch ich wenn nicht klapt dann mache ich ein neue Thread auf!
                                Danke Euch!
                                VG, Valentin
                                • P pampulea
                                  Alles klar!
                                  Danke Euch!
                                  VG, Valentin
                                  someyer
                                  @pampulea hallo, hast Du es hinbekommen?
                                  Meine beiden WB4 kann ich nicht flashen. Lampe bleibt nach dem schnellen Blinken einfach an.
