  4. Beta Test js-controller 3.0.x auf GitHub
    5.6k
js-controller
416 Beiträge 39 Kommentatoren 99.1k Aufrufe 38 Beobachtet
  • K Kueppert
    Sooo,
    node 12 ist nun drauf:
    ioBroker hab ich jetzt einfach mal direkt gestartet. Worauf muss ich jetzt im LOG wegen Rebuild achten?
    EDIT: Ah auf Fehler ^^ :
    host.ioBroker2	2020-04-09 11:39:53.468	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
    host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
    host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
    host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
    host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
    host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
    host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
    host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
    host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
    host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
    host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
    host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: ^
    host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: internal/modules/cjs/loader.js:1206
    EDIT2: SQL- sowie mein Zigbee-Adapter bleiben rot
    Errors nach Restart SQL-Adapter:
    host.ioBroker2	2020-04-09 11:43:49.928	info	Restart adapter system.adapter.sql.0 because enabled
    host.ioBroker2	2020-04-09 11:43:49.928	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker2	2020-04-09 11:43:49.928	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
    host.ioBroker2	2020-04-09 11:43:49.928	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
    host.ioBroker2	2020-04-09 11:43:49.928	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
    host.ioBroker2	2020-04-09 11:43:49.928	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
    host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
    host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
    host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
    host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
    host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
    host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
    host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
    host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: ^
    host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    host.ioBroker2	2020-04-09 11:43:49.925	error	Caught by controller[0]: internal/modules/cjs/loader.js:1206
    host.ioBroker2	2020-04-09 11:43:49.450	info	instance system.adapter.sql.0 started with pid 25250
    host.ioBroker2	2020-04-09 11:43:49.246	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.ioBroker2	2020-04-09 11:43:49.246	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker2	2020-04-09 11:43:49.246	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
    host.ioBroker2	2020-04-09 11:43:49.246	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
    host.ioBroker2	2020-04-09 11:43:49.246	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
    host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
    host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
    host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
    host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
    host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
    host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
    host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: ^
    host.ioBroker2	2020-04-09 11:43:49.243	error	Caught by controller[0]: throw e;
    host.ioBroker2	2020-04-09 11:43:49.243	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    host.ioBroker2	2020-04-09 11:43:48.971	info	instance system.adapter.zigbee.0 started with pid 25243
    Errors nach Zigbee-Restart:
    host.ioBroker2	2020-04-09 11:44:59.454	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.ioBroker2	2020-04-09 11:44:59.454	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
    host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
    host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
    host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
    host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
    host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
    host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
    host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
    host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
    host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: ^
    host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: throw e;
    host.ioBroker2	2020-04-09 11:44:59.451	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    host.ioBroker2	2020-04-09 11:44:59.161	info	instance system.adapter.zigbee.0 started with pid 26632
    Danke und vG, Thorsten
    Jan1
    #41
    @Kueppert
    Da hat wohl das automatische re-compiling nicht hin gehauen. Der Zigbee läuft bei mir mit Node 12 und JS-Controller 3.0.4 jedenfalls ohne Probleme. Hatte aber auch vorher schon Node 12 drauf.
    K 1 Antwort Letzte Antwort
    • J Jan1
      @Kueppert
      Kueppert
      #42
      @Jan1 sagte in Beta Test js-controller 3.0.x auf GitHub:
      @Kueppert
      Jo...wollte nur wissen, ob ich nmoch etwas testen soll ... aber dann mache ich das Rebuild nun manuell hinterher...ich melde mich ^^
      J 1 Antwort Letzte Antwort
      • K Kueppert
        @Kueppert
        Jan1
        #43
        @Kueppert
        Warte doch mal was @apollon77 dazu sagt, da es ja ne neue Funktion des Controller ist, die bei Dir wohl nicht so ganz geklappt hat.
        • J Jan1
          @Kueppert
          Kueppert
          schrieb am zuletzt editiert von Kueppert
          #44
          @Kueppert
          to late ^^ ist schon am rebuilden...ich kann das ganze ja auch nochmal machen und testen wenn gewünscht
          Fehler beim Rebuild:
          ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
             void init(v8::Handle<v8::Object> target) {
          ../src/serialport.cpp:460:17: error: ‘Handle’ is not a member of ‘v8’
          ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
          ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
          ../src/serialport.cpp:460:36: note: suggested alternative: ‘tzset’
                                              tzset
          In file included from ../../nan/nan.h:54,
                           from ../src/./serialport.h:6,
                           from ../src/serialport.cpp:1:
          ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
           NODE_MODULE(serialport, init);
          /root/.cache/node-gyp/12.16.2/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
                 (node::addon_register_func) (regfunc),                          \
          ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
          ../src/serialport.cpp:485:25: note: suggested alternative: ‘int’
          make: *** [serialport.target.mk:114: Release/obj.target/serialport/src/serialport.o] Fehler 1
          make: Verzeichnis „/opt/iobroker/node_modules/serialport/build“ wird verlassen
          gyp ERR! build error
          gyp ERR! stack Error: `make` failed with exit code: 2
          gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
          gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
          gyp ERR! System Linux 4.19.0-5-amd64
          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
          gyp ERR! cwd /opt/iobroker/node_modules/serialport
          gyp ERR! node -v v12.16.2
          gyp ERR! node-gyp -v v5.1.0
          gyp ERR! not ok
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the serialport@6.2.2 install script.
          npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR!     /root/.npm/_logs/2020-04-09T10_30_03_438Z-debug.log
          Hm...SQL sowie Zigbee sind im Admin auf grün. Mit dem Zigbee-Adapter lassen sich meine Lampen auch noch schalten...kann aber gern wenn gewünscht weiter testen :)
          • apollon77A apollon77
            @Jey-Cee sagte in Beta Test js-controller 3.0.x auf GitHub:
            readFile 2020-04-09 08:50:45.536 warn will not read this file (socketio.png) in future versions: socketio.admin is not an object of type "meta"
            Der ist interessant. Da scheinen die beiden adapter nicht sauber installiert zu sein.
            Kannst Du bitte mal "iobroker upload socketio" und "iobroker upload simple-api" versuchen und schauen ob der Fehler nochmal kommt wenn Du Admin öffnest ? (bitte vorher schauen das ein admin öffnen den auslöst - wäre meine Annahme). Danke!
            Jey CeeJ Online
            Jey CeeJ Online
            Jey Cee
            #45
            @apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
            Würde das nicht vorraussetzen das die Adapter installiert sind?
            Persönlicher Support
            Spenden -> paypal.me/J3YC33
              Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              #46
              Die Annahme scheint richtig zu sein. Nach upload ist die Meldung weg.
                @foxriver76 sagte in Beta Test js-controller 3.0.x auf GitHub:
                @ilovegym der ist leider noch 1 zu 1 der gleiche wie der von soef glaube ich
                da haben schon n paar dran gefummelt, aber besser geworden ist es leider nicht.. :-(
                foxriver76F Offline
                foxriver76F Offline
                foxriver76
                schrieb am zuletzt editiert von foxriver76
                #47
                @ilovegym Also folgendes, der wifilight Adapter wird jetzt über Community-Adapters gepflegt, heißt aber nun wieder wifilight ohne den community Zusatz. Gerne von Github installieren über https://github.com/iobroker-community-adapters/ioBroker.wifilight. Wenn das passt kann man die anderen Adapter auch so fixen - zumindest js-c 3 kompatibel machen.
                Test Thread: https://forum.iobroker.net/topic/32062/wifilight-1-1-0-testing
                Videotutorials & mehr
                • foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  #48
                  @sigi234 selbiges gilt für firetv https://github.com/iobroker-community-adapters/ioBroker.firetv, wobei ich da sagen muss, wenn ich die ersten 5 Zeilen sehe, wundert es mich, dass das Ding überhaupt läuft.. ;-)
                  Test Thread: https://forum.iobroker.net/topic/32063/firetv-1-0-0-testen
                  In beiden Fällen nach GitHub Install bitte unbedingt Upload ausführen. iob u firetv oder eben für wifilight
                  • harrymH Offline
                    harrymH Offline
                    harrym
                    #49
                    just4info: bekomm jetzt diese Warnings nach dem Upgrade ....
                    ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
                    • harrymH harrym
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      #50
                      @harrym das passt, muss in den Adaptern gefixt werden, bzw ist es glaube in den neusten Versionen.
                      • K Kueppert
                        Version 14 war leider nix:
                        Ich mach dann mal die 12er drauf.
                        #51
                        @Kueppert Für die nodejs 14 bist Du ca 12 Tage zu früh oder so (as I know)
                        • K Kueppert
                          Sooo,
                          #52
                          @Kueppert Und du bist ganz sicher das die 3.0.4 drauf ist. ich hab gestern getestet und lieff super mit sql. Ich vermisse im Log das er sagt "hey rebuild erkannt" und sowas
                          Mein log war so:
                          2020-04-08 17:37:32.555  - ESC[32minfoESC[39m: host.io-test instance system.adapter.sql.0 started with pid 32387
                          2020-04-08 17:37:33.001  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: internal/modules/cjs/loader.js:1197
                          2020-04-08 17:37:33.001  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                          2020-04-08 17:37:33.001  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:                  ^
                          2020-04-08 17:37:33.001  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
                          2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: was compiled against a different Node.js version using
                          2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
                          2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: NODE_MODULE_VERSION 79. Please try re-compiling or re-installing
                          2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                          2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1197:18)
                          2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:996:32)
                          2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:896:14)
                          2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1036:19)
                          2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
                          2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
                          2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1147:30)
                          2020-04-08 17:37:33.003  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1167:10)
                          2020-04-08 17:37:33.003  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:996:32)
                          2020-04-08 17:37:33.003  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:896:14)
                          2020-04-08 17:37:33.003  - ESC[31merrorESC[39m: host.io-test instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2020-04-08 17:37:33.003  - ESC[32minfoESC[39m: host.io-test Adapter system.adapter.sql.0 needs rebuild and will be restarted afterwards.
                          2020-04-08 17:37:33.004  - ESC[34mdebugESC[39m: Incoming Host message rebuildAdapter
                          2020-04-08 17:37:33.004  - ESC[32minfoESC[39m: host.io-test system.adapter.sql.0 will be rebuilt
                          2020-04-08 17:37:33.005  - ESC[33mwarnESC[39m: host.io-test adapter "sql" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                          2020-04-08 17:37:33.005  - ESC[32minfoESC[39m: host.io-test iobroker rebuild sql
                          2020-04-08 17:37:33.154  - ESC[32minfoESC[39m: host.io-test iobroker npm-rebuild: npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.sql"
                          Das sehe ich bei dir nicht. Und er sucht nach "NODE_MODULE_VERSION" was bei dir drin ist. Oder Log zu früh beim kopieren abgeschnitten? schau mal bitte rein
                          • K Kueppert
                            @Kueppert
        tzset
                            gyp ERR! not ok
                            npm ERR! errno 1
                            npm ERR!
                            #53
                            @Kueppert Hast Du jetzt manuell rebuilded?
                            • Jey CeeJ Jey Cee
                              #54
                              @Jey-Cee Es gab mal frrüüüüher js.controller Versionen die beim adapter löschen ggff Objekte zurückgelassen haben. Die versucht Admin jetzt zu lesen und da meckern dann Dinge :-(
                                Jey CeeJ Online
                                Jey CeeJ Online
                                Jey Cee
                                #55
                                @apollon77 Hm das war aber eine Nackte test Installation lediglich mit einer älteren js-controller Version die ich geupdatet habe und dann die Adapter installiert.
                                • Jey CeeJ Jey Cee
                                  #56
                                  @Jey-Cee schau mal. Du hast bestimmt system.adapter.xy Objekte rumliegende von Objekt Typ Adapter. Korrekt? Wo die her sind wäre dann die interessante Frage.
                                    Jey CeeJ Online
                                    Jey CeeJ Online
                                    Jey Cee
                                    #57
                                    Korrekt?
                                    Nein, hab sogar extra nochmal die VM mit dem Testsystem gestartet um ganz sicher zu sein.
                                      Kueppert
                                      #58
                                      @apollon77 jo, hab manuell nen Rebuild gemacht und nur die eine Fehlermeldung gehabt wegen Serialdings...hat aber nix mit dem neuen JS zu tun. Rebuild hat der nicht gemacht...hab ca. 1h gewartet - kamen immer nur die hier gemeldeten Fehlermeldungen...
                                      • K Kueppert
                                        #59
                                        @Kueppert Und du bist 100% sicher das der controller 3.x drauf war? Hm ... das volle log wäre cool. Mindestens mehr.
                                        • Jey CeeJ Jey Cee
                                          Korrekt?
                                          #60
                                          @Jey-Cee Schau mal bei den einzelnen Objekten weiter unten
