  4. Fehler bei Adapter Update
    6.4k
adapter update error
10 Beiträge 4 Kommentatoren 974 Aufrufe 4 Beobachtet
    smotomike
    Systemdata Bitte Ausfüllen
    Hardwaresystem: PI4
    Arbeitsspeicher: 2GB
    Festplattenart: SD-Karte
    Betriebssystem: Debian
    Nodejs-Version: 10.16.3
    NPM-Version: 6.9.0
    Installationsart: Manuell
    Image genutzt: Nein
    Ich habe ein Problem beim Updaten von manchen Adaptern wie z.B. Alexa. Hier bricht er mit folgendem Log ab.
    $ ./iobroker upgrade alexa2
    Update alexa2 from @2.6.4 to @3.0.5
    NPM version: 6.9.0npm install iobroker.alexa2@3.0.5 --loglevel error --prefix "/opt/iobroker" (System call)
    npm
     ERR!
    path /opt/iobroker/node_modules/iobroker.alexa2/node_modules/.bin/bvd
    npm
     ERR!
     code
     EEXIST
    npm ERR!
     Refusing to delete /opt/iobroker/node_modules/iobroker.alexa2/node_modules/.bin/bvd: is outside /opt/iobroker/node_modules/iobroker.alexa2/node_modules/virtual-device-sdk and not a linknpm
     ERR!
     File exists: /opt/iobroker/node_modules/iobroker.alexa2/node_modules/.bin/bvdnpm
     ERR! Move it away, and try again.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-03-01T11_32_38_992Z-debug.log
    upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
    upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
    upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
    upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
    upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
    upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
    upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
    upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
    upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
    upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
    upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
    upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
    upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
    upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
    upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
    upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
    upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot.png icons/echo_dot.png image/png
    upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo2.png icons/echo2.png image/png
    upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo.png icons/echo.png image/png
    upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/apps.png icons/apps.png image/png
    upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
    Adapter "alexa2" updated
    process exited with code 0
    Was könnte hier das Problem sein?
    Das Problem tritt seit dem Backup des Systems auf. Evtl. ein Schreibrechteproblem?
    sigi234S GlasfaserG 2 Antworten Letzte Antwort
    • S smotomike
      Hardwaresystem: PI4
      NPM-Version: 6.9.0
      Image genutzt: Nein
      npm
       ERR!
      npm
       ERR!
       code
       EEXIST
      npm ERR!
       ERR!
      sigi234S Online
      sigi234S Online
      sigi234
      @smotomike sagte in Fehler bei Adapter Update:
      Adapter "alexa2" updated process exited with code 0
      Wurde ja ausgeführt. Mal neu gestartet?
      Immer Daten sichern!
        smotomike
        Ja habe mehrmals Neu gestartet, ohne Erfolg.
        Hier mal das Ende des Logfiles der Installation.
        Das gleiche Problem auch bei Homematic Rega Adapter.
        1259 silly saveTree └── yargs@7.1.0
        1260 warn ws@7.2.1 requires a peer of bufferutil@^4.0.1 but none is installed. You must install peer dependencies yourself.
        1261 warn ws@7.2.1 requires a peer of utf-8-validate@^5.0.2 but none is installed. You must install peer dependencies yourself.
        1262 verbose stack Error: Refusing to delete /opt/iobroker/node_modules/iobroker.alexa2/node_modules/.bin/bvd: is outside /opt/iobroker/node_modules/iobroker.alexa2/node_modules/virtual-device-sdk and not a link
        1262 verbose stack     at clobberFail (/usr/local/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:121:12)
        1262 verbose stack     at isSafeToRm (/usr/local/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:114:15)
        1262 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:54:5
        1262 verbose stack     at LOOP (/usr/local/lib/node_modules/npm/node_modules/slide/lib/chain.js:7:26)
        1262 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/slide/lib/chain.js:18:7
        1262 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:180:7
        1262 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/gentle-fs/node_modules/iferr/index.js:13:50
        1262 verbose stack     at _readAllLinks (/usr/local/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:215:28)
        1262 verbose stack     at resolveSymlink (/usr/local/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:226:22)
        1262 verbose stack     at _readAllLinks (/usr/local/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:217:5)
        1262 verbose stack     at readAllLinks (/usr/local/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:212:3)
        1262 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:179:5
        1262 verbose stack     at cb (/usr/local/lib/node_modules/npm/node_modules/slide/lib/async-map.js:47:24)
        1262 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:153:16
        1263 verbose cwd /
        1264 verbose Linux 4.19.97-v7l+
        1265 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.alexa2@3.0.5" "--loglevel" "error" "--prefix" "/opt/iobroker"
        1266 verbose node v12.16.1
        1267 verbose npm  v6.13.4
        1268 error code EEXIST
        1269 error path /opt/iobroker/node_modules/iobroker.alexa2/node_modules/.bin/bvd
        1270 error Refusing to delete /opt/iobroker/node_modules/iobroker.alexa2/node_modules/.bin/bvd: is outside /opt/iobroker/node_modules/iobroker.alexa2/node_modules/virtual-device-sdk and not a link
        1271 error File exists: /opt/iobroker/node_modules/iobroker.alexa2/node_modules/.bin/bvd
        1272 error Remove the existing file and try again, or run npm
        1273 error with --force to overwrite files recklessly.
        1274 verbose exit [ 1, true ]
          smotomike
          schrieb am zuletzt editiert von smotomike
          Keiner ne Idee?
          Das Problem habe ich bei
          Alexa 2.0
          Homematic Rega
          Script Engine
          • S smotomike
            Keiner ne Idee?
            Alexa 2.0
            Homematic Rega
            Script Engine
            @smotomike
            nodeJS auch damals schon krumm installiert.
            • S smotomike
              Hardwaresystem: PI4
              NPM-Version: 6.9.0
              Image genutzt: Nein
              npm
               ERR!
              npm
               ERR!
               code
               EEXIST
              npm ERR!
               ERR!
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              @Thomas-Braun
              und auch die Adapter quer installiert ...
              und wie im anderen Thread auch erwähnt :
              Leider nutze ich kein Backup Adapter sondern sichere das ganze Raspberry Image automatisiert auf eine NAS.
              also alles immer schön mitgeschleppt .
              • GlasfaserG Glasfaser
                @Thomas-Braun
                smotomike
                Kann es sein, dass euch langweilig ist :-) ?
                Hätte mir das früher mal einer gesagt, hätte ich es evtl. nicht bis heute mitgeschleppt...
                Und ihr mit eurem quer und krum ^^
                Es geht bestimmt besser und ja, root ist immer ein Risiko...
                Aber ich bin Laie und für mich gilt solangs läuft, lass es laufen...
                Wir können aber auch gerne nen Termin in Teams machen und ihr zeigt mir Remote wie es richtig geht ;-)
                • S smotomike
                  @smotomike
                  Nö, das musst du dir schon selber anlesen.
                  Halt nur nicht wundern, wenn alles nicht funktioniert, wenn das ganze so schief installiert ist.
                  Und selbstbezeichneter Laie und dann root ist halt die denkbar schlechteste Kombination.
                  • S smotomike
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    Kann es sein, dass euch langweilig ist ?
                    Nein , uns ist nicht langweilig , wir wollen nur auf Fehler hinweisen bzw. und auch dir die Lösung dazu geben .( siehe die Links ,die ich dir gegeben habe )
                      smotomike
                      @glasfaser Dafür bin ich immer Dankbar und werde die Vorschläge oder besser gesagt, die dringenden Empfehlungen auch demnächst Umsetzen. ;-)
                      Falls ich dabei Probleme hab, weiß ich ja an wen ich mich wende. Schönen Abend noch und Danke
