  4. Zigbee - nach Update geht nichts mehr
zigbeecc2531update
6 Beiträge 3 Kommentatoren 915 Aufrufe 3 Beobachtet
  • J Offline
    janachti
    |Hardwaresystem:| Pi3 |
    |Arbeitsspeicher:| 1GB |
    |Node-Version:| 10.19.0 |
    |NPM-Version:| 6.13.4 |
    Hallo zuammen,
    ich verzweifle seitdem ich den Zigbee-Adapter auf 1.0.3 aktualisiert habe. Seitdem bekomme ich ihn nicht mehr zum Laufen. Direkt nach dem Update habe ich folgendes Fehlerlog bekommen:
    2020-02-27 20:13:18.656 - info: zigbee.0 (3412) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.19.0
    2020-02-27 20:13:18.706 - info: zigbee.0 (3412) Starting Zigbee...
    2020-02-27 20:13:18.708 - debug: zigbee.0 (3412) Starting zigbee-herdsman...
    2020-02-27 20:13:31.130 - error: zigbee.0 (3412) Failed to start Zigbee
    2020-02-27 20:13:31.131 - error: zigbee.0 (3412) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:72:23)
    at Generator.throw ()
    at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:6:65)
    2020-02-27 20:13:41.133 - info: zigbee.0 (3412) Try to reconnect. 1 attempts left
    2020-02-27 20:13:41.134 - info: zigbee.0 (3412) Starting Zigbee...
    2020-02-27 20:13:41.135 - debug: zigbee.0 (3412) Starting zigbee-herdsman...
    2020-02-27 20:13:46.358 - error: zigbee.0 (3412) Failed to start Zigbee
    2020-02-27 20:13:46.360 - error: zigbee.0 (3412) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
    at Znp. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
    at Generator.next ()
    at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
    at new Promise ()
    at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
    at SerialPort.serialPort.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
    at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
    at binding.open.then.err (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12)
    Ich habe aus Verzweiflung Node und NPM auf den neusten Stand gebracht, einen anderen CC2531-Stick getestet, alle Befehle, die ich in Foren gefunden habe benutzt, zig mal neu installiert...nichts gebracht.
    Hat vielleicht einer einen Tipp?
    Danke!
    • W Offline
      W Offline
      w00dy
      schrieb am zuletzt editiert von w00dy
      lösch doch die 1.0.3 Version und geh wieder zurück auf die Version davor (hoffe, das war die Stable-Version 1.0.2). Dann den alten Zigbee-Stick wieder einstecken den du mit der funktionierenden Version genutzt hast und die Zigbee-Backupdatei von vor deiner Aktualisierung wieder einspielen. Dann bist du wieder auf dem gleichen Stand wie vor deiner Aktualisierung und es müsste somit wieder laufen.
      Viele Grüße
      w00dy
      • J Offline
        janachti
        War auch mein Plan, aber ich habe blöderweise aus zeitlichen Gründen verpennt, das Backup zu speichern. Das wurde dann nach ein paar Tagen überschrieben.
        Auf ältere Versionen zu gehen, hat leider nichts bewirkt. Kann man den Adapter vielleicht rückstandsfrei entfernen und dann neu installieren?
        • J janachti
          Hallo zuammen,
          at new Promise ()
          Danke!
          arteckA Offline
          arteckA Offline
          arteck
          @janachti der serialport ist zu.. Schon mal die Kiste neu gestartet
          J 1 Antwort Letzte Antwort
          • arteckA arteck
            janachti
            @arteck Ich habe es nun wieder zum Laufen bekommen. Es lag tatsächlich an einem defekten CC2531.
            Und der erste Ersatz, den ich besorgt hatte, funktionierte auch nicht. Der wurde nicht mal am Win 10-PC erkannt.
            Den zweiten Stick reingesteckt und es ging problemlos.
            • J janachti
              arteckA Offline
              arteckA Offline
              arteck
              @janachti sehr gut
