  4. Fehler bei der Installation
iobroker installation
12 Beiträge 2 Kommentatoren 1.3k Aufrufe 1 Beobachtet
    martin
    Habe Debian 10.3.0 neu installiert und dann laut Anleitung iobroker.
    Leider kommen während der Installation unter Schritt 3 einige Meldungen mit denen ich nichts anfangen kann.
    Ist das alles korrekt so?
    root@iobroker:/# node -v
    v10.19.0
    root@iobroker:/# nodejs -v
    v10.19.0
    root@iobroker:/# npm -v
    6.13.4
    root@iobroker:/# curl -sL https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2020-01-30
        Welcome to the ioBroker installer!
        Installer version: 2020-01-25
        Installing prerequisites (1/4)
    OK:1 http://deb.debian.org/debian buster InRelease
    OK:2 http://security.debian.org/debian-security buster/updates InRelease
    OK:3 http://deb.debian.org/debian buster-updates InRelease
    OK:4 https://deb.nodesource.com/node_10.x buster InRelease
    Changing npm registry to https://registry.npmjs.org
    Installed gcc-c++
        Creating ioBroker user and directory (2/4)
    Created /etc/sudoers.d/iobroker
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    In file included from ../src/main.cpp:3:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    In file included from ../../nan/nan.h:54,
    ../src/main.cpp: At global scope:
    /root/.cache/node-gyp/10.19.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /root/.cache/node-gyp/10.19.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(diskusage, Init)
    In file included from /root/.cache/node-gyp/10.19.0/include/node/node.h:63,
    /root/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
    /root/.cache/node-gyp/10.19.0/include/node/node_object_wrap.h:84:78:   required from here
    /root/.cache/node-gyp/10.19.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                    reinterpret_cast<Callback>(callback), type);
    /root/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
    ../../nan/nan_object_wrap.h:65:61:   required from here
    /root/.cache/node-gyp/10.19.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    In file included from ../src/unix_dgram.cc:5:
    ../src/unix_dgram.cc: At global scope:
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
    Some packets could not be installed. Please install them manually
        Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.177.44:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    root@iobroker:/#
    FredFF 1 Antwort Letzte Antwort
    • M martin
      v10.19.0
      v10.19.0
      6.13.4
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      root@iobroker:/#
      FredFF Online
      FredFF Online
      FredF
      Most Active Forum Testing
      @martin sagte in Fehler bei der Installation:
      Diese Meldungen hatte ich auch. System läuft.
      Sind ja keine Fehlermeldungen und es wird gemeldet
        martin
        Danke.
        Habe jetzt versucht das letzte Backup einzuspielen.
        Hier aber jetzt Probleme mit denen ich nicht klar komme.
        root@iobroker:/# iobroker stop
        root@iobroker:/# iobroker restore 0
        host.iobroker Using backup file total_2019_11_25-02_00_10_backupiobroker.tar.gz
        host.iobroker Cannot find extracted file from file "/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json"
        iobroker controller daemon is not running
        host.iobroker OK.
        (node:4959) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
            at Object.openSync (fs.js:443:3)
            at Object.readFileSync (fs.js:343:35)
            at BackupRestore.restoreAfterStop (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:566:23)
            at Daemon.daemon.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:846:22)
            at Daemon.emit (events.js:203:15)
            at Daemon._kill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:246:14)
            at Daemon.stop (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:185:17)
            at tar.extract.err (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:848:20)
        (node:4959) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
        (node:4959) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
        root@iobroker:/#
        • M martin
          Danke.
          host.iobroker OK.
          root@iobroker:/#
          FredFF Online
          FredFF Online
          FredF
          @martin
          Ich bin mir nicht sicher, aber muß ioBroker vorher gestoppt werden?
            martin
            Wenn er läuft kommt die Meldung, dass man ihn stoppen soll.
            • M martin
              FredFF Online
              FredFF Online
              FredF
              @martin
              Das gemacht
                martin
                schrieb am zuletzt editiert von martin
                Ja, ich mache nach jedem Schritt ein Reboot.
                root@iobroker:~# iobroker upgrade self
                Host    "iobroker"       is up to date.
                • M martin
                  FredFF Online
                  FredFF Online
                  FredF
                  @martin Dann probier doch mal das fixer script drüber laufen zu lassen.
                    martin
                    Habe jetzt alles (Debian + Iobroker) neu aufgesetzt.
                    root@iobroker:~# iobroker restore 0
                    Dann das Fixer-Script laufen lassen (erfolgreich) und nochmal restore.
                    host.iobroker OK.
                    root@iobroker:~#
                    Ich habe von der gecrashten Festplatte den /opt/iobroker Ordner kopieren können.
                    Kann ich den einfach per FTP drüber bügeln?
                      martin
                      Habe es jetzt mal mit "backitup" versucht.
                      Log Backitup Restore:
                      [DEBUG] [iobroker] Start ioBroker Restore ...
                      [ERROR] [iobroker] host.iobroker Cannot find extracted file from file "/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json"
                      [DEBUG] [iobroker] iobroker controller daemon is not running
                      [DEBUG] [iobroker] host.iobroker OK.
                      [DEBUG] [iobroker] ioBroker Restore completed successfully
                      [EXIT] 9 **** Restore completed successfully!! ****
                      The log can be closed ...
                        martin
                        Und nach iobroker upgrade self das hier:
                        root@iobroker:/opt/iobroker# iobroker restore 0
                        host.iobroker Using backup file iobroker_2020_02_18-19_14_04_backupiobroker.tar.gz
                        host.iobroker OK.
                        (node:1151) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
                            at Object.openSync (fs.js:439:3)
                            at Object.readFileSync (fs.js:344:35)
                            at Daemon.emit (events.js:194:15)
                        (node:1151) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                        (node:1151) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                          martin
                          Lösung:
                          du legst dein Backup in den Ordner /opt/iobroker und führst folgenden Befehl in diesem Ordner aus:
                          iobroker stop
                          cd /opt/iobroker
                          sudo tar -xzvf Backupname.tar.gz -C /opt/iobroker
                          iobroker start
                          Jetzt läuft alles zumindest mal wieder und meine Daten sind da.
                          Werde die nächsten Tage mal ein Standard-Backup erstellen das ich dann hoffentlich in eine saubere Neuinstallation per "Restore" einspielen kann.
