  2. English
  3. ioBroker general
  4. EACCES: permission denied
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
adapters mqtt permission
9 Beiträge 3 Kommentatoren 4.3k Aufrufe 3 Beobachtet
  • Akra BatoA Offline
    Akra BatoA Offline
    Akra Bato
    schrieb am zuletzt editiert von Akra Bato
    Error EACCES: permission denied happens when I try to install adapters.
    root@wirenboard-AUCPMJ6J:~# iobroker install mqtt
    sudo: unable to resolve host wirenboard-AUCPMJ6J: No such file or directory
    NPM version: 6.11.3
    npm install iobroker.mqtt@2.0.4 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code EACCES
    npm ERR! syscall mkdir
    npm ERR! path /home/iobroker
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, mkdir '/home/iobroker'
    npm ERR!  { [Error: EACCES: permission denied, mkdir '/home/iobroker']
    npm ERR!   cause:
    npm ERR!    { Error: EACCES: permission denied, mkdir '/home/iobroker'
    npm ERR!      errno: -13,
    npm ERR!      code: 'EACCES',
    npm ERR!      syscall: 'mkdir',
    npm ERR!      path: '/home/iobroker' },
    npm ERR!   isOperational: true,
    npm ERR!   stack: 'Error: EACCES: permission denied, mkdir \'/home/iobroker\'',
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    I've found this topic https://forum.iobroker.net/topic/17206/javascript-adapter-lässt-sich-nicht-mehr-installieren and tried to follow recomendations from it:
    sudo chmod 777 /opt/iobroker
    sudo chown -R $(whoami) ~/.npm
    sudo chown -R $(whoami) ~/.config
    sudo chown -R $(whoami) /opt/iobroker
    also, as alternative:
    sudo chown -R iobroker /opt/iobroker
    All was useless.
    Could you help to solve the problem?
    • arteckA Offline
      arteckA Offline
      arteck
      check this
        Akra BatoA Offline
        Akra Bato
        I made it. Problem still exists.
        • arteckA Offline
          arteckA Offline
          arteck
          @Akra-Bato sagte in EACCES: permission denied:
          this is wron also
          check from
          cd /opt/iobroker
            Akra BatoA Offline
            Akra Bato
            I think the problem is that iobroker don't have rights to make any changes in /home/iobroker directory,
            although I work under root.
            • Akra BatoA Akra Bato
              arteckA Offline
              arteckA Offline
              arteck
              @Akra-Bato the folder /home/iobroker is the User folder.... here OK
              the install folder is /opt/iobroker .. OK also..
                Akra BatoA Offline
                Akra Bato
                I made some subdirectories manually, but it continues to display error messages with other subdirectories.
                • arteckA arteck
                  this is wron also
                  check from
                  cd /opt/iobroker
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  schrieb am zuletzt editiert von AlCalzone
                  @arteck sagte in EACCES: permission denied:
                  That command can be executed anywhere. Only for npm install you have to be careful.
                  @Akra-Bato
                  Does this help?
                  sudo chown -R iobroker:iobroker /home/iobroker
                  sudo chmod -R 755 /home/iobroker
                  Did you have any user named iobroker before installing?
                  Akra BatoA 1 Antwort Letzte Antwort
                  • AlCalzoneA AlCalzone
                    @Akra-Bato
                    Does this help?
                    Akra BatoA Offline
                    Akra BatoA Offline
                    Akra Bato
                    @AlCalzone , thank you! I solved the problem.
