  4. Adapter Yahka macht Probleme nach Update
    6.3k
yahka
5 Beiträge 3 Kommentatoren 698 Aufrufe 3 Beobachtet
    Realzippo
    Hallo.
    Ich habe "node" auf Version 10.17.0 aktualisiert.
    Alle Adapter bis auf den Yahka laufen wieder.
    Der Yahka Adapter wird grün angezeigt, schreibt jedoch folgende Fehler:
    host.raspberrypi	2019-11-30 09:22:45.729	error	instance system.adapter.yahka.0 terminated with code 1 ()
    host.raspberrypi	2019-11-30 09:22:45.729	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.raspberrypi	2019-11-30 09:22:45.729	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mdns/lib/dns_sd.js:24:20)
    host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
    host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
    host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: NODE_MODULE_VERSION 48. This version of Node.js requires
    host.raspberrypi	2019-11-30 09:22:45.727	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.raspberrypi	2019-11-30 09:22:45.727	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mdns/build/Release/dns_sd_bindings.node'
    host.raspberrypi	2019-11-30 09:22:45.727	error	Caught by controller[0]: ^
    host.raspberrypi	2019-11-30 09:22:45.727	error	Caught by controller[0]: throw ex;
    host.raspberrypi	2019-11-30 09:22:45.724	error	Caught by controller[0]: /opt/iobroker/node_modules/mdns/lib/dns_sd.js:35
    Was kann ich tun?
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    • R Realzippo
      Hallo.
      Was kann ich tun?
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @Realzippo sagte in Adapter Yahka macht Probleme nach Update:
      (for instance, using npm rebuild or npm install).
      Steht da doch.
      Einmal Google wie man das nutzt, eingeben, glücklich sein.
      Auf die konsole im iobroker, im Verzeichnis / opt/iobroker den Befehl npm rebuild ausführen.
      A.
        Realzippo
        Leider hat npm rebuild das Problem nicht behoben.
        • R Realzippo
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @Realzippo
          Dann empfehle ich den yahka Adapter einmal zu deinstallieren und neu zu installieren. Deine Einstellungen bleiben erhalten, es werden nur alle benötigten Pakete neu übersetzt.
          A.
          B 1 Antwort Letzte Antwort
          • AsgothianA Asgothian
            @Realzippo
            A.
            bjoernson
            @asgothian said in Adapter Yahka macht Probleme nach Update:
            Nur als Info für alle, die auf diesen Thread stoßen. Nach einer De- und Neuinstallation von Yahka sind alle Geräte und Einstellungen gelöscht. Besser ein Backup vorher erstellen.
