[Blockly] Weihnachtsbeleuchtung nach Datum
Hallo, @BBTown ,
würdest Du Dir mal dieses Blockly anschauen. Habe das heute geändert, meines hat nicht funktioniert.
<block xmlns="http://www.w3.org/1999/xhtml" id="Maqx,i1%viWIsix{-_ui" type="schedule" y="-187" x="-1687"> <field name="SCHEDULE">0 8,18 * * *</field> <statement name="STATEMENT"> <block id="-V[zgWaB+Ux=T(4pvBXQ" type="controls_if"> <value name="IF0"> <block id="IW1%E_qYGt-;,Sr,-+y-" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="7t`/0PVniOj^btX}l#D_" type="logic_operation" inline="false"> <field name="OP">OR</field> <value name="A"> <block id="nIt];269_l@)?e^TrQ$J" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="3=|^nIV4b`TK7B(%rqHY" type="logic_compare"> <field name="OP">GT</field> <value name="A"> <block id="$,1I0-~6DZ$ZkkREuuDN" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">wd</field> </block> </value> <value name="B"> <block id="K7?TyeS4Kf=[t+@5UK[*" type="math_number"> <field name="NUM">5</field> </block> </value> </block> </value> <value name="B"> <block id="cWSJ~;Hmr).*l5e!Lu$=" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id=",t|P%rkN?xU9Z[SRe]57" type="time_compare_ex"> <mutation actual_time="true" end_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"> <shadow id="G$`(Pcq/+iGaXEPF^M{A" type="text"> <field name="TEXT">08:00</field> </shadow> </value> <value name="END_TIME"> <shadow id="`idhm:N+md?vE{!G}sZZ" type="text"> <field name="TEXT">22:00</field> </shadow> </value> </block> </value> <value name="B"> <block id="@eQ^+e=KQgeLK8is$%L(" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="yqb?=i@isdZ`(tw5*U)Y" type="logic_compare"> <field name="OP">GTE</field> <value name="A"> <block id="$Tw!0Minp4x(h|f?w%~n" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">d</field> </block> </value> <value name="B"> <block id="e(RLV,[N/$,Gq^I9?`#6" type="math_number"> <field name="NUM">25</field> </block> </value> </block> </value> <value name="B"> <block id="kA3B9RSE)lu)SWh_i)Zz" type="logic_compare"> <field name="OP">GT</field> <value name="A"> <block id="M-e*kYt)=G/%9y;T:l5%" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">M</field> </block> </value> <value name="B"> <block id="hcznVI6p^VCGA;Il[8!F" type="math_number"> <field name="NUM">10</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> <value name="B"> <block id="/j2ZfO=5Y_R/D*)32H%N" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="nESG?B#xXk2:6^9uYxdi" type="logic_compare"> <field name="OP">LT</field> <value name="A"> <block id="3t~J6Y|?v`;rJf(ZP[`N" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">wd</field> </block> </value> <value name="B"> <block id="ccR+#irzQVJ@6K,1u}4+" type="math_number"> <field name="NUM">6</field> </block> </value> </block> </value> <value name="B"> <block id="-s$l4rw-VJ2K=JZv3,GO" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="gB{O9S@EP5gNk7~|Z.p0" type="time_compare_ex"> <mutation actual_time="true" end_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"> <shadow id="LLI`@Rw=[1$F$df5c7)%" type="text"> <field name="TEXT">1800</field> </shadow> </value> <value name="END_TIME"> <shadow id="#Bh+jseb??yNd}}H=VGd" type="text"> <field name="TEXT">22:00</field> </shadow> </value> </block> </value> <value name="B"> <block id="Im;4A3S*M$+:d)j=(Cu#" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="i1h?:6Apln-2[2n;k9Gz" type="logic_compare"> <field name="OP">GTE</field> <value name="A"> <block id="X;B]ZPErVC=.Rt=Pgmak" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">d</field> </block> </value> <value name="B"> <block id="vtt7NvDc92sd`i|99Sc," type="math_number"> <field name="NUM">25</field> </block> </value> </block> </value> <value name="B"> <block id="hJkY!p^~*M~0(mp-N2hD" type="logic_compare"> <field name="OP">GT</field> <value name="A"> <block id="%Mc02Uq?q.*ypIUjl#EM" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">M</field> </block> </value> <value name="B"> <block id="~hsjX#dEI}GJ:k2Qs$S@" type="math_number"> <field name="NUM">10</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> <value name="B"> <block id="|P2~Aw4!7Dqe%~,FF_y{" type="logic_operation" inline="false"> <field name="OP">OR</field> <value name="A"> <block id="-5FEg.sRZ1|wsG]vyx=U" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="uF9b0=|/on8w:3?lVt_V" type="logic_compare"> <field name="OP">GT</field> <value name="A"> <block id="`R*W#8f5CMbT6LyIyXD0" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">wd</field> </block> </value> <value name="B"> <block id="KDNOO:-IL!VnV%:_3lcJ" type="math_number"> <field name="NUM">5</field> </block> </value> </block> </value> <value name="B"> <block id="huHGSD`Z:8_/.!sF5PvS" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="?`q+sHUyk({#GmRZke{0" type="time_compare_ex"> <mutation actual_time="true" end_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"> <shadow id="2+:_:W63s[?5QI^2{Ymp" type="text"> <field name="TEXT">08:00</field> </shadow> </value> <value name="END_TIME"> <shadow id="o0dea}0[Tw[bS7ER@#]2" type="text"> <field name="TEXT">22:00</field> </shadow> </value> </block> </value> <value name="B"> <block id="ZUT*s$H!Tk=:2$LPNpB/" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="2V7BImOFp@6Kp`Gc]b+n" type="logic_compare"> <field name="OP">LTE</field> <value name="A"> <block id="T~cZ2)6VTO.NKxY(WqDf" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">d</field> </block> </value> <value name="B"> <block id="MBXR#y,aX.|fMBaH5uRv" type="math_number"> <field name="NUM">10</field> </block> </value> </block> </value> <value name="B"> <block id="/ug;u072!?zC$OOC[bbp" type="logic_compare"> <field name="OP">LT</field> <value name="A"> <block id=":p](V:I_tE+)69,b}e)v" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">M</field> </block> </value> <value name="B"> <block id="e%+Y2[w6],0*I/M5%@kH" type="math_number"> <field name="NUM">2</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> <value name="B"> <block id=".My=T2qR$!6m-@5aas35" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="%u?bHCkku{jvwjNWENw8" type="logic_compare"> <field name="OP">LT</field> <value name="A"> <block id="N)z!UHds[b3!89a8Cvga" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">wd</field> </block> </value> <value name="B"> <block id="z!QT^WFY[(PV~sBV}Vs)" type="math_number"> <field name="NUM">6</field> </block> </value> </block> </value> <value name="B"> <block id="rh,[/M?UJBoS6ifnp+*U" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="mA%luupV!~V/(~|;]0X_" type="time_compare_ex"> <mutation actual_time="true" end_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"> <shadow id="`wEapmZ9twAYkL@N:K4w" type="text"> <field name="TEXT">1800</field> </shadow> </value> <value name="END_TIME"> <shadow id="9F6n|Oa,dSV]dC/j`wZC" type="text"> <field name="TEXT">22:00</field> </shadow> </value> </block> </value> <value name="B"> <block id="gHle31CmSKV98MgYp`W_" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="1$HLehU!K8L-wEN{~z:e" type="logic_compare"> <field name="OP">LTE</field> <value name="A"> <block id="0ZV4/AZH,w[eUQ*]*UGd" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">d</field> </block> </value> <value name="B"> <block id="(=U2d_3%mF2|tbJ.fEb1" type="math_number"> <field name="NUM">10</field> </block> </value> </block> </value> <value name="B"> <block id="{tU6t(|HJTC#tY=*`$,b" type="logic_compare"> <field name="OP">LT</field> <value name="A"> <block id="?Q%1XN8E9+B%^QZSAEci" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">M</field> </block> </value> <value name="B"> <block id="xHX%#SAJMU!)RLM!J,6[" type="math_number"> <field name="NUM">2</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block id="A:/8ME2UchfO$ZK-J/=." type="controls_if"> <mutation else="1"></mutation> <value name="IF0"> <block id="f3P5Y@:Zr;z(D1t:PGc~" type="logic_compare"> <field name="OP">EQ</field> <value name="A"> <block id="dk)XiD:{GBA3uFB{bTn9" type="get_value"> <field name="ATTR">val</field> <field name="OID">admin.0.Anwesenheit</field> </block> </value> <value name="B"> <block id="@oB1@pJ4PH@Y$/|d|O;n" type="logic_boolean"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block id="l}m3h0T66oHez{WA-8Nd" type="control"> <mutation delay_input="false"></mutation> <field name="OID">hm-rega.0.32710.ProgramExecute</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block id="$4%EJp5K9*L{QYWz$EE2" type="logic_boolean"> <field name="BOOL">TRUE</field> </block> </value> <next> <block id="raVSaEfKJQeC6FP~s)#Y" type="control"> <mutation delay_input="true"></mutation> <field name="OID">hm-rega.0.32710.ProgramExecute</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">10000</field> <field name="UNIT">ms</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block id=".0GQ/f+njr01wnVr=|/+" type="logic_boolean"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </statement> <statement name="ELSE"> <block id="@~$=QH~0/R.rLJVlw,n]" type="control"> <mutation delay_input="false"></mutation> <field name="OID">hm-rega.0.32739.ProgramExecute</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block id="Jx1cmB85;f(X`,y(/6UV" type="logic_boolean"> <field name="BOOL">TRUE</field> </block> </value> <next> <block id="1ET#yT=rV_zMHL0cBa^~" type="control"> <mutation delay_input="true"></mutation> <field name="OID">hm-rega.0.32739.ProgramExecute</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">10000</field> <field name="UNIT">ms</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block id="7t(Krj!DVue=[9aYD?r(" type="logic_boolean"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </statement> </block> </statement> </block> </statement> </block>Ich möchte gern, dass zwischen dem 25.11. und dem 10.01. das Blockly am Wochentag um 18:00 und am Wochenende um 08.00 die Weihnachtsbeleuchtung einschaltet. Dabei soll die Beleuchtung nur eingeschaltet werden, wenn die Anwesenheit auf wahr steht. Bisher schaltet das Script nur um 08:00 Uhr. Egal ob Wochentag oder Wochenende.
Edit: Sorry, gerade noch einmal neu eingefügt.
Hallo, @BBTown ,
ich glaube, ich drehe die Falls-Bedingungen. Erst die Abfrage auf die Anwesenheit und nur dann, wenn die wahr ist, die Zeitbedinungen prüfen? das kostet weniger Laufzeit oder ist das egal?
@opossum ich würde das in eine Funktion packen und deine Uhrzeiten/Cron-Trigger als Auslöser nehmen:
Wochenende/Feiertag -> 08:00h einschalten = "LampeAn" -> Funktion "Beleuchtung" aufrufen
Arbeitstag -> 18:00h einschalten = "LampeAn" -> Funktion "Beleuchtung" aufrufen
täglich -> 22:00h ausschalten = "LampeAus" -> Funktion "Beleuchtung" aufrufen -
ich habe das jetzt hinbekommen, waren noch ein paar Schreibfehler bei den Uhrzeiten drin. Jetzt schaltet das Script um 18:01 Uhr die Beleuchtung ein (alles, was irgendwie mit Weihnachten und Licht zu tun hat). Ich schalte damit ein CuxD-Gerät. CuxD darum, weil die Brennenstuhlsteckdosen sich nur über das Brenenstuhlgateway ansteuern lassen. Das läuft noch über die CCU3. Ich musste aber in der CCU3 ein Programm bauen, dass keinen Trigger hat, sondern nur die drei Steckdosen im Dann-Zweig hat. Dieses Programm kann ich im Blockly mit Programm execute dann auf true schalten.
Das Blockly zum Einschalten sieht jetzt so aus:<block xmlns="http://www.w3.org/1999/xhtml" id="Maqx,i1%viWIsix{-_ui" type="schedule" y="-1037" x="-2287"> <field name="SCHEDULE">1 8,18 * * *</field> <statement name="STATEMENT"> <block id="-V[zgWaB+Ux=T(4pvBXQ" type="controls_if"> <mutation else="1"></mutation> <value name="IF0"> <block id="f3P5Y@:Zr;z(D1t:PGc~" type="logic_compare"> <field name="OP">EQ</field> <value name="A"> <block id="dk)XiD:{GBA3uFB{bTn9" type="get_value"> <field name="ATTR">val</field> <field name="OID">admin.0.Anwesenheit</field> </block> </value> <value name="B"> <block id="@oB1@pJ4PH@Y$/|d|O;n" type="logic_boolean"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block id="A:/8ME2UchfO$ZK-J/=." type="controls_if"> <value name="IF0"> <block id="IW1%E_qYGt-;,Sr,-+y-" type="logic_operation" inline="false"> <field name="OP">OR</field> <value name="A"> <block id="7t`/0PVniOj^btX}l#D_" type="logic_operation" inline="false"> <field name="OP">OR</field> <value name="A"> <block id="nIt];269_l@)?e^TrQ$J" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="3=|^nIV4b`TK7B(%rqHY" type="logic_compare"> <field name="OP">GT</field> <value name="A"> <block id="$,1I0-~6DZ$ZkkREuuDN" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">wd</field> </block> </value> <value name="B"> <block id="K7?TyeS4Kf=[t+@5UK[*" type="math_number"> <field name="NUM">5</field> </block> </value> </block> </value> <value name="B"> <block id="cWSJ~;Hmr).*l5e!Lu$=" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id=",t|P%rkN?xU9Z[SRe]57" type="time_compare_ex"> <mutation actual_time="true" end_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"> <shadow id="G$`(Pcq/+iGaXEPF^M{A" type="text"> <field name="TEXT">08:00</field> </shadow> </value> <value name="END_TIME"> <shadow id="`idhm:N+md?vE{!G}sZZ" type="text"> <field name="TEXT">22:00</field> </shadow> </value> </block> </value> <value name="B"> <block id="uiZKS+Hg%H.0MZQbTxn!" type="logic_operation" inline="false"> <field name="OP">OR</field> <value name="A"> <block id="@eQ^+e=KQgeLK8is$%L(" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="yqb?=i@isdZ`(tw5*U)Y" type="logic_compare"> <field name="OP">EQ</field> <value name="A"> <block id="$Tw!0Minp4x(h|f?w%~n" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">d</field> </block> </value> <value name="B"> <block id="e(RLV,[N/$,Gq^I9?`#6" type="math_number"> <field name="NUM">25</field> </block> </value> </block> </value> <value name="B"> <block id="kA3B9RSE)lu)SWh_i)Zz" type="logic_compare"> <field name="OP">EQ</field> <value name="A"> <block id="M-e*kYt)=G/%9y;T:l5%" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">M</field> </block> </value> <value name="B"> <block id="hcznVI6p^VCGA;Il[8!F" type="math_number"> <field name="NUM">11</field> </block> </value> </block> </value> </block> </value> <value name="B"> <block id="AMk/vOJ3O7;TX,aDh!,^" type="logic_compare"> <field name="OP">EQ</field> <value name="A"> <block id="$Yf0e2/S-{[/qgzDCugP" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">M</field> </block> </value> <value name="B"> <block id="D-Gr|;hh_fJ2X:$YyfL~" type="math_number"> <field name="NUM">12</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> <value name="B"> <block id="/j2ZfO=5Y_R/D*)32H%N" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="nESG?B#xXk2:6^9uYxdi" type="logic_compare"> <field name="OP">LT</field> <value name="A"> <block id="3t~J6Y|?v`;rJf(ZP[`N" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">wd</field> </block> </value> <value name="B"> <block id="ccR+#irzQVJ@6K,1u}4+" type="math_number"> <field name="NUM">6</field> </block> </value> </block> </value> <value name="B"> <block id="-s$l4rw-VJ2K=JZv3,GO" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="gB{O9S@EP5gNk7~|Z.p0" type="time_compare_ex"> <mutation actual_time="true" end_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"> <shadow id="LLI`@Rw=[1$F$df5c7)%" type="text"> <field name="TEXT">18:00</field> </shadow> </value> <value name="END_TIME"> <shadow id="#Bh+jseb??yNd}}H=VGd" type="text"> <field name="TEXT">22:00</field> </shadow> </value> </block> </value> <value name="B"> <block id="R6ij4vZHy/nO,P]_c$kP" type="logic_operation" inline="false"> <field name="OP">OR</field> <value name="A"> <block id="zJX{qyLwglIfT=]9G#54" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="rzwZDku3fB@^RE;7B^]," type="logic_compare"> <field name="OP">EQ</field> <value name="A"> <block id="Qx;S:z9)~;DQ??8+s.4N" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">d</field> </block> </value> <value name="B"> <block id="m;jiw?5HcZ;FE8h/5vE|" type="math_number"> <field name="NUM">25</field> </block> </value> </block> </value> <value name="B"> <block id="/MUE#nFew`EHj%337#1#" type="logic_compare"> <field name="OP">EQ</field> <value name="A"> <block id="B|$1fH^!4(RseR(;n^dC" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">M</field> </block> </value> <value name="B"> <block id="pFJM9vz`*`YyxHnq$GjC" type="math_number"> <field name="NUM">11</field> </block> </value> </block> </value> </block> </value> <value name="B"> <block id="4]mo5.#-c~Hq{?RvL.op" type="logic_compare"> <field name="OP">EQ</field> <value name="A"> <block id="YJzLr)rrg|mmpYeb3:#N" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">M</field> </block> </value> <value name="B"> <block id="8Ux2qW;J8XgX(fj6([ZK" type="math_number"> <field name="NUM">12</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> <value name="B"> <block id="|P2~Aw4!7Dqe%~,FF_y{" type="logic_operation" inline="false"> <field name="OP">OR</field> <value name="A"> <block id="-5FEg.sRZ1|wsG]vyx=U" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="uF9b0=|/on8w:3?lVt_V" type="logic_compare"> <field name="OP">GT</field> <value name="A"> <block id="`R*W#8f5CMbT6LyIyXD0" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">wd</field> </block> </value> <value name="B"> <block id="KDNOO:-IL!VnV%:_3lcJ" type="math_number"> <field name="NUM">5</field> </block> </value> </block> </value> <value name="B"> <block id="huHGSD`Z:8_/.!sF5PvS" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="?`q+sHUyk({#GmRZke{0" type="time_compare_ex"> <mutation actual_time="true" end_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"> <shadow id="2+:_:W63s[?5QI^2{Ymp" type="text"> <field name="TEXT">08:00</field> </shadow> </value> <value name="END_TIME"> <shadow id="o0dea}0[Tw[bS7ER@#]2" type="text"> <field name="TEXT">22:00</field> </shadow> </value> </block> </value> <value name="B"> <block id="k:d5CousqRoRR`)u{+Ao" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="GoAn9W)7?xFbTrYC:JMN" type="logic_compare"> <field name="OP">LTE</field> <value name="A"> <block id="iJUUa5hb]3mk{_DOM?:^" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">d</field> </block> </value> <value name="B"> <block id="`Kn+@?GdxY|k9Mc:?ecS" type="math_number"> <field name="NUM">10</field> </block> </value> </block> </value> <value name="B"> <block id="g`vAJRnmUf:%`jy7Z!x_" type="logic_compare"> <field name="OP">EQ</field> <value name="A"> <block id="m?CI]f:bs=ZDhJ7ziiv/" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">M</field> </block> </value> <value name="B"> <block id="3ar1|GuBMXz0tha4d,?U" type="math_number"> <field name="NUM">1</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> <value name="B"> <block id=".My=T2qR$!6m-@5aas35" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="%u?bHCkku{jvwjNWENw8" type="logic_compare"> <field name="OP">LT</field> <value name="A"> <block id="N)z!UHds[b3!89a8Cvga" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">wd</field> </block> </value> <value name="B"> <block id="z!QT^WFY[(PV~sBV}Vs)" type="math_number"> <field name="NUM">6</field> </block> </value> </block> </value> <value name="B"> <block id="rh,[/M?UJBoS6ifnp+*U" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="mA%luupV!~V/(~|;]0X_" type="time_compare_ex"> <mutation actual_time="true" end_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"> <shadow id="`wEapmZ9twAYkL@N:K4w" type="text"> <field name="TEXT">18:00</field> </shadow> </value> <value name="END_TIME"> <shadow id="9F6n|Oa,dSV]dC/j`wZC" type="text"> <field name="TEXT">22:00</field> </shadow> </value> </block> </value> <value name="B"> <block id="gHle31CmSKV98MgYp`W_" type="logic_operation" inline="false"> <field name="OP">AND</field> <value name="A"> <block id="1$HLehU!K8L-wEN{~z:e" type="logic_compare"> <field name="OP">LTE</field> <value name="A"> <block id="0ZV4/AZH,w[eUQ*]*UGd" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">M</field> </block> </value> <value name="B"> <block id="(=U2d_3%mF2|tbJ.fEb1" type="math_number"> <field name="NUM">10</field> </block> </value> </block> </value> <value name="B"> <block id="{tU6t(|HJTC#tY=*`$,b" type="logic_compare"> <field name="OP">EQ</field> <value name="A"> <block id="?Q%1XN8E9+B%^QZSAEci" type="time_get"> <mutation language="false" format="false"></mutation> <field name="OPTION">M</field> </block> </value> <value name="B"> <block id="xHX%#SAJMU!)RLM!J,6[" type="math_number"> <field name="NUM">1</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block id="l}m3h0T66oHez{WA-8Nd" type="control"> <mutation delay_input="false"></mutation> <field name="OID">hm-rega.0.32710.ProgramExecute</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block id="$4%EJp5K9*L{QYWz$EE2" type="logic_boolean"> <field name="BOOL">TRUE</field> </block> </value> <next> <block id="raVSaEfKJQeC6FP~s)#Y" type="control"> <mutation delay_input="true"></mutation> <field name="OID">hm-rega.0.32710.ProgramExecute</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">10000</field> <field name="UNIT">ms</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block id=".0GQ/f+njr01wnVr=|/+" type="logic_boolean"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </statement> </block> </statement> <statement name="ELSE"> <block id="@~$=QH~0/R.rLJVlw,n]" type="control"> <mutation delay_input="false"></mutation> <field name="OID">hm-rega.0.32739.ProgramExecute</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block id="Jx1cmB85;f(X`,y(/6UV" type="logic_boolean"> <field name="BOOL">TRUE</field> </block> </value> <next> <block id="1ET#yT=rV_zMHL0cBa^~" type="control"> <mutation delay_input="true"></mutation> <field name="OID">hm-rega.0.32739.ProgramExecute</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">10000</field> <field name="UNIT">ms</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block id="7t(Krj!DVue=[9aYD?r(" type="logic_boolean"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </statement> </block> </statement> </block>Sreenshot dazu:
Ich schalte das True nach 10 Sekunden wieder auf false. Zum Ausschalten der Beleuchtung ebenfalls ein Dummyprogramm in der CCU.
.Ist vielleicht auch einfacher zu bauen, aber jetzt funktioniert es und der WAF steht wieder auf 100%
Habe mich versucht hier durchzuwurschteln, konnte aber keine wirkliche Lösung zu der Antwort des Thread-Erstellers finden.
Eigentlich ist es doch ganz einfach was gewünscht wird:
Weihnachtsbeleuchtung soll nur vom 17.11. - 10.01. bei Sonnenuntergang geschaltet werden.
Beim Abschalten muss man übrigens einen weiteren Tag hinzupacken, da sonst am 11. Januar nicht ausgeschaltet wird, wenn das wichtig ist:
