  3. Entwicklung
  4. Update BackitUp 1.2.1 Fehlermeldungen
    5.6k
Geplant Angeheftet Gesperrt Verschoben Ungelöst Entwicklung
backitupjs-controller1.2.1
6 Beiträge 5 Kommentatoren 1.5k Aufrufe 5 Beobachtet
  • JB_SullivanJ Offline
    JB_Sullivan
    Kurze Frage am Rande - ich wollte heute auf BackitUp 1.2.1 updaten und habe die folgenden Fehlermeldung während des Updatevorgang bekommen.
    Ist das ggf. ein Problem welches mit dem neuen js-controller 2.0.33 zusammenhängen kann?
    $ ./iobroker upgrade backitup
    Update backitup from @1.2.0 to @1.2.1
    NPM version: 6.9.0
    npm install iobroker.backitup@1.2.1 --loglevel error --production --save --prefix "C:/ioBroker" (System call)
    npm
    ERR! path C:\ioBroker\node_modules\iobroker.backitupnpm ERR! code EPERMnpm ERR!
    errno
    -4048
    npm
    ERR!
    syscall
    rename
    npm
    ERR! Error: EPERM: operation not permitted, rename 'C:\ioBroker\node_modules\iobroker.backitup' -> 'C:\ioBroker\node_modules.iobroker.backitup.DELETE'npm
    ERR!
    { [Error: EPERM: operation not permitted, rename 'C:\ioBroker\node_modules\iobroker.backitup' -> 'C:\ioBroker\node_modules.iobroker.backitup.DELETE']
    npm
    ERR!
    cause:
    npm
    ERR!
    { Error: EPERM: operation not permitted, rename 'C:\ioBroker\node_modules\iobroker.backitup' -> 'C:\ioBroker\node_modules.iobroker.backitup.DELETE'
    npm
    ERR!
    errno: -4048,
    npm
    ERR!
    code: 'EPERM',
    npm
    ERR!
    syscall: 'rename',
    npm
    ERR!
    path: 'C:\ioBroker\node_modules\iobroker.backitup',
    npm
    ERR!
    dest: 'C:\ioBroker\node_modules\.iobroker.backitup.DELETE' },
    npm
    ERR!
    stack:
    npm
    ERR!
    'Error: EPERM: operation not permitted, rename 'C:\ioBroker\node_modules\iobroker.backitup' -> 'C:\ioBroker\node_modules\.iobroker.backitup.DELETE'',
    npm
    ERR!
    errno: -4048,
    npm
    ERR!
    code: 'EPERM',
    npm
    ERR!
    syscall: 'rename',
    npm
    ERR!
    npm
    ERR!
    dest: 'C:\ioBroker\node_modules\.iobroker.backitup.DELETE',
    npm
    ERR!
    parent: 'ioBroker' }
    npm
    ERR!
    npm
    ERR!
    The operation was rejected by your operating system.
    npm
    ERR!
    It's possible that the file was already in use (by a text editor or antivirus),
    npm
    ERR!
    or that you lack permissions to access it.
    npm
    ERR!
    npm
    ERR!
    If you believe this might be a permissions issue, please double-check the
    npm
    ERR!
    permissions of the file and its containing directories, or try running
    npm
    ERR!
    the command again as root/Administrator (though this is not recommended).
    npm ERR! A complete log of this run can be found in:npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-10-20T07_01_21_138Z-debug.log
    ERROR: host.iobroker Cannot install iobroker.backitup@1.2.1: 4294963248
    StabilostickS simatecS 2 Antworten Letzte Antwort
    • JB_SullivanJ JB_Sullivan
      NPM version: 6.9.0
      npm
      errno
      -4048
      npm
      ERR!
      syscall
      rename
      npm
      ERR!
      npm
      ERR!
      cause:
      npm
      ERR!
      npm
      ERR!
      errno: -4048,
      npm
      ERR!
      code: 'EPERM',
      npm
      ERR!
      syscall: 'rename',
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      stack:
      npm
      ERR!
      npm
      ERR!
      errno: -4048,
      npm
      ERR!
      code: 'EPERM',
      npm
      ERR!
      syscall: 'rename',
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      StabilostickS Offline
      Stabilostick
      @JB_Sullivan
      Stoppe vor dem Update alle diesbezüglichen Adapterinstanzen. Geht jetzt das Update?
        NPM version: 6.9.0
        npm
        errno
        -4048
        npm
        ERR!
        syscall
        rename
        npm
        ERR!
        npm
        ERR!
        cause:
        npm
        ERR!
        npm
        ERR!
        errno: -4048,
        npm
        ERR!
        code: 'EPERM',
        npm
        ERR!
        syscall: 'rename',
        npm
        ERR!
        npm
        ERR!
        npm
        ERR!
        stack:
        npm
        ERR!
        npm
        ERR!
        errno: -4048,
        npm
        ERR!
        code: 'EPERM',
        npm
        ERR!
        syscall: 'rename',
        npm
        ERR!
        npm
        ERR!
        npm
        ERR!
        npm
        ERR!
        npm
        ERR!
        npm
        ERR!
        npm
        ERR!
        npm
        ERR!
        npm
        ERR!
        npm
        ERR!
        npm
        ERR!
        simatecS Offline
        simatecS Offline
        simatec
        @JB_Sullivan Sollte mit Version 1.2.2 behoben sein ...
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        smartboartS 1 Antwort Letzte Antwort
        • simatecS simatec
          smartboartS Offline
          smartboartS Offline
          smartboart
          schrieb am zuletzt editiert von smartboart
          @simatec Hat sich bezüglich des js.controller 2.0.xx und redis file und state aktiv etwas im backup Widerherstellungsprozess geändert? Irgendwie hat es bei mir mit dem komplett Backup nicht hingehauen...
          J 1 Antwort Letzte Antwort
          • smartboartS smartboart
            Jan1
            @smartboart
            Das komplett Backup ist auch nicht die erste Wahl und je nach dem wo Du das wieder herstellen möchtest auch falsch.
            • smartboartS Offline
              smartboartS Offline
              smartboart
              Hatte mein system neu aufgesetzt wegen der ganzen node-gyp erros. node.js und npm sowie js controller alles aktuell bzw. genau wie im neu aufgesetzten System.
              iobroker stop.
              dann redis mit der Backup Datei ersetzt und
              sudo tar -xzvf Backupname.tar.gz -C /opt/iobroker
              dann iobroker start...
              hatte danach trotzdem nur den admin laufen wie im neu aufgesetzten system...
              Hatte vorher eigentlich immer funktioniert, also vor redis file Umstellung...
