  4. [GELÖST] Cannot read property 'split' of null
iot
8 Beiträge 4 Kommentatoren 3.5k Aufrufe 2 Beobachtet
  • LausiDL Offline
    LausiDL Offline
    LausiD
    schrieb am zuletzt editiert von LausiD
    "uncaught exception: Cannot read property 'split' of null"
    Bin mir nicht sicher ob das Problem m Zusammenhang mit den Updates von gestern steht......
    host.raspberrypi	2019-10-12 14:03:48.342	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
    host.raspberrypi	2019-10-12 14:03:48.341	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    host.raspberrypi	2019-10-12 14:03:48.341	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    host.raspberrypi	2019-10-12 14:03:48.340	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:75163)
    host.raspberrypi	2019-10-12 14:03:48.340	error	Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:2127:49)
    host.raspberrypi	2019-10-12 14:03:48.339	error	Caught by controller[0]: TypeError: Cannot read property 'split' of null
    iot.0	2019-10-12 14:03:48.277	info	(16814) Terminated (NO_ERROR): Without reason
    iot.0	2019-10-12 14:03:48.275	info	(16814) terminating
    iot.0	2019-10-12 14:03:47.999	error	(16814) TypeError: Cannot read property 'split' of null at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:2127:49) at (anonymous function).(anon
    iot.0	2019-10-12 14:03:47.998	error	(16814) uncaught exception: Cannot read property 'split' of null
    iot.0	2019-10-12 14:03:43.338	info	(16814) Connecting with xxxcxxxxxxxxxxxxxxx.iot.eu-west-1.amazonaws.com
    iot.0	2019-10-12 14:03:43.258	info	(16814) starting. Version 1.1.8 in /opt/iobroker/node_modules/iobroker.iot, node: v10.16.0
    sql.0	2019-10-12 14:03:38.702	info	(1040) enabled logging of system.adapter.iot.0.memRss, Alias=false
    Was mache ich falsch?
    Danke und Gruß
    LausiD
    Doku zum FHEM Adapter
    Aktuelles zum FHEM Adapter
    Test FHEM Adapter
    • LausiDL Offline
      LausiDL Offline
      LausiD
      @dslraser @FredF
      Vielen Dank für Eure Unterstützung
      Habe mir mal alexaSmartHomeV2.js angeschaut und das Problem gefunden.
      Bow was es alles gibt....die function sensor hatte als Inhalt ein null
        "fhem.0.HUEDevice12.state",
        "fhem.0.HUEDevice3.state",
        "fhem.0.HUEDevice4.state",
        null,
        null
      und das habe ich mir mit dem FHEM Adapter eingefangen :-(
      Also alles gut mit dem iot Adapter
      Danke und Gruß
      LausiD
      Test FHEM Adapter
      • LausiDL LausiD
        Danke und Gruß
        LausiD
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @LausiD sagte in [IOT] Cannot read property 'split' of null:
        Ich habe den Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
        ° Fixer ---> iob fix
        • LausiDL Offline
          LausiDL Offline
          LausiD
          Niemand eine Idee??
          Test FHEM Adapter
          • LausiDL Offline
            LausiDL Offline
            LausiD
            Bin mit meinem Latein am Ende :-(
            Instanz und Adapter entfernt. Neuinstallation und gleiches Problem.
            Wer kann helfen?
            Danke und Gruß
            LausiD
            Test FHEM Adapter
            FredFF 1 Antwort Letzte Antwort
            • LausiDL LausiD
              Wer kann helfen?
              Danke und Gruß
              LausiD
              FredFF Online
              FredFF Online
              FredF
              Most Active Forum Testing
              @LausiD
              Schreib doch mal was du hast:
              node -v
              nodejs -v
              npm -v
              und
              welcher js controller
              welcher iot Adpaterversion
              • LausiDL Offline
                LausiDL Offline
                LausiD
                @FredF
                Stimmt, könnte hilfreich sein. Sorry, hätte ich auch drauf kommen können :-(
                node -v 10.16.0
                nodejs -v 10.16.0
                npm - v 6.9.0
                js-controller 2.0.35
                iot Adapter 1.1.8
                Test FHEM Adapter
                • LausiDL LausiD
                  @FredF
                  node -v 10.16.0
                  nodejs -v 10.16.0
                  npm - v 6.9.0
                  iot Adapter 1.1.8
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  @LausiD
                  Hast Du mal den Fixer drüber laufen lassen ?
                  • LausiDL Offline
                    LausiDL Offline
                    LausiD
                    @dslraser @FredF
                      null,
                      null
                    Danke und Gruß
                    LausiD
                    Test FHEM Adapter
