  4. Node-Red
  5. (gelöst) Node-Red "Alexa local" nicht mehr möglich
    6.5k
86 Beiträge 10 Kommentatoren 15.9k Aufrufe 8 Beobachtet
  • V voodoo78
    @Jan1
    Das Problem ist, dass über das Amazon Echo Device ein Wert zwischen 1 und 254 weitergegeben wird, das Object aber Werte zwischen 0 und 100 erwartet.
    Jan1
    #81
    @voodoo78
    OK, dann bin ich raus, weil ich mich damit nicht auskenne.
    1-255 sind eben normale Dimmwerte und wie man die dann so skaliert, dass daraus 0-100 wird, weiß ich nicht.
    • V Offline
      V Offline
      voodoo78
      #82
      So, jetzt läuft alles! 👍
              "id": "5df1cdf9.12a114",
              "type": "amazon-echo-hub",
              "z": "485361c3.89313",
              "port": "8080",
              "enableinput": false,
              "x": 130,
              "y": 160,
              "wires": [
                      "d85d3a2c.2a4718"
              "id": "d85d3a2c.2a4718",
              "type": "amazon-echo-device",
              "name": "Bürolicht",
              "topic": "",
              "x": 320,
              "y": 160,
              "wires": [
                      "4ee1947d.ea686c"
              "id": "97d67de7.6ebf1",
              "type": "ioBroker out",
              "name": "Brightness",
              "topic": "zigbee.0.0017880102a2d093.brightness",
              "ack": "false",
              "autoCreate": "false",
              "x": 790,
              "y": 120,
              "wires": []
              "id": "780047d.93fc5b8",
              "type": "function",
              "name": "Dimmer",
              "func": "var newMsg = { payload: Math.round (msg.bri*100/254) } ;\nreturn newMsg;",
              "outputs": 1,
              "noerr": 0,
              "x": 620,
              "y": 120,
              "wires": [
                      "97d67de7.6ebf1"
              "id": "ab21ca8a.670b88",
              "name": "Switch state",
              "topic": "zigbee.0.0017880102a2d093.state",
              "ack": "false",
              "x": 850,
              "y": 200,
              "wires": []
              "id": "6bc055cb.09d2cc",
              "type": "change",
              "name": "on/off -> true/false",
              "rules": [
                      "t": "change",
                      "p": "payload",
                      "pt": "msg",
                      "from": "on",
                      "fromt": "str",
                      "to": "true",
                      "tot": "bool"
                      "t": "change",
                      "p": "payload",
                      "pt": "msg",
                      "from": "off",
                      "fromt": "str",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 650,
              "y": 200,
              "wires": [
                      "ab21ca8a.670b88"
              "id": "4ee1947d.ea686c",
              "type": "switch",
              "name": "on/off",
              "property": "payload",
              "propertyType": "msg",
              "rules": [
                      "t": "eq",
                      "v": "on",
                      "vt": "str"
                      "t": "eq",
                      "v": "off",
                      "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 470,
              "y": 160,
              "wires": [
                      "780047d.93fc5b8",
                      "6bc055cb.09d2cc"
                      "6bc055cb.09d2cc"
      J 1 Antwort Letzte Antwort
      • V voodoo78
                "port": "8080",
                "x": 130,
                "y": 160,
                "wires": [
                        "d85d3a2c.2a4718"
                "topic": "",
                "x": 320,
                "y": 160,
                "wires": [
                        "4ee1947d.ea686c"
                "ack": "false",
                "x": 790,
                "y": 120,
                "wires": []
                "type": "function",
                "name": "Dimmer",
                "outputs": 1,
                "noerr": 0,
                "x": 620,
                "y": 120,
                "wires": [
                        "97d67de7.6ebf1"
                "ack": "false",
                "x": 850,
                "y": 200,
                "wires": []
                "type": "change",
                "rules": [
                        "t": "change",
                        "p": "payload",
                        "pt": "msg",
                        "from": "on",
                        "fromt": "str",
                        "to": "true",
                        "tot": "bool"
                        "t": "change",
                        "p": "payload",
                        "pt": "msg",
                        "from": "off",
                        "fromt": "str",
                        "to": "false",
                        "tot": "bool"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 650,
                "y": 200,
                "wires": [
                        "ab21ca8a.670b88"
                "type": "switch",
                "name": "on/off",
                "rules": [
                        "t": "eq",
                        "v": "on",
                        "vt": "str"
                        "t": "eq",
                        "v": "off",
                        "vt": "str"
                "checkall": "true",
                "repair": false,
                "outputs": 2,
                "x": 470,
                "y": 160,
                "wires": [
                        "780047d.93fc5b8",
                        "6bc055cb.09d2cc"
                        "6bc055cb.09d2cc"
        Jan1
        #83
        @voodoo78
        Hast Dir das selber aus dem Ärmel geschüttelt? Wenn's fertig ist, sieht es immer so einfach und logisch aus🙂
        Kommt gleich in die Bibliothek, falls ich das mal brauch.
        V 1 Antwort Letzte Antwort
        • J Jan1
          @voodoo78
          V Offline
          V Offline
          voodoo78
          #84
          @Jan1
          Ja, ich habe bloß mal einen Denkanstoß gebraucht.
          • V voodoo78
            @Jan1
            Jan1
            #85
            @voodoo78
            dann plage ich Dich gleich mal weiter.
            Wie muss das aussehen, wenn man am Ausgang nur 0-3 haben möchte? 0 muss nicht unbedingt sein, 1-3 schon.
            OK, hab auch ein Hirn und mal nachgedacht😏
            Ergebnis sieht so aus:
            var newMsg = { payload: Math.round (msg.bri/3) } ;
            return newMsg;
              robudus
              #86
              So klappt es mit Node Red bei mir. Mit whitemode und RGB und Helligkeit bei Milight LEDs
                      "id": "bb6a24a9.7a0648",
                      "type": "tab",
                      "label": "Flow 2",
                      "disabled": false,
                      "info": ""
                      "id": "4edc288f.fb8d2",
                      "z": "bb6a24a9.7a0648",
                      "name": "Zone 1 ON",
                      "topic": "milight.0.zone1.on",
                      "ack": "false",
                      "x": 870,
                      "y": 340,
                      "wires": []
                      "id": "c7a3f1a9.66d89",
                      "name": "Zone 1 OFF",
                      "topic": "milight.0.zone1.off",
                      "ack": "false",
                      "x": 1570,
                      "y": 460,
                      "wires": []
                      "id": "b32b2e08.f13fa",
                      "name": "Led Licht",
                      "topic": "Led Licht",
                      "x": 460,
                      "y": 220,
                      "wires": [
                              "eebe38ee.e7fba8"
                      "id": "972a82a4.7286a",
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "off",
                              "fromt": "str",
                              "to": "true",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 900,
                      "y": 400,
                      "wires": [
                              "c7a3f1a9.66d89"
                      "id": "eebe38ee.e7fba8",
                      "type": "switch",
                      "name": "",
                      "rules": [
                              "t": "eq",
                              "v": "on",
                              "vt": "str"
                              "t": "eq",
                              "v": "off",
                              "vt": "str"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 640,
                      "y": 240,
                      "wires": [
                              "4edc288f.fb8d2",
                              "feaa5ed5.336b9",
                              "47531e52.0c6bb8",
                              "d1daa37a.6f41a"
                              "972a82a4.7286a"
                      "id": "feaa5ed5.336b9",
                      "type": "function",
                      "name": "Dimmer",
                      "outputs": 1,
                      "noerr": 0,
                      "x": 840,
                      "y": 160,
                      "wires": [
                              "99fac24d.8cb9"
                      "id": "99fac24d.8cb9",
                      "name": "Zone 1 Brightness",
                      "topic": "milight.0.zone1.brightness",
                      "ack": "false",
                      "autoCreate": "true",
                      "x": 1050,
                      "y": 160,
                      "wires": []
                      "id": "ffe043eb.210e5",
                      "name": "Zone 1 Color RGB",
                      "topic": "milight.0.zone1.rgb",
                      "ack": "false",
                      "x": 1550,
                      "y": 140,
                      "wires": []
                      "id": "3f9207a4.c2f028",
                      "name": "Led Lampe",
                      "topic": "Led Lampe",
                      "x": 450,
                      "y": 280,
                      "wires": [
                              "eebe38ee.e7fba8"
                      "id": "47531e52.0c6bb8",
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "rgb",
                              "tot": "msg"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 1050,
                      "y": 220,
                      "wires": [
                              "ffe043eb.210e5"
                      "id": "b1acd561.57c8c8",
                      "ack": "false",
                      "x": 1550,
                      "y": 240,
                      "wires": []
                      "id": "d1daa37a.6f41a",
                      "type": "function",
                      "name": "",
                      "func": "var newMsg = { payload: Math.round (msg.bri*100/254) } ;\nvar new2Msg = {payload: true};\n\nif (msg.colormode == \"ct\") {\n   return [ null, new2Msg ];\n} else {\n   return [ newMsg, null ];\n}",
                      "outputs": 2,
                      "noerr": 0,
                      "x": 1290,
                      "y": 280,
                      "wires": [
                              "b1acd561.57c8c8"
                              "cdea20f1.8b3c98"
                      "id": "cdea20f1.8b3c98",
                      "name": "Zone 1 White mode",
                      "topic": "milight.0.zone1.whiteMode",
                      "ack": "false",
                      "x": 1520,
                      "y": 340,
                      "wires": []
                      "id": "be63c33e.43c8f8",
                      "port": "80",
                      "processinput": 0,
                      "x": 220,
                      "y": 220,
                      "wires": [
                              "b32b2e08.f13fa",
                              "3f9207a4.c2f028"
