  5. [Vorlage] Hilfreiche JavaScript-Funktionen
    6.4k
javascript
23 Beiträge 10 Kommentatoren 14.8k Aufrufe 43 Beobachtet
  • Christoph1337C Christoph1337
    Moin zusammen,
    ich habe mal versucht ein paar der Funktionen bei mir einzufügen.
    Allerdings bekomme ich immer folgende Meldung:
    script.js.common.Array compile failed: at script.js.common.Array:256
    das komische. Das Script geht garnicht bis Zeile 256...
    Auch wenn ich dann alle Zeilen aus kommentiere habe ich dieses Problem.
     * Remove Duplicates from Array
     * Source - https://stackoverflow.com/questions/23237704/nodejs-how-to-remove-duplicates-from-array
     * @param {array} inputArray       Array to process
     * @return {array}  Array without duplicates.
    function GlobalarrayRemoveDublicates(inputArray) {
        let uniqueArray;
        uniqueArray = inputArray.filter(function(elem, pos) {
            return inputArray.indexOf(elem) == pos;
        return uniqueArray;
     * Clean Array: Removes all falsy values: undefined, null, 0, false, NaN and "" (empty string)
     * Source: https://stackoverflow.com/questions/281264/remove-empty-elements-from-an-array-in-javascript
     * @return {array}  Cleaned array
    function GlobalcleanArray(inputArray) {
      var newArray = [];
      for (let i = 0; i < inputArray.length; i++) {
        if (inputArray[i]) {
          newArray.push(inputArray[i]);
      return newArray;
     * Removing Array element(s) by input value.
     * @param {array}   arr             the input array
     * @param {string}  valRemove       the value to be removed
     * @param {boolean} [exact=true]    OPTIONAL: default is true. if true, it must fully match. if false, it matches also if valRemove is part of element string
     * @return {array}  the array without the element(s)
    function GlobalarrayRemoveElementsByValue(arr, valRemove, exact) {
        if (exact === undefined) exact = true;
        for ( let i = 0; i < arr.length; i++){
            if (exact) {
                if ( arr[i] === valRemove) {
                    arr.splice(i, 1);
                    i--; // required, see https://love2dev.com/blog/javascript-remove-from-array/
            } else {
                if (arr[i].indexOf(valRemove) != -1) {
                    arr.splice(i, 1);
                    i--; // see above
        return arr;
     * Checks if Array or String is not undefined, null or empty.
     * 08-Sep-2019: added check for [ and ] to also catch arrays with empty strings.
     * @param inputVar - Input Array or String, Number, etc.
     * @return true if it is undefined/null/empty, false if it contains value(s)
     * Array or String containing just whitespaces or >'< or >"< or >[< or >]< is considered empty
    function GlobalisLikeEmpty(inputVar) {
        if (typeof inputVar !== 'undefined' && inputVar !== null) {
            let strTemp = JSON.stringify(inputVar);
            strTemp = strTemp.replace(/\s+/g, ''); // remove all whitespaces
            strTemp = strTemp.replace(/\"+/g, "");  // remove all >"<
            strTemp = strTemp.replace(/\'+/g, "");  // remove all >'<
            strTemp = strTemp.replace(/[+/g, "");  // remove all >[<
            strTemp = strTemp.replace(/]+/g, "");  // remove all >]<
            if (strTemp !== '') {
                return false;
            } else {
                return true;
        } else {
            return true;
    Christoph1337C Offline
    Christoph1337
    Hab es selber gelöst:
    function GlobalIsLikeEmpty(inputVar)
            strTemp = strTemp.replace(/\[+/g, "");  // remove all >[<
                return false;
            } else {
                return true;
        } else {
            return true;
      Moin zusammen,
          let uniqueArray;
          return uniqueArray;
        var newArray = [];
        return newArray;
              if (exact) {
                      arr.splice(i, 1);
              } else {
                      arr.splice(i, 1);
                      i--; // see above
          return arr;
                  return false;
              } else {
                  return true;
          } else {
              return true;
      liv-in-skyL Offline
      liv-in-skyL Offline
      liv-in-sky
      @christoph1337 sagte in [Vorlage] Hilfreiche JavaScript-Funktionen:
      {1}
      da sind diese {1}
      drin - da ist evtl was beim kopieren schiefgegangen
      lösche die mal raus
        Moin zusammen,
            let uniqueArray;
            return uniqueArray;
          var newArray = [];
          return newArray;
                if (exact) {
                        arr.splice(i, 1);
                } else {
                        arr.splice(i, 1);
                        i--; // see above
            return arr;
                    return false;
                } else {
                    return true;
            } else {
                return true;
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        Hast du globale Skripte?
