  4. Bindings in vis
Bindings in vis
vis
81 Beiträge 17 Kommentatoren 18.7k Aufrufe 27 Beobachtet
  • SBorgS SBorg
    @doubled / @crunchip
    Aus welchem Grunde auch immer sind da die "escapeds" der Anführungszeichen innerhalb des Bindings verlorengegangen.
    Minimal-Backup (full gibt es ja nicht mehr ;) ) :
    [{"tpl":"tplJquiButtonState","data":{"oid":"backitup.0.oneClick.iobroker","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttontext":"{wert:backitup.0.oneClick.iobroker;wert === \"true\" || wert === true || wert === 1 ? \"Backup </br> wird erstellt\" : \"Backup </br>jetzt erstellen\"}","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"no_style":false,"value":"true","name":"Minimal-Backup_Button","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false},"style":{"left":"1497px","top":"55px","border-width":"2px","border-style":"solid","border-color":"#505253","width":"200px","height":"50px","z-index":"3","border-radius":"10px","box-shadow":"8px 8px 8px rgba(20, 20, 20, 50)"},"widgetSet":"jqui"}]
    #61
    @sborg sagte in Bindings in vis:
    wo? (habe nur gerade diesen Post gesehen)
    hier im Forum?
    da passiert das wegen Markdown.
    Bitte Link, dann seh ich mir das mal an
      escapeds
      jetzt musst ich erst mal beide vergleichen, was du da meinst🤔
      backslash
      SBorgS Offline
      SBorgS Offline
      SBorg
      #62
      @crunchip sagte in Bindings in vis:
      backslash
      Das ist was du siehst, programmtechnisch sind das Sonderzeichen escapen.
      Wen es genau interessiert:
      falsch beim Binding:
      "{wert:backitup.0.oneClick.iobroker;wert === "true" || wert === true || wert === 1 ? "Backup </br> wird erstellt" : "Backup </br>jetzt erstellen"}"
      korrekt:
      @homoran sagte in Bindings in vis:
      Ist im Spoiler anscheinend versiebt gegangen, ist mir bis eben aber auch nicht aufgefallen ;)
      https://forum.iobroker.net/post/281934
      LG SBorg ( SBorg auf GitHub)
      • SBorgS SBorg
        backslash
        korrekt:
        #63
        ich hab es mal innerhalb des Spoilers in codetags gesetzt
        Dann sollten die Escapes auch zu sehen sein
          SBorgS Offline
          SBorgS Offline
          SBorg
          #64
          @homoran Danke, habe gleich noch den doppelten Doppelpunkt beim "oder" im Binding ausgemerzt und den "Voll-Backup" als obsolet gekennzeichnet.
          • H Offline
            Hausbaer
            #65
            Guten Morgen,
            ich kämpfe auch mit den Bindings. Ich möchte die Farbe ändern, je nachdem in einem DP der Wert "true" oder "false" ist.
            Sieht momentan so aus:
            {wert:system.adapter.admin.0.alive; wert === "true" ? "#35ff05" : "#e66e05"}
            Ich habe mir die Farben unter 0_userdata definiert.
            Und dann funktionierts nicht mehr:
            {wert:system.adapter.admin.0.alive; wert === "true" ? "{0_userdata.0.einstellung_farben_schriftarten.farbe-4}" : "{0_userdata.0.einstellung_farben_schriftarten.farbe-5}"}
            Was fehlt da?
            OliverIOO liv-in-skyL 2 Antworten Letzte Antwort
            • H Hausbaer
              Guten Morgen,
              Was fehlt da?
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              #66
              @hausbaer
              Verschachtelte bindings gehen nicht
              Du musst den Inhalt des datenpunkt analog wie wert in eine Variable übernehmen und diese Variable dann verwenden
              Meine Adapter und Widgets
              Links im Profil
              • H Hausbaer
                Guten Morgen,
                Was fehlt da?
                liv-in-skyL Offline
                liv-in-skyL Offline
                liv-in-sky
                #67
                @hausbaer sagte in Bindings in vis:
                habe es nicht getestet - evtl geht das
                {wert:system.adapter.admin.0.alive;farbe4:0_userdata.0.einstellung_farben_schriftarten.farbe-4;farbe5:0_userdata.0.einstellung_farben_schriftarten.farbe-5; wert === "true" ? farbe4 : farbe5}
                • liv-in-skyL liv-in-sky
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  #68
                  @liv-in-sky sagte in Bindings in vis:
                  gleiche Idee hatte ich auch; und dann auch getestet, funktioniert !
                  {wert:0_userdata.0.wert_test; farb1:0_userdata.0.Farbe_1; farb2:0_userdata.0.Farbe_2; wert == "true" ? farb1 : farb2}
                  Danke.
                  • H Offline
                    Hausbaer
                    #69
                    Manchmal sieht man den Wald vor lauter Bäumen nicht. Danke, ihr seid die Besten.
                    Noch ein Thema. Unter diesem DP
                    admin.0.info.updatesList
                    gibt es, wenn Updates von Adaptern vorhanden sind, eine String Liste.
                    Wie kann ich diese Liste auswerten, um beim entsprechenden Adpater einen Hinweis einzublenden, dass dieser Adapter updatebar ist?
                    • H Hausbaer
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      #70
                      @hausbaer
                      https://www.smarthome-tricks.de/software-iobroker/vis-adapter-updates-auf-view-anzeigen/amp/
                      Gefunden mit Google
                      Iobroker vis Adapter update
                      H 1 Antwort Letzte Antwort
                        @hausbaer
                        Gefunden mit Google
                        Hausbaer
                        #71
                        @liv-in-sky das kenne ich, ist aber nicht das, was ich suche.
                        Ich möchte hinter dem Adaternamen im Falle eines Updates einen Text einblenden lassen.
                        • O Offline
                          O Offline
                          ocio
                          #72
                          Rundungen in Bindings scheinen knifflig zu sein. Die Funktion round(x, y) funktioniert nicht.
                          DP(type: number): 0_userdata.0.a = 1.2
                          Binding:
                          {a:0_userdata.0.a;Math.round(parseFloat(a)/10,2)}
                          Ergebnis im Widget: 0 (erwartet: 0.12 bzw. 0,12)
                          Vis Version: v1.4.15
                          • O ocio
                            Binding:
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            liv-in-sky
                            #73
                            @ocio
                            keine kommas sondern punkte bei /10.2 verwenden - nicht 10,2
                            O 1 Antwort Letzte Antwort
                              @ocio
                              O Offline
                              O Offline
                              ocio
                              #74
                              @liv-in-sky Danke für das feedback, aber das Komma trennt die zwei Argumente der round(x,y) Funktion, x der wert (a/10), y (=2) die Dezimalstellen.
                              • O ocio
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                liv-in-sky
                                #75
                                @ocio
                                ???? was passiert, wenn du ,2 wegnimmst
                                https://www.techonthenet.com/js/math_round.php
                                • O ocio
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  liv-in-sky
                                  #76
                                  @ocio sagte in Bindings in vis:
                                  zwei dezimalstellen sollte so sein
                                  {a:0_userdata.0.a;Math.round(parseFloat(a)/10*100)/100}
                                    O Offline
                                    O Offline
                                    ocio
                                    #77
                                    @liv-in-sky Danke, sehe jetzt meinen Fehler, round(x,y) gibt es in nicht in js :man-facepalming:
                                    liv-in-skyL OliverIOO 2 Antworten Letzte Antwort
                                    • O ocio
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      liv-in-sky
                                      #78
                                      @ocio
                                      nur nebenbei:
                                      wenn man die runtime in chrome öffnet, kann man die entwicklertools öffnen und unter dem tab console die fehler ansehen, die bei einem refresh der seite kommen - manchmal hilft das. um binding fehler zu finden
                                      • O ocio
                                        OliverIOO Offline
                                        OliverIOO Offline
                                        OliverIO
                                        #79
                                        Eigentlich schon
                                        https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Math/round?retiredLocale=de
                                        Links im Profil
                                        • OliverIOO OliverIO
                                          Eigentlich schon
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          liv-in-sky
                                          #80
                                          @oliverio
                                          ich sehe dort nicht, dass es eine function math.round gibt, bei der man 2 werte übergibt
                                          Math.round(x,y)
