  4. Wasserzähler - Selfmade
    6.7k
wasser wasserzählerhow-to
1.1k Beiträge 48 Kommentatoren 496.3k Aufrufe 72 Beobachtet
  • J jomjol
    Hi @ramon2krpi3,
    first it looks like, you are using the "master" branch of the docker server. I suggest to update to the "rolling" version. Within this a much better trained cnn-file is available (v 6.2.0). Just to know: the format has changed from h5 to tflite.
    That should already improve the recognition. If this is not enough, it might be necesarry to train your numbers.
    Best regards,
    jomjol
    ramon2krpi3
    #1021
    Hi @jomjol, could anybody summarize the step by step migration to rolling version?
    Thanks!
    R 1 Antwort Letzte Antwort
    • R ramon2krpi3
      Thanks!
      ramon2krpi3
      #1022
      15242873-7889-4aac-8398-2d7cbc1713bd-image.png @ramon2krpi3 This is how I did:
      1. Download the raspi-rolling image: sudo docker pull jomjol/wasserzaehler:raspi-rolling
      2. Over my old folders structure I created a new app folder and I copied my old /config & /log folders
      3. I downloaded “Train_CNN_Digital-Readout_Version_6.2.0.tflite” and put it in “/home/pi/water-meter-system-complete/code/app/config/neuralnets”
      4. I edited “/home/pi/water-meter-system-complete/code/app/config/config.ini” and changed the new Train_CNN tflite
      [Digital_Digit]
      names = D1, D2, D3, D4, D5, D6, D7, D8
      modelfile = ./config/neuralnets/Train_CNN_Digital-Readout_Version_6.2.0.tflite
      LogImageLocation=./log/digital_digit
      1. I run the docker and it seems do it well:
      pi@pi4:~ $ docker run -p 4000:3000 --mount type=bind,source=/home/pi/water-meter-system-complete/code/app/config,target=/app/config --mount type=bind,source=/home/pi/water-meter-system-complete/code/app/log,target=/app/log --memory-swap -1 jomjol/wasserzaehler:raspi-rolling
      92.0
      Start Init Zaehlerstand
      Analog Model Disabled
      Digital Model Init Done
      Prevalue loaded from file: 00000690.0000
      Wasserzaehler is serving at port 3000
      1. When I ask for a reading “http://192.168.1.234:4000/wasserzaehler.html&full” the docker gives me this error:
      Exception happened during processing of request from ('192.168.1.231', 59241)
      Traceback (most recent call last):
      File "/usr/lib/python3.7/socketserver.py", line 316, in _handle_request_noblock
      self.process_request(request, client_address)
      File "/usr/lib/python3.7/socketserver.py", line 347, in process_request
      self.finish_request(request, client_address)
      File "/usr/lib/python3.7/socketserver.py", line 360, in finish_request
      self.RequestHandlerClass(request, client_address, self)
      File "/usr/lib/python3.7/socketserver.py", line 720, in init
      self.handle()
      File "/usr/lib/python3.7/http/server.py", line 426, in handle
      self.handle_one_request()
      File "/usr/lib/python3.7/http/server.py", line 414, in handle_one_request
      method()
      File "./wasseruhr.py", line 37, in do_GET
      GlobalError = wasserzaehler.CheckError()
      File "/app/lib/ZaehlerstandClass.py", line 102, in CheckError
      if self.readAnalogNeedle.GlobalError:
      AttributeError: 'Zaehlerstand' object has no attribute 'readAnalogNeedle'
      I'm lost. Do I have to modify/install anything else?
      I didin't do nothing whit Tensorflow. May I do anything to manage TensoflowLite?
      Regards
      J 1 Antwort Letzte Antwort
      • R ramon2krpi3
        [Digital_Digit]
        92.0
        self.handle()
        method()
        Regards
        jomjol
        #1023
        Hi @ramon2krpi3,
        you run into a bug in the code. Disabling the "Analog Readout" did not work in this version due to an unknown bug. Seems you are the first one, who really used this feature.
        I just corrected it and the Docker-Container is under construction. Should take another hour, than it should work.
        Thanks for you support in the detailed error description, made my debugging much easier.
        Best regards,
        jomjol
        J R 2 Antworten Letzte Antwort
        • J jomjol
          Hi @ramon2krpi3,
          Best regards,
          jomjol
          jomjol
          schrieb am zuletzt editiert von jomjol
          #1024
          hier ein Update zu meinem neuen Projekt. Die erste Beta-Version für den integrierten Wasserzähler ist funktionsfähig!
          Hier mal ein Screenshot von der Benutzerschnittstelle:
          Wie ihr seht, habe ich die verschiedenen Features der Bildaufnahme und Auswertung mit einer Web-Oberfläche verknüpft. Dass wird in Zukunft den Betrieb und die Anpassung des Servers deutlich vereinfachen und noch mehr Nutzern zugänglich machen.
          Hier mal ein paar Key-Features:
          • Webserver mit einfacher Oberfläche integriert - einfach erweiterbar (Idee: z.B. Bearbeitung der Config.ini direkt im Browser ?)
          • Zusätzlich ein einfacher Fileserver für die SD-Karte (browse, upload, download, delete)
          • OTA-Schnittstelle über Web-Interface, inkl. Reboot - kein Aus-/Einbau für Updates!
          • Kamera, Bildbearbeitung & Ziffer/Zeiger-Erkennung alles auf dem ESP32
          • Abwährtkompatibel (95%) zur Schnittstelle zu Bilderfassung (.../capture_with_flashlight), wie auch zum Dockercontainer (.../wasserzaehler.html)
          • Systeme laufen alle parallel (Multitasking Programmstruktur). Damit könnt ihr auch erstmal die alten System unverändert weiter laufen lassen und alles parallel testen.
          Einziger Nachteil: momentan dauert ein Auswertezyklus bei mir ca. 2.5 Minuten. Da ist noch viel Potential (>50%), aber für Just-In-Time Abfragen zu lange. Daher habe ich einen Scheduler implementiert, der zyklisch (z.B. alle 5 Minuten) die Auswertung macht und bei Abfragen den letzten Wert meldet. Konsistenzchecks, analog zum Docker-Container, sind natürlich auch impementiert.
          Da ich aus Platzgründen den INI-Parser selbst schreiben musste, ist der Syntax nicht vollkommen kompatibel aber leicht zu adaptieren. Auch werden nur noch 2 Referenzen verwendet, das hat sogar den Vorteil, dass es nicht mehr zu einer Verzehrung kommen kann.
          Für alle, die mal einen Blick darauf werfen wollen, finden sich die Firmwaredateien und eine Anleitung zum Flashen hier:
          https://github.com/jomjol/AI-on-the-edge-device
          Für Fragen, Anregungen, Bug-Reports, ... bin ich wie immer offen.
          Beste Grüße,
          jomjol
          P.S.: das ist eine recht aufwendige Portierung geworden, ich musste alles in C++ neu schreiben und habe es auch für Restrukturierung genutzt. Daher bitte ich zunächst Bugs zu verzeihen :-)
          M G 2 Antworten Letzte Antwort
          • J jomjol
            Beste Grüße,
            jomjol
            mameier1234
            #1025
            @jomjol Unglaublich !! Ich habe riesigen Respect !!! Danke für die geile Arbeit, ich liebe das bisherige Ergebniss....
            Grüße,
            Martin
            • J jomjol
              Beste Grüße,
              jomjol
              gerald123
              #1026
              @jomjol Hallo jomjol,
              Die Bedienoberfläche schaut super aus 👍
              Um bei der Installation nichts falsch zu machen wollte ich frage ob es schon eine Anleitung in Deutsch gibt?
              Würde mir sehr helfen.
              Super tolles Projekt, bitte weiter so 👑
              Synology 918+ 4GB; ioBroker auf RPI4; Zigbee; Sonoff
              • G gerald123
                jomjol
                #1027
                @gerald123 Hallo Gerald,
                aktuell gibt es keine deutsche Anleitung und erstmal wollte ich es auch nicht zweisprachig machen. Aber ich kann dir gerne eine kurze Skype o.ä. Session anbieten und dann zeige ich es dir. Ist wirklich nicht schwierig. Bitte einfach kontakt per PM.
                Beste Grüße,
                jomjol
                G 1 Antwort Letzte Antwort
                • J jomjol
                  Beste Grüße,
                  jomjol
                  gerald123
                  #1028
                  Danke für das Angebot, werde es mal alleine probieren und sonst melde ich mich wieder.
                  Ist es richtig wenn ich die drei Codedateien auf den ESP flashe und den gesamten Ordner SD auf eine Speicherkarte speichere und in den ESP stecke. Das sollte es doch schon gewesen sein, oder?
                  • G gerald123
                    jomjol
                    #1029
                    @gerald123 Ja korrekt, du musst dann noch die config.ini anpassen. Die hat einen etwas anderen Syntax, ist aber inhaltlich gleich und hoffentlich fast selbsterklärend.
                    Unterstützte dich gerne als erster Beta-Nutzer :-). Einfach wirklich gerne melden.
                    Gruß,
                    jomjol
                    • J jomjol
                      Gruß,
                      jomjol
                      gerald123
                      #1030
                      @jomjol Danke, Installation am ESP hat heute schon geklappt 👍
                      Morgen werde ich versuchen die Config.ini einzurichten, hoffe das geht auch so toll.
                      Ich werde wieder berichten wie es läuft🤞
                      Schönen Abend wünsche ich dir noch!
                      • J jomjol
                        Gruß,
                        jomjol
                        gerald123
                        #1031
                        Jetzt benötige ich schon deine Hilfe!
                        Ich möchte die config.ini bearbeiten, aber leider ohne erfolg.
                        Direkt auf der Weboberfläche ist ein editieren nicht möglich und beim hochladen per WLan kommt auch immer eine Fehlermeldung.
                        Muss ich dazu die Speicherkarte wieder herausnehmen und direkt am PC bearbeiten?
                        Gerald
                        • G gerald123
                          Gerald
                          jomjol
                          #1032
                          Hallo @gerald123,
                          gar kein Problem - gerne. Direkte Bearbeitung im Brower geht (nocht) nicht. Der Fileserver ist ein reiner Viewer und Up/Download. Bevor du die Config.ini hochladen kannst, musst du die alte Config.ini löschen (Delete Button rechts). Aktuell ist der Filebrowser so eingestellt, dass er vorhandene Dateien nicht überschreibt.
                          SD-Karte rausholen und offline bearbeiten geht natürlich auch. Damit die neue Config.ini verwendet wird, musst du aber auch einen Reboot durchführen. Aktuell wird sie nur beim Start ausgelesen.
                          Gruß,
                          jomjol
                          • J jomjol
                            Hallo @gerald123,
                            Gruß,
                            jomjol
                            gerald123
                            #1033
                            @jomjol hab jetzt den Delete Button benutzt, leider kommt dann die Meldung „ Header fields are too long for server to interpret“ und wenn ich dann wieder über den File Server im config Ordner nachsehe ist die config.ini Datei noch immer vorhanden.
                            Muss ich wirklich die SD Karte rausholen
                            • G gerald123
                              jomjol
                              #1034
                              @gerald123 Diese Fehlermeldung kenne ich gar nicht. Bist du sicher, dass du die neueste Firmware verwendet?
                              • J jomjol
                                gerald123
                                #1035
                                @jomjol wie kann ich das prüfen?
                                • G gerald123
                                  jomjol
                                  #1036
                                  @gerald123 Versionierung fehlt noch. Die neueste Version ist von gesten Abend.
                                  • J jomjol
                                    gerald123
                                    #1037
                                    @jomjol kann ich die neue Version per OTA auf den ESP flashen?
                                    • W watcherkb
                                      @jomjol
                                      Hi, ich habe seit heute das Problem dass der Server mir beim Aufruf über http://192.168.1.36:3000/wasserzaehler.html nichts liefert. Die Seite bleibt leer. Der Parser-Adapter meckert auch:
                                      Cannot read link "http://192.168.1.36:3000/wasserzaehler.html": {"statusCode":200,"body":"","headers":{"server":"BaseHTTP/0.6 Python/3.7.4","date":"Tue, 30 Jun 2020 12:10:00 GMT","content-type"
                                      Der Aufruf http://192.168.1.36:3000/wasserzaehler.html&full funktioniert, hat aber die 6 falsch erkannt (letztes tf-file)
                                      Server und ESP sind bereits neu gestartet. Eine Idee was es sein kann?
                                      W Offline
                                      W Offline
                                      watcherkb
                                      #1038
                                      @watcherkb sagte in Wasserzähler - Selfmade:
                                      @jomjol
                                      @jomjol das Problem besteht bei mir weiterhin. In der ersten Reihe werden keine Werte angezeigt, deswegen auch keine Parserauswertung möglich. Konntest du schon gucken woran es liegen kann?
                                      CC2538+CC2592 PA-Zigbee-Funkmodul
                                      • W watcherkb
                                        @jomjol
                                        jomjol
                                        #1039
                                        @watcherkb
                                        Habe mir den Code gerade angeschaut. Die Fehlermeldung kann auftreten, wenn du zwar die Konsistenzprüfung eingeschaltet hast
                                        [ConsistencyCheck]
                                        Enabled=True
                                        aber in der Fehlerrückmeldung keine Errormessage angibst:
                                        ErrorReturn=OldValue, Readout
                                        Wie sieht denn deine Config.ini dort aus. Falls ErrorReturn so oder so ähnlich aussieht, probier mal:
                                        ErrorReturn=OldValue, ErrorMessage, Readout
                                        Wenn es das nicht ist, dann schick mir mal bitte dein Config.ini
                                        Gruß,
                                        jomjol
                                        W 1 Antwort Letzte Antwort
                                        • G gerald123
                                          jomjol
                                          #1040
                                          @gerald123 sagte in Wasserzähler - Selfmade:
                                          Ja, kann du. Aber bitte auch drauf achten, dass auch die Dateien im Verzeichnis /html aktualisiert werden. Dort ist die Ansteuerung für die OTA, ... und dort habe ich auch noch einiges optimiert. Sollte aber in Zukunft weniger werden.
