  4. IOBroker schon wieder kaputt
29 Beiträge 7 Kommentatoren 6.0k Aufrufe
    marschmello
    der cache clean hat etwas gebracht
    iobroker.js-controller@0.9.0 install /opt/iobroker/node_modules/iobroker.js-controller
    node lib/setup.js setup first
    iobroker.js-controller@0.9.0 node_modules/iobroker.js-controller
    ├── winston-daily-rotate-file@1.1.4
    ├── daemonize2@0.4.2
    ├── mime@1.3.4
    ├── ncp@2.0.0
    ├── node.extend@1.1.5 (is@3.1.0)
    ├── adm-zip@0.4.7
    ├── semver@4.3.6
    ├── node-schedule@1.0.0 (long-timeout@0.0.2, cron-parser@1.1.0)
    ├── yargs@3.32.0 (decamelize@1.2.0, camelcase@2.1.1, y18n@3.2.1, window-size@0.1.4, cliui@3.2.0, string-width@1.0.1, os-locale@1.4.0)
    ├── socket.io@1.4.6 (has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.2.6, engine.io@1.6.9, socket.io-adapter@0.4.0)
    ├── socket.io-client@1.4.6 (to-array@0.1.4, indexof@0.0.1, component-emitter@1.2.0, object-component@0.0.3, component-bind@1.0.0, backo2@1.0.2, has-binary@0.1.7, debug@2.2.0, parseuri@0.0.4, socket.io-parser@2.2.6, engine.io-client@1.6.9)
    ├── prompt@1.0.0 (revalidator@0.1.8, colors@1.1.2, pkginfo@0.4.0, read@1.0.7, winston@2.1.1, utile@0.3.0)
    ├── request@2.72.0 (is-typedarray@1.0.0, oauth-sign@0.8.2, aws-sign2@0.6.0, forever-agent@0.6.1, tunnel-agent@0.4.3, caseless@0.11.0, stringstream@0.0.5, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, aws4@1.4.1, node-uuid@1.4.7, combined-stream@1.0.5, qs@6.1.0, tough-cookie@2.2.2, mime-types@2.1.11, form-data@1.0.0-rc4, bl@1.1.2, http-signature@1.1.1, hawk@3.1.3, har-validator@2.0.6)
    ├── tar.gz@1.0.5 (commander@2.9.0, tar@2.2.1, bluebird@2.10.2, fstream@1.0.9, mout@0.11.1)
    └── npm@2.15.7 `
      marschmello
      einige sachen sind jetzt gestartet.
      ` > root@raspberrypi:/opt/iobroker# ps -A | grep io
      10 ? 00:00:00 migration/0
      11 ? 00:00:00 migration/1
      15 ? 00:00:00 migration/2
      19 ? 00:00:00 migration/3
      30 ? 00:00:00 bioset
      33 ? 00:00:00 rpciod
      36 ? 00:00:00 nfsiod
      49 ? 00:00:00 DWC Notificatio
      4376 ? 00:00:10 iobroker.js-con
      4395 ? 00:00:05 io.hm-rpc.0
      4406 ? 00:00:09 io.hm-rega.0
      4415 ? 00:00:06 io.web.0
      4447 ? 00:00:03 io.hm-rpc.1 `
      die Admin Seite kann ich aber leider noch nicht öffnen
        @marschmello:
        der cache clean hat etwas gebracht `
        sach bloß ;-)
        und nu?
        Rainer
          marschmello
          Die Instancen scheine alle zu laufen
          ` > system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.hm-rpc.0 : hm-rpc - enabled
          system.adapter.hm-rega.0 : hm-rega - enabled
          system.adapter.web.0 : web - enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.vis.0 : vis - enabled
          system.adapter.vis-timeandweather.0 : vis-timeandweather - enabled
          system.adapter.yr.0 : yr - enabled
          system.adapter.icons-material-png.0 : icons-material-png - enabled
          system.adapter.icons-mfd-png.0 : icons-mfd-png - enabled
          system.adapter.hm-rpc.1 : hm-rpc - enabled
          system.adapter.vis-fancyswitch.0 : vis-fancyswitch - enabled
          system.adapter.vis-hqwidgets.0 : vis-hqwidgets - enabled
          system.adapter.dwd.0 : dwd - enabled
          system.adapter.ical.0 : ical - enabled
          system.adapter.icons-mfd-svg.0 : icons-mfd-svg - enabled
          system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd - enabled
          root@raspberrypi:/opt/iobroker# `
            marschmello
            Leider kann ich nicht auf die Instancen zugreifen.
            Nicht auf Admin oder Vis.
            Die Vis Seite ist kurz aufbeblitzt und es stand dort etwas von Update gefunden
            danach aber nur noch eine leere Seite
            gruß
              STRG-F5
              mal probiert?
              reboot des RasPi mal probiert?
              …und noch so viele offenen Fragen :(
              Rainer
                marschmello
                Mein Pi ist Raspberry Pi 2 Model B QUAD-CORE CPU und 1 GB
                und den reboot hab ich schon einmal nach der installation gemacht.
                STRG F5 ??? Wo sollte ich das machen?? Im Browser???
                gruß Ralf
                ps Karte habe ich gescheckt. ist nicht voll
                  marschmello
                  Das Log würde ich dir gerne zur Verfügung stellen, nur sind das gefühlt an die 100 Seiten.
                  Kann ich das irgenwie filtern??
                    marschmello
                    Ich habe einen Fehler im Node gefunden
                    root@raspberrypi:/opt/iobroker# node node_modules/iobroker.admin/admin.js
                    module.js:338
                        throw err;
                    Error: Cannot find module 'merge-descriptors'
                        at Function.Module._resolveFilename (module.js:336:15)
                        at Function.Module._load (module.js:278:25)
                        at Module.require (module.js:365:17)
                        at require (module.js:384:17)
                        at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/express.js:16:13)
                        at Module._compile (module.js:460:26)
                        at Object.Module._extensions..js (module.js:478:10)
                        at Module.load (module.js:355:32)
                        at Function.Module._load (module.js:310:12)
                        at Module.require (module.js:365:17)</anonymous>
                    Vielleicht hilft dies ja weiter.
                    gruß
