  4. [gelöst]Meross Adapter Gelb
    6.8k
meross gelb
4 Beiträge 2 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • sigi234S Online
    sigi234S Online
    sigi234
    Hallo, Adapter bleibt Gelb.....wurde schon von einigen User berichtet. Auch in Facebook.
    Via Handy geht es aber.
    Edit: Geht wieder!
    Debug Log
    undefined2019-03-20 01:18:46.421  - info: host.Medion object change system.adapter.meross.0
    2019-03-20 01:18:46.467  - info: host.Medion instance system.adapter.meross.0 started with pid 4080
    2019-03-20 01:18:47.135  - debug: meross.0 objectDB connected
    2019-03-20 01:18:47.150  - debug: meross.0 statesDB connected
    2019-03-20 01:18:47.150  - info: meross.0 starting. Version 1.0.0 in C:/ioBroker/node_modules/iobroker.meross, node: v8.15.1
    2019-03-20 01:18:47.221  - debug: meross.0 connected set to false
    2019-03-20 01:18:52.918  - info: host.Medion object change system.adapter.meross.0
    2019-03-20 01:18:52.918  - info: host.Medion stopInstance system.adapter.meross.0
    2019-03-20 01:18:52.918  - info: host.Medion stopInstance system.adapter.meross.0 killing pid 4080
    2019-03-20 01:18:52.939  - warn: host.Medion instance system.adapter.meross.0 terminated due to SIGTERM
    2019-03-20 01:18:52.939  - info: host.Medion instance system.adapter.meross.0 terminated with code null ()
    2019-03-20 01:18:55.472  - info: host.Medion instance system.adapter.meross.0 started with pid 11832
    2019-03-20 01:18:55.986  - debug: meross.0 objectDB connected
    2019-03-20 01:18:55.994  - debug: meross.0 statesDB connected
    2019-03-20 01:18:56.009  - info: meross.0 starting. Version 1.0.0 in C:/ioBroker/node_modules/iobroker.meross, node: v8.15.1
    2019-03-20 01:18:56.082  - debug: meross.0 connected set to false
    2019-03-20 01:19:00.128  - info: javascript.0 script.js.Sigi.UWZ: []
    2019-03-20 01:19:09.323  - error: meross.0 Meross Connection Error: Error: 1402: A
    Immer Daten sichern!
    Jens BräunelJ 1 Antwort Letzte Antwort
    • sigi234S sigi234
      Edit: Geht wieder!
      Debug Log
      Jens BräunelJ Offline
      Jens Bräunel
      @sigi234
      Hallo sigi,
      wie hat sich das Problem bei dir damals behoben?
      Ich hab aktuell das gleiche Problem und irgendwie hilft nichts. (Neuinstallation des Adapter, Passwortänderung bei Meross, usw.)
      Viel Grüße
      • Jens BräunelJ Jens Bräunel
        @sigi234
        Hallo sigi,
        Viel Grüße
        sigi234S Online
        sigi234S Online
        sigi234
        @Jens-Bräunel
        Welche Version?
        • sigi234S sigi234
          @Jens-Bräunel
          Welche Version?
          Jens Bräunel
          @sigi234
          ich hab jetzt die 1.5.0 installiert.
          Mit der Handy app geht alles.
