  4. Skript für DarkSky Wetterdaten
    6.6k
javascriptclimate
11 Beiträge 5 Kommentatoren 2.4k Aufrufe 3 Beobachtet
    Dschaedl
    schrieb am zuletzt editiert von Dschaedl
    Hallo zusammen
    Da WU keine Daten mehr liefert (zumindest gratis nicht) habe ich mir heute ein Skript zum auslesen der DarkSky Daten gebaut (quick&dirty).
    Wenn's jemand gebrauchen kann, nur zu.
    Falls ich mal Zeit finde werde ich evtl. einen Adapter daraus machen - oder jemand von euch übernimmt ;-)
    var moment = require('moment');
    extractDarkSkyData(null);
    // Trigger
    schedule("*/5 * * * *", function (data) {
        extractDarkSkyData(data);
    function extractDarkSkyData(data) {
        log("calling Darksky Wetter URL", 'info');
        //https://api.darksky.net/forecast/2cd....997/47.2694981,8.6569669?units=si&lang=de
        request('https://api.darksky.net/forecast/<yourApiKey>/<yourCoordinates>?units=si&lang=de',
                 {json:true}, function (error, response, body) {
            log("looking for DarkSky data...", 'info');
            if (!error && response.statusCode == 200) {
                log ("error:" + error);
                log ("basics", 'info');
                setIfDifferent('darksky.latitude', "Latitude", body.latitude, 0, "°", true);
                setIfDifferent('darksky.longitude', "Longitude", body.longitude, 0, "°", true);
                setIfDifferent('darksky.timezone', "Timezone", body.timezone, "n/a", "", false);
                log ("current", 'info');
                setIfDifferent('darksky.currently.time', "time (unix, local)", body.currently.time, 0, " unix", true);
                setIfDifferent('darksky.currently.summary', "Weather", body.currently.summary, "n/a", "", false);
                setIfDifferent('darksky.currently.icon', "", body.currently.icon, "", "", false);
                setIfDifferent('darksky.currently.precipIntensity', "Niederschlag", body.currently.precipIntensity, 0, "mm/h", true);
                setIfDifferent('darksky.currently.precipProbability', "Niederschlag Wahrscheinlichkeit", body.currently.precipProbability *100, 0, "%", true);
                setIfDifferent('darksky.currently.precipType', "Niederschlag Typ", body.currently.precipType, "", "", false);
                setIfDifferent('darksky.currently.temperature', "Temperatur", body.currently.temperature, 0, "°C", true);
                setIfDifferent('darksky.currently.apparentTemperature', "Temperatur (Windchill)", body.currently.apparentTemperature, 0, "°C", true);
                setIfDifferent('darksky.currently.dewPoint', "Taupunkt", body.currently.dewPoint, 0, "°C", true);
                setIfDifferent('darksky.currently.humidity', "Luftfeuchtigkeit", body.currently.humidity *100, 0, "%", true);
                setIfDifferent('darksky.currently.pressure', "Luftdruck", body.currently.pressure, 0, "hPa", true);
                setIfDifferent('darksky.currently.windSpeed', "Windgeschwindigkeit", body.currently.windSpeed, 0, "m/s", true);
                setIfDifferent('darksky.currently.windGust', "Boen", body.currently.windGust, 0, "m/s", true);
                setIfDifferent('darksky.currently.windBearing', "Windrichtung", body.currently.windBearing, 0, "°", true);
                setIfDifferent('darksky.currently.cloudCover', "Bedeckungsgrad", body.currently.cloudCover *100, 0, "%", true);
                setIfDifferent('darksky.currently.uvIndex', "UV Index", body.currently.uvIndex, 0, "", true);
                setIfDifferent('darksky.currently.visibility', "Sichtweite", body.currently.visibility, 0, "km", true);
                setIfDifferent('darksky.currently.ozone', "Ozon", body.currently.ozone, 0, "DU", true);
                var obsDate = moment.unix(body.currently.time);
                var now = moment();
                var age = moment.duration(now.diff(obsDate));
                log("age in Seconds: " + age.asSeconds(), 'info');
                setIfDifferent('darksky.currently.age', 'current_age', age.asSeconds(), 0, 's', true);
                setIfDifferent('darksky.currently.time2', 'Zeit', obsDate.format("DD.MM.YYYY HH:mm:ss ZZ"), "", '', false);
                log ("hourly", 'info');
                var i=0;
                body.hourly.data.forEach(function(value, index, array){
                    var obsDate = moment.unix(value.time);
                    var now = moment();
                    //I'm only interested in future data. If you want all data, remove the 'if'
                    if (age < 0) {
                        log("future entry. store it", 'debug');
                        setIfDifferent('darksky.hourly.'+i+'.time', "time (unix, local)", value.time, 0, "unix", true);
                        setIfDifferent('darksky.hourly.'+i+'.summary', "Weather", value.summary, "n/a", "", false);
                        setIfDifferent('darksky.hourly.'+i+'.icon', "", value.icon, "", "", false);
                        setIfDifferent('darksky.hourly.'+i+'.precipIntensity', "Niederschlag", value.precipIntensity, 0, "mm/h", true);
                        setIfDifferent('darksky.hourly.'+i+'.precipProbability', "Niederschlag Wahrscheinlichkeit", value.precipProbability *100, 0, "%", true);
                        setIfDifferent('darksky.hourly.'+i+'.precipType', "Niederschlag Typ", value.precipType, "", "", false);
                        setIfDifferent('darksky.hourly.'+i+'.temperature', "Temperatur", value.temperature, 0, "°C", true);
                        setIfDifferent('darksky.hourly.'+i+'.apparentTemperature', "Temperatur (Windchill)", value.apparentTemperature, 0, "°C", true);
                        setIfDifferent('darksky.hourly.'+i+'.dewPoint', "Taupunkt", value.dewPoint, 0, "°C", true);
                        setIfDifferent('darksky.hourly.'+i+'.humidity', "Luftfeuchtigkeit", value.humidity *100, 0, "%", true);
                        setIfDifferent('darksky.hourly.'+i+'.pressure', "Luftdruck", value.pressure, 0, "hPa", true);
                        setIfDifferent('darksky.hourly.'+i+'.windSpeed', "Windgeschwindigkeit", value.windSpeed, 0, "m/s", true);
                        setIfDifferent('darksky.hourly.'+i+'.windGust', "Boen", value.windGust, 0, "m/s", true);
                        setIfDifferent('darksky.hourly.'+i+'.windBearing', "Windrichtung", value.windBearing, 0, "°", true);
                        setIfDifferent('darksky.hourly.'+i+'.cloudCover', "Bedeckungsgrad", value.cloudCover *100, 0, "%", true);
                        setIfDifferent('darksky.hourly.'+i+'.uvIndex', "UV Index", value.uvIndex, 0, "", true);
                        setIfDifferent('darksky.hourly.'+i+'.visibility', "Sichtweite", value.visibility, 0, "km", true);
                        setIfDifferent('darksky.hourly.'+i+'.ozone', "Ozon", value.ozone, 0, "DU", true);
                        setIfDifferent('darksky.hourly.'+i+'.age', 'current_age', age.asSeconds(), 0, 's', true);
                        setIfDifferent('darksky.hourly.'+i+'.time2', 'Zeit', obsDate.format("DD.MM.YYYY HH:mm:ss ZZ"), "", '', false);
                        i++
                    } else {
                        log("past entry - not stored");
                log ("daily", 'info');
                i=0;
                body.daily.data.forEach(function(value, index, array){
                    var now = moment();
                    if (age < 0) {
                        setIfDifferent('darksky.daily.'+i+'.time', "time (unix, local)", value.time, 0, "unix", true);
                        setIfDifferent('darksky.daily.'+i+'.summary', "Weather", value.summary, "n/a", "", false);
                        setIfDifferent('darksky.daily.'+i+'.icon', "", value.icon, "", "", false);
                        setIfDifferent('darksky.daily.'+i+'.sunriseTime', "Sonnenaufgang", value.sunriseTime, "", "unix", true);
                        setIfDifferent('darksky.daily.'+i+'.sunsetTime', "Sonnenuntergang", value.sunsetTime, "", "unix", true);
                        setIfDifferent('darksky.daily.'+i+'.moonPhase', "Mondphase", value.moonPhase *100, 0, "%", true);
                        setIfDifferent('darksky.daily.'+i+'.precipIntensity', "Niederschlag", value.precipIntensity, 0, "mm/h", true);
                        setIfDifferent('darksky.daily.'+i+'.precipIntensityMax', "Niederschlag MAX", value.precipIntensityMax, 0, "mm/h", true);
                        setIfDifferent('darksky.daily.'+i+'.precipIntensityMaxTime', "Niederschlag MAX Zeit", value.precipIntensityMaxTime, 0, "unix", true);
                        setIfDifferent('darksky.daily.'+i+'.precipProbability', "Niederschlag Wahrscheinlichkeit", value.precipProbability *100, 0, "%", true);
                        setIfDifferent('darksky.daily.'+i+'.precipType', "Niederschlag Typ", value.precipType, "", "", false);
                        setIfDifferent('darksky.daily.'+i+'.temperatureHigh', "Temperatur High", value.temperatureHigh, 0, "°C", true);
                        setIfDifferent('darksky.daily.'+i+'.temperatureHighTime', "Temperatur High Zeit", value.temperatureHighTime, 0, "unix", true);
                        setIfDifferent('darksky.daily.'+i+'.temperatureLow', "Temperatur Low", value.temperatureLow, 0, "°C", true);
                        setIfDifferent('darksky.daily.'+i+'.temperatureLowTime', "Temperatur Low Zeit", value.temperatureLowTime, 0, "unix", true);
                        setIfDifferent('darksky.daily.'+i+'.apparentTemperatureHigh', "Temperatur High (Windchill)", value.apparentTemperatureHigh, 0, "°C", true);
                        setIfDifferent('darksky.daily.'+i+'.apparentTemperatureHighTime', "Temperatur (Windchill) High Zeit", value.apparentTemperatureHighTime, 0, "unix", true);
                        setIfDifferent('darksky.daily.'+i+'.apparentTemperatureLow', "Temperatur Low (Windchill)", value.apparentTemperatureLow, 0, "°C", true);
                        setIfDifferent('darksky.daily.'+i+'.apparentTemperatureLowTime', "Temperatur (windchill) Low Zeit", value.apparentTemperatureLowTime, 0, "unix", true);
                        setIfDifferent('darksky.daily.'+i+'.dewPoint', "Taupunkt", value.dewPoint, 0, "°C", true);
                        setIfDifferent('darksky.daily.'+i+'.humidity', "Luftfeuchtigkeit", value.humidity *100, 0, "%", true);
                        setIfDifferent('darksky.daily.'+i+'.pressure', "Luftdruck", value.pressure, 0, "hPa", true);
                        setIfDifferent('darksky.daily.'+i+'.windSpeed', "Windgeschwindigkeit", value.windSpeed, 0, "m/s", true);
                        setIfDifferent('darksky.daily.'+i+'.windGust', "Boen", value.windGust, 0, "m/s", true);
                        setIfDifferent('darksky.daily.'+i+'.windGustTime', "Boen Zeit", value.windGustTime, 0, "unix", true);
                        setIfDifferent('darksky.daily.'+i+'.windBearing', "Windrichtung", value.windBearing, 0, "°", true);
                        setIfDifferent('darksky.daily.'+i+'.cloudCover', "Bedeckungsgrad", value.cloudCover *100, 0, "%", true);
                        setIfDifferent('darksky.daily.'+i+'.uvIndex', "UV Index", value.uvIndex, 0, "", true);
                        setIfDifferent('darksky.daily.'+i+'.uvIndexTime', "UV Index Zeit", value.uvIndexTime, 0, "unix", true);
                        setIfDifferent('darksky.daily.'+i+'.visibility', "Sichtweite", value.visibility, 0, "km", true);
                        setIfDifferent('darksky.daily.'+i+'.ozone', "Ozon", value.ozone, 0, "DU", true);
                        setIfDifferent('darksky.daily.'+i+'.temperatureMax', "Temperatur MAX", value.temperatureMax, 0, "°C", true);
                        setIfDifferent('darksky.daily.'+i+'.temperatureMaxTime', "Temperatur MAX Zeit", value.temperatureMaxTime, 0, "unix", true);
                        setIfDifferent('darksky.daily.'+i+'.temperatureMin', "Temperatur MIN", value.temperatureMin, 0, "°C", true);
                        setIfDifferent('darksky.daily.'+i+'.temperatureMinTime', "Temperatur MIN Zeit", value.temperatureMinTime, 0, "unix", true);
                        setIfDifferent('darksky.daily.'+i+'.apparentTemperatureMax', "Temperatur MAX (Windchill)", value.apparentTemperatureMax, 0, "°C", true);
                        setIfDifferent('darksky.daily.'+i+'.apparentTemperatureMaxTime', "Temperatur (Windchill) MAX Zeit", value.apparentTemperatureMaxTime, 0, "unix", true);
                        setIfDifferent('darksky.daily.'+i+'.apparentTemperatureMin', "Temperatur MIN (Windchill)", value.apparentTemperatureMin, 0, "°C", true);
                        setIfDifferent('darksky.daily.'+i+'.apparentTemperatureMinTime', "Temperatur (windchill) MAX Zeit", value.apparentTemperatureMinTime, 0, "unix", true);
                        setIfDifferent('darksky.daily.'+i+'.age', 'current_age', age.asSeconds(), 0, 's', true);
                        setIfDifferent('darksky.daily.'+i+'.time2', 'Zeit', obsDate.format("DD.MM.YYYY HH:mm:ss ZZ"), "", '', false);
                        i++
                    } else {
            } else {
                log ("error:" + error.stack, 'error');
            log("END Darksky Wetter data...", 'info');
    function setIfDifferent(id, name, value, initVal, unit, isNumber) {
        var oldVal = getState(id);
        if (oldVal.notExist) {
            createState(id, {name: name, initialValue: initVal, unit: unit}, function(){
            log("new State created: " + id + " ->" + name);
            setIfDifferent(id, name, value, initVal, unit);
        else if (oldVal.val != value) {
            if (isNumber) {
                setState(id, parseFloat(value));
            } else {
                setState(id, value);
            log("new Value set for " + name + " (" + id + ")" + ": " + value + " / old: " + oldVal.val, 'info');
    viele Grüsse
    Daniel
      martin111
      Wollte das Script ausprobieren.
      Nur bekomme ich es nicht zum laufen.
      Fehlermeldungen direkt aus dem Script-Editor und aus dem Log habe ich angehängt.
      Habe ich da ein Problem in Zeile 16 mit constants ? Wenn ich mit Maus über das Wort fahre erhalte ich folgenden Text:
      Cannot find name 'constants'. Did you mean '"constants"'?
      any
      Wahrscheinlich ist es eh nur eine Kleinigkeit, aber für mich sind Scripte Neuland.
      LG
      Martin
        Dschaedl
        Hallo Martin
        Lass diese Option einfach mal weg. die braucht es eigentlich gar nicht:
        also
        viele Grüsse
        Daniel
        P.S.
        Ich nehme sie oben auch raus.
          martin111
          Danke, danke, danke.
          Funktioniert nun perferkt.
            dos1973
            das script funktioniert bei mir und holt Daten, aber mein iobroker schmiert total ab???
            • D Dschaedl
              Hallo zusammen
              // Trigger
                          var now = moment();
                          var i=0;
                              var now = moment();
                              if (age < 0) {
                                  i++
                              } else {
                          i=0;
                              var now = moment();
                              if (age < 0) {
                                  i++
                              } else {
                      } else {
                      if (isNumber) {
                      } else {
              viele Grüsse
              Daniel
              sigi234S Online
              sigi234S Online
              sigi234
              @Dschaedl sagte in Skript für DarkSky Wetterdaten:
              Siehe mal da:
              Link
              Immer Daten sichern!
                dos1973
                da gibts aber wieder kein "current" also aktuelles wetter, oder?
                Darksky hat auch das "jetzt" wetter
                • D dos1973
                  sigi234S Online
                  sigi234S Online
                  sigi234
                  @dos1973 sagte in Skript für DarkSky Wetterdaten:
                  Doch, ein Auszug davon:
                    dos1973
                    ok, dann schau ich da mal rein, Danke
                    • D dos1973
                      martin111
                      hmm, also bei mir rennt das Script nun seit 28.März ohne Probleme durch, und auch Iobroker macht keine Zicken
                      • J Offline
                        JB72
                        deute ich das hier richtig:
                        das die 5 bedeutet alle 5 Minuten werden die aktuellen Daten geholt? Weil ich mich gewundert habe in der Darksky API, das da schon über 200 Aufrufe waren, wobei das
                        Script erst ein paar Stunden lief.
                        Kann man hier einen kleineren Intervall einstellen? So oft muss das ja nicht sein die Daten abzurufen, auch wenn 1000 Aufrufe kostenfrei sind.
                        Grüße
                        JB
