  4. iogo-Adapter lässt sich nicht installieren
    6.0k
iogo adapter
11 Beiträge 5 Kommentatoren 1.3k Aufrufe 4 Beobachtet
    Strizz
    die Installation des iogo-Adapters führt bei mir zu folgenden Fehlermeldungen im Log:
    2019-02-17 12:21:50.340 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/grpc_extension.js:57
    2019-02-17 12:21:50.340 - error: Caught by controller[0]: throw e;
    2019-02-17 12:21:50.341 - error: Caught by controller[0]: ^
    2019-02-17 12:21:50.341 - error: Caught by controller[0]: Error: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/node/extension_binary/node-v57-linux-arm-glibc/grpc_node.node)
    2019-02-17 12:21:50.341 - error: Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
    2019-02-17 12:21:50.341 - error: Caught by controller[0]: at Module.load (module.js:566:32)
    2019-02-17 12:21:50.341 - error: Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    2019-02-17 12:21:50.341 - error: Caught by controller[0]: at Function.Module._load (module.js:498:3)
    2019-02-17 12:21:50.342 - error: Caught by controller[0]: at Module.require (module.js:597:17)
    2019-02-17 12:21:50.342 - error: Caught by controller[0]: at require (internal/module.js:11:18)
    2019-02-17 12:21:50.342 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/grpc_extension.js:32:13)
    2019-02-17 12:21:50.342 - error: Caught by controller[0]: at Module._compile (module.js:653:30)
    2019-02-17 12:21:50.342 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    2019-02-17 12:21:50.342 - error: Caught by controller[0]: at Module.load (module.js:566:32)
    2019-02-17 12:21:50.343 - error: host.orangepiplus2e instance system.adapter.iogo.0 terminated with code 1 ()
    2019-02-17 12:21:50.343 - info: host.orangepiplus2e Restart adapter system.adapter.iogo.0 because enabledcode_text
    Ich habe versucht, libstdc++6 noch einmal zu installieren. Da bekomme ich dann allerdings folgende Meldung:
    root@orangepiplus2e:~# apt-get install libstdc++6
    Reading package lists... Done
    Building dependency tree
    libstdc++6 is already the newest version.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Bin jetzt etwas ratlos. Kann ich sonst noch was tun?
    npm: vers 6.4.1
    node: vers 8.15.0
    Hat jemand eine Idee?
    Strizz
    ? 1 Antwort Letzte Antwort
    • S Strizz
      npm: vers 6.4.1
      node: vers 8.15.0
      Strizz
      @Strizz ich kenn zwar den Adapter gut... habe aber leider auch keine Idee 😕
        Strizz
        @nisio
        Dann sind wir schon mal zu zweit.😀 Danke für die Info. Werde meinen iobroker gelegentlich noch mal neu aufsetzen, und es dann noch einmal probieren.
        Strizz
          anubiss1337
          schrieb am zuletzt editiert von anubiss1337
          hab so da so ein ähnliches wenn nicht sogar das gleiche Problem.
          2019-10-10 18:39:11.372 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/grpc_extension.js:57
          2019-10-10 18:39:11.372 - error: Caught by controller[0]: throw e;
          2019-10-10 18:39:11.372 - error: Caught by controller[0]: ^
          2019-10-10 18:39:11.372 - error: Caught by controller[0]: Error: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm-glibc/grpc_node.node)
          2019-10-10 18:39:11.372 - error: Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
          2019-10-10 18:39:11.372 - error: Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
          2019-10-10 18:39:11.372 - error: Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          2019-10-10 18:39:11.373 - error: Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          2019-10-10 18:39:11.373 - error: Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
          2019-10-10 18:39:11.373 - error: Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
          2019-10-10 18:39:11.373 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/grpc_extension.js:32:13)
          2019-10-10 18:39:11.373 - error: Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
          2019-10-10 18:39:11.373 - error: Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          2019-10-10 18:39:11.373 - error: Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
          2019-10-10 18:39:11.373 - error: host.axtpi instance system.adapter.iogo.0 terminated with code 1 ()
          nodej -v
          v6.14.3
          noe -v
          v10.16.3
          npm -v
          v6.11.3
          @Strizz
          hast Du das Problem gelöst?
          • A anubiss1337
            nodej -v
            v6.14.3
            noe -v
            v10.16.3
            npm -v
            v6.11.3
            @Strizz
            Strizz
            @anubiss1337 Leider nein! Habe aufgegeben!
            Strizz
            • ? Offline
              Welche Hardware und welches Betriebssystem nutzt ihr?
                Strizz
                @nis
                Hardware: Ornagepi Plus 2e
                Betriebssystem: Linux
                Strizz
                  anubiss1337
                  Hardware: raspberry pi 3b
                  Software: linux
                  • E Offline
                    e-s
                    Schaut mal bitte nochmal nach den Nodejs Versionen. Und updated diese auf v8 bzw v10. Oben bei der einen Angabe ist ist die node und Nodejs Version nicht gleich. Also bitte da nochmal nachschauen.
                      anubiss1337
                      Hab jetzt, nach vielen Probleme, folgendes hinbekommen:
                      /opt/iobroker $ nodejs -v
                      v10.16.3
                      /opt/iobroker $ node -v
                      v10.16.3
                      /opt/iobroker $ npm -v
                      6.11.3
                      Um dahin zu kommen, hab ich, wenn ich das richtig verstanden habe, iobroker komplett neu aufgesetzt. Danach hab ich, mein zum Glück vorher ertelltes Backup eingespielt.
                      Vielleicht gehört das nicht hierrein aber bei der Instanz tr-064.0 hab ich seit längerem dieses Problem:
                      2019-10-13 11:09:13.457 - error: Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
                      2019-10-13 11:09:13.457 - error: Caught by controller[0]: fns.adapter = fns.adapter(options);
                      2019-10-13 11:09:13.457 - error: Caught by controller[0]: ^
                      2019-10-13 11:09:13.457 - error: Caught by controller[0]: TypeError: fns.adapter is not a function
                      2019-10-13 11:09:13.458 - error: Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
                      2019-10-13 11:09:13.458 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:15:20)
                      2019-10-13 11:09:13.458 - error: Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                      2019-10-13 11:09:13.458 - error: Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                      2019-10-13 11:09:13.458 - error: Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                      2019-10-13 11:09:13.458 - error: Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                      2019-10-13 11:09:13.458 - error: Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                      2019-10-13 11:09:13.458 - error: Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                      2019-10-13 11:09:13.459 - error: Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
                      2019-10-13 11:09:13.459 - error: Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
                      2019-10-13 11:09:13.459 - error: host.axtpi instance system.adapter.tr-064.0 terminated with code 1 ()
                      haben diese Fehler evtl. etwas gemeinsam?
                      • A anubiss1337
                        v10.16.3
                        v10.16.3
                        6.11.3
                        sigi234S Online
                        sigi234S Online
                        sigi234
                        @anubiss1337 sagte in iogo-Adapter lässt sich nicht installieren:
                        Suche mal nach soef oder nimm den neuen Adapter.
                        https://forum.iobroker.net/topic/22782/aufruf-test-community-version-vom-tr-064-adapter
                        Immer Daten sichern!
