  4. Laut Log Probleme mit Blockly [gelöst]
    5.8k
20 Beiträge 3 Kommentatoren 1.4k Aufrufe
    Altersrentner
    Ich habe im LOG sehr viel gelbe oder orangene Einträge.
    Es handelt sich um javescript.0 Einträge von Blocklys.
    Diese schalten aber problemlos, so das es keinen Grund zur Beanstandung gab.
    Beispiel
    fhem.0	2019-01-30 20:15:59.557	info	event ioBroker "fhem.0.VentilFussbodenhzg_WC.state off" > set VentilFussbodenhzg_WC off
    javascript.0	2019-01-30 20:15:59.554	warn	at TCP.onread (net.js:597:20)
    javascript.0	2019-01-30 20:15:59.554	warn	at Socket.Readable.push (_stream_readable.js:208:10)
    javascript.0	2019-01-30 20:15:59.554	warn	at readableAddChunk (_stream_readable.js:250:11)
    javascript.0	2019-01-30 20:15:59.554	warn	at addChunk (_stream_readable.js:263:12)
    javascript.0	2019-01-30 20:15:59.554	warn	at Socket.emit (events.js:211:7)
    javascript.0	2019-01-30 20:15:59.554	warn	at emitOne (events.js:116:13)
    javascript.0	2019-01-30 20:15:59.554	warn	at Socket. <anonymous>(/opt/iobroker/node_modules/redis/index.js:274:27)
    javascript.0	2019-01-30 20:15:59.554	warn	at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
    javascript.0	2019-01-30 20:15:59.553	warn	at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
    javascript.0	2019-01-30 20:15:59.553	warn	at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:833:9)
    javascript.0	2019-01-30 20:15:59.553	warn	at return_pub_sub (/opt/iobroker/node_modules/redis/index.js:794:18)
    javascript.0	2019-01-30 20:15:59.553	warn	at RedisClient.emit (events.js:217:7)
    javascript.0	2019-01-30 20:15:59.553	warn	at emitThree (events.js:136:13)
    javascript.0	2019-01-30 20:15:59.553	warn	at RedisClient. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:596:25)
    javascript.0	2019-01-30 20:15:59.553	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
    javascript.0	2019-01-30 20:15:59.552	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
    javascript.0	2019-01-30 20:15:59.552	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:756:38)
    javascript.0	2019-01-30 20:15:59.552	warn	at Object. <anonymous>(script.js.Heizung.WC_Fußbodenheizung:10:5)
    javascript.0	2019-01-30 20:15:59.551	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1236:28)
    javascript.0	2019-01-30 20:15:59.549	warn	Wrong type of fhem.0.VentilFussbodenhzg_WC.state: "boolean". Please fix, while deprecated and will not work in next versions.
    fhem.0	2019-01-30 20:21:21.249	info	event ioBroker "fhem.0.VentilFussbodenhzg_WC.state off" > set VentilFussbodenhzg_WC off</anonymous></anonymous></anonymous>
    fhem.0	2019-01-30 20:15:56.600	info	event ioBroker "fhem.0.Ventilation.state on" > set Ventilation on
    javascript.0	2019-01-30 20:15:56.053	warn	at Timer.listOnTimeout (timers.js:290:5)
    javascript.0	2019-01-30 20:15:56.053	warn	at tryOnTimeout (timers.js:323:5)
    javascript.0	2019-01-30 20:15:56.053	warn	at ontimeout (timers.js:511:34)
    javascript.0	2019-01-30 20:15:56.053	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1294:29)
    javascript.0	2019-01-30 20:15:56.052	warn	at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1236:28)
    javascript.0	2019-01-30 20:15:56.051	warn	Wrong type of fhem.0.Ventilation.state: "boolean". Please fix, while deprecated and will not work in next versions.
    fhem.0	2019-01-30 20:15:55.299	info	event ioBroker "fhem.0.GewaechshausLED_Ventilation.state on" > set GewaechshausLED_Ventilation on
    javascript.0	2019-01-30 20:15:55.056	warn	at Timer.listOnTimeout (timers.js:290:5)
    javascript.0	2019-01-30 20:15:55.055	warn	at tryOnTimeout (timers.js:323:5)
    javascript.0	2019-01-30 20:15:55.055	warn	at ontimeout (timers.js:511:34)
    javascript.0	2019-01-30 20:15:55.055	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1294:29)
    javascript.0	2019-01-30 20:15:55.054	warn	at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1236:28)
    javascript.0	2019-01-30 20:15:55.052	warn	Wrong type of fhem.0.GewaechshausLED_Ventilation.state: "boolean". Please fix, while deprecated and will not work in next versions.
    Es gibt noch andere Einträge, die alle in etwa den selben Wortlaut haben, sich jedoch auf andere Datenpunkte beziehen.
    Ich habe schon versucht das Problem zu beseitigen. Leider ohne Erfolg.
    Wer kann mir bitte behilflich sein.
    Gruß Michael
    • paul53P Offline
      @Altersrentner:
      Die Steuerung mit wahr / unwahr ist offenbar falsch.
        Altersrentner
        Hallo paul53,
        Danke für deine Nachricht.
        Meinst Du im Blockly?
        Ventil einschalten mit wahr und auschalten mit unwahr.
        Das sollte doch passen.
        Unter Objekte/fhem/ventil…../state wird momentan unter Wert false angezeigt.
        Das ist auch richtig, da T>31°
        Gruß Michael
        • paul53P Offline
          @Altersrentner:
          Das sollte doch passen. `
          Offenbar nicht. Welchen Datenpunkttyp (Art) hat das Objekt fhem.0.GewaechshausLED_Ventilation.state (Bleistift rechts) ?
            Altersrentner
            Typ ist "state" und Wert "false"
            Meinst Du das?
            • paul53P Offline
              @Altersrentner:
              Typ ist "state" und Wert "false" `
              Laut FHEM-Adapter-Doku sind Datenpunkt mit der Rolle state vom Typ "Zeichenkette" (string).
              Gehe mal auf den Bleistift rechts in der Zeile. Was wird als Art (ganz oben) angezeigt ?
                Altersrentner
                Wenn ich auf den Bleistift recht klicke öffnet ein Fenster :
                " objekt bearbeiten fhem.0.VentilFussbodenhzg_WC.state "
                Aber ich finde "Art" nicht
                • paul53P Offline
                  @Altersrentner:
                  Aber ich finde "Art" nicht `
                  • LausiDL Offline
                    LausiDL Offline
                    LausiD
                    sorry wenn ich mich einmische :-)
                    @paul53:
                    Gehe mal auf den Bleistift rechts in der Zeile. Was wird als Art (ganz oben) angezeigt ? `
                    Stimmt so, state ist Typ Zeichenkette
                    Aber state_switch ist Typ Logikwert :-)
                    @Michael
                    Ändere in deinem Blocky den Wert "fhem.0.VentilFussbodenhzg_WC.state" auf "fhem.0.VentilFussbodenhzg_WC.state_switch" und sollte gut sein.
                    Ab FHEM Adapter buildDate > 03.12.18 gilt folgendes:
                    Da state eines FHEM Device unterschiedliche Zustände/Funktionen haben kann, werden bei Bedarf im ioBroker automatisch zusätzliche Objekte angelegt.
                    1. fhem.x.Device.state enthält den Wert aus FHEM 1:1 als String
                    a. fhem.x.Device.state_switch true/false als Boolean, wenn state on oder off ist oder Possible Sets on und off enthalten.
                    Dadurch kann zB auch ein dummy als Schalter verwendet werden.
                    b. fhem.x.Device.state_boolean true/false , wenn state open/ooened/close/closed/present/absent ist.
                    c. fhem.x.Device.state_value 0/2 für die Werte von state_boolean
                    Nachtrag: fhem.x.Device.state enthält den Wert aus FHEM 1:1 als String nur wenn fhem.0.info.Configurations.oldState auf false steht
                    LausiD
                    Doku zum FHEM Adapter
                    Aktuelles zum FHEM Adapter
                    Test FHEM Adapter
                      Altersrentner
                      Dann war ich ja schon auf dem richtigen Weg.
                      "Logikwert" sollte durch "Zeichenkette" ersetzt werden?
                      Ist das richtig?
                      • paul53P Offline
                        @Altersrentner:
                        "Logikwert" sollte durch "Zeichenkette" ersetzt werden? `
                        Wenn der Datenpunkttyp "Logikwert" (boolean) ist, verstehe ich die Warnung nicht:
                          Altersrentner
                          Also nicht"Zeichenkette"
                          Der Schalter ist ein FS20 Device.
                          Kann es damit zusammen hängen?
                            Altersrentner
                            Hallo paul53,
                            Danke für Deinen Tipp mit dem "Logikwert"
                            Ich habe heute alle Datenpunkte die gemeckert hatten dahingehend geändert.
                            Seitdemgibt esdiesbezüglich keine gelben Eintragungen mehr.
                            Außer:
                             fhem.0	2019-01-31 19:41:17.381	warn	unhandled event FHEM "readingsGroup CN.Brennstoffverbrauch CN.BrennstoffverbrauchDay.Verbrauch_Woche: 92.18 kg" > jsonlist2
                            fhem.0	2019-01-31 19:41:17.381	warn	unhandled event FHEM "readingsGroup CN.Brennstoffverbrauch CN.BrennstoffverbrauchDay.Verbrauch_Jahr: 364.13 kg" > jsonlist2
                            fhem.0	2019-01-31 19:41:17.381	warn	unhandled event FHEM "readingsGroup CN.Brennstoffverbrauch CN.BrennstoffverbrauchDay.Verbrauch_Monat: 364.13 kg" > jsonlist2
                            fhem.0	2019-01-31 19:41:17.381	warn	unhandled event FHEM "readingsGroup CN.Brennstoffkosten CN.BrennstoffverbrauchDay.Kosten_Woche: 21.50 €" > jsonlist2
                            fhem.0	2019-01-31 19:41:17.381	warn	unhandled event FHEM "readingsGroup CN.Brennstoffkosten CN.BrennstoffverbrauchDay.Kosten_Jahr: 84.91 €" > jsonlist2
                            fhem.0	2019-01-31 19:41:17.380	warn	unhandled event FHEM "readingsGroup CN.Brennstoffkosten CN.BrennstoffverbrauchDay.Kosten_Monat: 84.91 €" > jsonlist2
                            fhem.0	2019-01-31 19:41:17.380	warn	unhandled event FHEM "readingsGroup CN.Brennstoffverbrauch CN.BrennstoffverbrauchDay.Verbrauch_Tag: 16.97 kg" > jsonlist2
                            fhem.0	2019-01-31 19:41:17.380	info	check channel CN.Brennstoffkosten > jsonlist2 CN.Brennstoffkosten
                            fhem.0	2019-01-31 19:41:17.380	warn	unhandled event FHEM "readingsGroup CN.Brennstoffkosten CN.BrennstoffverbrauchDay.Kosten_Tag: 3.96 €" > jsonlist2
                            Dieser Aktor wird aber im ioBroker in keinem Skript benutzt.
                            Hast Du eine Idee?
                            Danke Gruß Michael
                            • paul53P Offline
                              @Altersrentner:
                              Hast Du eine Idee? `
                              Nein. Den FHEM-Adapter kenne ich nicht, denn ich nutze FHEM nicht.
                              Mache dazu bitte ein neues Thema auf und markiere dieses Thema hier im Betreff des ersten Beitrags als [gelöst].
                                Altersrentner
                                Hallo paul53,
                                Danke für Deine Hilfe.
                                damit ist das Problem gelöst.
                                Gruß Michael
                                  Altersrentner
                                  gelöst
                                  • paul53P Offline
                                    @Altersrentner:
                                    gelöst `
                                    @paul53:
                                    im Betreff des <u>ersten</u> Beitrags als [gelöst]. `
                                      Altersrentner
                                      Hallo paul53,
                                      Danke für den Hinweis!
                                      Aber das Problem ist doch noch nicht ausgestanden.
                                      Obwohl ich wie beschrieben Art in "Logikwert" geändert und gespeichert habe
                                      ist am nächsten Tag wieder "Zeichenkette" eingetragen. Das kann ich nun überhaupt nicht verstehen.
                                      Hallo LausiD
                                      Ich hatte Deine Nachricht total übersehen. Tut mir leid,
                                      Habe eben Deine Hinweis gelesen und umgesetzt. Das erklärt dann auch sicherlich
                                      die Änderung am kommenden Tag - oder?
                                      Gruß Michael
                                      • LausiDL Offline
                                        LausiDL Offline
                                        LausiD
                                        Hallo Michael,
                                        nach einem Neustart FHEM Adapter wird xxxxxx.state wieder auf Art Zeichenkette gesetzt.
                                        xxxxxxx.state_switch bleibt immer auf Art Logikwert :-)
                                        LausiD
                                        Test FHEM Adapter
                                          Altersrentner
                                          Hallo LausiD,
                                          Danke, damit hast Du meine Überlegung bestätigt.
                                          Nun kann ich den Betreff beenden.
                                          Gruß Michael
