  4. Iobroker.zigbee: Adapter wechselt nur auf gelb und anschl. wieder rot
    6.7k
3 Beiträge 2 Kommentatoren 906 Aufrufe
  • F Offline
    flubb
    habe mir einen fertig geflashten CC2531-Stick besorgt und wollte ihn gerade in Betrieb nehmen, jedoch bekomme ich den Zigbee-Adapter leider nicht zum laufen.
    Im Log findet sich folgendes:
    ` > host.raspberrypi 2019-01-25 13:36:50.408 error instance system.adapter.zigbee.0 terminated with code 0 (OK)
    Caught 2019-01-25 13:36:50.408 error by controller[8]: 2019-01-25T12:36:45.324Z zigbee:controller info zigbee-shepherd stopped undefined
    Caught 2019-01-25 13:36:50.408 error by controller[7]: 2019-01-25T12:36:45.322Z zigbee-shepherd zigbee-shepherd is stopped.
    Caught 2019-01-25 13:36:50.407 error by controller[6]: 2019-01-25T12:36:45.311Z zigbee-shepherd zigbee-shepherd is stopping.
    Caught 2019-01-25 13:36:50.407 error by controller[5]: at process._tickCallback (internal/process/next_tick.js:181:9)
    Caught 2019-01-25 13:36:50.407 error by controller[5]: at _combinedTickCallback (internal/process/next_tick.js:132:7)
    Caught 2019-01-25 13:36:50.406 error by controller[5]: at flush (/opt/iobroker/node_modules/q/q.js:125:13)
    Caught 2019-01-25 13:36:50.406 error by controller[5]: at runSingle (/opt/iobroker/node_modules/q/q.js:137:13)
    Caught 2019-01-25 13:36:50.406 error by controller[5]: at /opt/iobroker/node_modules/q/q.js:2059:17
    Caught 2019-01-25 13:36:50.405 error by controller[5]: at shepherd.start (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:78:47)
    Caught 2019-01-25 13:36:50.405 error by controller[5]: TypeError: Cannot read property 'close' of undefined
    Caught 2019-01-25 13:36:50.405 error by controller[4]: 2019-01-25T12:36:45.295Z zigbee:controller debug Error while starting zigbee-shepherd, attemping to fix… (takes 60 seconds) undefined
    Caught 2019-01-25 13:36:50.404 error by controller[4]: at Timer.listOnTimeout (timers.js:290:5)
    Caught 2019-01-25 13:36:50.404 error by controller[4]: at tryOnTimeout (timers.js:323:5)
    Caught 2019-01-25 13:36:50.404 error by controller[4]: at ontimeout (timers.js:498:11)
    Caught 2019-01-25 13:36:50.404 error by controller[4]: at Timeout. <anonymous>(/opt/iobroker/node_modules/cc-znp/lib/ccznp.js:233:18)
    Caught 2019-01-25 13:36:50.403 error by controller[4]: at CcZnp.emit (events.js:211:7)
    Caught 2019-01-25 13:36:50.403 error by controller[4]: at emitOne (events.js:116:13)
    Caught 2019-01-25 13:36:50.403 error by controller[4]: at Object.onceWrapper (events.js:315:30)
    Caught 2019-01-25 13:36:50.402 error by controller[4]: at CcZnp. <anonymous>(/opt/iobroker/node_modules/cc-znp/lib/ccznp.js:254:22)
    Caught 2019-01-25 13:36:50.402 error by controller[4]: 2019-01-25T12:36:45.292Z zigbee-shepherd:init Coordinator initialize had an error: Error: request timeout
    Caught 2019-01-25 13:36:50.402 error by controller[4]: 2019-01-25T12:36:45.283Z zigbee-shepherd:request RSP <– SYS:osalNvRead
    Caught 2019-01-25 13:36:50.401 error by controller[4]: Fri, 25 Jan 2019 12:36:45 GMT cc-znp:SRSP <– SYS:osalNvRead, timeout
    Caught 2019-01-25 13:36:50.401 error by controller[3]: Fri, 25 Jan 2019 12:36:42 GMT cc-znp:SREQ –> SYS:osalNvRead, { id: 3840, offset: 0, len: 1, value: [ 85 ] }
    Caught 2019-01-25 13:36:50.401 error by controller[2]: 2019-01-25T12:36:42.245Z zigbee-shepherd:request REQ –> SYS:osalNvRead
    Caught 2019-01-25 13:36:50.400 error by controller[1]: Fri, 25 Jan 2019 12:36:42 GMT cc-znp The serialport /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0XD0B5C2ED6BF3FFFF-if00 is opened.
    Caught 2019-01-25 13:36:50.400 error by controller[0]: 2019-01-25T12:36:32.164Z zigbee-shepherd:init zigbee-shepherd booting…
    zigbee.0 2019-01-25 13:36:45.326 info zigbee-shepherd stopped
    zigbee.0 2019-01-25 13:36:45.307 error at process._tickCallback (internal/process/next_tick.js:181:9)
    zigbee.0 2019-01-25 13:36:45.307 error at _combinedTickCallback (internal/process/next_tick.js:132:7)
    zigbee.0 2019-01-25 13:36:45.307 error at flush (/opt/iobroker/node_modules/q/q.js:125:13)
    zigbee.0 2019-01-25 13:36:45.307 error at runSingle (/opt/iobroker/node_modules/q/q.js:137:13)
    zigbee.0 2019-01-25 13:36:45.307 error at /opt/iobroker/node_modules/q/q.js:2059:17
    zigbee.0 2019-01-25 13:36:45.307 error at shepherd.start (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:78:47)
    zigbee.0 2019-01-25 13:36:45.307 error TypeError: Cannot read property 'close' of undefined
    zigbee.0 2019-01-25 13:36:45.305 error uncaught exception: Cannot read property 'close' of undefined
    zigbee.0 2019-01-25 13:36:32.131 info Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0XD0B5C2ED6BF3FFFF-if00 with panID 6754 channel 11
    zigbee.0 2019-01-25 13:36:32.119 info starting. Version 0.8.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.15.0</anonymous></anonymous> `
    Mache ich was falsch oder ist der Stick kaputt?
    Bei Port habe zum einen "/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0XD0B5C2ED6BF3FFFF-if00" und auch "/dev/ttyACM0" ausprobiert, funktioniert jedoch beides nicht.
    Danke, Grüße
    Markus
    • arteckA Offline
      arteckA Offline
      arteck
      installier mein Repo bitte
      https://github.com/arteck/ioBroker.zigbee
      • F Offline
        flubb
        hat sich erledigt, habe das Gehäuse entfernt und gesehen dass auf dem Chip cc2540 steht. Verkäufer hat da wohl was verwechselt und schickt mir jetzt den Richtigen ;)
        nächstes mal kaufe ich gleich hier und nicht bei Kleinanzeigen :?
