  4. Pine 64+
    5.0k
Pine 64+
76 Beiträge 10 Kommentatoren 14.7k Aufrufe
    #61
    Ich hatte in der Zwischenzeit mit Ubuntu experimentiert.
    Immerhin bekommt man mit apt-get install nodejs ein anscheinen funktionierendes node v4.2.6
    Die ioBroker Installation klappte trotzdem nicht.
    Es fehlte noch npm
    ok dann noch mit apt-get install npm das fehlende Paket installiert.
    ioBroker liess sich immer noch nicht installieren.
    Nach anfänglichen grafikspielchen des Fortschritts kam dann das böse Erwachen.
    ! ` > root@localhost:/opt/iobroker# npm install iobroker –unsafe-perm
    iobroker@0.7.1 install /opt/iobroker/node_modules/iobroker
    node lib/setup.js
    sh: 1: node: not found
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
    npm WARN iobroker No description
    npm WARN iobroker No repository field.
    npm WARN iobroker No README data
    npm WARN iobroker No license field.
    npm ERR! Linux 3.10.65-7-pine64-longsleep
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker" "--unsafe-perm"
    npm ERR! node v4.2.6
    npm ERR! npm v3.5.2
    npm ERR! file sh
    npm ERR! code ELIFECYCLE
    npm ERR! errno ENOENT
    npm ERR! syscall spawn
    npm ERR! iobroker@0.7.1 install: node lib/setup.js
    npm ERR! spawn ENOENT
    npm ERR!
    npm ERR! Failed at the iobroker@0.7.1 install script 'node lib/setup.js'.
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR! If you do, this is most likely a problem with the iobroker package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node lib/setup.js
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs iobroker
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR! npm owner ls iobroker
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm ERR! /opt/iobroker/npm-debug.log `
    Alle Fehlermeldungen ignoriert; bis auf npm v3.5.2
    Da war doch was,
    apt-get purge npm
    aber wie installiere ich version 2.xx
    da stand so etwas hier im thread.
    npm install -g npm@latest-2
    geht doch gar nicht muss sicher apt-get…. heißen.
    Nein auch nicht, also wieder v3.xx installiert und dann npm install -g npm@latest-2 ausgeführt. Der scheint es auch ordentlich zu downgraden
    root@localhost:/# npm install -g npm@latest-2
    /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
    /usr/local/lib
    └─┬ npm@2.15.9
    ├── abbrev@1.0.9
    ├── ansi@0.3.1
    ├── ansi-regex@2.0.0
    ├── ansicolors@0.3.2
    ├── ansistyles@0.1.3
    ├── archy@1.0.0
    ├── async-some@1.0.2
    ├── block-stream@0.0.9
    ├── char-spinner@1.0.1
    ├── chmodr@1.0.2
    ├── chownr@1.0.1
    ├── cmd-shim@2.0.2
    ├─┬ columnify@1.5.4
    │ └─┬ wcwidth@1.0.0
    │ └─┬ defaults@1.0.3
    │ └── clone@1.0.2
    ├─┬ config-chain@1.1.10
    │ └── proto-list@1.2.4
    ├─┬ dezalgo@1.0.3
    │ └── asap@2.0.3
    ├── editor@1.0.0
    ├── fs-vacuum@1.2.9
    ├─┬ fs-write-stream-atomic@1.0.8
    │ └── iferr@0.1.5
    ├── fstream@1.0.10
    ├─┬ fstream-npm@1.0.7
    │ └── fstream-ignore@1.0.3
    ├── github-url-from-git@1.4.0
    ├── github-url-from-username-repo@1.0.2
    ├─┬ glob@7.0.4
    │ ├── fs.realpath@1.0.0
    │ └── path-is-absolute@1.0.0
    ├── graceful-fs@4.1.4
    ├── hosted-git-info@2.1.4
    ├── imurmurhash@0.1.4
    ├── inflight@1.0.5
    ├── inherits@2.0.1
    ├── ini@1.3.4
    ├─┬ init-package-json@1.9.4
    │ ├─┬ glob@6.0.4
    │ │ └── path-is-absolute@1.0.0
    │ └── promzard@0.3.0
    ├── lockfile@1.0.1
    ├─┬ lru-cache@4.0.1
    │ ├── pseudomap@1.0.2
    │ └── yallist@2.0.0
    ├─┬ minimatch@3.0.0
    │ └─┬ brace-expansion@1.1.1
    │ ├── balanced-match@0.2.1
    │ └── concat-map@0.0.1
    ├─┬ mkdirp@0.5.1
    │ └── minimist@0.0.8
    ├─┬ node-gyp@3.4.0
    │ ├─┬ minimatch@3.0.2
    │ │ └─┬ brace-expansion@1.1.5
    │ │ ├── balanced-match@0.4.1
    │ │ └── concat-map@0.0.1
    │ └─┬ path-array@1.0.1
    │ └─┬ array-index@1.0.0
    │ ├─┬ debug@2.2.0
    │ │ └── ms@0.7.1
    │ └─┬ es6-symbol@3.1.0
    │ ├── d@0.1.1
    │ └─┬ es5-ext@0.10.11
    │ ├── es6-iterator@2.0.0
    │ └── es6-symbol@3.0.2
    ├── nopt@3.0.6
    ├── normalize-git-url@3.0.2
    ├─┬ normalize-package-data@2.3.5
    │ └─┬ is-builtin-module@1.0.0
    │ └── builtin-modules@1.1.0
    ├── npm-cache-filename@1.0.2
    ├── npm-install-checks@1.0.7
    ├── npm-package-arg@4.1.0
    ├─┬ npm-registry-client@7.1.2
    │ ├─┬ concat-stream@1.5.1
    │ │ ├─┬ readable-stream@2.0.6
    │ │ │ ├── core-util-is@1.0.2
    │ │ │ ├── isarray@1.0.0
    │ │ │ ├── process-nextick-args@1.0.7
    │ │ │ ├── string_decoder@0.10.31
    │ │ │ └── util-deprecate@1.0.2
    │ │ └── typedarray@0.0.6
    │ └── retry@0.8.0
    ├── npm-user-validate@0.1.4
    ├─┬ npmlog@2.0.4
    │ ├─┬ are-we-there-yet@1.1.2
    │ │ └── delegates@1.0.0
    │ └─┬ gauge@1.2.7
    │ ├── has-unicode@2.0.0
    │ ├─┬ lodash.pad@4.4.0
    │ │ ├── lodash._baseslice@4.0.0
    │ │ ├── lodash._basetostring@4.12.0
    │ │ └── lodash.tostring@4.1.3
    │ ├─┬ lodash.padend@4.5.0
    │ └─┬ lodash.padstart@4.5.0
    ├── once@1.3.3
    ├── opener@1.4.1
    ├─┬ osenv@0.1.3
    │ ├── os-homedir@1.0.0
    │ └── os-tmpdir@1.0.1
    ├── path-is-inside@1.0.1
    ├─┬ read@1.0.7
    │ └── mute-stream@0.0.5
    ├─┬ read-installed@4.0.3
    │ ├── debuglog@1.0.1
    │ ├── readdir-scoped-modules@1.0.2
    │ └── util-extend@1.0.1
    ├─┬ read-package-json@2.0.4
    │ ├─┬ glob@6.0.4
    │ └─┬ json-parse-helpfulerror@1.0.3
    │ └── jju@1.3.0
    ├─┬ readable-stream@2.1.4
    │ ├── buffer-shims@1.0.0
    │ ├── isarray@1.0.0
    ├── realize-package-specifier@3.0.1
    ├─┬ request@2.72.0
    │ ├── aws-sign2@0.6.0
    │ ├── aws4@1.3.2
    │ ├─┬ bl@1.1.2
    │ │ └─┬ readable-stream@2.0.6
    │ ├── caseless@0.11.0
    │ ├─┬ combined-stream@1.0.5
    │ │ └── delayed-stream@1.0.0
    │ ├── extend@3.0.0
    │ ├── forever-agent@0.6.1
    │ ├─┬ form-data@1.0.0-rc4
    │ │ └── async@1.5.2
    │ ├─┬ har-validator@2.0.6
    │ │ ├─┬ chalk@1.1.3
    │ │ │ ├── ansi-styles@2.2.1
    │ │ │ ├── escape-string-regexp@1.0.5
    │ │ │ ├── has-ansi@2.0.0
    │ │ │ └── supports-color@2.0.0
    │ │ ├─┬ commander@2.9.0
    │ │ │ └── graceful-readlink@1.0.1
    │ │ ├─┬ is-my-json-valid@2.13.1
    │ │ │ ├── generate-function@2.0.0
    │ │ │ ├─┬ generate-object-property@1.2.0
    │ │ │ │ └── is-property@1.0.2
    │ │ │ ├── jsonpointer@2.0.0
    │ │ │ └── xtend@4.0.1
    │ │ └─┬ pinkie-promise@2.0.1
    │ │ └── pinkie@2.0.4
    │ ├─┬ hawk@3.1.3
    │ │ ├── boom@2.10.1
    │ │ ├── cryptiles@2.0.5
    │ │ ├── hoek@2.16.3
    │ │ └── sntp@1.0.9
    │ ├─┬ http-signature@1.1.1
    │ │ ├── assert-plus@0.2.0
    │ │ ├─┬ jsprim@1.2.2
    │ │ │ ├── extsprintf@1.0.2
    │ │ │ ├── json-schema@0.2.2
    │ │ │ └── verror@1.3.6
    │ │ └─┬ sshpk@1.8.3
    │ │ ├── asn1@0.2.3
    │ │ ├── assert-plus@1.0.0
    │ │ ├── dashdash@1.13.1
    │ │ ├── ecc-jsbn@0.1.1
    │ │ ├── getpass@0.1.6
    │ │ ├── jodid25519@1.0.2
    │ │ ├── jsbn@0.1.0
    │ │ └── tweetnacl@0.13.3
    │ ├── is-typedarray@1.0.0
    │ ├── isstream@0.1.2
    │ ├── json-stringify-safe@5.0.1
    │ ├─┬ mime-types@2.1.11
    │ │ └── mime-db@1.23.0
    │ ├── node-uuid@1.4.7
    │ ├── oauth-sign@0.8.2
    │ ├── qs@6.1.0
    │ ├── stringstream@0.0.5
    │ ├── tough-cookie@2.2.2
    │ └── tunnel-agent@0.4.3
    ├── retry@0.9.0
    ├─┬ rimraf@2.5.2
    │ └─┬ glob@7.0.0
    ├── semver@5.1.0
    ├─┬ sha@2.0.1
    │ └─┬ readable-stream@2.0.2
    │ ├── core-util-is@1.0.1
    │ ├── isarray@0.0.1
    │ ├── process-nextick-args@1.0.3
    │ └── util-deprecate@1.0.1
    ├── slide@1.1.6
    ├── sorted-object@2.0.0
    ├── spdx-license-ids@1.2.1
    ├── strip-ansi@3.0.1
    ├── tar@2.2.1
    ├── text-table@0.2.0
    ├── uid-number@0.0.6
    ├── umask@1.1.0
    ├─┬ validate-npm-package-license@3.0.1
    │ ├── spdx-correct@1.0.2
    │ └─┬ spdx-expression-parse@1.0.2
    │ └── spdx-exceptions@1.0.4
    ├─┬ validate-npm-package-name@2.2.2
    │ └── builtins@0.0.7
    ├─┬ which@1.2.10
    │ └── isexe@1.1.2
    ├── wrappy@1.0.2
    └── write-file-atomic@1.1.4
    Erneuter Versuch mit iobroker - gleicher Fehler.
    Kann doch gaar nicht sein! Was sagt denn npm -v? Ich fall vom Glauben ab:
    root@localhost:/opt/iobroker# npm -v
    3.5.2
    nochmal downgrade - 2.15.9 - bestätigt; npm -v wieder 3.5.2
    3.5.2
    root@localhost:/opt/iobroker# npm install -g npm@latest-2
    /usr/local/lib
    └── npm@2.15.9
    >! root@localhost:/opt/iobroker# npm -v
    3.5.2
    /usr/local/lib
    └── npm@2.15.9
    3.5.2
    root@localhost:/opt/iobroker# cd ..
    root@localhost:/opt# cd /
    root@localhost:/# npm -v
    3.5.2
    /usr/local/lib
    └── npm@2.15.9
    >! root@localhost:/# npm -v
    3.5.2
    Wie um alles bekomme ich eine npm 2.xx installiert???
    Rainer
    • paul53P Offline
      #62
      Ich habe mal mit 7-zip in die "node-v4.4.7-linux-arm64.tar.gz" geschaut: Die dort enthaltene Version von npm ist 2.15.8.
      • eric2905E Offline
        eric2905E Offline
        eric2905
        #63
        Moin zusammen,
        @derAuge:
        hier mein Lösungsansatz:
        Download Image
        Ubuntu Base Longsleep (3.10.65 BSP) `
        mit Ubuntu funktioniert es sehr gut, nur eben mit Debian nicht - was Rainer ja gerne nutzen möchte.
        Und die Jungs von nodejs.org haben ihm ja quasi (überspitzt) zwischen den Zeilen gesagt "Nerv nicht, wir können nicht alle Plattformen und Varianten beachten. Evtl. schauen wir uns das später an - aber nicht jetzt". :-)
        Für Debian habe ich auch noch keine Lösung parat.
        Gruß,
        Eric
        • derAugeD Offline
          derAugeD Offline
          derAuge
          #64
          @Homoran:
          Es fehlte noch npm
          node lib/setup.js `
          Moin Rainer,
          das sieht doch bis dahin ganz gut aus. Es fehlt nur noch der SysLink von NodeJs auf Node
          Versuch mal:
          ` > root@localhost:/home/ubuntu# cd /usr/bin/
          root@localhost:/usr/bin# ls -la node*
          lrwxrwxrwx 1 root root 33 Dec 7 2015 node-gyp -> ../share/node-gyp/bin/node-gyp.js
          -rwxr-xr-x 1 root root 10281544 May 20 23:57 nodejs `
          Da ist ja kein node vorhanden. Daher auch deine Fehlermeldung: "sh: 1: node: not found"
          Symlink anlegen
          > root@localhost:/usr/bin# ****ln -s nodejs node****
          lrwxrwxrwx 1 root root 6 Jul 22 20:56 node -> nodejs
          ubuntu@localhost:~$ uname -a
          Linux localhost.localdomain 3.10.102-2-pine64-longsleep #66 SMP PREEMPT Sat Jul 16 10:53:13 CEST 2016 aarch64 aarch64 aarch64 GNU/Linux
          ubuntu@localhost:~$ npm -v
          3.5.2
          ubuntu@localhost:~$ node -v
          v4.2.6
          ubuntu@localhost:~$ nodejs -v
          v4.2.6
          Dann sollte die Installation auch funktionieren
          Jürgen
            #65
            Hallo Jürgen,
            Danke.
            War erstens gestern schon zu spät und zweitens fehlt mir da das Wissen.
            Habe ja auch geschrieben, dass ich erstmal alle anderen Fehlermeldungen ignoriert habe um npm auf 2.xx zu bekommen.
            Wollte mich danach reinarbeiten.
            Werde das mal umsetzen, aber:
            Hast du dann auch npm 3.5.x?
            Das läuft lt. Bluefox nicht rund.
            Rainer
            • eric2905E Offline
              eric2905E Offline
              eric2905
              #66
              Moin zusammen,
              auf dem Pine habe ich es bisher nicht geschafft, npm mit einer Version höher als 3.5.x zu installieren.
              ioBroker läuft aber rund damit (bisher).
              Gruß,
              Eric
                #67
                Nicht höher! Niedriger! 2.xx soll es sein.
                Und du hast keine Probleme mit 3.xx?
                Rainer
                • derAugeD Offline
                  derAugeD Offline
                  derAuge
                  #68
                  @Homoran:
                  Rainer `
                  Das sind meine installierten Versionen
                  3.5.2
                  v4.2.6
                  v4.2.6
                  Jürgen
                  PS: Teste gerade den zweiten. Die Geräte habe die gleiche MAC-Adresse. Werde das auch noch suchen müssen
                    #69
                    Auch du hast npm 3.xx
                    Auch ohne Probleme?
                    @derAuge:
                    PS: Teste gerade den zweiten. Die Geräte habe die gleiche MAC-Adresse. Werde das auch noch suchen müssen `
                    Da gibt es bei pine64 einen Beitrag.
                    Hatte gehofft dass das ein Einzelfall war.
                    Mein zweiter ist noch in der Schachtel.
                    Ich habe im Moment aber anscheinend Probleme mit dem CEC beim HDMI.
                    Bin nativ auf dem Pine an einem Monitor mit drei Eingängen. DVI für den PC und HDMI für alles was ich teste.
                    Könnte bisher immer hin und herschalten. Jetzt muss ich den HDMI während des POST an haben, damit ich etwas sehe, zu früh und der Monitor schaltet auf VGA, zu spät und der Pine liefert kein Bild.
                    Ebenso, wenn ich zwischendurch auf DVI schalte bekomme ich hinterher kein Bildmehr vom Pine :(
                    Rainer
                    • eric2905E Offline
                      eric2905E Offline
                      eric2905
                      #70
                      Bzgl. MAC kommt das wohl von OS - das ignoriert die HW-Mac u d nimmt seine eigene (dummerweise immer die gleiche).
                      Mit npm 3.5.2 habe ich bisher nichts im normalen Betrieb feststellen können. Allerdings läuft da auch nur ein abgespecktes Mini-System mit hm-rpc und hm-rega.
                      Ich habe mir extra einen neuen Monitor gekauft, weil mein alter Dell 27" (1920 x 1200) die Umschaltung und Darstellung nicht hinbekommen hat.
                      Gruß,
                      Eric
                      • derAugeD Offline
                        derAugeD Offline
                        derAuge
                        #71
                        @eric2905:
                        Bzgl. MAC kommt das wohl von OS - das ignoriert die HW-Mac u d nimmt seine eigene (dummerweise immer die gleiche). `
                        nach dem Schreiben des Images muss auf der SD-Karte die Datei "uEnv.txt" angepasst werden
                        • ethaddr=36:c9:e3:f1:b8:xx
                        Diese angepasste MAC-Adressen wird bei Ubuntu und Debian übernommen.
                        Jürgen
                        EDIT:
                        Sollte man ein System bereits laufen haben, kann man auch als root die Datei anpassen:
                        sudo mount /dev/mmcblk0p1 /mnt/
                        vi /mnt/uEnv.txt
                        reboot
                        Ein Neustart ist natürlich dann erforderlich
                        • eric2905E Offline
                          eric2905E Offline
                          eric2905
                          #72
                          Genau das meinte ich.
                          Bin nicht zu Hause, um das nachsehen zu können.
                          Danke Dir.
                          Gruß,
                          Eric
                          • derAugeD Offline
                            derAugeD Offline
                            derAuge
                            #73
                            so,
                            habe noch mal etwas getestet.
                            Debian Base (3.10.102 BSP 2)
                            https://www.pine64.pro/download.php?opt … ptionid=59
                            pine64-image-debianbase-310102bsp-2.img
                            7zip file and selecting "Extract All"
                            Win32 Disk Imager
                            <u>Vorbereitungen / Einstellungen</u>
                            ##### Now insert your SD card into the Pine64 and power it on #####
                            ## For Debian
                            sudo passwd root
                            sudo -i
                            nano /etc/hosts
                            nano /etc/hostname
                            /usr/local/sbin/pine64_update_uboot.sh
                            /usr/local/sbin/pine64_update_kernel.sh
                            ##### Speicherpatz erweitern #####
                            resize_rootfs.sh
                            ##### Nutzer anlegen
                            adduser auge
                            usermod -aG sudo auge
                            sudo dpkg-reconfigure locales
                            reboot
                            <u>Als root weiter arbeiten</u>
                            ##### System auf den aktuellen Stand bringen #####
                            apt update && apt upgrade -y
                            <u>Dann das ARM Binarie laden und auspacken</u>
                            ##### Download ARM Binarie (.tar.xz) im Verzeichniss /home/auge ###########
                            wget https://nodejs.org/dist/v4.4.7/node-v4.4.7-linux-arm64.tar.xz
                            cd /usr/local
                            tar --strip-components=1 -xvf /home/auge/node-v4.4.7-linux-arm64.tar.xz
                            <u>Der Rest ist ja bekannt</u>
                            ##### Nun zur Installation von ioBroker #####
                            mkdir /opt/iobroker
                            cd /opt/iobroker
                            npm install --unsafe-perm iobroker
                            <u>Läuft zur Zeit im Testbetrieb</u>
                            root@Pine64-2:/opt/iobroker# uname -a
                            Linux Pine64-2 3.10.102-2-pine64-longsleep #66 SMP PREEMPT Sat Jul 16 10:53:13 CEST 2016 aarch64 GNU/Linux
                            root@Pine64-2:/opt/iobroker# npm -v
                            2.15.8
                            root@Pine64-2:/opt/iobroker# node -v
                            hier kommt keine Angabe :roll:
                            Jürgen
                              #74
                              Das klingt gut
                              Evtl reichen mir ja sogar Teile davon.
                              @derAuge:
                              hier kommt keine Angabe `
                              du musst ja auch nodejs -v eingeben.
                              Rainer
                              • derAugeD Offline
                                derAugeD Offline
                                derAuge
                                #75
                                @Homoran:
                                Das klingt gut
                                @derAuge:
                                Rainer `
                                nein
                                ~$ nodejs -v
                                -bash: nodejs: Kommando nicht gefunden.
                                  Maxtox
                                  #76
                                  Debian Image von http://wiki.pine64.org/index.php/Pine_A … eep_kernel
                                  Direkt link: http://files.pine64.org/os/debian/debia ... 64-8GB.zip
                                  Login with
                                  username: debian
                                  password: debian
                                  Nach dem login:
                                  resize_rootfs.sh
                                  Um Partition zu vergrößern.
                                  sudo apt-get update
                                  sudo apt-get upgrade
                                  sudo apt-get install -y build-essential
                                  cd /tmp
                                  wget https://nodejs.org/dist/v4.5.0/node-v4.5.0-linux-arm64.tar.xz
                                  cd /usr/local
                                  sudo tar --strip-components=1 -xvf /tmp/node-v4.5.0-linux-arm64.tar.xz
                                  mkdir /opt/iobroker
                                  cd /opt/iobroker
                                  sudo npm install --unsafe-perm iobroker
                                  chmod 777 * -R
                                  Die Version 4.5.0 wurde von Bluefox empfohlen.
                                  Um den ganzen GUI Müll zu entsorgen (mehr "Platz"im RAM ):
                                  sudo apt-get remove --purge x11-common
                                  sudo apt-get autoremove
                                  getestet…LÄUFT sauber!
                                  Arduino MEGA 2560 R3 / ioBroker / DOino Sketch
