  4. Zigbee-Adapter verursacht ioBroker-Absturz
    6.6k
2 Beiträge 2 Kommentatoren 445 Aufrufe
    rustycobold
    ich habe auf meinem Pi3 den IOBroker via Image installiert und u.a. den Zigbee-Adapter (Zigbee adapter for Xiaomi (and other) devices via TI cc2531/cc2530).
    Nach ca. 1 1/2 Tagen "stürzt" der ioBroker-Dienst immer ab.
    Wenn ich in das Protokoll des ioBrokers schaue steht da folgendes vor dem Absturz, bzw. der Nichterreichbarkeit des ioBrokers:
    2019-01-04 00:36:09.554 - [32minfo[39m: zigbee.0 List of ports: []
    2019-01-04 01:44:25.370 - [32minfo[39m: host.ioBroker-RasPi Delete log file iobroker.2018-12-28.log
    2019-01-04 07:58:00.276 - [33mwarn[39m: host.ioBroker-RasPi instance system.adapter.zigbee.0 terminated due to SIGSEGV
    2019-01-04 07:58:00.277 - [31merror[39m: host.ioBroker-RasPi instance system.adapter.zigbee.0 terminated with code null ()
    2019-01-04 07:58:00.278 - [32minfo[39m: host.ioBroker-RasPi Restart adapter system.adapter.zigbee.0 because enabled
    2019-01-04 07:58:30.303 - [32minfo[39m: host.ioBroker-RasPi instance system.adapter.zigbee.0 started with pid 15414
    2019-01-04 07:58:32.025 - [32minfo[39m: zigbee.0 States connected to redis: 127.0.0.1:6379
    2019-01-04 07:58:32.191 - [32minfo[39m: zigbee.0 starting. Version 0.8.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.15.0
    2019-01-04 07:58:32.197 - [32minfo[39m: zigbee.0 Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___Adresse entfernt with panID 6754 channel 11
    2019-01-04 07:58:32.919 - [32minfo[39m: zigbee.0 zigbee-shepherd started!
    2019-01-04 07:58:32.928 - [32minfo[39m: zigbee.0 zigbee-shepherd ready. version: 2.6.3 rev 20180815
    2019-01-04 07:58:32.943 - [32minfo[39m: zigbee.0 (Adresse-entfernt): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2019-01-04 07:58:32.947 - [32minfo[39m: zigbee.0 (Adresse-entfernt-xyz): AB3257001NJ - OSRAM Smart+ plug (Router)
    2019-01-04 07:58:32.953 - [32minfo[39m: zigbee.0 (Adresse-entfernt): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2019-01-04 07:58:32.953 - [32minfo[39m: zigbee.0 (Adresse-entfernt): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
    2019-01-04 07:58:33.831 - [32minfo[39m: zigbee.0 Succesfully configured Adresse-entfernt-xyz
    2019-01-04 09:11:14.958 - [31merror[39m: zigbee.0 uncaught exception: write EPIPE
    2019-01-04 09:11:14.958 - [31merror[39m: zigbee.0 Error: write EPIPE
    at WriteWrap.afterWrite [as oncomplete] (net.js:868:14)
    2019-01-04 09:11:14.972 - [32minfo[39m: zigbee.0 terminating
    Ich verstehe auch ehrlich gesagt nicht genau was da genau passiert. Es sieht so aus, als würde die Protokollbereinigung laufen und danach der Zigbee-Adapter gestoppt werden. Kurz darauf startet der Zigbee-Adapter scheinbar neu und terminiert dabei.
    Nach dieser Fehlermeldung gibt es keine Protokollmeldungen mehr und der Pi ist nur noch per SSH und Konole zu erreichen. Das ioBroker Web-Interface und der ioBroker Dienst laufen nicht mehr.
    Merkwürdigerweise reagieren die ioBroker-Dienste auch nicht mehr auf einen Neustart.
    Folgendes ist installiert:
    ioBroker.admin 3.5.10
    npm -v 4.6.1
    node -v: v8.15.0
    js-controller : 1.4.2
    Zigbee-Adapter: 0.8.0
    Die Fehlermeldung konnte ich auch durch keine Web-Recherche näher erörtern.
    Andere Fehler wirft das Protokoll des ioBrokers keine.
    Nach einem Neustart des Raspberry Pis läuft alles wieder (damit ist ja auch ein Neustart der ioBroker-Prozesse verbunden).
    Da das Update-Repo gerade wegen der Server-Problematik nicht erreichbar ist kann ich nicht prüfen, ob ein anderer Zigbee-Adapter, so denn verfügbar, Linderung bringen würde.
    Wenn einer eine Idee hat wäre ich dankbar.
    • arteckA Offline
      arteckA Offline
      arteck
      dann installiere den nochmal vom git
      cd /opt/iobroker
      npm install https://github.com/ioBroker/ioBroker.zigbee
