  4. [GELÖST] HILFE - Nach update js-controller nicht installierbar
22 Beiträge 5 Kommentatoren 6.0k Aufrufe 1 Beobachtet
  • G Offline
    Glarios
    Ich habe genau des gleiche Problem nach einem Update von Node.js. Bei mir läuft leider der unsafe Befehl nicht:
    pi@ioBroker-RasPi:/opt/iobroker $ sudo npm install iobroker.js-controller –unsafe-perm
    npm ERR! code EINVALIDTAGNAME
    npm ERR! Invalid tag name "–unsafe-perm": Tags may not have any characters that encodeURIComponent encodes.
    npm ERR!     /root/.npm/_logs/2019-09-01T14_48_36_805Z-debug.log
    Hat jemand eine Idee?
    • G Offline
      Glarios
      Ich habe jetzt mal einfach nur -unsafe ausprobiert. Ergebnis aber wie vorher ohne diese Zusatz:
      pi@ioBroker-RasPi:/opt/iobroker $ sudo npm install iobroker.js-controller unsafe
      > iobroker.js-controller@1.5.14 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.9.0
      npm version >= 5: disabling package-lock
      > serialport@4.0.7 install /opt/iobroker/node_modules/serialport
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp info it worked if it ends with ok
      node-pre-gyp verb cli [ '/usr/bin/node',
      node-pre-gyp verb cli   '/opt/iobroker/node_modules/serialport/node_modules/.bin/node-pre-gyp',
      node-pre-gyp verb cli   'install',
      node-pre-gyp verb cli   '--fallback-to-build' ]
      node-pre-gyp info using node-pre-gyp@0.6.32
      node-pre-gyp info using node@10.16.3 | linux | arm
      node-pre-gyp verb command install []
      node-pre-gyp info check checked for "/opt/iobroker/node_modules/serialport/build/Release/serialport.node" (not found)
      node-pre-gyp http GET https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-        v4.0.7-node-v64-linux-arm.tar.gz
      node-pre-gyp ERR! Tried to download(undefined): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/        download/4.0.7/serialport-v4.0.7-node-v64-linux-arm.tar.gz
      node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@10.16.3 (node-v64 ABI) (falling back to so        urce compile with node-gyp)
      node-pre-gyp http EACCES: permission denied, mkdir '/opt/iobroker/node_modules/serialport/build'
      node-pre-gyp verb command build [ 'rebuild' ]
      node-pre-gyp http 404 https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-        v4.0.7-node-v64-linux-arm.tar.gz
      node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/downlo        ad/4.0.7/serialport-v4.0.7-node-v64-linux-arm.tar.gz
      node-pre-gyp http 404 status code downloading tarball https://github.com/EmergingTechnologyAdvisors/node-serialport/rel        eases/download/4.0.7/serialport-v4.0.7-node-v64-linux-arm.tar.gz
      node-pre-gyp http Connection closed while downloading tarball file
      gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/10.16.3"
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
      gyp ERR! configure error
      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/serialport/build'
      gyp ERR! System Linux 4.19.66-v7+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallb        ack-to-build" "--module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport"        "--module_path=/opt/iobroker/node_modules/serialport/build/Release"
      gyp ERR! cwd /opt/iobroker/node_modules/serialport
      gyp ERR! node -v v10.16.3
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/nod        e-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node --m        odule_name=serialport --module_path=/opt/iobroker/node_modules/serialport/build/Release' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/serialport/node_modules/node-pre-gy        p/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      node-pre-gyp ERR! System Linux 4.19.66-v7+
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/serialport/node_modules/.bin/node-pre-gyp" "insta        ll" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/serialport
      node-pre-gyp ERR! node -v v10.16.3
      node-pre-gyp ERR! node-pre-gyp -v v0.6.32
      node-pre-gyp ERR! not ok
      Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-t        o-build --module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_        path=/opt/iobroker/node_modules/serialport/build/Release' (1)
      > iobroker.js-controller@1.5.14 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      gyp ERR! not ok
      gyp ERR! not ok
      Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-cont        roller/lib/setup/../../_service_iobroker.bat'
      Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-cont        roller/lib/setup/../../iobroker.bat'
      fs.js:114
          throw err;
      Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
          at Object.mkdirSync (fs.js:757:3)
          at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:189:58)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:653:27
          at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:691:15)
          at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3193:5)
          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:38)
          at Module._compile (internal/modules/cjs/loader.js:778:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          at Module.load (internal/modules/cjs/loader.js:653:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 (node_modules/serialport):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 install: `node-pre-gyp install --fallback-to-build`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.js-controller@1.5.14 install: `node iobroker.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@1.5.14 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /root/.npm/_logs/2019-09-01T14_57_46_659Z-debug.log
      Ist da noch etwas zu retten, oder muss ich alles neu aufsetzen? :(
