  4. Rechteproblem-AmazonDash
    6.5k
4 Beiträge 3 Kommentatoren 655 Aufrufe
    Siegfried
    Forum Testing
    Hallo
    Hab ein Rechteproblem. Eigentlich nur mehr mit dem Amazon-Dash Adapter.
    Wenn ich mit:````
    sudo iobroker start
    Aber lasse ich ihn nur über den Autostart von alleine starten lasse läuft wohl einiges nicht so richtig( vermute ich)
    Bemerken tu ich es eigentlich nur mehr am Amazon-dash
    Bekomme folgende meldungen im Log:
    >! host.ioBrokerPC 2018-12-30 14:47:01.803 info Restart adapter system.adapter.amazon-dash.0 because enabled
    >! host.ioBrokerPC 2018-12-30 14:47:01.802 error instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
    >! host.ioBrokerPC 2018-12-30 14:47:01.802 error Caught by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:787:25)
    >! host.ioBrokerPC 2018-12-30 14:47:01.802 error Caught by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:748:13)
    >! host.ioBrokerPC 2018-12-30 14:47:01.801 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:788:29
    >! host.ioBrokerPC 2018-12-30 14:47:01.801 error Caught by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4990:18)
    >! host.ioBrokerPC 2018-12-30 14:47:01.801 error Caught by controller[0]: at Adapter.emit (events.js:208:7)
    >! host.ioBrokerPC 2018-12-30 14:47:01.800 error Caught by controller[0]: at emitNone (events.js:106:13)
    >! host.ioBrokerPC 2018-12-30 14:47:01.800 error Caught by controller[0]: at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:43:5)
    >! host.ioBrokerPC 2018-12-30 14:47:01.799 error Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
    >! host.ioBrokerPC 2018-12-30 14:47:01.799 error Caught by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:123:12)
    >! host.ioBrokerPC 2018-12-30 14:47:01.799 error Caught by controller[0]: at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:49:39)
    >! host.ioBrokerPC 2018-12-30 14:47:01.798 error Caught by controller[0]: Error: socket: Operation not permitted
    >! amazon-dash.0 2018-12-30 14:47:01.787 info cleaned everything up…
    >! amazon-dash.0 2018-12-30 14:47:01.787 error Error: socket: Operation not permitted at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:49:39) at Object.exports.createSession (/opt/iobroker/node_
    >! amazon-dash.0 2018-12-30 14:47:01.787 error uncaught exception: socket: Operation not permitted
    >! amazon-dash.0 2018-12-30 14:47:01.787 info starting pcap session on default interface
    >! amazon-dash.0 2018-12-30 14:47:01.786 info starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v8.14.0
    >! host.ioBrokerPC 2018-12-30 14:47:01.335 info instance system.adapter.amazon-dash.0 started with pid 1216</anonymous></anonymous>
    Was kann ich da machen?
    Danke schon mal :-)
    Edit: Auch der Bluetooth adapter läuft ohne sudo nicht ganz einwandfrei (er kann die Objekte nicht neuschreiben wenn ich sie rauslösche) mit Sudo gehts
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      Wenn du nicht allzu viel Arbeit in deine Installation gesteckt hast, empfehle ich dir noch mal nach der aktuellen Doku (siehe gepinnter thread im forum allgemein) neu aufzusetzen. Da scheint einiges im argen zu sein was vermutlich mangels deiner Erfahrung von unbedarften Befehlsausführungen kommt
      Gesendet von unterwegs
        Siegfried
        Forum Testing
        Ja ich weis hab nicht sehr viel erfahrung mit Linux.
        Nur leider ist die Installation mitlerweil gar nicht mehr so klein (Besonders wenn ich Z-Wave und Zigbeegeräte neu anleren muss) und wenn ich es vermeiden kann alles neu aufzusetzten werde ich es machen.
        Wenn ich den ioBroker mittels sudo starte (was mir scheint dass es ja viele so machen) läuft alles einwandfrei ohne sudo scheinen nur die 2 Adapter nicht zu laufen.
        Sg und ein gutes neues Jahr
        • L Offline
          leuchtturm
          Ich habe genau das gleiche Phänomen.
          Es ist nur der Amazon Dash Adapter.
          Die Fehlermeldungen sind exakt gleich.
