  4. [gelöst]Problem mit Node-Red
    6.4k
17 Beiträge 2 Kommentatoren 1.3k Aufrufe
    Torsten_MG
    mir ist eben aufgefallen, dass ich über den Tag öfter viele Meldungen von Node-Red im log habe:
    `2018-11-19 16:45:15.284  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:15.680  - [33mwarn[39m: node-red.0 19 Nov 16:45:15 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:15.969  - [31merror[39m: node-red.0 19 Nov 16:45:15 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:15.971  - [31merror[39m: node-red.0 19 Nov 16:45:15 - [error] Error: port in use
    2018-11-19 16:45:16.028  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:21.029  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:24.509  - [33mwarn[39m: node-red.0 19 Nov 16:45:24 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:24.622  - [31merror[39m: node-red.0 19 Nov 16:45:24 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:24.623  - [31merror[39m: node-red.0 19 Nov 16:45:24 - [error] Error: port in use
    2018-11-19 16:45:24.676  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:28.141  - [33mwarn[39m: node-red.0 19 Nov 16:45:28 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:28.247  - [31merror[39m: node-red.0 19 Nov 16:45:28 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:28.250  - [31merror[39m: node-red.0 19 Nov 16:45:28 - [error] Error: port in use
    2018-11-19 16:45:28.304  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:29.679  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:33.305  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:35.117  - [33mwarn[39m: node-red.0 19 Nov 16:45:35 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:35.478  - [31merror[39m: node-red.0 19 Nov 16:45:35 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:35.480  - [31merror[39m: node-red.0 19 Nov 16:45:35 - [error] Error: port in use
    2018-11-19 16:45:35.568  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:39.612  - [33mwarn[39m: node-red.0 19 Nov 16:45:39 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:39.712  - [31merror[39m: node-red.0 19 Nov 16:45:39 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:39.714  - [31merror[39m: node-red.0 19 Nov 16:45:39 - [error] Error: port in use
    2018-11-19 16:45:39.759  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:40.569  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:41.814  - [34mdebug[39m: daswetter.0 nothing to do
    2018-11-19 16:45:41.852  - [32minfo[39m: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (OK)
    2018-11-19 16:45:44.759  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:47.192  - [33mwarn[39m: node-red.0 19 Nov 16:45:47 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:47.491  - [31merror[39m: node-red.0 19 Nov 16:45:47 - [error] Unable to listen on http://127.0.0.1:1880/
    19 Nov 16:45:47 - [error] Error: port in use
    2018-11-19 16:45:47.543  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:49.979  - [33mwarn[39m: node-red.0 19 Nov 16:45:49 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:50.162  - [31merror[39m: node-red.0 19 Nov 16:45:50 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:50.163  - [31merror[39m: node-red.0 19 Nov 16:45:50 - [error] Error: port in use
    2018-11-19 16:45:50.202  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:52.545  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:55.204  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:55.516  - [33mwarn[39m: node-red.0 19 Nov 16:45:55 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:55.708  - [31merror[39m: node-red.0 19 Nov 16:45:55 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:55.711  - [31merror[39m: node-red.0 19 Nov 16:45:55 - [error] Error: port in use
    2018-11-19 16:45:55.745  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:58.521  - [33mwarn[39m: node-red.0 19 Nov 16:45:58 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:58.699  - [31merror[39m: node-red.0 19 Nov 16:45:58 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:58.700  - [31merror[39m: node-red.0 19 Nov 16:45:58 - [error] Error: port in use
    2018-11-19 16:45:58.733  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:00.746  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:03.735  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:06.002  - [33mwarn[39m: node-red.0 19 Nov 16:46:06 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:06.230  - [31merror[39m: node-red.0 19 Nov 16:46:06 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:06.232  - [31merror[39m: node-red.0 19 Nov 16:46:06 - [error] Error: port in use
    2018-11-19 16:46:06.273  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:09.224  - [33mwarn[39m: node-red.0 19 Nov 16:46:09 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:09.311  - [31merror[39m: node-red.0 19 Nov 16:46:09 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:09.314  - [31merror[39m: node-red.0 19 Nov 16:46:09 - [error] Error: port in use
    2018-11-19 16:46:09.346  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:11.275  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:14.347  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:14.789  - [33mwarn[39m: node-red.0 19 Nov 16:46:14 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:15.709  - [31merror[39m: node-red.0 19 Nov 16:46:15 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:15.712  - [31merror[39m: node-red.0 19 Nov 16:46:15 - [error] Error: port in use
    2018-11-19 16:46:15.758  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:17.908  - [33mwarn[39m: node-red.0 19 Nov 16:46:17 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:18.000  - [31merror[39m: node-red.0 19 Nov 16:46:17 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:18.003  - [31merror[39m: node-red.0 19 Nov 16:46:18 - [error] Error: port in use
    2018-11-19 16:46:18.049  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:20.759  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:23.051  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:26.017  - [33mwarn[39m: node-red.0 19 Nov 16:46:26 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:26.256  - [31merror[39m: node-red.0 19 Nov 16:46:26 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:26.257  - [31merror[39m: node-red.0 19 Nov 16:46:26 - [error] Error: port in use
    2018-11-19 16:46:26.311  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:28.974  - [33mwarn[39m: node-red.0 19 Nov 16:46:28 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:29.173  - [31merror[39m: node-red.0 19 Nov 16:46:29 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:29.176  - [31merror[39m: node-red.0 19 Nov 16:46:29 - [error] Error: port in use
    2018-11-19 16:46:29.213  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:31.313  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:34.215  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:35.096  - [33mwarn[39m: node-red.0 19 Nov 16:46:35 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:35.289  - [31merror[39m: node-red.0 19 Nov 16:46:35 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:35.291  - [31merror[39m: node-red.0 19 Nov 16:46:35 - [error] Error: port in use
    2018-11-19 16:46:35.356  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:37.277  - [33mwarn[39m: node-red.0 19 Nov 16:46:37 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:37.479  - [31merror[39m: node-red.0 19 Nov 16:46:37 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:37.480  - [31merror[39m: node-red.0 19 Nov 16:46:37 - [error] Error: port in use
    2018-11-19 16:46:37.518  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:40.358  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:42.519  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:45.668  - [33mwarn[39m: node-red.0 19 Nov 16:46:45 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:45.934  - [31merror[39m: node-red.0 19 Nov 16:46:45 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:45.939  - [31merror[39m: node-red.0 19 Nov 16:46:45 - [error] Error: port in use
    2018-11-19 16:46:46.000  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:48.584  - [33mwarn[39m: node-red.0 19 Nov 16:46:48 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:48.707  - [31merror[39m: node-red.0 19 Nov 16:46:48 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:48.710  - [31merror[39m: node-red.0 19 Nov 16:46:48 - [error] Error: port in use
    2018-11-19 16:46:48.753  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:51.002  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:53.754  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:55.181  - [33mwarn[39m: node-red.0 19 Nov 16:46:55 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:55.337  - [31merror[39m: node-red.0 19 Nov 16:46:55 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:55.343  - [31merror[39m: node-red.0 19 Nov 16:46:55 - [error] Error: port in use
    2018-11-19 16:46:55.450  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:57.477  - [33mwarn[39m: node-red.0 19 Nov 16:46:57 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:57.681  - [31merror[39m: node-red.0 19 Nov 16:46:57 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:57.685  - [31merror[39m: node-red.0 19 Nov 16:46:57 - [error] Error: port in use
    2018-11-19 16:46:57.719  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:00.452  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:02.722  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:05.281  - [33mwarn[39m: node-red.0 19 Nov 16:47:05 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:05.511  - [31merror[39m: node-red.0 19 Nov 16:47:05 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:05.514  - [31merror[39m: node-red.0 19 Nov 16:47:05 - [error] Error: port in use
    2018-11-19 16:47:05.558  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:07.984  - [33mwarn[39m: node-red.0 19 Nov 16:47:07 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:08.145  - [31merror[39m: node-red.0 19 Nov 16:47:08 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:08.146  - [31merror[39m: node-red.0 19 Nov 16:47:08 - [error] Error: port in use
    2018-11-19 16:47:08.181  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:10.561  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:13.183  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:14.677  - [33mwarn[39m: node-red.0 19 Nov 16:47:14 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:14.898  - [31merror[39m: node-red.0 19 Nov 16:47:14 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:14.900  - [31merror[39m: node-red.0 19 Nov 16:47:14 - [error] Error: port in use
    2018-11-19 16:47:14.944  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:16.626  - [32minfo[39m: hue.0 final lightState for Philips_hue.Hue_ambiance_spot_1:{"bri":254,"on":true,"level":100}
    2018-11-19 16:47:17.227  - [33mwarn[39m: node-red.0 19 Nov 16:47:17 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:17.297  - [31merror[39m: node-red.0 19 Nov 16:47:17 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:17.299  - [31merror[39m: node-red.0 19 Nov 16:47:17 - [error] Error: port in use
    2018-11-19 16:47:17.330  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:18.976  - [32minfo[39m: hue.0 final lightState for Philips_hue.Hue_ambiance_spot_1:{"bri":0,"on":false,"level":0}
    2018-11-19 16:47:19.946  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:22.331  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:25.204  - [33mwarn[39m: node-red.0 19 Nov 16:47:25 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:25.420  - [31merror[39m: node-red.0 19 Nov 16:47:25 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:25.421  - [31merror[39m: node-red.0 19 Nov 16:47:25 - [error] Error: port in use
    2018-11-19 16:47:25.456  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:27.907  - [32minfo[39m: hue.0 final lightState for Philips_hue.Hue_ambiance_spot_1:{"bri":254,"on":true,"level":100}
    2018-11-19 16:47:28.439  - [33mwarn[39m: node-red.0 19 Nov 16:47:28 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:28.670  - [31merror[39m: node-red.0 19 Nov 16:47:28 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:28.672  - [31merror[39m: node-red.0 19 Nov 16:47:28 - [error] Error: port in use
    2018-11-19 16:47:28.712  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:28.823  - [32minfo[39m: hue.0 final lightState for Philips_hue.Hue_ambiance_spot_1:{"bri":0,"on":false,"level":0}
    2018-11-19 16:47:30.459  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:33.712  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:34.267  - [33mwarn[39m: node-red.0 19 Nov 16:47:34 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:34.455  - [31merror[39m: node-red.0 19 Nov 16:47:34 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:34.456  - [31merror[39m: node-red.0 19 Nov 16:47:34 - [error] Error: port in use
    2018-11-19 16:47:34.493  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:37.306  - [33mwarn[39m: node-red.0 19 Nov 16:47:37 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:37.403  - [31merror[39m: node-red.0 19 Nov 16:47:37 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:37.406  - [31merror[39m: node-red.0 19 Nov 16:47:37 - [error] Error: port in use
    2018-11-19 16:47:37.447  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:39.495  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:42.448  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:44.518  - [33mwarn[39m: node-red.0 19 Nov 16:47:44 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:44.753  - [31merror[39m: node-red.0 19 Nov 16:47:44 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:44.754  - [31merror[39m: node-red.0 19 Nov 16:47:44 - [error] Error: port in use
    2018-11-19 16:47:44.800  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:47.569  - [33mwarn[39m: node-red.0 19 Nov 16:47:47 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:47.757  - [31merror[39m: node-red.0 19 Nov 16:47:47 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:47.759  - [31merror[39m: node-red.0 19 Nov 16:47:47 - [error] Error: port in use
    2018-11-19 16:47:47.800  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:49.800  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:52.801  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:53.829  - [33mwarn[39m: node-red.0 19 Nov 16:47:53 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:54.094  - [31merror[39m: node-red.0 19 Nov 16:47:54 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:54.100  - [31merror[39m: node-red.0 19 Nov 16:47:54 - [error] Error: port in use
    2018-11-19 16:47:54.142  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:56.869  - [33mwarn[39m: node-red.0 19 Nov 16:47:56 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:57.071  - [31merror[39m: node-red.0 19 Nov 16:47:57 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:57.074  - [31merror[39m: node-red.0 19 Nov 16:47:57 - [error] Error: port in use
    2018-11-19 16:47:57.106  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:59.143  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:02.108  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:04.133  - [33mwarn[39m: node-red.0 19 Nov 16:48:04 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    19 Nov 16:48:04 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:04.438  - [31merror[39m: node-red.0 19 Nov 16:48:04 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:04.439  - [31merror[39m: node-red.0 19 Nov 16:48:04 - [error] Error: port in use
    2018-11-19 16:48:04.498  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:07.553  - [33mwarn[39m: node-red.0 19 Nov 16:48:07 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:07.784  - [31merror[39m: node-red.0 19 Nov 16:48:07 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:07.787  - [31merror[39m: node-red.0 19 Nov 16:48:07 - [error] Error: port in use
    2018-11-19 16:48:07.825  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:09.500  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:12.826  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:13.218  - [33mwarn[39m: node-red.0 19 Nov 16:48:13 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:13.396  - [31merror[39m: node-red.0 19 Nov 16:48:13 - [error] Unable to listen on http://127.0.0.1:1880/
    19 Nov 16:48:13 - [error] Error: port in use
    2018-11-19 16:48:13.460  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:16.436  - [33mwarn[39m: node-red.0 19 Nov 16:48:16 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:16.619  - [31merror[39m: node-red.0 19 Nov 16:48:16 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:16.620  - [31merror[39m: node-red.0 19 Nov 16:48:16 - [error] Error: port in use
    2018-11-19 16:48:16.657  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:18.462  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:21.659  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:23.125  - [33mwarn[39m: node-red.0 19 Nov 16:48:23 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:23.401  - [31merror[39m: node-red.0 19 Nov 16:48:23 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:23.402  - [31merror[39m: node-red.0 19 Nov 16:48:23 - [error] Error: port in use
    2018-11-19 16:48:23.452  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:26.944  - [33mwarn[39m: node-red.0 19 Nov 16:48:26 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:27.140  - [31merror[39m: node-red.0 19 Nov 16:48:27 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:27.141  - [31merror[39m: node-red.0 19 Nov 16:48:27 - [error] Error: port in use
    2018-11-19 16:48:27.183  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:28.455  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:32.185  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:33.014  - [33mwarn[39m: node-red.0 19 Nov 16:48:33 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:33.226  - [31merror[39m: node-red.0 19 Nov 16:48:33 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:33.229  - [31merror[39m: node-red.0 19 Nov 16:48:33 - [error] Error: port in use
    2018-11-19 16:48:33.295  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:36.362  - [33mwarn[39m: node-red.0 19 Nov 16:48:36 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:36.568  - [31merror[39m: node-red.0 19 Nov 16:48:36 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:36.570  - [31merror[39m: node-red.0 19 Nov 16:48:36 - [error] Error: port in use
    2018-11-19 16:48:36.604  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:38.297  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:41.605  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:42.678  - [33mwarn[39m: node-red.0 19 Nov 16:48:42 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:42.898  - [31merror[39m: node-red.0 19 Nov 16:48:42 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:42.899  - [31merror[39m: node-red.0 19 Nov 16:48:42 - [error] Error: port in use
    2018-11-19 16:48:42.935  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:46.247  - [33mwarn[39m: node-red.0 19 Nov 16:48:46 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:46.411  - [31merror[39m: node-red.0 19 Nov 16:48:46 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:46.413  - [31merror[39m: node-red.0 19 Nov 16:48:46 - [error] Error: port in use
    2018-11-19 16:48:46.459  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:47.937  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:51.460  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:51.567  - [33mwarn[39m: node-red.0 19 Nov 16:48:51 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:51.731  - [31merror[39m: node-red.0 19 Nov 16:48:51 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:51.733  - [31merror[39m: node-red.0 19 Nov 16:48:51 - [error] Error: port in use
    2018-11-19 16:48:51.781  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:55.368  - [33mwarn[39m: node-red.0 19 Nov 16:48:55 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    19 Nov 16:48:55 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:55.549  - [31merror[39m: node-red.0 19 Nov 16:48:55 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:55.551  - [31merror[39m: node-red.0 19 Nov 16:48:55 - [error] Error: port in use
    2018-11-19 16:48:55.591  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:56.782  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:00.592  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:01.937  - [33mwarn[39m: node-red.0 19 Nov 16:49:01 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:02.152  - [31merror[39m: node-red.0 19 Nov 16:49:02 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:02.154  - [31merror[39m: node-red.0 19 Nov 16:49:02 - [error] Error: port in use
    2018-11-19 16:49:02.195  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:05.710  - [33mwarn[39m: node-red.0 19 Nov 16:49:05 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:05.915  - [31merror[39m: node-red.0 19 Nov 16:49:05 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:05.917  - [31merror[39m: node-red.0 19 Nov 16:49:05 - [error] Error: port in use
    2018-11-19 16:49:05.954  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:07.197  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:10.955  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:11.447  - [33mwarn[39m: node-red.0 19 Nov 16:49:11 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:11.627  - [31merror[39m: node-red.0 19 Nov 16:49:11 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:11.628  - [31merror[39m: node-red.0 19 Nov 16:49:11 - [error] Error: port in use
    2018-11-19 16:49:11.669  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:14.851  - [33mwarn[39m: node-red.0 19 Nov 16:49:14 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:15.014  - [31merror[39m: node-red.0 19 Nov 16:49:15 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:15.015  - [31merror[39m: node-red.0 19 Nov 16:49:15 - [error] Error: port in use
    2018-11-19 16:49:15.047  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:16.672  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:20.048  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:21.451  - [33mwarn[39m: node-red.0 19 Nov 16:49:21 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:21.532  - [31merror[39m: node-red.0 19 Nov 16:49:21 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:21.533  - [31merror[39m: node-red.0 19 Nov 16:49:21 - [error] Error: port in use
    2018-11-19 16:49:21.570  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:25.133  - [33mwarn[39m: node-red.0 19 Nov 16:49:25 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:25.349  - [31merror[39m: node-red.0 19 Nov 16:49:25 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:25.350  - [31merror[39m: node-red.0 19 Nov 16:49:25 - [error] Error: port in use
    2018-11-19 16:49:25.384  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:26.572  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:30.386  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:30.983  - [33mwarn[39m: node-red.0 19 Nov 16:49:30 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:31.064  - [31merror[39m: node-red.0 19 Nov 16:49:31 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:31.065  - [31merror[39m: node-red.0 19 Nov 16:49:31 - [error] Error: port in use
    2018-11-19 16:49:31.106  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:34.400  - [33mwarn[39m: node-red.0 19 Nov 16:49:34 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:34.481  - [31merror[39m: node-red.0 19 Nov 16:49:34 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:34.482  - [31merror[39m: node-red.0 19 Nov 16:49:34 - [error] Error: port in use
    2018-11-19 16:49:34.515  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:36.107  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:39.517  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:41.089  - [33mwarn[39m: node-red.0 19 Nov 16:49:41 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:41.296  - [31merror[39m: node-red.0 19 Nov 16:49:41 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:41.297  - [31merror[39m: node-red.0 19 Nov 16:49:41 - [error] Error: port in use
    2018-11-19 16:49:41.346  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:44.940  - [33mwarn[39m: node-red.0 19 Nov 16:49:44 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:45.118  - [31merror[39m: node-red.0 19 Nov 16:49:45 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:45.120  - [31merror[39m: node-red.0 19 Nov 16:49:45 - [error] Error: port in use
    2018-11-19 16:49:45.154  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:46.348  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:50.154  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:50.766  - [33mwarn[39m: node-red.0 19 Nov 16:49:50 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:51.038  - [31merror[39m: node-red.0 19 Nov 16:49:51 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:51.039  - [31merror[39m: node-red.0 19 Nov 16:49:51 - [error] Error: port in use
    2018-11-19 16:49:51.078  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:54.065  - [33mwarn[39m: node-red.0 19 Nov 16:49:54 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:54.246  - [31merror[39m: node-red.0 19 Nov 16:49:54 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:54.249  - [31merror[39m: node-red.0 19 Nov 16:49:54 - [error] Error: port in use
    2018-11-19 16:49:54.292  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:56.080  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:59.293  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:59.695  - [33mwarn[39m: node-red.0 19 Nov 16:49:59 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:59.882  - [31merror[39m: node-red.0 19 Nov 16:49:59 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:59.884  - [31merror[39m: node-red.0 19 Nov 16:49:59 - [error] Error: port in use
    2018-11-19 16:49:59.926  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:03.666  - [33mwarn[39m: node-red.0 19 Nov 16:50:03 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:03.827  - [31merror[39m: node-red.0 19 Nov 16:50:03 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:03.828  - [31merror[39m: node-red.0 19 Nov 16:50:03 - [error] Error: port in use
    2018-11-19 16:50:03.864  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:04.927  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:08.865  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:10.593  - [33mwarn[39m: node-red.0 19 Nov 16:50:10 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:10.856  - [31merror[39m: node-red.0 19 Nov 16:50:10 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:10.858  - [31merror[39m: node-red.0 19 Nov 16:50:10 - [error] Error: port in use
    2018-11-19 16:50:10.900  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:14.029  - [33mwarn[39m: node-red.0 19 Nov 16:50:14 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:14.241  - [31merror[39m: node-red.0 19 Nov 16:50:14 - [error] Unable to listen on http://127.0.0.1:1880/
    19 Nov 16:50:14 - [error] Error: port in use
    2018-11-19 16:50:14.296  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:15.902  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:19.297  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:19.782  - [33mwarn[39m: node-red.0 19 Nov 16:50:19 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:19.868  - [31merror[39m: node-red.0 19 Nov 16:50:19 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:19.870  - [31merror[39m: node-red.0 19 Nov 16:50:19 - [error] Error: port in use
    2018-11-19 16:50:19.957  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:23.220  - [33mwarn[39m: node-red.0 19 Nov 16:50:23 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:23.410  - [31merror[39m: node-red.0 19 Nov 16:50:23 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:23.411  - [31merror[39m: node-red.0 19 Nov 16:50:23 - [error] Error: port in use
    2018-11-19 16:50:23.444  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:24.958  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:28.444  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:29.527  - [33mwarn[39m: node-red.0 19 Nov 16:50:29 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:29.710  - [31merror[39m: node-red.0 19 Nov 16:50:29 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:29.712  - [31merror[39m: node-red.0 19 Nov 16:50:29 - [error] Error: port in use
    2018-11-19 16:50:29.750  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:33.365  - [33mwarn[39m: node-red.0 19 Nov 16:50:33 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:33.540  - [31merror[39m: node-red.0 19 Nov 16:50:33 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:33.542  - [31merror[39m: node-red.0 19 Nov 16:50:33 - [error] Error: port in use
    2018-11-19 16:50:33.579  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:34.751  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:38.580  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:39.361  - [33mwarn[39m: node-red.0 19 Nov 16:50:39 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:39.471  - [31merror[39m: node-red.0 19 Nov 16:50:39 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:39.473  - [31merror[39m: node-red.0 19 Nov 16:50:39 - [error] Error: port in use
    2018-11-19 16:50:39.521  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:42.591  - [33mwarn[39m: node-red.0 19 Nov 16:50:42 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:42.790  - [31merror[39m: node-red.0 19 Nov 16:50:42 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:42.791  - [31merror[39m: node-red.0 19 Nov 16:50:42 - [error] Error: port in use
    2018-11-19 16:50:42.830  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:44.523  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:47.833  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:49.474  - [33mwarn[39m: node-red.0 19 Nov 16:50:49 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:49.661  - [31merror[39m: node-red.0 19 Nov 16:50:49 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:49.663  - [31merror[39m: node-red.0 19 Nov 16:50:49 - [error] Error: port in use
    2018-11-19 16:50:49.715  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:52.794  - [33mwarn[39m: node-red.0 19 Nov 16:50:52 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:52.997  - [31merror[39m: node-red.0 19 Nov 16:50:52 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:52.999  - [31merror[39m: node-red.0 19 Nov 16:50:52 - [error] Error: port in use
    2018-11-19 16:50:53.038  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:54.715  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:58.038  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:58.582  - [33mwarn[39m: node-red.0 19 Nov 16:50:58 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:58.811  - [31merror[39m: node-red.0 19 Nov 16:50:58 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:58.813  - [31merror[39m: node-red.0 19 Nov 16:50:58 - [error] Error: port in use
    2018-11-19 16:50:58.856  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:02.008  - [33mwarn[39m: node-red.0 19 Nov 16:51:02 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:02.173  - [31merror[39m: node-red.0 19 Nov 16:51:02 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:02.175  - [31merror[39m: node-red.0 19 Nov 16:51:02 - [error] Error: port in use
    2018-11-19 16:51:02.211  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:03.858  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:07.212  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:08.084  - [33mwarn[39m: node-red.0 19 Nov 16:51:08 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:08.309  - [31merror[39m: node-red.0 19 Nov 16:51:08 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:08.310  - [31merror[39m: node-red.0 19 Nov 16:51:08 - [error] Error: port in use
    2018-11-19 16:51:08.354  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:11.684  - [33mwarn[39m: node-red.0 19 Nov 16:51:11 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:11.863  - [31merror[39m: node-red.0 19 Nov 16:51:11 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:11.865  - [31merror[39m: node-red.0 19 Nov 16:51:11 - [error] Error: port in use
    2018-11-19 16:51:11.910  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:13.356  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:16.912  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:18.037  - [33mwarn[39m: node-red.0 19 Nov 16:51:18 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:18.224  - [31merror[39m: node-red.0 19 Nov 16:51:18 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:18.225  - [31merror[39m: node-red.0 19 Nov 16:51:18 - [error] Error: port in use
    2018-11-19 16:51:18.266  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:22.282  - [33mwarn[39m: node-red.0 19 Nov 16:51:22 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:22.363  - [31merror[39m: node-red.0 19 Nov 16:51:22 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:22.366  - [31merror[39m: node-red.0 19 Nov 16:51:22 - [error] Error: port in use
    2018-11-19 16:51:22.434  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:23.271  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:27.434  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:27.994  - [33mwarn[39m: node-red.0 19 Nov 16:51:27 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:28.187  - [31merror[39m: node-red.0 19 Nov 16:51:28 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:28.188  - [31merror[39m: node-red.0 19 Nov 16:51:28 - [error] Error: port in use
    2018-11-19 16:51:28.245  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:31.714  - [33mwarn[39m: node-red.0 19 Nov 16:51:31 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:31.889  - [31merror[39m: node-red.0 19 Nov 16:51:31 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:31.890  - [31merror[39m: node-red.0 19 Nov 16:51:31 - [error] Error: port in use
    2018-11-19 16:51:31.923  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:33.248  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:36.924  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:37.067  - [33mwarn[39m: node-red.0 19 Nov 16:51:37 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:37.241  - [31merror[39m: node-red.0 19 Nov 16:51:37 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:37.244  - [31merror[39m: node-red.0 19 Nov 16:51:37 - [error] Error: port in use
    2018-11-19 16:51:37.279  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:40.765  - [33mwarn[39m: node-red.0 19 Nov 16:51:40 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:40.957  - [31merror[39m: node-red.0 19 Nov 16:51:40 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:40.958  - [31merror[39m: node-red.0 19 Nov 16:51:40 - [error] Error: port in use
    2018-11-19 16:51:40.993  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:42.282  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:45.994  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:47.339  - [33mwarn[39m: node-red.0 19 Nov 16:51:47 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    19 Nov 16:51:47 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:47.424  - [31merror[39m: node-red.0 19 Nov 16:51:47 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:47.425  - [31merror[39m: node-red.0 19 Nov 16:51:47 - [error] Error: port in use
    2018-11-19 16:51:47.468  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:50.677  - [33mwarn[39m: node-red.0 19 Nov 16:51:50 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:50.784  - [31merror[39m: node-red.0 19 Nov 16:51:50 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:50.785  - [31merror[39m: node-red.0 19 Nov 16:51:50 - [error] Error: port in use
    2018-11-19 16:51:50.836  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:52.469  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:55.838  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:56.899  - [33mwarn[39m: node-red.0 19 Nov 16:51:56 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:56.987  - [31merror[39m: node-red.0 19 Nov 16:51:56 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:56.989  - [31merror[39m: node-red.0 19 Nov 16:51:56 - [error] Error: port in use
    2018-11-19 16:51:57.029  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:00.237  - [33mwarn[39m: node-red.0 19 Nov 16:52:00 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:00.401  - [31merror[39m: node-red.0 19 Nov 16:52:00 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:00.404  - [31merror[39m: node-red.0 19 Nov 16:52:00 - [error] Error: port in use
    2018-11-19 16:52:00.473  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:02.029  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:05.474  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:06.871  - [33mwarn[39m: node-red.0 19 Nov 16:52:06 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:07.121  - [31merror[39m: node-red.0 19 Nov 16:52:07 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:07.124  - [31merror[39m: node-red.0 19 Nov 16:52:07 - [error] Error: port in use
    2018-11-19 16:52:07.179  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:10.079  - [33mwarn[39m: node-red.0 19 Nov 16:52:10 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:10.159  - [31merror[39m: node-red.0 19 Nov 16:52:10 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:10.161  - [31merror[39m: node-red.0 19 Nov 16:52:10 - [error] Error: port in use
    2018-11-19 16:52:10.196  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:12.181  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:15.197  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:15.989  - [33mwarn[39m: node-red.0 19 Nov 16:52:15 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:16.171  - [31merror[39m: node-red.0 19 Nov 16:52:16 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:16.172  - [31merror[39m: node-red.0 19 Nov 16:52:16 - [error] Error: port in use
    2018-11-19 16:52:16.208  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:20.191  - [33mwarn[39m: node-red.0 19 Nov 16:52:20 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:20.402  - [31merror[39m: node-red.0 19 Nov 16:52:20 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:20.404  - [31merror[39m: node-red.0 19 Nov 16:52:20 - [error] Error: port in use
    2018-11-19 16:52:20.441  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:21.210  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:25.443  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:27.142  - [33mwarn[39m: node-red.0 19 Nov 16:52:27 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:27.420  - [31merror[39m: node-red.0 19 Nov 16:52:27 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:27.422  - [31merror[39m: node-red.0 19 Nov 16:52:27 - [error] Error: port in use
    2018-11-19 16:52:27.508  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:30.508  - [33mwarn[39m: node-red.0 19 Nov 16:52:30 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:30.585  - [31merror[39m: node-red.0 19 Nov 16:52:30 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:30.587  - [31merror[39m: node-red.0 19 Nov 16:52:30 - [error] Error: port in use
    2018-11-19 16:52:30.629  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:32.509  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:35.630  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:35.831  - [33mwarn[39m: node-red.0 19 Nov 16:52:35 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:36.030  - [31merror[39m: node-red.0 19 Nov 16:52:36 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:36.032  - [31merror[39m: node-red.0 19 Nov 16:52:36 - [error] Error: port in use
    2018-11-19 16:52:36.069  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:39.771  - [33mwarn[39m: node-red.0 19 Nov 16:52:39 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:39.934  - [31merror[39m: node-red.0 19 Nov 16:52:39 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:39.936  - [31merror[39m: node-red.0 19 Nov 16:52:39 - [error] Error: port in use
    2018-11-19 16:52:39.968  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:41.070  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:44.970  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:46.348  - [33mwarn[39m: node-red.0 19 Nov 16:52:46 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:46.529  - [31merror[39m: node-red.0 19 Nov 16:52:46 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:46.532  - [31merror[39m: node-red.0 19 Nov 16:52:46 - [error] Error: port in use
    2018-11-19 16:52:46.572  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:50.003  - [33mwarn[39m: node-red.0 19 Nov 16:52:50 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    19 Nov 16:52:50 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:50.091  - [31merror[39m: node-red.0 19 Nov 16:52:50 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:50.093  - [31merror[39m: node-red.0 19 Nov 16:52:50 - [error] Error: port in use
    2018-11-19 16:52:50.131  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:51.575  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:55.132  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:55.510  - [33mwarn[39m: node-red.0 19 Nov 16:52:55 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:55.693  - [31merror[39m: node-red.0 19 Nov 16:52:55 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:55.694  - [31merror[39m: node-red.0 19 Nov 16:52:55 - [error] Error: port in use
    2018-11-19 16:52:55.731  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:58.959  - [33mwarn[39m: node-red.0 19 Nov 16:52:58 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:59.122  - [31merror[39m: node-red.0 19 Nov 16:52:59 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:59.125  - [31merror[39m: node-red.0 19 Nov 16:52:59 - [error] Error: port in use
    2018-11-19 16:52:59.157  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:00.732  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:04.159  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:06.223  - [33mwarn[39m: node-red.0 19 Nov 16:53:06 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:06.429  - [31merror[39m: node-red.0 19 Nov 16:53:06 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:06.431  - [31merror[39m: node-red.0 19 Nov 16:53:06 - [error] Error: port in use
    2018-11-19 16:53:06.481  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:09.903  - [33mwarn[39m: node-red.0 19 Nov 16:53:09 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:10.091  - [31merror[39m: node-red.0 19 Nov 16:53:10 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:10.093  - [31merror[39m: node-red.0 19 Nov 16:53:10 - [error] Error: port in use
    2018-11-19 16:53:10.149  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:11.482  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:15.100  - [33mwarn[39m: node-red.0 19 Nov 16:53:15 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:15.153  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:15.322  - [31merror[39m: node-red.0 19 Nov 16:53:15 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:15.323  - [31merror[39m: node-red.0 19 Nov 16:53:15 - [error] Error: port in use
    2018-11-19 16:53:15.356  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:18.186  - [33mwarn[39m: node-red.0 19 Nov 16:53:18 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:18.357  - [31merror[39m: node-red.0 19 Nov 16:53:18 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:18.358  - [31merror[39m: node-red.0 19 Nov 16:53:18 - [error] Error: port in use
    2018-11-19 16:53:18.391  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:20.358  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:23.393  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:26.208  - [33mwarn[39m: node-red.0 19 Nov 16:53:26 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:26.445  - [31merror[39m: node-red.0 19 Nov 16:53:26 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:26.448  - [31merror[39m: node-red.0 19 Nov 16:53:26 - [error] Error: port in use
    2018-11-19 16:53:26.491  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:30.149  - [33mwarn[39m: node-red.0 19 Nov 16:53:30 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:30.786  - [31merror[39m: node-red.0 19 Nov 16:53:30 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:30.787  - [31merror[39m: node-red.0 19 Nov 16:53:30 - [error] Error: port in use
    2018-11-19 16:53:30.825  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:31.492  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:35.827  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:35.839  - [33mwarn[39m: node-red.0 19 Nov 16:53:35 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    19 Nov 16:53:35 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:36.048  - [31merror[39m: node-red.0 19 Nov 16:53:36 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:36.051  - [31merror[39m: node-red.0 19 Nov 16:53:36 - [error] Error: port in use
    2018-11-19 16:53:36.101  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:38.072  - [33mwarn[39m: node-red.0 19 Nov 16:53:38 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:38.242  - [31merror[39m: node-red.0 19 Nov 16:53:38 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:38.243  - [31merror[39m: node-red.0 19 Nov 16:53:38 - [error] Error: port in use
    2018-11-19 16:53:38.284  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:41.103  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:43.286  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:45.737  - [33mwarn[39m: node-red.0 19 Nov 16:53:45 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:45.949  - [31merror[39m: node-red.0 19 Nov 16:53:45 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:45.951  - [31merror[39m: node-red.0 19 Nov 16:53:45 - [error] Error: port in use
    2018-11-19 16:53:46.002  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:49.667  - [33mwarn[39m: node-red.0 19 Nov 16:53:49 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:49.852  - [31merror[39m: node-red.0 19 Nov 16:53:49 - [error] Unable to listen on http://127.0.0.1:1880/
    19 Nov 16:53:49 - [error] Error: port in use
    2018-11-19 16:53:49.910  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:51.005  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:54.910  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:54.932  - [33mwarn[39m: node-red.0 19 Nov 16:53:54 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:55.009  - [31merror[39m: node-red.0 19 Nov 16:53:55 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:55.010  - [31merror[39m: node-red.0 19 Nov 16:53:55 - [error] Error: port in use
    2018-11-19 16:53:55.061  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:57.944  - [33mwarn[39m: node-red.0 19 Nov 16:53:57 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:58.140  - [31merror[39m: node-red.0 19 Nov 16:53:58 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:58.142  - [31merror[39m: node-red.0 19 Nov 16:53:58 - [error] Error: port in use
    2018-11-19 16:53:58.177  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:00.062  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:03.179  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:05.020  - [33mwarn[39m: node-red.0 19 Nov 16:54:05 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:05.259  - [31merror[39m: node-red.0 19 Nov 16:54:05 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:05.262  - [31merror[39m: node-red.0 19 Nov 16:54:05 - [error] Error: port in use
    2018-11-19 16:54:05.310  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:09.537  - [33mwarn[39m: node-red.0 19 Nov 16:54:09 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:09.734  - [31merror[39m: node-red.0 19 Nov 16:54:09 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:09.736  - [31merror[39m: node-red.0 19 Nov 16:54:09 - [error] Error: port in use
    2018-11-19 16:54:09.770  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:10.312  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:14.771  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:15.153  - [33mwarn[39m: node-red.0 19 Nov 16:54:15 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:15.377  - [31merror[39m: node-red.0 19 Nov 16:54:15 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:15.378  - [31merror[39m: node-red.0 19 Nov 16:54:15 - [error] Error: port in use
    2018-11-19 16:54:15.420  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:18.009  - [33mwarn[39m: node-red.0 19 Nov 16:54:18 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:18.190  - [31merror[39m: node-red.0 19 Nov 16:54:18 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:18.192  - [31merror[39m: node-red.0 19 Nov 16:54:18 - [error] Error: port in use
    2018-11-19 16:54:18.236  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:20.421  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:23.238  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:24.001  - [33mwarn[39m: node-red.0 19 Nov 16:54:24 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:24.259  - [31merror[39m: node-red.0 19 Nov 16:54:24 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:24.262  - [31merror[39m: node-red.0 19 Nov 16:54:24 - [error] Error: port in use
    2018-11-19 16:54:24.306  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:29.308  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:29.343  - [33mwarn[39m: node-red.0 19 Nov 16:54:29 - [info] Context store  : 'default' [module=memory]
    19 Nov 16:54:29 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    19 Nov 16:54:29 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    19 Nov 16:54:29 - [info] Flows file     : /opt/iobroker/iobroker-data/node-red/flows.json
    2018-11-19 16:54:29.566  - [31merror[39m: node-red.0 19 Nov 16:54:29 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:29.569  - [31merror[39m: node-red.0 19 Nov 16:54:29 - [error] Error: port in use
    2018-11-19 16:54:29.633  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:34.636  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:35.002  - [33mwarn[39m: node-red.0 19 Nov 16:54:35 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:35.223  - [31merror[39m: node-red.0 19 Nov 16:54:35 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:35.224  - [31merror[39m: node-red.0 19 Nov 16:54:35 - [error] Error: port in use
    2018-11-19 16:54:35.268  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:38.043  - [33mwarn[39m: node-red.0 19 Nov 16:54:38 - [info] Context store  : 'default' [module=memory]
    19 Nov 16:54:38 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    19 Nov 16:54:38 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    19 Nov 16:54:38 - [info] Flows file     : /opt/iobroker/iobroker-data/node-red/flows.json
    2018-11-19 16:54:38.276  - [31merror[39m: node-red.0 19 Nov 16:54:38 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:38.278  - [31merror[39m: node-red.0 19 Nov 16:54:38 - [error] Error: port in use
    2018-11-19 16:54:38.311  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:40.269  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:43.313  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:44.127  - [33mwarn[39m: node-red.0 19 Nov 16:54:44 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:44.382  - [31merror[39m: node-red.0 19 Nov 16:54:44 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:44.384  - [31merror[39m: node-red.0 19 Nov 16:54:44 - [error] Error: port in use
    2018-11-19 16:54:44.421  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:48.989  - [33mwarn[39m: node-red.0 19 Nov 16:54:48 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:49.199  - [31merror[39m: node-red.0 19 Nov 16:54:49 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:49.201  - [31merror[39m: node-red.0 19 Nov 16:54:49 - [error] Error: port in use
    2018-11-19 16:54:49.236  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:49.422  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:54.237  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:54.471  - [33mwarn[39m: node-red.0 19 Nov 16:54:54 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:54.724  - [31merror[39m: node-red.0 19 Nov 16:54:54 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:54.725  - [31merror[39m: node-red.0 19 Nov 16:54:54 - [error] Error: port in use
    2018-11-19 16:54:54.766  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:57.212  - [33mwarn[39m: node-red.0 19 Nov 16:54:57 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:57.394  - [31merror[39m: node-red.0 19 Nov 16:54:57 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:57.395  - [31merror[39m: node-red.0 19 Nov 16:54:57 - [error] Error: port in use
    2018-11-19 16:54:57.431  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:59.767  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:02.432  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:03.304  - [33mwarn[39m: node-red.0 19 Nov 16:55:03 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:03.540  - [31merror[39m: node-red.0 19 Nov 16:55:03 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:03.541  - [31merror[39m: node-red.0 19 Nov 16:55:03 - [error] Error: port in use
    2018-11-19 16:55:03.600  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:08.243  - [33mwarn[39m: node-red.0 19 Nov 16:55:08 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:08.479  - [31merror[39m: node-red.0 19 Nov 16:55:08 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:08.480  - [31merror[39m: node-red.0 19 Nov 16:55:08 - [error] Error: port in use
    2018-11-19 16:55:08.545  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:08.601  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:13.546  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:14.757  - [33mwarn[39m: node-red.0 19 Nov 16:55:14 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:15.002  - [31merror[39m: node-red.0 19 Nov 16:55:15 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:15.005  - [31merror[39m: node-red.0 19 Nov 16:55:15 - [error] Error: port in use
    2018-11-19 16:55:15.052  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:17.030  - [33mwarn[39m: node-red.0 19 Nov 16:55:17 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:17.296  - [31merror[39m: node-red.0 19 Nov 16:55:17 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:17.300  - [31merror[39m: node-red.0 19 Nov 16:55:17 - [error] Error: port in use
    2018-11-19 16:55:17.352  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:20.054  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:22.353  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:22.964  - [33mwarn[39m: node-red.0 19 Nov 16:55:22 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:23.057  - [31merror[39m: node-red.0 19 Nov 16:55:23 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:23.059  - [31merror[39m: node-red.0 19 Nov 16:55:23 - [error] Error: port in use
    2018-11-19 16:55:23.103  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:27.937  - [33mwarn[39m: node-red.0 19 Nov 16:55:27 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:28.104  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:28.159  - [31merror[39m: node-red.0 19 Nov 16:55:28 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:28.160  - [31merror[39m: node-red.0 19 Nov 16:55:28 - [error] Error: port in use
    2018-11-19 16:55:28.240  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:33.240  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:33.957  - [33mwarn[39m: node-red.0 19 Nov 16:55:33 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:34.244  - [31merror[39m: node-red.0 19 Nov 16:55:34 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:34.247  - [31merror[39m: node-red.0 19 Nov 16:55:34 - [error] Error: port in use
    2018-11-19 16:55:34.328  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:36.384  - [33mwarn[39m: node-red.0 19 Nov 16:55:36 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:36.472  - [31merror[39m: node-red.0 19 Nov 16:55:36 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:36.473  - [31merror[39m: node-red.0 19 Nov 16:55:36 - [error] Error: port in use
    2018-11-19 16:55:36.514  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:39.329  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:41.515  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:42.494  - [33mwarn[39m: node-red.0 19 Nov 16:55:42 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:42.783  - [31merror[39m: node-red.0 19 Nov 16:55:42 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:42.787  - [31merror[39m: node-red.0 19 Nov 16:55:42 - [error] Error: port in use
    2018-11-19 16:55:42.864  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:47.865  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:49.625  - [33mwarn[39m: node-red.0 19 Nov 16:55:49 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:49.853  - [31merror[39m: node-red.0 19 Nov 16:55:49 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:49.857  - [31merror[39m: node-red.0 19 Nov 16:55:49 - [error] Error: port in use
    2018-11-19 16:55:49.970  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:54.971  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:55.905  - [33mwarn[39m: node-red.0 19 Nov 16:55:55 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:56.122  - [31merror[39m: node-red.0 19 Nov 16:55:56 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:56.125  - [31merror[39m: node-red.0 19 Nov 16:55:56 - [error] Error: port in use
    2018-11-19 16:55:56.166  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:58.750  - [33mwarn[39m: node-red.0 19 Nov 16:55:58 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:58.956  - [31merror[39m: node-red.0 19 Nov 16:55:58 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:58.957  - [31merror[39m: node-red.0 19 Nov 16:55:58 - [error] Error: port in use
    2018-11-19 16:55:58.994  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:01.167  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:03.461  - [33mwarn[39m: node-red.0 19 Nov 16:56:03 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:56:03.622  - [31merror[39m: node-red.0 19 Nov 16:56:03 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:56:03.623  - [31merror[39m: node-red.0 19 Nov 16:56:03 - [error] Error: port in use
    2018-11-19 16:56:03.654  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:03.995  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:08.654  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:09.472  - [33mwarn[39m: node-red.0 19 Nov 16:56:09 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:56:09.746  - [31merror[39m: node-red.0 19 Nov 16:56:09 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:56:09.765  - [31merror[39m: node-red.0 19 Nov 16:56:09 - [error] Error: port in use
    2018-11-19 16:56:09.876  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:14.882  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:15.309  - [33mwarn[39m: node-red.0 19 Nov 16:56:15 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:56:15.508  - [31merror[39m: node-red.0 19 Nov 16:56:15 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:56:15.513  - [31merror[39m: node-red.0 19 Nov 16:56:15 - [error] Error: port in use
    2018-11-19 16:56:15.557  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:19.003  - [33mwarn[39m: node-red.0 19 Nov 16:56:19 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:56:19.204  - [31merror[39m: node-red.0 19 Nov 16:56:19 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:56:19.208  - [31merror[39m: node-red.0 19 Nov 16:56:19 - [error] Error: port in use
    2018-11-19 16:56:19.265  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:20.559  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:24.161  - [33mwarn[39m: node-red.0 19 Nov 16:56:24 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:56:24.268  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:24.351  - [31merror[39m: node-red.0 19 Nov 16:56:24 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:56:24.355  - [31merror[39m: node-red.0 19 Nov 16:56:24 - [error] Error: port in use
    2018-11-19 16:56:24.465  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:29.466  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:29.531  - [33mwarn[39m: node-red.0 19 Nov 16:56:29 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:56:29.801  - [31merror[39m: node-red.0 19 Nov 16:56:29 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:56:29.805  - [31merror[39m: node-red.0 19 Nov 16:56:29 - [error] Error: port in use
    2018-11-19 16:56:29.865  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:34.866  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:36.257  - [33mwarn[39m: node-red.0 19 Nov 16:56:36 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:56:36.508  - [31merror[39m: node-red.0 19 Nov 16:56:36 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:56:36.513  - [31merror[39m: node-red.0 19 Nov 16:56:36 - [error] Error: port in use
    2018-11-19 16:56:36.561  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:37.915  - [32minfo[39m: host.raspberrypi object change system.adapter.node-red.0
    2018-11-19 16:56:37.916  - [32minfo[39m: host.raspberrypi "system.adapter.node-red.0" disabled
    2018-11-19 16:56:37.916  - [32minfo[39m: host.raspberrypi stopInstance system.adapter.node-red.0
    2018-11-19 16:56:37.936  - [32minfo[39m: node-red.0 Adapter is disabled => stop
    2018-11-19 16:56:38.923  - [32minfo[39m: host.raspberrypi stopInstance timeout "1000 system.adapter.node-red.0 killing pid  3154
    2018-11-19 16:56:38.940  - [32minfo[39m: node-red.0 terminating
    2018-11-19 16:56:38.986  - [32minfo[39m: node-red.0 terminating
    2018-11-19 16:56:39.003  - [32minfo[39m: host.raspberrypi instance system.adapter.node-red.0 terminated with code 0 (OK)[/code]`
    Weiß jemand was es damit auf sich hat?
    • wendy2702W Online
      wendy2702W Online
      wendy2702
      Mal geschaut was den PORT belegt?
      2018-11-19 16:45:35.478  - [31merror[39m: node-red.0 19 Nov 16:45:35 - [error] Unable to listen on http://127.0.0.1:1880/
      2018-11-19 16:45:35.480  - [31merror[39m: node-red.0 19 Nov 16:45:35 - [error] Error: port in use
        Torsten_MG
        @wendy2702:
        Da habe ich doch glatt nochmal 2 Fragen:
        1. 127.0.0.1 ist localhost, ist das richtig? iob und node-red sind auf dem selben pi
        2. Wie kriege ich raus, was noch den PORT 1880 belegt?
        • wendy2702W Online
          wendy2702W Online
          wendy2702
          localhost ist der eigene Rechner.
          NodeRed stoppen
          Schauen ob kein weiterer NodeRed prozeß läuft:
          ps -ef |grep node
          ````–> Denke der Prozeß heißt irgendwas mit "Node"
          Wenn weiterer Prozeß läuft diesen "killen" oder Rechner neu starten.
          Wenn kein weiterer Prozeß läuft nach belegten Ports schauen:
          netstat -an |grep LISTEN
          und
          netstat -l
          oder direkt so:
          netstat -tanp | grep 1880
            Torsten_MG
            @wendy2702:
            NodeRed stoppen
            ps -ef |grep node
            /opt/iobroker$ ps -ef |grep node
            root 3867 1 17 16:56 ? 00:22:55 node-red
            root 9877 29609 0 19:06 ? 00:00:00 /bin/sh -c ps -ef |grep node
            root 9879 9877 0 19:06 ? 00:00:00 grep node
            /opt/iobroker$
              ` > Wenn kein weiterer Prozeß läuft nach belegten Ports schauen:
            und
            netstat -l
            oder direkt so:
            /opt/iobroker$ netstate -an |grep LISTEN
            /bin/sh: 1: netstate: not found
            /opt/iobroker$
            ^C
            /opt/iobroker$ netstate -tanp | grep 1880
            /opt/iobroker$ netstate -tanp |grep 1880
            /opt/iobroker$
            Mir sagt das jetzt nichts, bin da leider zu unerfahren auf diesem Gebiet
            • wendy2702W Online
              wendy2702W Online
              wendy2702
              Du hast ein „e“ Zuviel hinter````
              netstat
              Und NodeRed läuft noch oder es gibt einen hängenden Prozess
                Torsten_MG
                @wendy2702:
                netstat
                Gesendet von iPhone mit Tapatalk Pro `
                neuer Versuch :D
                /opt/iobroker$ netstat -an |grep LISTEN
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN
                tcp6       0      0 :::8081                 :::*                    LISTEN
                tcp6       0      0 :::8082                 :::*                    LISTEN
                tcp6       0      0 :::22                   :::*                    LISTEN
                tcp6       0      0 :::8088                 :::*                    LISTEN
                tcp6       0      0 :::1883                 :::*                    LISTEN
                /opt/iobroker$ netstat -tanp |grep 1880
                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      3867/node-red
                /opt/iobroker$
                • wendy2702W Online
                  wendy2702W Online
                  wendy2702
                  Also wenn du den NodeRed Adapter wirklich gestoppt hast… dann läuft da noch ein Prozeß.
                  Also entweder den Prozeß "killen" –>kill 9879–> solltest du dich dafür entscheiden danach nochmal mit````
                  ps -ef |grep node
                  Oder den iobroker Rechner komplett neu starten.
                    Torsten_MG
                    @wendy2702:
                    ps -ef |grep node
                    Oder den iobroker Rechner komplett neu starten. `
                    Wie kommst du auf````
                    kill 9879
                    So sieht die Instanz aus
                     ![9214_node10.jpg](/assets/uploads/files/9214_node10.jpg)
                    • wendy2702W Online
                      wendy2702W Online
                      wendy2702
                      @Torsten_MG:
                      Wie kommst du aufkill 9879die Zahl 9879? `
                      Sorry, mein Fehler.
                      Richtig ist 3867 und das ist die Prozeß ID.
                      Sieht man bei Abfrage der Prozesse.
                        Torsten_MG
                        Sieht jetzt so aus:
                        /opt/iobroker$ kill 3867
                        root     13629 29609  0 20:24 ?        00:00:00 /bin/sh -c ps -ef |grep node
                        root     13631 13629  0 20:24 ?        00:00:00 grep node
                        /opt/iobroker$
                        • wendy2702W Online
                          wendy2702W Online
                          wendy2702
                          Jetzt NodeRed Instanz wieder starten und ins log schauen ob die Meldungen weg sind.
                            Torsten_MG
                            @wendy2702:
                            Jetzt NodeRed Instanz wieder starten und ins log schauen ob die Meldungen weg sind. `
                            Bis jetzt kommen nur diese Meldungen
                            node-red.0	2018-11-19 20:38:45.969	warn	19 Nov 20:38:45 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
                            node-red.0	2018-11-19 20:38:31.027	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                            node-red.0	2018-11-19 20:38:29.302	info	starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v8.11.4
                            • wendy2702W Online
                              wendy2702W Online
                              wendy2702
                              Und NodeRed ist grün?
                                Torsten_MG
                                @wendy2702:
                                Gesendet von iPhone mit Tapatalk Pro ` Ja ist grün
                                Gesendet von Unterwegs mit Tapatalk
                                • wendy2702W Online
                                  wendy2702W Online
                                  wendy2702
                                  Dann sollte dein Problem gelöst sein.
                                  Bitte noch den Betreff vom ersten Post um ein````
                                  Gelöst:
                                    Torsten_MG
                                    Vielen Dank für die Hilfe!
