  4. [gelöst]Problem mit Node-Red
17 Beiträge 2 Kommentatoren 1.1k Aufrufe
    Torsten_MG
    mir ist eben aufgefallen, dass ich über den Tag öfter viele Meldungen von Node-Red im log habe:
    `2018-11-19 16:45:15.284  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:15.680  - [33mwarn[39m: node-red.0 19 Nov 16:45:15 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:15.969  - [31merror[39m: node-red.0 19 Nov 16:45:15 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:15.971  - [31merror[39m: node-red.0 19 Nov 16:45:15 - [error] Error: port in use
    2018-11-19 16:45:16.028  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:21.029  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:24.509  - [33mwarn[39m: node-red.0 19 Nov 16:45:24 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:24.622  - [31merror[39m: node-red.0 19 Nov 16:45:24 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:24.623  - [31merror[39m: node-red.0 19 Nov 16:45:24 - [error] Error: port in use
    2018-11-19 16:45:24.676  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:28.141  - [33mwarn[39m: node-red.0 19 Nov 16:45:28 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:28.247  - [31merror[39m: node-red.0 19 Nov 16:45:28 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:28.250  - [31merror[39m: node-red.0 19 Nov 16:45:28 - [error] Error: port in use
    2018-11-19 16:45:28.304  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:29.679  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:33.305  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:35.117  - [33mwarn[39m: node-red.0 19 Nov 16:45:35 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:35.478  - [31merror[39m: node-red.0 19 Nov 16:45:35 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:35.480  - [31merror[39m: node-red.0 19 Nov 16:45:35 - [error] Error: port in use
    2018-11-19 16:45:35.568  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:39.612  - [33mwarn[39m: node-red.0 19 Nov 16:45:39 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:39.712  - [31merror[39m: node-red.0 19 Nov 16:45:39 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:39.714  - [31merror[39m: node-red.0 19 Nov 16:45:39 - [error] Error: port in use
    2018-11-19 16:45:39.759  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:40.569  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:41.814  - [34mdebug[39m: daswetter.0 nothing to do
    2018-11-19 16:45:41.852  - [32minfo[39m: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (OK)
    2018-11-19 16:45:44.759  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:47.192  - [33mwarn[39m: node-red.0 19 Nov 16:45:47 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:47.491  - [31merror[39m: node-red.0 19 Nov 16:45:47 - [error] Unable to listen on http://127.0.0.1:1880/
    19 Nov 16:45:47 - [error] Error: port in use
    2018-11-19 16:45:47.543  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:49.979  - [33mwarn[39m: node-red.0 19 Nov 16:45:49 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:50.162  - [31merror[39m: node-red.0 19 Nov 16:45:50 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:50.163  - [31merror[39m: node-red.0 19 Nov 16:45:50 - [error] Error: port in use
    2018-11-19 16:45:50.202  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:52.545  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:55.204  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:45:55.516  - [33mwarn[39m: node-red.0 19 Nov 16:45:55 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:55.708  - [31merror[39m: node-red.0 19 Nov 16:45:55 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:55.711  - [31merror[39m: node-red.0 19 Nov 16:45:55 - [error] Error: port in use
    2018-11-19 16:45:55.745  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:45:58.521  - [33mwarn[39m: node-red.0 19 Nov 16:45:58 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:45:58.699  - [31merror[39m: node-red.0 19 Nov 16:45:58 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:45:58.700  - [31merror[39m: node-red.0 19 Nov 16:45:58 - [error] Error: port in use
    2018-11-19 16:45:58.733  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:00.746  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:03.735  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:06.002  - [33mwarn[39m: node-red.0 19 Nov 16:46:06 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:06.230  - [31merror[39m: node-red.0 19 Nov 16:46:06 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:06.232  - [31merror[39m: node-red.0 19 Nov 16:46:06 - [error] Error: port in use
    2018-11-19 16:46:06.273  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:09.224  - [33mwarn[39m: node-red.0 19 Nov 16:46:09 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:09.311  - [31merror[39m: node-red.0 19 Nov 16:46:09 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:09.314  - [31merror[39m: node-red.0 19 Nov 16:46:09 - [error] Error: port in use
    2018-11-19 16:46:09.346  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:11.275  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:14.347  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:14.789  - [33mwarn[39m: node-red.0 19 Nov 16:46:14 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:15.709  - [31merror[39m: node-red.0 19 Nov 16:46:15 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:15.712  - [31merror[39m: node-red.0 19 Nov 16:46:15 - [error] Error: port in use
    2018-11-19 16:46:15.758  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:17.908  - [33mwarn[39m: node-red.0 19 Nov 16:46:17 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:18.000  - [31merror[39m: node-red.0 19 Nov 16:46:17 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:18.003  - [31merror[39m: node-red.0 19 Nov 16:46:18 - [error] Error: port in use
    2018-11-19 16:46:18.049  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:20.759  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:23.051  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:26.017  - [33mwarn[39m: node-red.0 19 Nov 16:46:26 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:26.256  - [31merror[39m: node-red.0 19 Nov 16:46:26 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:26.257  - [31merror[39m: node-red.0 19 Nov 16:46:26 - [error] Error: port in use
    2018-11-19 16:46:26.311  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:28.974  - [33mwarn[39m: node-red.0 19 Nov 16:46:28 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:29.173  - [31merror[39m: node-red.0 19 Nov 16:46:29 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:29.176  - [31merror[39m: node-red.0 19 Nov 16:46:29 - [error] Error: port in use
    2018-11-19 16:46:29.213  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:31.313  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:34.215  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:35.096  - [33mwarn[39m: node-red.0 19 Nov 16:46:35 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:35.289  - [31merror[39m: node-red.0 19 Nov 16:46:35 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:35.291  - [31merror[39m: node-red.0 19 Nov 16:46:35 - [error] Error: port in use
    2018-11-19 16:46:35.356  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:37.277  - [33mwarn[39m: node-red.0 19 Nov 16:46:37 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:37.479  - [31merror[39m: node-red.0 19 Nov 16:46:37 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:37.480  - [31merror[39m: node-red.0 19 Nov 16:46:37 - [error] Error: port in use
    2018-11-19 16:46:37.518  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:40.358  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:42.519  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:45.668  - [33mwarn[39m: node-red.0 19 Nov 16:46:45 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:45.934  - [31merror[39m: node-red.0 19 Nov 16:46:45 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:45.939  - [31merror[39m: node-red.0 19 Nov 16:46:45 - [error] Error: port in use
    2018-11-19 16:46:46.000  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:48.584  - [33mwarn[39m: node-red.0 19 Nov 16:46:48 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:48.707  - [31merror[39m: node-red.0 19 Nov 16:46:48 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:48.710  - [31merror[39m: node-red.0 19 Nov 16:46:48 - [error] Error: port in use
    2018-11-19 16:46:48.753  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:51.002  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:53.754  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:46:55.181  - [33mwarn[39m: node-red.0 19 Nov 16:46:55 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:55.337  - [31merror[39m: node-red.0 19 Nov 16:46:55 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:55.343  - [31merror[39m: node-red.0 19 Nov 16:46:55 - [error] Error: port in use
    2018-11-19 16:46:55.450  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:46:57.477  - [33mwarn[39m: node-red.0 19 Nov 16:46:57 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:46:57.681  - [31merror[39m: node-red.0 19 Nov 16:46:57 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:46:57.685  - [31merror[39m: node-red.0 19 Nov 16:46:57 - [error] Error: port in use
    2018-11-19 16:46:57.719  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:00.452  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:02.722  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:05.281  - [33mwarn[39m: node-red.0 19 Nov 16:47:05 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:05.511  - [31merror[39m: node-red.0 19 Nov 16:47:05 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:05.514  - [31merror[39m: node-red.0 19 Nov 16:47:05 - [error] Error: port in use
    2018-11-19 16:47:05.558  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:07.984  - [33mwarn[39m: node-red.0 19 Nov 16:47:07 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:08.145  - [31merror[39m: node-red.0 19 Nov 16:47:08 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:08.146  - [31merror[39m: node-red.0 19 Nov 16:47:08 - [error] Error: port in use
    2018-11-19 16:47:08.181  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:10.561  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:13.183  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:14.677  - [33mwarn[39m: node-red.0 19 Nov 16:47:14 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:14.898  - [31merror[39m: node-red.0 19 Nov 16:47:14 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:14.900  - [31merror[39m: node-red.0 19 Nov 16:47:14 - [error] Error: port in use
    2018-11-19 16:47:14.944  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:16.626  - [32minfo[39m: hue.0 final lightState for Philips_hue.Hue_ambiance_spot_1:{"bri":254,"on":true,"level":100}
    2018-11-19 16:47:17.227  - [33mwarn[39m: node-red.0 19 Nov 16:47:17 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:17.297  - [31merror[39m: node-red.0 19 Nov 16:47:17 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:17.299  - [31merror[39m: node-red.0 19 Nov 16:47:17 - [error] Error: port in use
    2018-11-19 16:47:17.330  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:18.976  - [32minfo[39m: hue.0 final lightState for Philips_hue.Hue_ambiance_spot_1:{"bri":0,"on":false,"level":0}
    2018-11-19 16:47:19.946  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:22.331  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:25.204  - [33mwarn[39m: node-red.0 19 Nov 16:47:25 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:25.420  - [31merror[39m: node-red.0 19 Nov 16:47:25 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:25.421  - [31merror[39m: node-red.0 19 Nov 16:47:25 - [error] Error: port in use
    2018-11-19 16:47:25.456  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:27.907  - [32minfo[39m: hue.0 final lightState for Philips_hue.Hue_ambiance_spot_1:{"bri":254,"on":true,"level":100}
    2018-11-19 16:47:28.439  - [33mwarn[39m: node-red.0 19 Nov 16:47:28 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:28.670  - [31merror[39m: node-red.0 19 Nov 16:47:28 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:28.672  - [31merror[39m: node-red.0 19 Nov 16:47:28 - [error] Error: port in use
    2018-11-19 16:47:28.712  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:28.823  - [32minfo[39m: hue.0 final lightState for Philips_hue.Hue_ambiance_spot_1:{"bri":0,"on":false,"level":0}
    2018-11-19 16:47:30.459  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:33.712  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:34.267  - [33mwarn[39m: node-red.0 19 Nov 16:47:34 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:34.455  - [31merror[39m: node-red.0 19 Nov 16:47:34 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:34.456  - [31merror[39m: node-red.0 19 Nov 16:47:34 - [error] Error: port in use
    2018-11-19 16:47:34.493  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:37.306  - [33mwarn[39m: node-red.0 19 Nov 16:47:37 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:37.403  - [31merror[39m: node-red.0 19 Nov 16:47:37 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:37.406  - [31merror[39m: node-red.0 19 Nov 16:47:37 - [error] Error: port in use
    2018-11-19 16:47:37.447  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:39.495  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:42.448  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:44.518  - [33mwarn[39m: node-red.0 19 Nov 16:47:44 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:44.753  - [31merror[39m: node-red.0 19 Nov 16:47:44 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:44.754  - [31merror[39m: node-red.0 19 Nov 16:47:44 - [error] Error: port in use
    2018-11-19 16:47:44.800  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:47.569  - [33mwarn[39m: node-red.0 19 Nov 16:47:47 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:47.757  - [31merror[39m: node-red.0 19 Nov 16:47:47 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:47.759  - [31merror[39m: node-red.0 19 Nov 16:47:47 - [error] Error: port in use
    2018-11-19 16:47:47.800  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:49.800  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:52.801  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:47:53.829  - [33mwarn[39m: node-red.0 19 Nov 16:47:53 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:54.094  - [31merror[39m: node-red.0 19 Nov 16:47:54 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:54.100  - [31merror[39m: node-red.0 19 Nov 16:47:54 - [error] Error: port in use
    2018-11-19 16:47:54.142  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:56.869  - [33mwarn[39m: node-red.0 19 Nov 16:47:56 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:47:57.071  - [31merror[39m: node-red.0 19 Nov 16:47:57 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:47:57.074  - [31merror[39m: node-red.0 19 Nov 16:47:57 - [error] Error: port in use
    2018-11-19 16:47:57.106  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:47:59.143  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:02.108  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:04.133  - [33mwarn[39m: node-red.0 19 Nov 16:48:04 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    19 Nov 16:48:04 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:04.438  - [31merror[39m: node-red.0 19 Nov 16:48:04 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:04.439  - [31merror[39m: node-red.0 19 Nov 16:48:04 - [error] Error: port in use
    2018-11-19 16:48:04.498  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:07.553  - [33mwarn[39m: node-red.0 19 Nov 16:48:07 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:07.784  - [31merror[39m: node-red.0 19 Nov 16:48:07 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:07.787  - [31merror[39m: node-red.0 19 Nov 16:48:07 - [error] Error: port in use
    2018-11-19 16:48:07.825  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:09.500  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:12.826  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:13.218  - [33mwarn[39m: node-red.0 19 Nov 16:48:13 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:13.396  - [31merror[39m: node-red.0 19 Nov 16:48:13 - [error] Unable to listen on http://127.0.0.1:1880/
    19 Nov 16:48:13 - [error] Error: port in use
    2018-11-19 16:48:13.460  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:16.436  - [33mwarn[39m: node-red.0 19 Nov 16:48:16 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:16.619  - [31merror[39m: node-red.0 19 Nov 16:48:16 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:16.620  - [31merror[39m: node-red.0 19 Nov 16:48:16 - [error] Error: port in use
    2018-11-19 16:48:16.657  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:18.462  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:21.659  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:23.125  - [33mwarn[39m: node-red.0 19 Nov 16:48:23 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:23.401  - [31merror[39m: node-red.0 19 Nov 16:48:23 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:23.402  - [31merror[39m: node-red.0 19 Nov 16:48:23 - [error] Error: port in use
    2018-11-19 16:48:23.452  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:26.944  - [33mwarn[39m: node-red.0 19 Nov 16:48:26 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:27.140  - [31merror[39m: node-red.0 19 Nov 16:48:27 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:27.141  - [31merror[39m: node-red.0 19 Nov 16:48:27 - [error] Error: port in use
    2018-11-19 16:48:27.183  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:28.455  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:32.185  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:33.014  - [33mwarn[39m: node-red.0 19 Nov 16:48:33 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:33.226  - [31merror[39m: node-red.0 19 Nov 16:48:33 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:33.229  - [31merror[39m: node-red.0 19 Nov 16:48:33 - [error] Error: port in use
    2018-11-19 16:48:33.295  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:36.362  - [33mwarn[39m: node-red.0 19 Nov 16:48:36 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:36.568  - [31merror[39m: node-red.0 19 Nov 16:48:36 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:36.570  - [31merror[39m: node-red.0 19 Nov 16:48:36 - [error] Error: port in use
    2018-11-19 16:48:36.604  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:38.297  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:41.605  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:42.678  - [33mwarn[39m: node-red.0 19 Nov 16:48:42 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:42.898  - [31merror[39m: node-red.0 19 Nov 16:48:42 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:42.899  - [31merror[39m: node-red.0 19 Nov 16:48:42 - [error] Error: port in use
    2018-11-19 16:48:42.935  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:46.247  - [33mwarn[39m: node-red.0 19 Nov 16:48:46 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:46.411  - [31merror[39m: node-red.0 19 Nov 16:48:46 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:46.413  - [31merror[39m: node-red.0 19 Nov 16:48:46 - [error] Error: port in use
    2018-11-19 16:48:46.459  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:47.937  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:51.460  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:48:51.567  - [33mwarn[39m: node-red.0 19 Nov 16:48:51 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:51.731  - [31merror[39m: node-red.0 19 Nov 16:48:51 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:51.733  - [31merror[39m: node-red.0 19 Nov 16:48:51 - [error] Error: port in use
    2018-11-19 16:48:51.781  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:55.368  - [33mwarn[39m: node-red.0 19 Nov 16:48:55 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    19 Nov 16:48:55 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:48:55.549  - [31merror[39m: node-red.0 19 Nov 16:48:55 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:48:55.551  - [31merror[39m: node-red.0 19 Nov 16:48:55 - [error] Error: port in use
    2018-11-19 16:48:55.591  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:48:56.782  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:00.592  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:01.937  - [33mwarn[39m: node-red.0 19 Nov 16:49:01 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:02.152  - [31merror[39m: node-red.0 19 Nov 16:49:02 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:02.154  - [31merror[39m: node-red.0 19 Nov 16:49:02 - [error] Error: port in use
    2018-11-19 16:49:02.195  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:05.710  - [33mwarn[39m: node-red.0 19 Nov 16:49:05 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:05.915  - [31merror[39m: node-red.0 19 Nov 16:49:05 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:05.917  - [31merror[39m: node-red.0 19 Nov 16:49:05 - [error] Error: port in use
    2018-11-19 16:49:05.954  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:07.197  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:10.955  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:11.447  - [33mwarn[39m: node-red.0 19 Nov 16:49:11 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:11.627  - [31merror[39m: node-red.0 19 Nov 16:49:11 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:11.628  - [31merror[39m: node-red.0 19 Nov 16:49:11 - [error] Error: port in use
    2018-11-19 16:49:11.669  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:14.851  - [33mwarn[39m: node-red.0 19 Nov 16:49:14 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:15.014  - [31merror[39m: node-red.0 19 Nov 16:49:15 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:15.015  - [31merror[39m: node-red.0 19 Nov 16:49:15 - [error] Error: port in use
    2018-11-19 16:49:15.047  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:16.672  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:20.048  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:21.451  - [33mwarn[39m: node-red.0 19 Nov 16:49:21 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:21.532  - [31merror[39m: node-red.0 19 Nov 16:49:21 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:21.533  - [31merror[39m: node-red.0 19 Nov 16:49:21 - [error] Error: port in use
    2018-11-19 16:49:21.570  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:25.133  - [33mwarn[39m: node-red.0 19 Nov 16:49:25 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:25.349  - [31merror[39m: node-red.0 19 Nov 16:49:25 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:25.350  - [31merror[39m: node-red.0 19 Nov 16:49:25 - [error] Error: port in use
    2018-11-19 16:49:25.384  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:26.572  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:30.386  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:30.983  - [33mwarn[39m: node-red.0 19 Nov 16:49:30 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:31.064  - [31merror[39m: node-red.0 19 Nov 16:49:31 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:31.065  - [31merror[39m: node-red.0 19 Nov 16:49:31 - [error] Error: port in use
    2018-11-19 16:49:31.106  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:34.400  - [33mwarn[39m: node-red.0 19 Nov 16:49:34 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:34.481  - [31merror[39m: node-red.0 19 Nov 16:49:34 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:34.482  - [31merror[39m: node-red.0 19 Nov 16:49:34 - [error] Error: port in use
    2018-11-19 16:49:34.515  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:36.107  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:39.517  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:41.089  - [33mwarn[39m: node-red.0 19 Nov 16:49:41 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:41.296  - [31merror[39m: node-red.0 19 Nov 16:49:41 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:41.297  - [31merror[39m: node-red.0 19 Nov 16:49:41 - [error] Error: port in use
    2018-11-19 16:49:41.346  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:44.940  - [33mwarn[39m: node-red.0 19 Nov 16:49:44 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:45.118  - [31merror[39m: node-red.0 19 Nov 16:49:45 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:45.120  - [31merror[39m: node-red.0 19 Nov 16:49:45 - [error] Error: port in use
    2018-11-19 16:49:45.154  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:46.348  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:50.154  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:50.766  - [33mwarn[39m: node-red.0 19 Nov 16:49:50 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:51.038  - [31merror[39m: node-red.0 19 Nov 16:49:51 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:51.039  - [31merror[39m: node-red.0 19 Nov 16:49:51 - [error] Error: port in use
    2018-11-19 16:49:51.078  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:54.065  - [33mwarn[39m: node-red.0 19 Nov 16:49:54 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:54.246  - [31merror[39m: node-red.0 19 Nov 16:49:54 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:54.249  - [31merror[39m: node-red.0 19 Nov 16:49:54 - [error] Error: port in use
    2018-11-19 16:49:54.292  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:49:56.080  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:59.293  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:49:59.695  - [33mwarn[39m: node-red.0 19 Nov 16:49:59 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:49:59.882  - [31merror[39m: node-red.0 19 Nov 16:49:59 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:49:59.884  - [31merror[39m: node-red.0 19 Nov 16:49:59 - [error] Error: port in use
    2018-11-19 16:49:59.926  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:03.666  - [33mwarn[39m: node-red.0 19 Nov 16:50:03 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:03.827  - [31merror[39m: node-red.0 19 Nov 16:50:03 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:03.828  - [31merror[39m: node-red.0 19 Nov 16:50:03 - [error] Error: port in use
    2018-11-19 16:50:03.864  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:04.927  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:08.865  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:10.593  - [33mwarn[39m: node-red.0 19 Nov 16:50:10 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:10.856  - [31merror[39m: node-red.0 19 Nov 16:50:10 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:10.858  - [31merror[39m: node-red.0 19 Nov 16:50:10 - [error] Error: port in use
    2018-11-19 16:50:10.900  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:14.029  - [33mwarn[39m: node-red.0 19 Nov 16:50:14 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:14.241  - [31merror[39m: node-red.0 19 Nov 16:50:14 - [error] Unable to listen on http://127.0.0.1:1880/
    19 Nov 16:50:14 - [error] Error: port in use
    2018-11-19 16:50:14.296  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:15.902  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:19.297  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:19.782  - [33mwarn[39m: node-red.0 19 Nov 16:50:19 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:19.868  - [31merror[39m: node-red.0 19 Nov 16:50:19 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:19.870  - [31merror[39m: node-red.0 19 Nov 16:50:19 - [error] Error: port in use
    2018-11-19 16:50:19.957  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:23.220  - [33mwarn[39m: node-red.0 19 Nov 16:50:23 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:23.410  - [31merror[39m: node-red.0 19 Nov 16:50:23 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:23.411  - [31merror[39m: node-red.0 19 Nov 16:50:23 - [error] Error: port in use
    2018-11-19 16:50:23.444  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:24.958  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:28.444  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:29.527  - [33mwarn[39m: node-red.0 19 Nov 16:50:29 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:29.710  - [31merror[39m: node-red.0 19 Nov 16:50:29 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:29.712  - [31merror[39m: node-red.0 19 Nov 16:50:29 - [error] Error: port in use
    2018-11-19 16:50:29.750  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:33.365  - [33mwarn[39m: node-red.0 19 Nov 16:50:33 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:33.540  - [31merror[39m: node-red.0 19 Nov 16:50:33 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:33.542  - [31merror[39m: node-red.0 19 Nov 16:50:33 - [error] Error: port in use
    2018-11-19 16:50:33.579  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:34.751  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:38.580  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:39.361  - [33mwarn[39m: node-red.0 19 Nov 16:50:39 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:39.471  - [31merror[39m: node-red.0 19 Nov 16:50:39 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:39.473  - [31merror[39m: node-red.0 19 Nov 16:50:39 - [error] Error: port in use
    2018-11-19 16:50:39.521  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:42.591  - [33mwarn[39m: node-red.0 19 Nov 16:50:42 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:42.790  - [31merror[39m: node-red.0 19 Nov 16:50:42 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:42.791  - [31merror[39m: node-red.0 19 Nov 16:50:42 - [error] Error: port in use
    2018-11-19 16:50:42.830  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:44.523  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:47.833  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:49.474  - [33mwarn[39m: node-red.0 19 Nov 16:50:49 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:49.661  - [31merror[39m: node-red.0 19 Nov 16:50:49 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:49.663  - [31merror[39m: node-red.0 19 Nov 16:50:49 - [error] Error: port in use
    2018-11-19 16:50:49.715  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:52.794  - [33mwarn[39m: node-red.0 19 Nov 16:50:52 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:52.997  - [31merror[39m: node-red.0 19 Nov 16:50:52 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:52.999  - [31merror[39m: node-red.0 19 Nov 16:50:52 - [error] Error: port in use
    2018-11-19 16:50:53.038  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:50:54.715  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:58.038  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:50:58.582  - [33mwarn[39m: node-red.0 19 Nov 16:50:58 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:50:58.811  - [31merror[39m: node-red.0 19 Nov 16:50:58 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:50:58.813  - [31merror[39m: node-red.0 19 Nov 16:50:58 - [error] Error: port in use
    2018-11-19 16:50:58.856  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:02.008  - [33mwarn[39m: node-red.0 19 Nov 16:51:02 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:02.173  - [31merror[39m: node-red.0 19 Nov 16:51:02 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:02.175  - [31merror[39m: node-red.0 19 Nov 16:51:02 - [error] Error: port in use
    2018-11-19 16:51:02.211  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:03.858  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:07.212  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:08.084  - [33mwarn[39m: node-red.0 19 Nov 16:51:08 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:08.309  - [31merror[39m: node-red.0 19 Nov 16:51:08 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:08.310  - [31merror[39m: node-red.0 19 Nov 16:51:08 - [error] Error: port in use
    2018-11-19 16:51:08.354  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:11.684  - [33mwarn[39m: node-red.0 19 Nov 16:51:11 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:11.863  - [31merror[39m: node-red.0 19 Nov 16:51:11 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:11.865  - [31merror[39m: node-red.0 19 Nov 16:51:11 - [error] Error: port in use
    2018-11-19 16:51:11.910  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:13.356  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:16.912  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:18.037  - [33mwarn[39m: node-red.0 19 Nov 16:51:18 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:18.224  - [31merror[39m: node-red.0 19 Nov 16:51:18 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:18.225  - [31merror[39m: node-red.0 19 Nov 16:51:18 - [error] Error: port in use
    2018-11-19 16:51:18.266  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:22.282  - [33mwarn[39m: node-red.0 19 Nov 16:51:22 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:22.363  - [31merror[39m: node-red.0 19 Nov 16:51:22 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:22.366  - [31merror[39m: node-red.0 19 Nov 16:51:22 - [error] Error: port in use
    2018-11-19 16:51:22.434  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:23.271  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:27.434  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:27.994  - [33mwarn[39m: node-red.0 19 Nov 16:51:27 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:28.187  - [31merror[39m: node-red.0 19 Nov 16:51:28 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:28.188  - [31merror[39m: node-red.0 19 Nov 16:51:28 - [error] Error: port in use
    2018-11-19 16:51:28.245  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:31.714  - [33mwarn[39m: node-red.0 19 Nov 16:51:31 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:31.889  - [31merror[39m: node-red.0 19 Nov 16:51:31 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:31.890  - [31merror[39m: node-red.0 19 Nov 16:51:31 - [error] Error: port in use
    2018-11-19 16:51:31.923  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:33.248  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:36.924  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:37.067  - [33mwarn[39m: node-red.0 19 Nov 16:51:37 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:37.241  - [31merror[39m: node-red.0 19 Nov 16:51:37 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:37.244  - [31merror[39m: node-red.0 19 Nov 16:51:37 - [error] Error: port in use
    2018-11-19 16:51:37.279  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:40.765  - [33mwarn[39m: node-red.0 19 Nov 16:51:40 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:40.957  - [31merror[39m: node-red.0 19 Nov 16:51:40 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:40.958  - [31merror[39m: node-red.0 19 Nov 16:51:40 - [error] Error: port in use
    2018-11-19 16:51:40.993  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:42.282  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:45.994  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:47.339  - [33mwarn[39m: node-red.0 19 Nov 16:51:47 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    19 Nov 16:51:47 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:47.424  - [31merror[39m: node-red.0 19 Nov 16:51:47 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:47.425  - [31merror[39m: node-red.0 19 Nov 16:51:47 - [error] Error: port in use
    2018-11-19 16:51:47.468  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:50.677  - [33mwarn[39m: node-red.0 19 Nov 16:51:50 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:50.784  - [31merror[39m: node-red.0 19 Nov 16:51:50 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:50.785  - [31merror[39m: node-red.0 19 Nov 16:51:50 - [error] Error: port in use
    2018-11-19 16:51:50.836  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:51:52.469  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:55.838  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:51:56.899  - [33mwarn[39m: node-red.0 19 Nov 16:51:56 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:51:56.987  - [31merror[39m: node-red.0 19 Nov 16:51:56 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:51:56.989  - [31merror[39m: node-red.0 19 Nov 16:51:56 - [error] Error: port in use
    2018-11-19 16:51:57.029  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:00.237  - [33mwarn[39m: node-red.0 19 Nov 16:52:00 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:00.401  - [31merror[39m: node-red.0 19 Nov 16:52:00 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:00.404  - [31merror[39m: node-red.0 19 Nov 16:52:00 - [error] Error: port in use
    2018-11-19 16:52:00.473  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:02.029  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:05.474  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:06.871  - [33mwarn[39m: node-red.0 19 Nov 16:52:06 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:07.121  - [31merror[39m: node-red.0 19 Nov 16:52:07 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:07.124  - [31merror[39m: node-red.0 19 Nov 16:52:07 - [error] Error: port in use
    2018-11-19 16:52:07.179  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:10.079  - [33mwarn[39m: node-red.0 19 Nov 16:52:10 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:10.159  - [31merror[39m: node-red.0 19 Nov 16:52:10 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:10.161  - [31merror[39m: node-red.0 19 Nov 16:52:10 - [error] Error: port in use
    2018-11-19 16:52:10.196  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:12.181  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:15.197  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:15.989  - [33mwarn[39m: node-red.0 19 Nov 16:52:15 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:16.171  - [31merror[39m: node-red.0 19 Nov 16:52:16 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:16.172  - [31merror[39m: node-red.0 19 Nov 16:52:16 - [error] Error: port in use
    2018-11-19 16:52:16.208  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:20.191  - [33mwarn[39m: node-red.0 19 Nov 16:52:20 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:20.402  - [31merror[39m: node-red.0 19 Nov 16:52:20 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:20.404  - [31merror[39m: node-red.0 19 Nov 16:52:20 - [error] Error: port in use
    2018-11-19 16:52:20.441  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:21.210  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:25.443  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:27.142  - [33mwarn[39m: node-red.0 19 Nov 16:52:27 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:27.420  - [31merror[39m: node-red.0 19 Nov 16:52:27 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:27.422  - [31merror[39m: node-red.0 19 Nov 16:52:27 - [error] Error: port in use
    2018-11-19 16:52:27.508  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:30.508  - [33mwarn[39m: node-red.0 19 Nov 16:52:30 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:30.585  - [31merror[39m: node-red.0 19 Nov 16:52:30 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:30.587  - [31merror[39m: node-red.0 19 Nov 16:52:30 - [error] Error: port in use
    2018-11-19 16:52:30.629  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:32.509  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:35.630  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:35.831  - [33mwarn[39m: node-red.0 19 Nov 16:52:35 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:36.030  - [31merror[39m: node-red.0 19 Nov 16:52:36 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:36.032  - [31merror[39m: node-red.0 19 Nov 16:52:36 - [error] Error: port in use
    2018-11-19 16:52:36.069  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:39.771  - [33mwarn[39m: node-red.0 19 Nov 16:52:39 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:39.934  - [31merror[39m: node-red.0 19 Nov 16:52:39 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:39.936  - [31merror[39m: node-red.0 19 Nov 16:52:39 - [error] Error: port in use
    2018-11-19 16:52:39.968  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:41.070  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:44.970  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:46.348  - [33mwarn[39m: node-red.0 19 Nov 16:52:46 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:46.529  - [31merror[39m: node-red.0 19 Nov 16:52:46 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:46.532  - [31merror[39m: node-red.0 19 Nov 16:52:46 - [error] Error: port in use
    2018-11-19 16:52:46.572  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:50.003  - [33mwarn[39m: node-red.0 19 Nov 16:52:50 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    19 Nov 16:52:50 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:50.091  - [31merror[39m: node-red.0 19 Nov 16:52:50 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:50.093  - [31merror[39m: node-red.0 19 Nov 16:52:50 - [error] Error: port in use
    2018-11-19 16:52:50.131  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:51.575  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:55.132  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:52:55.510  - [33mwarn[39m: node-red.0 19 Nov 16:52:55 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:55.693  - [31merror[39m: node-red.0 19 Nov 16:52:55 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:55.694  - [31merror[39m: node-red.0 19 Nov 16:52:55 - [error] Error: port in use
    2018-11-19 16:52:55.731  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:52:58.959  - [33mwarn[39m: node-red.0 19 Nov 16:52:58 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:52:59.122  - [31merror[39m: node-red.0 19 Nov 16:52:59 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:52:59.125  - [31merror[39m: node-red.0 19 Nov 16:52:59 - [error] Error: port in use
    2018-11-19 16:52:59.157  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:00.732  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:04.159  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:06.223  - [33mwarn[39m: node-red.0 19 Nov 16:53:06 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:06.429  - [31merror[39m: node-red.0 19 Nov 16:53:06 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:06.431  - [31merror[39m: node-red.0 19 Nov 16:53:06 - [error] Error: port in use
    2018-11-19 16:53:06.481  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:09.903  - [33mwarn[39m: node-red.0 19 Nov 16:53:09 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:10.091  - [31merror[39m: node-red.0 19 Nov 16:53:10 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:10.093  - [31merror[39m: node-red.0 19 Nov 16:53:10 - [error] Error: port in use
    2018-11-19 16:53:10.149  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:11.482  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:15.100  - [33mwarn[39m: node-red.0 19 Nov 16:53:15 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:15.153  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:15.322  - [31merror[39m: node-red.0 19 Nov 16:53:15 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:15.323  - [31merror[39m: node-red.0 19 Nov 16:53:15 - [error] Error: port in use
    2018-11-19 16:53:15.356  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:18.186  - [33mwarn[39m: node-red.0 19 Nov 16:53:18 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:18.357  - [31merror[39m: node-red.0 19 Nov 16:53:18 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:18.358  - [31merror[39m: node-red.0 19 Nov 16:53:18 - [error] Error: port in use
    2018-11-19 16:53:18.391  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:20.358  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:23.393  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:26.208  - [33mwarn[39m: node-red.0 19 Nov 16:53:26 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:26.445  - [31merror[39m: node-red.0 19 Nov 16:53:26 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:26.448  - [31merror[39m: node-red.0 19 Nov 16:53:26 - [error] Error: port in use
    2018-11-19 16:53:26.491  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:30.149  - [33mwarn[39m: node-red.0 19 Nov 16:53:30 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:30.786  - [31merror[39m: node-red.0 19 Nov 16:53:30 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:30.787  - [31merror[39m: node-red.0 19 Nov 16:53:30 - [error] Error: port in use
    2018-11-19 16:53:30.825  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:31.492  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:35.827  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:35.839  - [33mwarn[39m: node-red.0 19 Nov 16:53:35 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    19 Nov 16:53:35 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:36.048  - [31merror[39m: node-red.0 19 Nov 16:53:36 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:36.051  - [31merror[39m: node-red.0 19 Nov 16:53:36 - [error] Error: port in use
    2018-11-19 16:53:36.101  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:38.072  - [33mwarn[39m: node-red.0 19 Nov 16:53:38 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:38.242  - [31merror[39m: node-red.0 19 Nov 16:53:38 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:38.243  - [31merror[39m: node-red.0 19 Nov 16:53:38 - [error] Error: port in use
    2018-11-19 16:53:38.284  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:41.103  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:43.286  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:45.737  - [33mwarn[39m: node-red.0 19 Nov 16:53:45 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:45.949  - [31merror[39m: node-red.0 19 Nov 16:53:45 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:45.951  - [31merror[39m: node-red.0 19 Nov 16:53:45 - [error] Error: port in use
    2018-11-19 16:53:46.002  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:49.667  - [33mwarn[39m: node-red.0 19 Nov 16:53:49 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:49.852  - [31merror[39m: node-red.0 19 Nov 16:53:49 - [error] Unable to listen on http://127.0.0.1:1880/
    19 Nov 16:53:49 - [error] Error: port in use
    2018-11-19 16:53:49.910  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:51.005  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:54.910  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:53:54.932  - [33mwarn[39m: node-red.0 19 Nov 16:53:54 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:55.009  - [31merror[39m: node-red.0 19 Nov 16:53:55 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:55.010  - [31merror[39m: node-red.0 19 Nov 16:53:55 - [error] Error: port in use
    2018-11-19 16:53:55.061  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:53:57.944  - [33mwarn[39m: node-red.0 19 Nov 16:53:57 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:53:58.140  - [31merror[39m: node-red.0 19 Nov 16:53:58 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:53:58.142  - [31merror[39m: node-red.0 19 Nov 16:53:58 - [error] Error: port in use
    2018-11-19 16:53:58.177  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:00.062  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:03.179  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:05.020  - [33mwarn[39m: node-red.0 19 Nov 16:54:05 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:05.259  - [31merror[39m: node-red.0 19 Nov 16:54:05 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:05.262  - [31merror[39m: node-red.0 19 Nov 16:54:05 - [error] Error: port in use
    2018-11-19 16:54:05.310  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:09.537  - [33mwarn[39m: node-red.0 19 Nov 16:54:09 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:09.734  - [31merror[39m: node-red.0 19 Nov 16:54:09 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:09.736  - [31merror[39m: node-red.0 19 Nov 16:54:09 - [error] Error: port in use
    2018-11-19 16:54:09.770  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:10.312  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:14.771  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:15.153  - [33mwarn[39m: node-red.0 19 Nov 16:54:15 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:15.377  - [31merror[39m: node-red.0 19 Nov 16:54:15 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:15.378  - [31merror[39m: node-red.0 19 Nov 16:54:15 - [error] Error: port in use
    2018-11-19 16:54:15.420  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:18.009  - [33mwarn[39m: node-red.0 19 Nov 16:54:18 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:18.190  - [31merror[39m: node-red.0 19 Nov 16:54:18 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:18.192  - [31merror[39m: node-red.0 19 Nov 16:54:18 - [error] Error: port in use
    2018-11-19 16:54:18.236  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:20.421  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:23.238  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:24.001  - [33mwarn[39m: node-red.0 19 Nov 16:54:24 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:24.259  - [31merror[39m: node-red.0 19 Nov 16:54:24 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:24.262  - [31merror[39m: node-red.0 19 Nov 16:54:24 - [error] Error: port in use
    2018-11-19 16:54:24.306  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:29.308  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:29.343  - [33mwarn[39m: node-red.0 19 Nov 16:54:29 - [info] Context store  : 'default' [module=memory]
    19 Nov 16:54:29 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    19 Nov 16:54:29 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    19 Nov 16:54:29 - [info] Flows file     : /opt/iobroker/iobroker-data/node-red/flows.json
    2018-11-19 16:54:29.566  - [31merror[39m: node-red.0 19 Nov 16:54:29 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:29.569  - [31merror[39m: node-red.0 19 Nov 16:54:29 - [error] Error: port in use
    2018-11-19 16:54:29.633  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:34.636  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:35.002  - [33mwarn[39m: node-red.0 19 Nov 16:54:35 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:35.223  - [31merror[39m: node-red.0 19 Nov 16:54:35 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:35.224  - [31merror[39m: node-red.0 19 Nov 16:54:35 - [error] Error: port in use
    2018-11-19 16:54:35.268  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:38.043  - [33mwarn[39m: node-red.0 19 Nov 16:54:38 - [info] Context store  : 'default' [module=memory]
    19 Nov 16:54:38 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
    19 Nov 16:54:38 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    19 Nov 16:54:38 - [info] Flows file     : /opt/iobroker/iobroker-data/node-red/flows.json
    2018-11-19 16:54:38.276  - [31merror[39m: node-red.0 19 Nov 16:54:38 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:38.278  - [31merror[39m: node-red.0 19 Nov 16:54:38 - [error] Error: port in use
    2018-11-19 16:54:38.311  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:40.269  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:43.313  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:44.127  - [33mwarn[39m: node-red.0 19 Nov 16:54:44 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:44.382  - [31merror[39m: node-red.0 19 Nov 16:54:44 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:44.384  - [31merror[39m: node-red.0 19 Nov 16:54:44 - [error] Error: port in use
    2018-11-19 16:54:44.421  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:48.989  - [33mwarn[39m: node-red.0 19 Nov 16:54:48 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:49.199  - [31merror[39m: node-red.0 19 Nov 16:54:49 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:49.201  - [31merror[39m: node-red.0 19 Nov 16:54:49 - [error] Error: port in use
    2018-11-19 16:54:49.236  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:49.422  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:54.237  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:54:54.471  - [33mwarn[39m: node-red.0 19 Nov 16:54:54 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:54.724  - [31merror[39m: node-red.0 19 Nov 16:54:54 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:54.725  - [31merror[39m: node-red.0 19 Nov 16:54:54 - [error] Error: port in use
    2018-11-19 16:54:54.766  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:57.212  - [33mwarn[39m: node-red.0 19 Nov 16:54:57 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:54:57.394  - [31merror[39m: node-red.0 19 Nov 16:54:57 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:54:57.395  - [31merror[39m: node-red.0 19 Nov 16:54:57 - [error] Error: port in use
    2018-11-19 16:54:57.431  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:54:59.767  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:02.432  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:03.304  - [33mwarn[39m: node-red.0 19 Nov 16:55:03 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:03.540  - [31merror[39m: node-red.0 19 Nov 16:55:03 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:03.541  - [31merror[39m: node-red.0 19 Nov 16:55:03 - [error] Error: port in use
    2018-11-19 16:55:03.600  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:08.243  - [33mwarn[39m: node-red.0 19 Nov 16:55:08 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:08.479  - [31merror[39m: node-red.0 19 Nov 16:55:08 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:08.480  - [31merror[39m: node-red.0 19 Nov 16:55:08 - [error] Error: port in use
    2018-11-19 16:55:08.545  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:08.601  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:13.546  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:14.757  - [33mwarn[39m: node-red.0 19 Nov 16:55:14 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:15.002  - [31merror[39m: node-red.0 19 Nov 16:55:15 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:15.005  - [31merror[39m: node-red.0 19 Nov 16:55:15 - [error] Error: port in use
    2018-11-19 16:55:15.052  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:17.030  - [33mwarn[39m: node-red.0 19 Nov 16:55:17 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:17.296  - [31merror[39m: node-red.0 19 Nov 16:55:17 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:17.300  - [31merror[39m: node-red.0 19 Nov 16:55:17 - [error] Error: port in use
    2018-11-19 16:55:17.352  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:20.054  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:22.353  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:22.964  - [33mwarn[39m: node-red.0 19 Nov 16:55:22 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:23.057  - [31merror[39m: node-red.0 19 Nov 16:55:23 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:23.059  - [31merror[39m: node-red.0 19 Nov 16:55:23 - [error] Error: port in use
    2018-11-19 16:55:23.103  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:27.937  - [33mwarn[39m: node-red.0 19 Nov 16:55:27 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:28.104  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:28.159  - [31merror[39m: node-red.0 19 Nov 16:55:28 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:28.160  - [31merror[39m: node-red.0 19 Nov 16:55:28 - [error] Error: port in use
    2018-11-19 16:55:28.240  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:33.240  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:33.957  - [33mwarn[39m: node-red.0 19 Nov 16:55:33 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:34.244  - [31merror[39m: node-red.0 19 Nov 16:55:34 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:34.247  - [31merror[39m: node-red.0 19 Nov 16:55:34 - [error] Error: port in use
    2018-11-19 16:55:34.328  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:36.384  - [33mwarn[39m: node-red.0 19 Nov 16:55:36 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:36.472  - [31merror[39m: node-red.0 19 Nov 16:55:36 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:36.473  - [31merror[39m: node-red.0 19 Nov 16:55:36 - [error] Error: port in use
    2018-11-19 16:55:36.514  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:39.329  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:41.515  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:42.494  - [33mwarn[39m: node-red.0 19 Nov 16:55:42 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:42.783  - [31merror[39m: node-red.0 19 Nov 16:55:42 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:42.787  - [31merror[39m: node-red.0 19 Nov 16:55:42 - [error] Error: port in use
    2018-11-19 16:55:42.864  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:47.865  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:49.625  - [33mwarn[39m: node-red.0 19 Nov 16:55:49 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:49.853  - [31merror[39m: node-red.0 19 Nov 16:55:49 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:49.857  - [31merror[39m: node-red.0 19 Nov 16:55:49 - [error] Error: port in use
    2018-11-19 16:55:49.970  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:54.971  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:55:55.905  - [33mwarn[39m: node-red.0 19 Nov 16:55:55 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:56.122  - [31merror[39m: node-red.0 19 Nov 16:55:56 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:56.125  - [31merror[39m: node-red.0 19 Nov 16:55:56 - [error] Error: port in use
    2018-11-19 16:55:56.166  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:55:58.750  - [33mwarn[39m: node-red.0 19 Nov 16:55:58 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:55:58.956  - [31merror[39m: node-red.0 19 Nov 16:55:58 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:55:58.957  - [31merror[39m: node-red.0 19 Nov 16:55:58 - [error] Error: port in use
    2018-11-19 16:55:58.994  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:01.167  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:03.461  - [33mwarn[39m: node-red.0 19 Nov 16:56:03 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:56:03.622  - [31merror[39m: node-red.0 19 Nov 16:56:03 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:56:03.623  - [31merror[39m: node-red.0 19 Nov 16:56:03 - [error] Error: port in use
    2018-11-19 16:56:03.654  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:03.995  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:08.654  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:09.472  - [33mwarn[39m: node-red.0 19 Nov 16:56:09 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:56:09.746  - [31merror[39m: node-red.0 19 Nov 16:56:09 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:56:09.765  - [31merror[39m: node-red.0 19 Nov 16:56:09 - [error] Error: port in use
    2018-11-19 16:56:09.876  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:14.882  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:15.309  - [33mwarn[39m: node-red.0 19 Nov 16:56:15 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:56:15.508  - [31merror[39m: node-red.0 19 Nov 16:56:15 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:56:15.513  - [31merror[39m: node-red.0 19 Nov 16:56:15 - [error] Error: port in use
    2018-11-19 16:56:15.557  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:19.003  - [33mwarn[39m: node-red.0 19 Nov 16:56:19 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:56:19.204  - [31merror[39m: node-red.0 19 Nov 16:56:19 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:56:19.208  - [31merror[39m: node-red.0 19 Nov 16:56:19 - [error] Error: port in use
    2018-11-19 16:56:19.265  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:20.559  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:24.161  - [33mwarn[39m: node-red.0 19 Nov 16:56:24 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:56:24.268  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:24.351  - [31merror[39m: node-red.0 19 Nov 16:56:24 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:56:24.355  - [31merror[39m: node-red.0 19 Nov 16:56:24 - [error] Error: port in use
    2018-11-19 16:56:24.465  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:29.466  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:29.531  - [33mwarn[39m: node-red.0 19 Nov 16:56:29 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:56:29.801  - [31merror[39m: node-red.0 19 Nov 16:56:29 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:56:29.805  - [31merror[39m: node-red.0 19 Nov 16:56:29 - [error] Error: port in use
    2018-11-19 16:56:29.865  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:34.866  - [32minfo[39m: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2018-11-19 16:56:36.257  - [33mwarn[39m: node-red.0 19 Nov 16:56:36 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    2018-11-19 16:56:36.508  - [31merror[39m: node-red.0 19 Nov 16:56:36 - [error] Unable to listen on http://127.0.0.1:1880/
    2018-11-19 16:56:36.513  - [31merror[39m: node-red.0 19 Nov 16:56:36 - [error] Error: port in use
    2018-11-19 16:56:36.561  - [32minfo[39m: node-red.0 node-red exited with 1
    2018-11-19 16:56:37.915  - [32minfo[39m: host.raspberrypi object change system.adapter.node-red.0
    2018-11-19 16:56:37.916  - [32minfo[39m: host.raspberrypi "system.adapter.node-red.0" disabled
    2018-11-19 16:56:37.916  - [32minfo[39m: host.raspberrypi stopInstance system.adapter.node-red.0
    2018-11-19 16:56:37.936  - [32minfo[39m: node-red.0 Adapter is disabled => stop
    2018-11-19 16:56:38.923  - [32minfo[39m: host.raspberrypi stopInstance timeout "1000 system.adapter.node-red.0 killing pid  3154
    2018-11-19 16:56:38.940  - [32minfo[39m: node-red.0 terminating
    2018-11-19 16:56:38.986  - [32minfo[39m: node-red.0 terminating
    2018-11-19 16:56:39.003  - [32minfo[39m: host.raspberrypi instance system.adapter.node-red.0 terminated with code 0 (OK)[/code]`
    Weiß jemand was es damit auf sich hat?
    • wendy2702W Offline
      wendy2702W Offline
      Mal geschaut was den PORT belegt?
      2018-11-19 16:45:35.478  - [31merror[39m: node-red.0 19 Nov 16:45:35 - [error] Unable to listen on http://127.0.0.1:1880/
      2018-11-19 16:45:35.480  - [31merror[39m: node-red.0 19 Nov 16:45:35 - [error] Error: port in use
        Torsten_MG
        @wendy2702:
        Da habe ich doch glatt nochmal 2 Fragen:
        1. 127.0.0.1 ist localhost, ist das richtig? iob und node-red sind auf dem selben pi
        2. Wie kriege ich raus, was noch den PORT 1880 belegt?
          wendy2702W Offline
          localhost ist der eigene Rechner.
          NodeRed stoppen
          Schauen ob kein weiterer NodeRed prozeß läuft:
          ps -ef |grep node
          ````–> Denke der Prozeß heißt irgendwas mit "Node"
          Wenn weiterer Prozeß läuft diesen "killen" oder Rechner neu starten.
          Wenn kein weiterer Prozeß läuft nach belegten Ports schauen:
          netstat -an |grep LISTEN
          und
          netstat -l
          oder direkt so:
          netstat -tanp | grep 1880
            Torsten_MG
            @wendy2702:
            NodeRed stoppen
            ps -ef |grep node
            /opt/iobroker$ ps -ef |grep node
            root 3867 1 17 16:56 ? 00:22:55 node-red
            root 9877 29609 0 19:06 ? 00:00:00 /bin/sh -c ps -ef |grep node
            root 9879 9877 0 19:06 ? 00:00:00 grep node
            /opt/iobroker$
              ` > Wenn kein weiterer Prozeß läuft nach belegten Ports schauen:
            und
            netstat -l
            oder direkt so:
            /opt/iobroker$ netstate -an |grep LISTEN
            /bin/sh: 1: netstate: not found
            /opt/iobroker$
            ^C
            /opt/iobroker$ netstate -tanp | grep 1880
            /opt/iobroker$ netstate -tanp |grep 1880
            /opt/iobroker$
            Mir sagt das jetzt nichts, bin da leider zu unerfahren auf diesem Gebiet
              wendy2702W Offline
              Du hast ein „e“ Zuviel hinter````
              netstat
              Und NodeRed läuft noch oder es gibt einen hängenden Prozess
                Torsten_MG
                @wendy2702:
                netstat
                Gesendet von iPhone mit Tapatalk Pro `
                neuer Versuch :D
                /opt/iobroker$ netstat -an |grep LISTEN
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN
                tcp6       0      0 :::8081                 :::*                    LISTEN
                tcp6       0      0 :::8082                 :::*                    LISTEN
                tcp6       0      0 :::22                   :::*                    LISTEN
                tcp6       0      0 :::8088                 :::*                    LISTEN
                tcp6       0      0 :::1883                 :::*                    LISTEN
                /opt/iobroker$ netstat -tanp |grep 1880
                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      3867/node-red
                /opt/iobroker$
                  wendy2702W Offline
                  Also wenn du den NodeRed Adapter wirklich gestoppt hast… dann läuft da noch ein Prozeß.
                  Also entweder den Prozeß "killen" –>kill 9879–> solltest du dich dafür entscheiden danach nochmal mit````
                  ps -ef |grep node
                  Oder den iobroker Rechner komplett neu starten.
                    Torsten_MG
                    @wendy2702:
                    ps -ef |grep node
                    Oder den iobroker Rechner komplett neu starten. `
                    Wie kommst du auf````
                    kill 9879
                    So sieht die Instanz aus
                     ![9214_node10.jpg](/assets/uploads/files/9214_node10.jpg)
                      wendy2702W Offline
                      @Torsten_MG:
                      Wie kommst du aufkill 9879die Zahl 9879? `
                      Sorry, mein Fehler.
                      Richtig ist 3867 und das ist die Prozeß ID.
                      Sieht man bei Abfrage der Prozesse.
                        Torsten_MG
                        Sieht jetzt so aus:
                        /opt/iobroker$ kill 3867
                        root     13629 29609  0 20:24 ?        00:00:00 /bin/sh -c ps -ef |grep node
                        root     13631 13629  0 20:24 ?        00:00:00 grep node
                        /opt/iobroker$
                          wendy2702W Offline
                          Jetzt NodeRed Instanz wieder starten und ins log schauen ob die Meldungen weg sind.
                            Torsten_MG
                            @wendy2702:
                            Jetzt NodeRed Instanz wieder starten und ins log schauen ob die Meldungen weg sind. `
                            Bis jetzt kommen nur diese Meldungen
                            node-red.0	2018-11-19 20:38:45.969	warn	19 Nov 20:38:45 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
                            node-red.0	2018-11-19 20:38:31.027	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                            node-red.0	2018-11-19 20:38:29.302	info	starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v8.11.4
                              wendy2702W Offline
                              Und NodeRed ist grün?
                                Torsten_MG
                                @wendy2702:
                                Gesendet von iPhone mit Tapatalk Pro ` Ja ist grün
                                Gesendet von Unterwegs mit Tapatalk
                                  wendy2702W Offline
                                  Dann sollte dein Problem gelöst sein.
                                  Bitte noch den Betreff vom ersten Post um ein````
                                  Gelöst:
                                    Torsten_MG
                                    Vielen Dank für die Hilfe!
