  4. Ikea tradfri
    6.6k
Ikea tradfri
31 Beiträge 5 Kommentatoren 7.8k Aufrufe
    stephan
    Ich versuche den Ikea Adapter zu installieren leider bekomme ich es nicht hin das er sich verbindet.
    Hat jemand es erfolgreich hinbekommen.
    host.ioBroker-Pi 2018-11-04 16:04:12.360 error instance system.adapter.tradfri.0 terminated with code 1 ()
    Caught 2018-11-04 16:04:12.360 error by controller[0]: at Function.Module._load (module.js:445:3)
    Caught 2018-11-04 16:04:12.360 error by controller[0]: at tryModuleLoad (module.js:453:12)
    Caught 2018-11-04 16:04:12.360 error by controller[0]: at Module.load (module.js:494:32)
    Caught 2018-11-04 16:04:12.360 error by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    Caught 2018-11-04 16:04:12.359 error by controller[0]: at Module._compile (module.js:577:32)
    Caught 2018-11-04 16:04:12.359 error by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-tradfri-client/node_modules/node-coap-client/node_modules/node-dtls-client/node_modules/node
    Caught 2018-11-04 16:04:12.359 error by controller[0]: at require (internal/module.js:20:19)
    Caught 2018-11-04 16:04:12.359 error by controller[0]: at Module.require (module.js:504:17)
    Caught 2018-11-04 16:04:12.359 error by controller[0]: at Function.Module._load (module.js:424:25)
    Caught 2018-11-04 16:04:12.358 error by controller[0]: at Function.Module._resolveFilename (module.js:476:15)
    Caught 2018-11-04 16:04:12.358 error by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-tradfri-client/node_modules/node-coap-client/node_modules/node-dtls-client/node_modules/node
    Caught 2018-11-04 16:04:12.358 error by controller[0]: ^
    Caught 2018-11-04 16:04:12.358 error by controller[0]: throw err;
    Caught 2018-11-04 16:04:12.357 error by controller[0]: module.js:478
    Das sind die Fehler die ich bekomme.
    Wäre für jeden Ratschlag dankbar.</anonymous>
    • apollon77A Offline
      Bitte das log von der Installation des Adapters Posten. Scheinbar ist da was nicht sauber gelaufen. Ggf nochmal neu installieren.
      Gesendet vom Handy …
        stephan
        Also ich habe es bereits 3x neu installiert.
          Dann hast du ja 3 Logs von der Installation die du Posten kannst
            stephan
            wo finde ich die..
              /opt/iobroker/log/…
              Gesendet vom Handy ...
                stephan
                2018-11-04 15:36:30.854 - [32minfo[39m: iobroker NPM version: 2.15.11
                2018-11-04 15:36:31.773 - [32minfo[39m: iobroker npm install iobroker.tradfri@1.4.1 –production --save --prefix "/opt/iobroker" (System call)
                2018-11-04 15:36:42.999 - [32minfo[39m: iobroker npm
                2018-11-04 15:36:43.001 - [32minfo[39m: iobroker WARN engine node-tradfri-client@1.4.3: wanted: {"node":">= 6.0.0"} (current: {"node":"4.8.0","npm":"2.15.11"})
                2018-11-04 15:36:43.736 - [32minfo[39m: iobroker npm
                2018-11-04 15:36:43.738 - [32minfo[39m: iobroker WARN engine node-coap-client@1.0.1: wanted: {"node":">= 6.0.0"} (current: {"node":"4.8.0","npm":"2.15.11"})
                2018-11-04 15:36:44.592 - [32minfo[39m: iobroker npm
                2018-11-04 15:36:44.593 - [32minfo[39m: iobroker
                2018-11-04 15:36:44.595 - [32minfo[39m: iobroker WARN
                2018-11-04 15:36:44.596 - [32minfo[39m: iobroker
                2018-11-04 15:36:44.598 - [32minfo[39m: iobroker engine
                2018-11-04 15:36:44.599 - [32minfo[39m: iobroker node-dtls-client@0.5.6: wanted: {"node":">=6"} (current: {"node":"4.8.0","npm":"2.15.11"})
                2018-11-04 15:36:45.104 - [32minfo[39m: iobroker npm
                2018-11-04 15:36:45.105 - [32minfo[39m: iobroker
                2018-11-04 15:36:45.106 - [32minfo[39m: iobroker WARN
                2018-11-04 15:36:45.108 - [32minfo[39m: iobroker
                2018-11-04 15:36:45.109 - [32minfo[39m: iobroker engine
                2018-11-04 15:36:45.111 - [32minfo[39m: iobroker node-aead-crypto@2.0.0: wanted: {"node":">4 <10"} (current: {"node":"4.8.0","npm":"2.15.11"})
                2018-11-04 15:36:47.619 - [32minfo[39m: host.ioBroker-Pi instance system.adapter.tradfri.0 started with pid 1837
                Meinst Du das.
                  Ja … und jetzt ließ es mal ....
                  Was siehst du?
                  Tip: hat was mit deiner nodejs Version zu tun und dem was der Adapter als minimal Version will
                    stephan
                    richtig habe ich auch bereits gelesen…leider traue ich mich upzudaten da ich dann bestimmt wieder probleme mit einigen anderen Adaptern bekomme.. habe ich bereits gehabt..
                    Was mache ich denn nun..
                      stephan
                      Aber eigentlich ist es doch richtig oder?
                        stephan
                        Ich finde leider den Fehler nicht.
                          RappiRN
                          Node und nodejs sollen (müssen?) gleich sein.
                          Vielleicht kommst du mit dieser Anleitung weiter:
                          http://www.iobroker.net/docu/?page_id=5 … ion_Nodejs
                          Enrico
                            stephan
                            Danke damit habe ich es bereits versucht. wenn ich alles update dann geht der Adapter Tradfri aber meine Adapter Dash Button und Rflink nicht mehr..
                              Naja mit einem "vermurksten" System wirst Du mittelfristig mehr Probleme als Freude haben.
                              Von daher: schau das Du es sauber hinbekommst. Die Adapter laufen alle unter node 8 oder 6 sauber … such Dir ewas aus, richte Dein System dazu ein und dann fixe die Probleme. Oder setze parallel sauber neu auf, spiele Backup ein
                                RappiRN
                                Hast du dich dabei genau an die Anleitung gehalten? Ich meine speziell die Version? Vielleicht ist die Version 8 inkompatibel mit dem Dash Button.
                                Die Deinstallation hast du auch geprüft? Und wenn die erfolgreich war dann einfach anstelle der 8 die 6 eingeben.
                                Enrico
                                  stephan
                                  Habe mein System neu aufgesetzt aber bekomme immer noch eine Fehlermeldung von Tradfri..
                                  [31merror[39m: Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-tradfri-client/node_modules/node-coap-client/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v57-linux-arm/node_aead_crypto.node'
                                  2018-11-06 21:53:51.179 - [31merror[39m: Caught by controller[0]: at Function.Module._resolveFilename (module.js:548:15)
                                  2018-11-06 21:53:51.179 - [31merror[39m: Caught by controller[0]: at Function.Module._load (module.js:475:25)
                                  2018-11-06 21:53:51.179 - [31merror[39m: Caught by controller[0]: at Module.require (module.js:597:17)
                                  2018-11-06 21:53:51.179 - [31merror[39m: Caught by controller[0]: at require (internal/module.js:11:18)
                                  2018-11-06 21:53:51.179 - [31merror[39m: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-tradfri-client/node_modules/node-coap-client/node_modules/node-dtls-client/node_modules/node-aead-crypto/index.js:4:15)
                                  2018-11-06 21:53:51.180 - [31merror[39m: Caught by controller[0]: at Module._compile (module.js:653:30)
                                  2018-11-06 21:53:51.180 - [31merror[39m: Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                                  2018-11-06 21:53:51.180 - [31merror[39m: Caught by controller[0]: at Module.load (module.js:566:32)
                                  2018-11-06 21:53:51.180 - [31merror[39m: Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                                  2018-11-06 21:53:51.180 - [31merror[39m: Caught by controller[0]: at Function.Module._load (module.js:498:3)
                                  was kann ich denn noch probieren..
                                  Bin über jeden Vorschlag dankbar.</anonymous>
                                  • AlCalzoneA Offline
                                    AlCalzoneA Offline
                                    AlCalzone
                                    Welche Version hast du denn installiert? Ich habe kürzlich etwas an der Installationsroutine geändert, damit das Problem nicht mehr auftreten sollte. Dein Installationslog ist leider nicht vollständig
                                    In deinem Fall sollte helfen
                                    cd /opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-tradfri-client/node_modules/node-coap-client/node_modules/node-dtls-client/node_modules/node-aead-crypto
                                    npm i --production
                                    bzw wenn das nicht geht
                                    npm i --production --unsafe-perm
                                      stephan
                                      Du meinst Tradri version… habe ich die 1.4.1 installiert.
                                        AlCalzoneA Offline
                                        AlCalzone
                                        Ok sieht aus als hätte ich vergessen das zu veröffentlichen.
                                        Probier mal die manuelle Installation von Version 1.5.2:
                                        cd /opt/iobroker
                                        npm i iobroker.tradfri@1.5.2
                                          stephan
                                          Also leider hat es alles nichts gebracht..
                                          Habe meinen Raspi nun komplett neu aufgesetzt und meine Sicherung wieder eingebracht.
                                          Leider immer wieder Fehlermeldungen.
                                          host.ioBroker-RasPi 2018-11-10 01:41:02.286 error instance system.adapter.tradfri.0 terminated with code 1 ()
                                          host.ioBroker-RasPi 2018-11-10 01:41:02.285 error Caught by controller[5]: instead. Afterwards, restart this adapter.
                                          host.ioBroker-RasPi 2018-11-10 01:41:02.285 error Caught by controller[4]: sudo npm install –production --unsafe-perm
                                          host.ioBroker-RasPi 2018-11-10 01:41:02.285 error Caught by controller[3]: If that fails due to missing access rights, run
                                          host.ioBroker-RasPi 2018-11-10 01:41:02.285 error Caught by controller[2]: npm install –production
                                          host.ioBroker-RasPi 2018-11-10 01:41:02.284 error Caught by controller[1]: To try reinstalling it, goto "/opt/iobroker/node_modules/iobroker.tradfri" and run
                                          host.ioBroker-RasPi 2018-11-10 01:41:02.284 error Caught by controller[0]: The module "node-aead-crypto" was not installed correctly!
