  4. Amazon-DASH-Button
    6.3k
Amazon-DASH-Button
6 Beiträge 4 Kommentatoren 533 Aufrufe
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    ich habe den Amazon-Dash-Button am laufen. Aber auf einmal will er nicht mehr (nach Neustart des Rechners):
    host.zotac	2018-10-16 22:45:13.007	info	Restart adapter system.adapter.amazon-dash.0 because enabled
    host.zotac	2018-10-16 22:45:13.006	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
    host.zotac	2018-10-16 22:45:13.005	error	Caught by controller[1]: at Module.load (module.js:566:32)
    host.zotac	2018-10-16 22:45:13.005	error	Caught by controller[1]: at Object.Module._extensions..js (module.js:664:10)
    host.zotac	2018-10-16 22:45:13.005	error	Caught by controller[1]: at Module._compile (module.js:653:30)
    host.zotac	2018-10-16 22:45:13.005	error	Caught by controller[1]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21)
    host.zotac	2018-10-16 22:45:13.005	error	Caught by controller[1]: at require (internal/module.js:11:18)
    host.zotac	2018-10-16 22:45:13.005	error	Caught by controller[1]: at Module.require (module.js:597:17)
    host.zotac	2018-10-16 22:45:13.005	error	Caught by controller[1]: at Function.Module._load (module.js:498:3)
    host.zotac	2018-10-16 22:45:13.005	error	Caught by controller[1]: at tryModuleLoad (module.js:506:12)
    host.zotac	2018-10-16 22:45:13.005	error	Caught by controller[1]: at Object.Module._extensions..node (module.js:682:18)
    host.zotac	2018-10-16 22:45:13.005	error	Caught by controller[1]: the module (for instance, using `npm rebuild` or `npm install`).
    host.zotac	2018-10-16 22:45:13.005	error	Caught by controller[1]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
    host.zotac	2018-10-16 22:45:13.005	error	Caught by controller[1]: NODE_MODULE_VERSION 64\. This version of Node.js requires
    host.zotac	2018-10-16 22:45:13.005	error	Caught by controller[1]: was compiled against a different Node.js version using
    host.zotac	2018-10-16 22:45:13.005	error	Caught by controller[1]: 2018-10-16 22:45:12.487 - [31merror[39m: amazon-dash.0 Error: The module '/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node'
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[1]: was compiled against a different Node.js version using
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[1]: 2018-10-16 22:45:12.487 - amazon-dash.0 uncaught exception: The module '/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node'
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[0]: at Module.load (module.js:566:32)
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[0]: at Module._compile (module.js:653:30)
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21)
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[0]: at require (internal/module.js:11:18)
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[0]: at Module.require (module.js:597:17)
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[0]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[0]: NODE_MODULE_VERSION 64\. This version of Node.js requires
    host.zotac	2018-10-16 22:45:13.004	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.zotac	2018-10-16 22:45:13.003	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node'
    amazon-dash.0	2018-10-16 22:45:12.540	info	starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v8.12.0
    host.zotac	2018-10-16 22:45:12.275	info	instance system.adapter.amazon-dash.0 started with pid 31568</anonymous></anonymous>
    Nachdem ich ein reinstall vom iobroker gemacht hatte, lief es für zwei Tage. Nach Neustart des Rechners war der Fehler aber wieder da.
    Ideen was da schief läuft?
    npm 6.4.1
    nodejs v8.12.0
    node v10.12.0
    Neustarten von iobroker hat geholfen. Aber immer nur bis zum nächsten Neustart des Rechners.
    MfG
    Sissi
    • arteckA Offline
      arteckA Offline
      arteck
      steht doch da..
      von wegen nix gemacht… :roll: ein node update ist gelaufen..
      • foxriver76F Offline
        foxriver76F Offline
        foxriver76
        Das Problem sind deine zwei Node Versionen. Solltest Node und Nodejs mal komplett deinstallieren und dann entsprechend der Anleitung installieren.
        Deshalb könnte es auch passieren, dass der Adapter mit einer anderen Version kompiliert wurde als er versucht wird auszuführen.
        Videotutorials & mehr
          Brati
          Ich kann Dash momentan gar nicht installieren, hatte auf node 8 geupgraded, alles außer Dash läuft danach.
          $ ./iobroker add amazon-dash --host ioBroker
          NPM version: 4.6.1
          npm install iobroker.amazon-dash --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
          npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)
          npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
          npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
          npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
          npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:42:5
          npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/mode.js:8:5
          npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/graceful-fs/polyfills.js:284:29
          npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:152:21)
          npm WARN addRemoteGit git+https://github.com/bytzdev/node-socketwatcher.git resetting remote /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02de because of error: { Error: not found: git
          npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:152:21) code: 'ENOGIT' }
          ! npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/bytzdev/node-socketwatcher.git /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02de: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/bytzdev/node-socketwatcher.git /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02de: undefined
          ! npm ERR!
          code ENOGIT
          npm ERR! not found: gitnpm
          ERR! npm ERR! Failed using git.
          npm ERR! This is most likely not a problem with npm itself.
          npm ERR! Please check if you have git installed and in your PATH.
          ! npm ERR!
          A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2018-10-22T12_40_34_326Z-debug.log
          ! host.ioBroker create instance amazon-dash
          ERROR: host.ioBroker error: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json'
          ERROR: process exited with code 20
          node v8.12.0
          npm v4.6.1
          Jemand eine Idee?
          Grüße
          Brati
          CCU2 - 46 Geräte, ioBroker auf Intel NUC (DN2820FYKH) mit Tab als Frontend, Projekt Gartenhaus mit HM
            foxriver76F Offline
            foxriver76
            Schaut aus als wäre git nicht installiert. Lässt sich z. B. mittels apt installieren
              Brati
              @foxriver76:
              Schaut aus als wäre git nicht installiert. Lässt sich z. B. mittels apt installieren `
              Danke, das war einfach. Ich habs nicht gelöscht :roll: (oder keine Ahnung was da beim Update passiert ist…)
