  4. Tradfri adapter installation nicht möglich
15 Beiträge 3 Kommentatoren 1.8k Aufrufe
  • G Offline
    gcaruso
    ich kann Tradfri adapter nicht mehr installieren. Bekomme immer dieser fehlermeldung bei der katze:
    $ ./iobroker url "https://github.com/AlCalzone/ioBroker.tradfri/tarball/master" tradfri
    install https://github.com/AlCalzone/ioBroker.tradfri/tarball/master
    npm install https://github.com/AlCalzone/ioBroker.tradfri/tarball/master --production --save --prefix "/opt/iobroker" (System call)
    node-pre-gyp WARN Pre-built binaries not installable for node-aead-crypto@1.1.4 and node@8.12.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error Remote end closed socket abruptly.
    node-pre-gyp WARN Hit error bad download
    rm: das Entfernen von './Release/.deps/Release/obj.target/node_aead_crypto/src/node-aes-ccm.o.d.raw' ist nicht möglich
    : Datei oder Verzeichnis nicht gefunden
    make: *** [Release/obj.target/node_aead_crypto/src/node-aes-ccm.o] Fehler 1
    gyp
     ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at emitTwo (events.js:126:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 4.14.30-v7+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v57-linux-arm/node_aead_crypto.node" "--module_name=node_aead_crypto" "--module_path=/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v57-linux-arm" "--napi_version=3" "--node_abi_napi=napi"
    gyp ERR! cwd /opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto
    gyp ERR! node -v v8.12.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v57-linux-arm/node_aead_crypto.node --module_name=node_aead_crypto --module_path=/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v57-linux-arm --napi_version=3 --node_abi_napi=napi' (1)node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at emitTwo (events.js:126:13)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:915:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
    node-pre-gyp ERR! System Linux 4.14.30-v7+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto
    node-pre-gyp ERR! node -v v8.12.0
    node-pre-gyp ERR! node-pre-gyp -v v0.10.2
    node-pre-gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! node-aead-crypto@1.1.4 install:default: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the node-aead-crypto@1.1.4 install:default script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /root/.npm/_logs/2018-09-18T22_50_29_912Z-debug.log
    child_process.js:645    throw err;
    Error: Command failed: npm run install:default
        at checkExecSyncError (child_process.js:602:13)
        at execSync (child_process.js:642:13)
        at Object. <anonymous>(/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/lib/install.js:22:1)
        at Module._compile (module.js:653:30)
        at Object.Module._extensions..js (module.js:664:10)
        at Module.load (module.js:566:32)
        at tryModuleLoad (module.js:506:12)
        at Function.Module._load (module.js:498:3)
        at Function.Module.runMain (module.js:694:10)
        at startup (bootstrap_node.js:204:16)
    npm ERR! errno 1
    npm ERR! node-aead-crypto@1.1.4 install: `node lib/install.js`npm ERR! Exit status 1
    npm ERR! npm ERR! Failed at the node-aead-crypto@1.1.4 install script.
    npm
    ERR!
     A complete log of this run can be found in:
    npm
    ERR!     /root/.npm/_logs/2018-09-18T22_50_32_126Z-debug.log
    ../src/node-aes-gcm.cc:269:1: fatal error: opening dependency file ./Release/.deps/Release/obj.target/node_aead_crypto/src/node-aes-gcm.o.d.raw: Datei oder Verzeichnis nicht gefundencompilation terminated.
    make: *** [Release/obj.target/node_aead_crypto/src/node-aes-gcm.o] Fehler 1
    gyp
     ERR! build error
    gyp ERR! System Linux 4.14.30-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v57-linux-arm/node_aead_crypto.node" "--module_name=node_aead_crypto" "--module_path=/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v57-linux-arm" "--napi_version=3" "--node_abi_napi=napi"
    gyp ERR! not ok
    npm
     WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
    npm
     ERR! code ELIFECYCLEnpm ERR! errno 1
    npm ERR! node-dtls-client@0.5.4 install: `node install/postinstall.js`
    npm ERR! npm ERR! Failed at the node-dtls-client@0.5.4 install script.
    npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-09-18T22_50_39_514Z-debug.log
    ERROR: Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
    process exited with code 0</anonymous></anonymous>
    und dieser bei latest version (1.4.1)
    $ ./iobroker add tradfri  --host ioBroker-RasPi
    NPM version: 6.4.1
    npm install iobroker.tradfri --production --save --prefix "/opt/iobroker" (System call)
    node-pre-gyp WARN
    node-pre-gyp
     WARN
    cp: reguläre Datei 'Release/node_aead_crypto.node' kann nicht angelegt werden
    : Die Datei existiert bereits
    make: *** [Release/node_aead_crypto.node] Fehler 1
    gyp
     ERR! build error
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v57-linux-arm/node_aead_crypto.node" "--module_name=node_aead_crypto" "--module_path=/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v57-linux-arm" "--napi_version=3" "--node_abi_napi=napi"gyp ERR! cwd /opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto
    gyp ERR!
     not ok
    node-pre-gyp
    ERR!
    node-pre-gyp
    ERR! stack     at ChildProcess.emit (events.js:214:7)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:915:16)
    node-pre-gyp
    ERR! node -v v8.12.0node-pre-gyp ERR! node-pre-gyp -v v0.10.2
    npm ERR! errno 1
    npm ERR! npm ERR! Failed at the node-aead-crypto@1.1.4 install:default script.
    npm ERR!     /root/.npm/_logs/2018-09-18T22_53_46_253Z-debug.log
    npm ERR! code ELIFECYCLEnpm ERR! errno 1
    npm ERR!
    npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-09-18T22_53_52_467Z-debug.log
    npm
    npm ERR! errno 1npm ERR! node-dtls-client@0.5.4 install: `node install/postinstall.js`
    npm ERR!
    npm ERR!     /root/.npm/_logs/2018-09-18T22_54_01_545Z-debug.log
    host.ioBroker-RasPi install adapter tradfri
    NPM version: 6.4.1
    node-pre-gyp
    node-pre-gyp
     WARN Pre-built binaries not installable for node-aead-crypto@1.1.4 and node@8.12.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error ENOENT: Cannot cd into '/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v57-linux-arm'
    rm: das Entfernen von './Release/.deps/Release/obj.target/node_aead_crypto/src/node-aes-ccm.o.d.raw' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
    gyp
    ERR! build error
    gyp
     ERR!
    command
    ERR! cwd
     /opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-cryptogyp
    gyp ERR!
     not ok
    node-pre-gyp
     ERR! build error
    node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at emitTwo (events.js:126:13)
    node-pre-gyp
     ERR! System Linux 4.14.30-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp
     ERR! cwd /opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-cryptonode-pre-gyp ERR! node -v v8.12.0
    node-pre-gyp
     ERR! not ok
    npm
    npm
     ERR! npm ERR!
    npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-09-18T22_55_25_038Z-debug.log
    npm ERR! errno 1
    npm ERR!
    npm ERR!     /root/.npm/_logs/2018-09-18T22_55_26_667Z-debug.log
    gyp
     ERR!
     build error
    gyp ERR! not ok
    npm
     react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.npm
    npm
     ERR! errno 1
    npm ERR! node-dtls-client@0.5.4 install: `node install/postinstall.js`npm ERR! Exit status 1
    npm
    npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-09-18T22_55_38_673Z-debug.log
    NPM version: 6.4.1
    node-pre-gyp
    WARN
    node-pre-gyp
     WARN
    rm: das Entfernen von './Release/.deps/Release/obj.target/node_aead_crypto/src/node-aes-ccm.o.d.raw' ist nicht möglich: Datei oder Verzeichnis nicht gefundenmake: *** [Release/obj.target/node_aead_crypto/src/node-aes-ccm.o] Fehler 1
    gyp ERR! stack
    gyp ERR!
     command
     ERR! cwd /opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-cryptogyp ERR! node -v v8.12.0
    gyp ERR! not ok
    node-pre-gyp ERR! System Linux 4.14.30-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    npm ERR!
    npm
    ERR!
    ERR!     /root/.npm/_logs/2018-09-18T22_57_14_198Z-debug.logchild_process.js:645
        throw err;
    npm
    npm ERR! errno 1
    npm
    npm ERR!
    npm ERR!
     A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-09-18T22_57_16_885Z-debug.log
    gyp ERR! not ok
    npm
     WARN
    npm
    WARN
    WARN
    npm
     ERR! errno 1npm
    npm ERR!
    npm ERR!
     Failed at the node-dtls-client@0.5.4 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
         /root/.npm/_logs/2018-09-18T22_57_32_183Z-debug.log
    ERROR: host.ioBroker-RasPi Cannot install tradfri
    ERROR: process exited with code 13</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
    und hier die o.g. log datei:
    8294_2018-09-18t23_08_47_835z-debug.log
    Vielen dank im voraus für eure hilfe.
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      Den Fehler hab ich so noch nicht gesehen. Üblicherweise hilft aber die manuelle Installation per Konsole. Dazu am besten alle vorherigen Spuren beseitigen (wenn es Rechteprobleme gibt, dann sudo vor rm schreiben):
      cd /opt/iobroker/node_modules
      rm -rf iobroker.tradfri
      rm -rf node-tradfri-client
      rm -rf node-coap-client
      rm -rf node-dtls-client
      rm -rf node-aead-crypto
      Und jetzt den Adapter mit erhöhten Rechten installieren:
      cd /opt/iobroker
      sudo npm i iobroker.tradfri --unsafe-perm
      • G Offline
        gcaruso
        Hallo AlCalzone,
        erstmal danke für die schnelle antwort.
        Geht leider auch nicht.
        root@ioBroker-RasPi:~# cd /opt/iobroker/node_modules
        root@ioBroker-RasPi:/opt/iobroker/node_modules# rm -rf iobroker.tradfri
        root@ioBroker-RasPi:/opt/iobroker/node_modules# rm -rf node-tradfri-client
        root@ioBroker-RasPi:/opt/iobroker/node_modules# rm -rf node-coap-client
        root@ioBroker-RasPi:/opt/iobroker/node_modules# rm -rf node-dtls-client
        root@ioBroker-RasPi:/opt/iobroker/node_modules# rm -rf node-aead-crypto
        root@ioBroker-RasPi:/opt/iobroker/node_modules# cd /opt/iobroker
        root@ioBroker-RasPi:/opt/iobroker# sudo npm i iobroker.tradfri --unsafe-perm
        > node-dtls-client@0.5.4 install /opt/iobroker/node_modules/node-dtls-client
        node-dtls-client: testing NodeJS version
          Version < 10, installing node-aead-crypto...
        > node-aead-crypto@1.1.4 install /opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto
        > node lib/install.js
        running default installation script
        > node-aead-crypto@1.1.4 install:default /opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto
        make: Verzeichnis „/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build“ wird betreten
          CXX(target) Release/obj.target/node_aead_crypto/src/node-aes-ccm.o
        rm: das Entfernen von './Release/.deps/Release/obj.target/node_aead_crypto/src/node-aes-ccm.o.d.raw' ist nicht möglich  CXX(target) Release/obj.target/node_aead_crypto/src/node-aes-gcm.o
        node_aead_crypto.target.mk:101: die Regel für Ziel „Release/obj.target/node_aead_crypto/src/node-aes-ccm.o“ scheiterte
        make: Verzeichnis „/opt/iobroker/node_modules/node-dtls-client/node_modules/node-aead-crypto/build“ wird verlassen
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        npm ERR!     /root/.npm/_logs/2018-09-19T06_53_17_556Z-debug.log
            throw err;
        npm ERR! errno 1
        npm ERR!
        npm ERR!     /root/.npm/_logs/2018-09-19T06_53_19_422Z-debug.log
        node_aead_crypto.target.mk:101: die Regel für Ziel „Release/obj.target/node_aead_crypto/src/node-aes-gcm.o“ scheiterte
        gyp ERR! not ok
        npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
        npm ERR! errno 1
        npm ERR!
        npm ERR!     /root/.npm/_logs/2018-09-19T06_53_29_807Z-debug.log
        root@ioBroker-RasPi:/opt/iobroker#</anonymous></anonymous>
        8294_2018-09-19t06_53_29_807z-debug.log
        Soll ich iobroker lieber komplett neu aufsetzen?
        Giovanni
          AlCalzoneA Offline
          AlCalzone
          Nein, lass erst mal alles wie es ist. Da scheint ein Problem mit node-pre-gyp zu existieren, das intern zur Installation des einen Pakets verwendet wird.
          Ich release gerade eine neue Version von node-aead-crypto, mit der das hoffentlich wieder funktioniert. Probiere es in ca. 30 Minuten nochmal.
          • G Offline
            gcaruso
            @AlCalzone:
            Ich release gerade eine neue Version von node-aead-crypto, mit der das hoffentlich wieder funktioniert. Probiere es in ca. 30 Minuten nochmal. `
            Hallo AlCalzone,
            hier was ich um 16:15 Uhr installiert habe:
            pi@ioBroker-RasPi:/opt/iobroker $ sudo iobroker del tradfri
            Delete adapter "tradfri"
            host.ioBroker-RasPi no instances of adapter tradfri found
            npm uninstall iobroker.tradfri --silent --save --prefix "/opt/iobroker" (System call)
            pi@ioBroker-RasPi:/opt/iobroker $ cd /opt/iobroker/node_modules
            pi@ioBroker-RasPi:/opt/iobroker/node_modules $ sudo rm -rf iobroker.tradfri
            pi@ioBroker-RasPi:/opt/iobroker/node_modules $ sudo rm -rf node-tradfri-client
            pi@ioBroker-RasPi:/opt/iobroker/node_modules $ sudo rm -rf node-coap-client
            pi@ioBroker-RasPi:/opt/iobroker/node_modules $ sudo rm -rf node-dtls-client
            pi@ioBroker-RasPi:/opt/iobroker/node_modules $ sudo rm -rf node-aead-crypto
            pi@ioBroker-RasPi:/opt/iobroker/node_modules $ cd /opt/iobroker
            pi@ioBroker-RasPi:/opt/iobroker $ sudo npm i iobroker.tradfri --unsafe-perm
            > node lib/install.js
            gyp ERR! not ok
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /root/.npm/_logs/2018-09-19T14_17_49_014Z-debug.log
                throw err;
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /root/.npm/_logs/2018-09-19T14_17_50_977Z-debug.log
            gyp ERR! not ok
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /root/.npm/_logs/2018-09-19T14_17_59_453Z-debug.log
            pi@ioBroker-RasPi:/opt/iobroker $</anonymous></anonymous>
            und dass passiert wenn ich versuche eine instanz zu erzeugen:
            pi@ioBroker-RasPi:/opt/iobroker $ iobroker add tradfri
            NPM version: 6.4.1
            gyp ERR! not ok
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /home/pi/.npm/_logs/2018-09-19T14_24_07_528Z-debug.log
                throw err;
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /home/pi/.npm/_logs/2018-09-19T14_24_09_583Z-debug.log
            gyp ERR! not ok
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /home/pi/.npm/_logs/2018-09-19T14_24_23_098Z-debug.log
            NPM version: 6.4.1
            gyp ERR! not ok
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /home/pi/.npm/_logs/2018-09-19T14_27_02_857Z-debug.log
                throw err;
            In file included from ../src/node-aes-gcm.cc:24:0:
            ../../nan/nan.h:202:54: fatal error: nan_converters.h: Datei oder Verzeichnis nicht gefunden
            gyp ERR! not ok
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /home/pi/.npm/_logs/2018-09-19T14_27_04_642Z-debug.log
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /home/pi/.npm/_logs/2018-09-19T14_27_12_676Z-debug.log
            NPM version: 6.4.1
            gyp ERR! not ok
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /home/pi/.npm/_logs/2018-09-19T14_30_05_529Z-debug.log
                throw err;
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /home/pi/.npm/_logs/2018-09-19T14_30_07_569Z-debug.log
            gyp ERR! not ok
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /home/pi/.npm/_logs/2018-09-19T14_30_16_434Z-debug.log
            pi@ioBroker-RasPi:/opt/iobroker $</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
            LG
            Giovanni
              AlCalzoneA Offline
              AlCalzone
              Da hab ich Held doch glatt vergessen, auch die neue Version der Library (1.1.6) auf npm zu veröffentlichen. Probiers in einer halben Stunde bitte nochmal, ich arbeite gerade noch an einem weiteren Fix.
              • G Offline
                gcaruso
                @AlCalzone:
                Da hab ich Held doch glatt vergessen, auch die neue Version der Library (1.1.6) auf npm zu veröffentlichen. Probiers in einer halben Stunde bitte nochmal, ich arbeite gerade noch an einem weiteren Fix. `
                Ok habe gerade eben probiert.
                log.txt
                  AlCalzoneA Offline
                  AlCalzone
                  Okay, jetzt haben wir ein anderes Rechteproblem. Das müsste so zu lösen sein:
                  cd /opt/iobroker
                  sudo chown $(whoami) -R .
                  Punkt am Ende nicht vergessen!
                  Danach sollte
                  ohne sudo(!) funktionieren.
                  • G Offline
                    gcaruso
                    @AlCalzone:
                    cd /opt/iobroker
                    Danach sollte
                    ohne sudo(!) funktionieren. `
                    Genial!!!
                    Du kennst eindeutig dein Werk!!!!
                    Jetzt geht wieder alles.
                    Vielen DANK.
                    • G Offline
                      gcaruso
                      Ups. Jetzt wieder ein fehler…
                      tradfri.0	2018-09-19 21:42:32.591	warn	Not connected to the gateway. Cannot send changes!
                      tradfri.0	2018-09-19 21:42:31.215	warn	Not connected to the gateway. Cannot send changes!
                      tradfri.0	2018-09-19 21:42:29.492	warn	Not connected to the gateway. Cannot send changes!
                      tradfri.0	2018-09-19 21:42:28.493	warn	Not connected to the gateway. Cannot send changes!
                      tradfri.0	2018-09-19 21:42:19.902	warn	Lost connection to gateway
                      tradfri.0	2018-09-19 21:41:06.912	warn	object was: {"5850":1,"5851":127,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                      tradfri.0	2018-09-19 21:41:06.911	warn	found unknown property with key 9108
                      tradfri.0	2018-09-19 21:41:04.561	warn	object was: {"5850":0,"5851":127,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                      tradfri.0	2018-09-19 21:41:04.560	warn	found unknown property with key 9108
                      tradfri.0	2018-09-19 21:39:28.562	warn	object was: {"5850":0,"5851":254,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                      tradfri.0	2018-09-19 21:39:28.561	warn	found unknown property with key 9108
                      tradfri.0	2018-09-19 21:39:26.793	warn	object was: {"5850":1,"5851":254,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                      tradfri.0	2018-09-19 21:39:26.792	warn	found unknown property with key 9108
                      admin.0	2018-09-19 21:39:12.904	warn	Disable logging, because no one socket connected
                      scenes.0	2018-09-19 21:39:05.917	info	restartAdapter
                      tradfri.0	2018-09-19 21:38:41.907	warn	object was: {"5850":1,"5851":254,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                      tradfri.0	2018-09-19 21:38:41.906	warn	found unknown property with key 9108
                      tradfri.0	2018-09-19 21:38:38.625	warn	object was: {"5850":0,"5851":254,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                      tradfri.0	2018-09-19 21:38:38.624	warn	found unknown property with key 9108
                      tradfri.0	2018-09-19 21:38:37.000	warn	object was: {"5850":1,"5851":254,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                      tradfri.0	2018-09-19 21:38:36.999	warn	found unknown property with key 9108
                      tradfri.0	2018-09-19 21:38:35.997	warn	object was: {"5850":1,"5851":185,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                      tradfri.0	2018-09-19 21:38:35.996	warn	found unknown property with key 9108
                      tradfri.0	2018-09-19 21:38:34.329	warn	object was: {"5850":1,"5851":188,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                      tradfri.0	2018-09-19 21:38:34.328	warn	found unknown property with key 9108
                      tradfri.0	2018-09-19 21:38:32.189	warn	object was: {"5850":1,"5851":0,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                      tradfri.0	2018-09-19 21:38:32.187	warn	found unknown property with key 9108
                      tradfri.0	2018-09-19 21:38:31.061	warn	object was: {"5850":0,"5851":0,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                      tradfri.0	2018-09-19 21:38:31.060	warn	found unknown property with key 9108
                      web.0	2018-09-19 21:38:27.860	info	==>Connected system.user.admin from ::ffff:192.168.188.20
                      tradfri.0	2018-09-19 21:37:45.130	info	updating possible scenes for group 131086: ["196650","196651","196652"]
                      tradfri.0	2018-09-19 21:37:45.128	info	received all groups and scenes
                      tradfri.0	2018-09-19 21:37:45.096	info	updating possible scenes for group 131086: ["196650","196651"]
                      tradfri.0	2018-09-19 21:37:45.059	info	updating possible scenes for group 131086: ["196650"]
                      tradfri.0	2018-09-19 21:37:45.002	info	got all scenes in group 131086: [196650,196651,196652]
                      tradfri.0	2018-09-19 21:37:44.957	warn	object was: {"5850":0,"5851":0,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                      tradfri.0	2018-09-19 21:37:44.956	warn	found unknown property with key 9108
                      tradfri.0	2018-09-19 21:37:44.930	info	got all groups: [131086]
                      tradfri.0	2018-09-19 21:37:44.883	info	received all devices
                      tradfri.0	2018-09-19 21:37:44.645	info	got all devices: [65573,65570,65569,65572,65571]
                      tradfri.0	2018-09-19 21:37:44.307	info	startfile = /opt/iobroker/node_modules/iobroker.tradfri/main.js
                      tradfri.0	2018-09-19 21:37:44.173	info	starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.tradfri, node: v8.12.0
                      tradfri.0	2018-09-19 21:37:44.107	info	States connected to redis: 127.0.0.1:6379
                      host.ioBroker-RasPi	2018-09-19 21:37:42.234	info	instance system.adapter.tradfri.0 started with pid 1049
                      host.ioBroker-RasPi	2018-09-19 21:37:39.775	info	instance system.adapter.tradfri.0 terminated with code 0 (OK)
                      host.ioBroker-RasPi	2018-09-19 21:37:39.721	info	stopInstance system.adapter.tradfri.0 killing pid 1034
                      host.ioBroker-RasPi	2018-09-19 21:37:39.720	info	stopInstance system.adapter.tradfri.0
                      host.ioBroker-RasPi	2018-09-19 21:37:39.719	info	object change system.adapter.tradfri.0
                      tradfri.0	2018-09-19 21:37:39.684	info	The authentication was successful. The adapter should now restart. If not, please restart it manually.
                      tradfri.0	2018-09-19 21:37:39.421	info	startfile = /opt/iobroker/node_modules/iobroker.tradfri/main.js
                      tradfri.0	2018-09-19 21:37:39.147	info	starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.tradfri, node: v8.12.0
                      tradfri.0	2018-09-19 21:37:39.078	info	States connected to redis: 127.0.0.1:6379
                      und die meiste States sind von alleine verschwunden:
                      Das einzige was hilft ist die gruppe aus objects zu löschen und adapter neu starten. Dann sind kurzer zeit alle states da und nach paar mal mit VIS/Alexa oder Fernbedienung bedienen sind alle wieder weg.
                        AlCalzoneA Offline
                        AlCalzone
                        Das mit den States ist mir auch schon aufgefallen. Ich komme aktuell aber nicht zum Debuggen.
                        Den Verbindungsabbruch habe ich nur extrem selten, und dann macht mein Router irgendeinen Murks.
                        • G Offline
                          gcaruso
                          Ok meinst du soll ich lieber iobroker neu aufsetzen?
                          Wenn ja ist die Version mit node 8.11.1 ok? Ich habe ein Raspberry Pi 3B.
                          LG
                          Giovanni
                            AlCalzoneA Offline
                            AlCalzone
                            @gcaruso:
                            Ok meinst du soll ich lieber iobroker neu aufsetzen? `
                            Warum willst du ständig neu aufsetzen? Langeweile?
                            Die fehlenden States werden damit nicht behoben, dazu muss ich die Ursache finden und lösen. Wenn du Verbindungsprobleme zum Gateway hast, werden die auch nicht besser - da musst du an anderer Stelle suchen.
                            • G Offline
                              gcaruso
                              @AlCalzone:
                              @gcaruso:
                              Die fehlenden States werden damit nicht behoben, dazu muss ich die Ursache finden und lösen. Wenn du Verbindungsprobleme zum Gateway hast, werden die auch nicht besser - da musst du an anderer Stelle suchen. `
                              Hallo AlCalzone,
                              ich habe gestern neue image aufgesetzt und backup restore gemacht. Jetzt geht alles wieder und die states bleiben auch stabil.
                              Hatte vorher nodejs 8.12.0, npm 6.4.1, jscontroller 1.5.3 und tradfri 2.0.0
                              Jetzt nodejs 8.11.1, nom 6.4.1, jscontroller 1.4.2 und tradfri 1.4.1.
                              Falls du jergen welche log oder so brauchst der dir helfen kann um den fehler zu finden, sag mir einfach bescheid und ich schick dir zu.
                              Hier ein log von tradfri adapter. Wenn ich die gruppe ein oder ausschalte bekomme immer eine komische fehlermeldung aber es funktioniert trotzdem (dieser fehlermeldung hatte ich auch bei meine alte installation bevor die states verschwunden sind).
                              States:
                              Debug log mit ein und ausschalten von gruppe:
                              tradfri.0	2018-09-20 12:07:50.239	debug	setting next timeout in 10000
                              tradfri.0	2018-09-20 12:07:50.239	debug	ping succeeded
                              tradfri.0	2018-09-20 12:07:40.230	debug	setting next timeout in 10000
                              tradfri.0	2018-09-20 12:07:40.229	debug	ping succeeded
                              tradfri.0	2018-09-20 12:07:30.218	debug	setting next timeout in 10000
                              tradfri.0	2018-09-20 12:07:30.217	debug	ping succeeded
                              tradfri.0	2018-09-20 12:07:21.011	debug	 state with id tradfri.0.VG-00001.state updated: ack=true; val=false
                              tradfri.0	2018-09-20 12:07:21.010	debug	redis pmessage io.tradfri.0.* io.tradfri.0.VG-00001.state {"val":false,"ack":true,"ts":1537438041004,"q":0,"from":"system.adapter.tradfri.0","lc":1537438041004}
                              tradfri.0	2018-09-20 12:07:21.010	debug	 state with id tradfri.0.G-131086.state updated: ack=true; val=false
                              tradfri.0	2018-09-20 12:07:21.010	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.state {"val":false,"ack":true,"ts":1537438041003,"q":0,"from":"system.adapter.tradfri.0","lc":1537438040595}
                              tradfri.0	2018-09-20 12:07:21.009	debug	 state with id tradfri.0.VG-00001.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:21.009	debug	redis pmessage io.tradfri.0.* io.tradfri.0.VG-00001.brightness {"val":100,"ack":true,"ts":1537438040999,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819636}
                              tradfri.0	2018-09-20 12:07:21.009	debug	 state with id tradfri.0.G-131086.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:21.008	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.brightness {"val":100,"ack":true,"ts":1537438040999,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819262}
                              tradfri.0	2018-09-20 12:07:20.758	debug	 state with id tradfri.0.L-65573.lightbulb.state updated: ack=true; val=false
                              tradfri.0	2018-09-20 12:07:20.758	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65573.lightbulb.state {"val":false,"ack":true,"ts":1537438040724,"q":0,"from":"system.adapter.tradfri.0","lc":1537438040724}
                              tradfri.0	2018-09-20 12:07:20.757	debug	 state with id tradfri.0.L-65573.lightbulb.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:20.757	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65573.lightbulb.brightness {"val":100,"ack":true,"ts":1537438040723,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819335}
                              tradfri.0	2018-09-20 12:07:20.757	debug	 state with id tradfri.0.L-65573.lastSeen updated: ack=true; val=1537402461
                              tradfri.0	2018-09-20 12:07:20.756	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65573.lastSeen {"val":1537402461,"ack":true,"ts":1537438040723,"q":0,"from":"system.adapter.tradfri.0","lc":1537402508065}
                              tradfri.0	2018-09-20 12:07:20.756	debug	 state with id tradfri.0.L-65573.alive updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:20.756	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65573.alive {"val":true,"ack":true,"ts":1537438040722,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407608}
                              tradfri.0	2018-09-20 12:07:20.756	debug	 state with id tradfri.0.L-65570.lightbulb.state updated: ack=true; val=false
                              tradfri.0	2018-09-20 12:07:20.755	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65570.lightbulb.state {"val":false,"ack":true,"ts":1537438040722,"q":0,"from":"system.adapter.tradfri.0","lc":1537438040722}
                              tradfri.0	2018-09-20 12:07:20.755	debug	 state with id tradfri.0.L-65570.lightbulb.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:20.755	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65570.lightbulb.brightness {"val":100,"ack":true,"ts":1537438040721,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819376}
                              tradfri.0	2018-09-20 12:07:20.754	debug	 state with id tradfri.0.L-65570.lastSeen updated: ack=true; val=1537402458
                              tradfri.0	2018-09-20 12:07:20.754	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65570.lastSeen {"val":1537402458,"ack":true,"ts":1537438040720,"q":0,"from":"system.adapter.tradfri.0","lc":1537402508009}
                              tradfri.0	2018-09-20 12:07:20.754	debug	 state with id tradfri.0.L-65570.alive updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:20.753	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65570.alive {"val":true,"ack":true,"ts":1537438040720,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407539}
                              tradfri.0	2018-09-20 12:07:20.753	debug	 state with id tradfri.0.L-65572.lightbulb.state updated: ack=true; val=false
                              tradfri.0	2018-09-20 12:07:20.753	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65572.lightbulb.state {"val":false,"ack":true,"ts":1537438040719,"q":0,"from":"system.adapter.tradfri.0","lc":1537438040719}
                              tradfri.0	2018-09-20 12:07:20.752	debug	 state with id tradfri.0.L-65572.lightbulb.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:20.752	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65572.lightbulb.brightness {"val":100,"ack":true,"ts":1537438040719,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819379}
                              tradfri.0	2018-09-20 12:07:20.752	debug	 state with id tradfri.0.L-65572.lastSeen updated: ack=true; val=1537402460
                              tradfri.0	2018-09-20 12:07:20.752	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65572.lastSeen {"val":1537402460,"ack":true,"ts":1537438040718,"q":0,"from":"system.adapter.tradfri.0","lc":1537402508049}
                              tradfri.0	2018-09-20 12:07:20.751	debug	 state with id tradfri.0.L-65572.alive updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:20.751	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65572.alive {"val":true,"ack":true,"ts":1537438040718,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407584}
                              tradfri.0	2018-09-20 12:07:20.751	debug	 state with id tradfri.0.L-65571.lightbulb.state updated: ack=true; val=false
                              tradfri.0	2018-09-20 12:07:20.750	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65571.lightbulb.state {"val":false,"ack":true,"ts":1537438040717,"q":0,"from":"system.adapter.tradfri.0","lc":1537438040717}
                              tradfri.0	2018-09-20 12:07:20.750	debug	 state with id tradfri.0.L-65571.lightbulb.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:20.750	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65571.lightbulb.brightness {"val":100,"ack":true,"ts":1537438040716,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819355}
                              tradfri.0	2018-09-20 12:07:20.749	debug	 state with id tradfri.0.L-65571.lastSeen updated: ack=true; val=1537402459
                              tradfri.0	2018-09-20 12:07:20.749	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65571.lastSeen {"val":1537402459,"ack":true,"ts":1537438040716,"q":0,"from":"system.adapter.tradfri.0","lc":1537402508028}
                              tradfri.0	2018-09-20 12:07:20.749	debug	 state with id tradfri.0.L-65571.alive updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:20.748	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65571.alive {"val":true,"ack":true,"ts":1537438040715,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407558}
                              tradfri.0	2018-09-20 12:07:20.729	debug	observeDevice > {"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb GU10 W 400lm","2":"","3":"1.2.214","6":1},"3311":[{"5850":0,"5851":254,"9003":0}],"5750":2,"9001":"Bett Spot","9002":1529075846,"9003":6557
                              tradfri.0	2018-09-20 12:07:20.728	debug	observeDevice > {"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb GU10 W 400lm","2":"","3":"1.2.214","6":1},"3311":[{"5850":0,"5851":254,"9003":0}],"5750":2,"9001":"Schrank Spot","9002":1529075106,"9003":6
                              tradfri.0	2018-09-20 12:07:20.728	debug	observeDevice > {"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb GU10 W 400lm","2":"","3":"1.2.214","6":1},"3311":[{"5850":0,"5851":254,"9003":0}],"5750":2,"9001":"Couch Spot","9002":1529075812,"9003":655
                              tradfri.0	2018-09-20 12:07:20.728	debug	observeDevice > {"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb GU10 W 400lm","2":"","3":"1.2.214","6":1},"3311":[{"5850":0,"5851":254,"9003":0}],"5750":2,"9001":"Schreibtisch Spot","9002":1529075731,"90
                              tradfri.0	2018-09-20 12:07:20.727	debug	 state with id tradfri.0.G-131086.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:20.727	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.brightness {"val":100,"ack":true,"ts":1537438040648,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819262}
                              tradfri.0	2018-09-20 12:07:20.727	debug	 state with id tradfri.0.G-131086.transitionDuration updated: ack=true; val=undefined
                              tradfri.0	2018-09-20 12:07:20.727	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.transitionDuration {"ack":true,"ts":1537438040646,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407652}
                              tradfri.0	2018-09-20 12:07:20.726	debug	 state with id tradfri.0.G-131086.state updated: ack=true; val=false
                              tradfri.0	2018-09-20 12:07:20.726	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.state {"val":false,"ack":true,"ts":1537438040645,"q":0,"from":"system.adapter.tradfri.0","lc":1537438040595}
                              tradfri.0	2018-09-20 12:07:20.726	debug	 state with id tradfri.0.G-131086.activeScene updated: ack=true; val=196650
                              tradfri.0	2018-09-20 12:07:20.725	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.activeScene {"val":196650,"ack":true,"ts":1537438040644,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407650}
                              tradfri.0	2018-09-20 12:07:20.651	warn	object was: {"5850":0,"5851":254,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                              tradfri.0	2018-09-20 12:07:20.650	warn	found unknown property with key 9108
                              tradfri.0	2018-09-20 12:07:20.618	debug	updateResource(15004/131086) > sending payload: {"5850":0}
                              tradfri.0	2018-09-20 12:07:20.617	debug	updateResource(15004/131086) > comparing {"isProxy":true,"options":{},"name":"Schlafzimmer Deckenlicht","createdAt":1529075060,"instanceId":131086,"onOff":false,"dimmer":100,"deviceIDs":[65569,65573,6
                              tradfri.0	2018-09-20 12:07:20.617	debug	 state with id tradfri.0.G-131086.state updated: ack=false; val=false
                              tradfri.0	2018-09-20 12:07:20.616	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.state {"val":false,"ack":false,"ts":1537438040595,"q":0,"from":"system.adapter.web.0","lc":1537438040595}
                              tradfri.0	2018-09-20 12:07:20.223	debug	setting next timeout in 10000
                              tradfri.0	2018-09-20 12:07:20.222	debug	ping succeeded
                              tradfri.0	2018-09-20 12:07:17.389	debug	 state with id tradfri.0.VG-00001.state updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:17.389	debug	redis pmessage io.tradfri.0.* io.tradfri.0.VG-00001.state {"val":true,"ack":true,"ts":1537438037382,"q":0,"from":"system.adapter.tradfri.0","lc":1537438037382}
                              tradfri.0	2018-09-20 12:07:17.388	debug	 state with id tradfri.0.G-131086.state updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:17.388	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.state {"val":true,"ack":true,"ts":1537438037380,"q":0,"from":"system.adapter.tradfri.0","lc":1537438036949}
                              tradfri.0	2018-09-20 12:07:17.388	debug	 state with id tradfri.0.VG-00001.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:17.388	debug	redis pmessage io.tradfri.0.* io.tradfri.0.VG-00001.brightness {"val":100,"ack":true,"ts":1537438037379,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819636}
                              tradfri.0	2018-09-20 12:07:17.387	debug	 state with id tradfri.0.G-131086.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:17.387	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.brightness {"val":100,"ack":true,"ts":1537438037379,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819262}
                              tradfri.0	2018-09-20 12:07:17.133	debug	 state with id tradfri.0.L-65570.lightbulb.state updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:17.133	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65570.lightbulb.state {"val":true,"ack":true,"ts":1537438037118,"q":0,"from":"system.adapter.tradfri.0","lc":1537438037118}
                              tradfri.0	2018-09-20 12:07:17.133	debug	 state with id tradfri.0.L-65570.lightbulb.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:17.132	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65570.lightbulb.brightness {"val":100,"ack":true,"ts":1537438037117,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819376}
                              tradfri.0	2018-09-20 12:07:17.132	debug	 state with id tradfri.0.L-65570.lastSeen updated: ack=true; val=1537402458
                              tradfri.0	2018-09-20 12:07:17.132	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65570.lastSeen {"val":1537402458,"ack":true,"ts":1537438037116,"q":0,"from":"system.adapter.tradfri.0","lc":1537402508009}
                              tradfri.0	2018-09-20 12:07:17.131	debug	 state with id tradfri.0.L-65570.alive updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:17.131	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65570.alive {"val":true,"ack":true,"ts":1537438037113,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407539}
                              tradfri.0	2018-09-20 12:07:17.131	debug	 state with id tradfri.0.L-65571.lightbulb.state updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:17.130	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65571.lightbulb.state {"val":true,"ack":true,"ts":1537438037103,"q":0,"from":"system.adapter.tradfri.0","lc":1537438037103}
                              tradfri.0	2018-09-20 12:07:17.130	debug	 state with id tradfri.0.L-65571.lightbulb.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:17.130	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65571.lightbulb.brightness {"val":100,"ack":true,"ts":1537438037102,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819355}
                              tradfri.0	2018-09-20 12:07:17.130	debug	 state with id tradfri.0.L-65571.lastSeen updated: ack=true; val=1537402459
                              tradfri.0	2018-09-20 12:07:17.129	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65571.lastSeen {"val":1537402459,"ack":true,"ts":1537438037102,"q":0,"from":"system.adapter.tradfri.0","lc":1537402508028}
                              tradfri.0	2018-09-20 12:07:17.129	debug	 state with id tradfri.0.L-65571.alive updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:17.129	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65571.alive {"val":true,"ack":true,"ts":1537438037101,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407558}
                              tradfri.0	2018-09-20 12:07:17.128	debug	observeDevice > {"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb GU10 W 400lm","2":"","3":"1.2.214","6":1},"3311":[{"5850":1,"5851":254,"9003":0}],"5750":2,"9001":"Schrank Spot","9002":1529075106,"9003":6
                              tradfri.0	2018-09-20 12:07:17.128	debug	observeDevice > {"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb GU10 W 400lm","2":"","3":"1.2.214","6":1},"3311":[{"5850":1,"5851":254,"9003":0}],"5750":2,"9001":"Schreibtisch Spot","9002":1529075731,"90
                              tradfri.0	2018-09-20 12:07:17.091	debug	 state with id tradfri.0.L-65573.lightbulb.state updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:17.091	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65573.lightbulb.state {"val":true,"ack":true,"ts":1537438037083,"q":0,"from":"system.adapter.tradfri.0","lc":1537438037083}
                              tradfri.0	2018-09-20 12:07:17.090	debug	 state with id tradfri.0.L-65573.lightbulb.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:17.090	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65573.lightbulb.brightness {"val":100,"ack":true,"ts":1537438037082,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819335}
                              tradfri.0	2018-09-20 12:07:17.090	debug	 state with id tradfri.0.L-65573.lastSeen updated: ack=true; val=1537402461
                              tradfri.0	2018-09-20 12:07:17.089	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65573.lastSeen {"val":1537402461,"ack":true,"ts":1537438037082,"q":0,"from":"system.adapter.tradfri.0","lc":1537402508065}
                              tradfri.0	2018-09-20 12:07:17.089	debug	 state with id tradfri.0.L-65573.alive updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:17.089	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65573.alive {"val":true,"ack":true,"ts":1537438037081,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407608}
                              tradfri.0	2018-09-20 12:07:17.080	debug	observeDevice > {"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb GU10 W 400lm","2":"","3":"1.2.214","6":1},"3311":[{"5850":1,"5851":254,"9003":0}],"5750":2,"9001":"Bett Spot","9002":1529075846,"9003":6557
                              tradfri.0	2018-09-20 12:07:17.060	debug	 state with id tradfri.0.L-65572.lightbulb.state updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:17.060	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65572.lightbulb.state {"val":true,"ack":true,"ts":1537438037051,"q":0,"from":"system.adapter.tradfri.0","lc":1537438037051}
                              tradfri.0	2018-09-20 12:07:17.060	debug	 state with id tradfri.0.L-65572.lightbulb.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:17.060	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65572.lightbulb.brightness {"val":100,"ack":true,"ts":1537438037051,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819379}
                              tradfri.0	2018-09-20 12:07:17.059	debug	 state with id tradfri.0.L-65572.lastSeen updated: ack=true; val=1537402460
                              tradfri.0	2018-09-20 12:07:17.059	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65572.lastSeen {"val":1537402460,"ack":true,"ts":1537438037050,"q":0,"from":"system.adapter.tradfri.0","lc":1537402508049}
                              tradfri.0	2018-09-20 12:07:17.059	debug	 state with id tradfri.0.L-65572.alive updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:17.058	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65572.alive {"val":true,"ack":true,"ts":1537438037050,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407584}
                              tradfri.0	2018-09-20 12:07:17.052	debug	observeDevice > {"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb GU10 W 400lm","2":"","3":"1.2.214","6":1},"3311":[{"5850":1,"5851":254,"9003":0}],"5750":2,"9001":"Couch Spot","9002":1529075812,"9003":655
                              tradfri.0	2018-09-20 12:07:17.034	debug	 state with id tradfri.0.G-131086.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:17.033	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.brightness {"val":100,"ack":true,"ts":1537438037012,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819262}
                              tradfri.0	2018-09-20 12:07:17.033	debug	 state with id tradfri.0.G-131086.transitionDuration updated: ack=true; val=undefined
                              tradfri.0	2018-09-20 12:07:17.032	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.transitionDuration {"ack":true,"ts":1537438037010,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407652}
                              tradfri.0	2018-09-20 12:07:17.031	debug	 state with id tradfri.0.G-131086.state updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:17.028	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.state {"val":true,"ack":true,"ts":1537438037009,"q":0,"from":"system.adapter.tradfri.0","lc":1537438036949}
                              tradfri.0	2018-09-20 12:07:17.026	debug	 state with id tradfri.0.G-131086.activeScene updated: ack=true; val=196650
                              tradfri.0	2018-09-20 12:07:17.024	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.activeScene {"val":196650,"ack":true,"ts":1537438037008,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407650}
                              tradfri.0	2018-09-20 12:07:17.022	warn	object was: {"5850":1,"5851":254,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                              tradfri.0	2018-09-20 12:07:17.022	warn	found unknown property with key 9108
                              tradfri.0	2018-09-20 12:07:16.985	debug	updateResource(15004/131086) > sending payload: {"5850":1}
                              tradfri.0	2018-09-20 12:07:16.983	debug	updateResource(15004/131086) > comparing {"isProxy":true,"options":{},"name":"Schlafzimmer Deckenlicht","createdAt":1529075060,"instanceId":131086,"onOff":true,"dimmer":100,"deviceIDs":[65569,65573,65
                              tradfri.0	2018-09-20 12:07:16.981	debug	 state with id tradfri.0.G-131086.state updated: ack=false; val=true
                              tradfri.0	2018-09-20 12:07:16.980	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.state {"val":true,"ack":false,"ts":1537438036949,"q":0,"from":"system.adapter.web.0","lc":1537438036949}
                              tradfri.0	2018-09-20 12:07:10.197	debug	setting next timeout in 10000
                              tradfri.0	2018-09-20 12:07:10.194	debug	ping succeeded
                              tradfri.0	2018-09-20 12:07:01.061	debug	 state with id tradfri.0.G-131086.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:01.061	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.brightness {"val":100,"ack":true,"ts":1537438021053,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819262}
                              tradfri.0	2018-09-20 12:07:01.059	debug	 state with id tradfri.0.G-131086.state updated: ack=true; val=false
                              tradfri.0	2018-09-20 12:07:01.058	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.state {"val":false,"ack":true,"ts":1537438021051,"q":0,"from":"system.adapter.tradfri.0","lc":1537437895200}
                              tradfri.0	2018-09-20 12:07:01.044	debug	 state with id tradfri.0.VG-00001.state updated: ack=true; val=false
                              tradfri.0	2018-09-20 12:07:01.043	debug	redis pmessage io.tradfri.0.* io.tradfri.0.VG-00001.state {"val":false,"ack":true,"ts":1537438021037,"q":0,"from":"system.adapter.tradfri.0","lc":1537437895566}
                              tradfri.0	2018-09-20 12:07:01.041	debug	 state with id tradfri.0.VG-00001.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:01.041	debug	redis pmessage io.tradfri.0.* io.tradfri.0.VG-00001.brightness {"val":100,"ack":true,"ts":1537438021035,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819636}
                              tradfri.0	2018-09-20 12:07:00.973	debug	 object with id tradfri.0.G-131086.activeScene updated
                              tradfri.0	2018-09-20 12:07:00.965	info	updating possible scenes for group 131086: ["196650","196651","196652"]
                              tradfri.0	2018-09-20 12:07:00.965	info	received all groups and scenes
                              tradfri.0	2018-09-20 12:07:00.938	debug	 object with id tradfri.0.G-131086.activeScene updated
                              tradfri.0	2018-09-20 12:07:00.932	info	updating possible scenes for group 131086: ["196650","196651"]
                              tradfri.0	2018-09-20 12:07:00.907	debug	 object with id tradfri.0.G-131086.activeScene updated
                              tradfri.0	2018-09-20 12:07:00.895	info	updating possible scenes for group 131086: ["196650"]
                              tradfri.0	2018-09-20 12:07:00.836	debug	 state with id tradfri.0.G-131086.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:00.836	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.brightness {"val":100,"ack":true,"ts":1537438020816,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819262}
                              tradfri.0	2018-09-20 12:07:00.835	debug	 state with id tradfri.0.G-131086.transitionDuration updated: ack=true; val=undefined
                              tradfri.0	2018-09-20 12:07:00.835	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.transitionDuration {"ack":true,"ts":1537438020815,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407652}
                              tradfri.0	2018-09-20 12:07:00.835	debug	 state with id tradfri.0.G-131086.state updated: ack=true; val=false
                              tradfri.0	2018-09-20 12:07:00.835	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.state {"val":false,"ack":true,"ts":1537438020812,"q":0,"from":"system.adapter.tradfri.0","lc":1537437895200}
                              tradfri.0	2018-09-20 12:07:00.835	debug	 state with id tradfri.0.G-131086.activeScene updated: ack=true; val=196650
                              tradfri.0	2018-09-20 12:07:00.834	debug	redis pmessage io.tradfri.0.* io.tradfri.0.G-131086.activeScene {"val":196650,"ack":true,"ts":1537438020811,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407650}
                              tradfri.0	2018-09-20 12:07:00.834	debug	removing scenes with keys [] from group 131086
                              tradfri.0	2018-09-20 12:07:00.834	debug	adding scenes with keys [196650,196651,196652] to group 131086
                              tradfri.0	2018-09-20 12:07:00.833	info	got all scenes in group 131086: [196650,196651,196652]
                              tradfri.0	2018-09-20 12:07:00.810	warn	object was: {"5850":0,"5851":254,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                              tradfri.0	2018-09-20 12:07:00.810	warn	found unknown property with key 9108
                              tradfri.0	2018-09-20 12:07:00.809	debug	 state with id tradfri.0.L-65573.lightbulb.state updated: ack=true; val=false
                              tradfri.0	2018-09-20 12:07:00.809	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65573.lightbulb.state {"val":false,"ack":true,"ts":1537438020766,"q":0,"from":"system.adapter.tradfri.0","lc":1537437895268}
                              tradfri.0	2018-09-20 12:07:00.809	debug	 state with id tradfri.0.L-65573.lightbulb.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:00.809	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65573.lightbulb.brightness {"val":100,"ack":true,"ts":1537438020765,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819335}
                              tradfri.0	2018-09-20 12:07:00.808	debug	 state with id tradfri.0.L-65573.lastSeen updated: ack=true; val=1537402461
                              tradfri.0	2018-09-20 12:07:00.808	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65573.lastSeen {"val":1537402461,"ack":true,"ts":1537438020764,"q":0,"from":"system.adapter.tradfri.0","lc":1537402508065}
                              tradfri.0	2018-09-20 12:07:00.808	debug	 state with id tradfri.0.L-65573.alive updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:00.808	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65573.alive {"val":true,"ack":true,"ts":1537438020763,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407608}
                              tradfri.0	2018-09-20 12:07:00.807	debug	removing groups with keys []
                              tradfri.0	2018-09-20 12:07:00.807	debug	adding groups with keys [131086]
                              tradfri.0	2018-09-20 12:07:00.807	info	got all groups: [131086]
                              tradfri.0	2018-09-20 12:07:00.807	info	received all devices
                              tradfri.0	2018-09-20 12:07:00.806	debug	observeDevice > {"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb GU10 W 400lm","2":"","3":"1.2.214","6":1},"3311":[{"5850":0,"5851":254,"9003":0}],"5750":2,"9001":"Bett Spot","9002":1529075846,"9003":6557
                              tradfri.0	2018-09-20 12:07:00.806	debug	 state with id tradfri.0.L-65572.lightbulb.state updated: ack=true; val=false
                              tradfri.0	2018-09-20 12:07:00.806	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65572.lightbulb.state {"val":false,"ack":true,"ts":1537438020734,"q":0,"from":"system.adapter.tradfri.0","lc":1537437895301}
                              tradfri.0	2018-09-20 12:07:00.806	debug	 state with id tradfri.0.L-65572.lightbulb.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:00.805	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65572.lightbulb.brightness {"val":100,"ack":true,"ts":1537438020733,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819379}
                              tradfri.0	2018-09-20 12:07:00.805	debug	 state with id tradfri.0.L-65572.lastSeen updated: ack=true; val=1537402460
                              tradfri.0	2018-09-20 12:07:00.805	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65572.lastSeen {"val":1537402460,"ack":true,"ts":1537438020732,"q":0,"from":"system.adapter.tradfri.0","lc":1537402508049}
                              tradfri.0	2018-09-20 12:07:00.805	debug	 state with id tradfri.0.L-65572.alive updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:00.804	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65572.alive {"val":true,"ack":true,"ts":1537438020731,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407584}
                              tradfri.0	2018-09-20 12:07:00.804	debug	 state with id tradfri.0.L-65571.lightbulb.state updated: ack=true; val=false
                              tradfri.0	2018-09-20 12:07:00.804	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65571.lightbulb.state {"val":false,"ack":true,"ts":1537438020716,"q":0,"from":"system.adapter.tradfri.0","lc":1537437895290}
                              tradfri.0	2018-09-20 12:07:00.804	debug	 state with id tradfri.0.L-65571.lightbulb.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:00.803	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65571.lightbulb.brightness {"val":100,"ack":true,"ts":1537438020715,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819355}
                              tradfri.0	2018-09-20 12:07:00.803	debug	 state with id tradfri.0.L-65571.lastSeen updated: ack=true; val=1537402459
                              tradfri.0	2018-09-20 12:07:00.803	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65571.lastSeen {"val":1537402459,"ack":true,"ts":1537438020714,"q":0,"from":"system.adapter.tradfri.0","lc":1537402508028}
                              tradfri.0	2018-09-20 12:07:00.803	debug	 state with id tradfri.0.L-65571.alive updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:00.802	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65571.alive {"val":true,"ack":true,"ts":1537438020713,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407558}
                              tradfri.0	2018-09-20 12:07:00.802	debug	observeDevice > {"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb GU10 W 400lm","2":"","3":"1.2.214","6":1},"3311":[{"5850":0,"5851":254,"9003":0}],"5750":2,"9001":"Couch Spot","9002":1529075812,"9003":655
                              tradfri.0	2018-09-20 12:07:00.802	debug	observeDevice > {"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb GU10 W 400lm","2":"","3":"1.2.214","6":1},"3311":[{"5850":0,"5851":254,"9003":0}],"5750":2,"9001":"Schreibtisch Spot","9002":1529075731,"90
                              tradfri.0	2018-09-20 12:07:00.801	debug	 state with id tradfri.0.L-65570.lightbulb.state updated: ack=true; val=false
                              tradfri.0	2018-09-20 12:07:00.801	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65570.lightbulb.state {"val":false,"ack":true,"ts":1537438020687,"q":0,"from":"system.adapter.tradfri.0","lc":1537437895310}
                              tradfri.0	2018-09-20 12:07:00.801	debug	 state with id tradfri.0.L-65570.lightbulb.brightness updated: ack=true; val=100
                              tradfri.0	2018-09-20 12:07:00.801	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65570.lightbulb.brightness {"val":100,"ack":true,"ts":1537438020686,"q":0,"from":"system.adapter.tradfri.0","lc":1537425819376}
                              tradfri.0	2018-09-20 12:07:00.800	debug	 state with id tradfri.0.L-65570.lastSeen updated: ack=true; val=1537402458
                              tradfri.0	2018-09-20 12:07:00.800	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65570.lastSeen {"val":1537402458,"ack":true,"ts":1537438020684,"q":0,"from":"system.adapter.tradfri.0","lc":1537402508009}
                              tradfri.0	2018-09-20 12:07:00.800	debug	 state with id tradfri.0.L-65570.alive updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:00.799	debug	redis pmessage io.tradfri.0.* io.tradfri.0.L-65570.alive {"val":true,"ack":true,"ts":1537438020683,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407539}
                              tradfri.0	2018-09-20 12:07:00.799	debug	 state with id tradfri.0.RC-65569.lastSeen updated: ack=true; val=1537391279
                              tradfri.0	2018-09-20 12:07:00.799	debug	redis pmessage io.tradfri.0.* io.tradfri.0.RC-65569.lastSeen {"val":1537391279,"ack":true,"ts":1537438020664,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407519}
                              tradfri.0	2018-09-20 12:07:00.799	debug	 state with id tradfri.0.RC-65569.alive updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:00.798	debug	redis pmessage io.tradfri.0.* io.tradfri.0.RC-65569.alive {"val":true,"ack":true,"ts":1537438020663,"q":0,"from":"system.adapter.tradfri.0","lc":1537399407517}
                              tradfri.0	2018-09-20 12:07:00.798	debug	observeDevice > {"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb GU10 W 400lm","2":"","3":"1.2.214","6":1},"3311":[{"5850":0,"5851":254,"9003":0}],"5750":2,"9001":"Schrank Spot","9002":1529075106,"9003":6
                              tradfri.0	2018-09-20 12:07:00.798	debug	observeDevice > {"3":{"0":"IKEA of Sweden","1":"TRADFRI remote control","2":"","3":"1.2.214","6":3,"9":87},"5750":0,"9001":"TRADFRI remote control","9002":1529075058,"9003":65569,"9019":1,"9020":15373
                              tradfri.0	2018-09-20 12:07:00.632	debug	removing devices with keys []
                              tradfri.0	2018-09-20 12:07:00.632	debug	adding devices with keys [65569,65570,65571,65572,65573]
                              tradfri.0	2018-09-20 12:07:00.631	info	got all devices: [65571,65572,65569,65573,65570]
                              tradfri.0	2018-09-20 12:07:00.204	debug	 state with id tradfri.0.info.connection updated: ack=true; val=true
                              tradfri.0	2018-09-20 12:07:00.185	debug	redis pmessage io.tradfri.0.* io.tradfri.0.info.connection {"val":true,"ack":true,"ts":1537438020172,"q":0,"from":"system.adapter.tradfri.0","lc":1537438020172}
                              tradfri.0	2018-09-20 12:07:00.179	debug	Connection successful
                              tradfri.0	2018-09-20 12:07:00.158	debug	system.adapter.admin.0: logging true
                              tradfri.0	2018-09-20 12:07:00.156	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1537438019823,"q":0,"from":"system.adapter.admin.0","lc":1537438019823}
                              host.ioBroker-RasPi	2018-09-20 12:06:55.797	info	instance system.adapter.tradfri.0 started with pid 13499
                              Info log nach ein und ausschalten von gruppe:
                              tradfri.0	2018-09-20 12:11:24.725	warn	object was: {"5850":0,"5851":254,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                              tradfri.0	2018-09-20 12:11:24.724	warn	found unknown property with key 9108
                              tradfri.0	2018-09-20 12:11:22.414	warn	object was: {"5850":1,"5851":254,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                              tradfri.0	2018-09-20 12:11:22.414	warn	found unknown property with key 9108
                              tradfri.0	2018-09-20 12:11:09.708	info	updating possible scenes for group 131086: ["196650","196651","196652"]
                              tradfri.0	2018-09-20 12:11:09.707	info	received all groups and scenes
                              tradfri.0	2018-09-20 12:11:09.669	info	updating possible scenes for group 131086: ["196650","196651"]
                              tradfri.0	2018-09-20 12:11:09.638	info	updating possible scenes for group 131086: ["196650"]
                              tradfri.0	2018-09-20 12:11:09.577	info	got all scenes in group 131086: [196650,196651,196652]
                              tradfri.0	2018-09-20 12:11:09.564	warn	object was: {"5850":0,"5851":254,"9001":"Schlafzimmer Deckenlicht","9002":1529075060,"9003":131086,"9018":{"15002":{"9003":[65569,65573,65572,65571,65570]}},"9039":196650,"9108":0}
                              tradfri.0	2018-09-20 12:11:09.562	warn	found unknown property with key 9108
                              tradfri.0	2018-09-20 12:11:09.539	info	got all groups: [131086]
                              tradfri.0	2018-09-20 12:11:09.539	info	received all devices
                              tradfri.0	2018-09-20 12:11:09.410	info	got all devices: [65571,65572,65569,65573,65570]
                              tradfri.0	2018-09-20 12:11:08.567	info	startfile = /opt/iobroker/node_modules/iobroker.tradfri/main.js
                              tradfri.0	2018-09-20 12:11:08.462	info	starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.tradfri, node: v8.11.1
                              host.ioBroker-RasPi	2018-09-20 12:11:06.478	info	instance system.adapter.tradfri.0 started with pid 13512
                              host.ioBroker-RasPi	2018-09-20 12:11:04.007	info	instance system.adapter.tradfri.0 terminated with code 0 (OK)
                              Nochmal vielen dank.
                              LG
                              Giovanni
                              • K Offline
                                Kueppert
                                Liegt evtl am neuen js1.5.3 hatte damit auch meine Probleme… Bin auf 1.4.2 zurück via Backup und alles funktionierte wie gehabt. Würde aktuell js1.5.3 meiden. Da wird noch dran gearbeitet glaub ich gelesen zu haben.
