  4. Update discovery geht nicht
4 Beiträge 3 Kommentatoren 598 Aufrufe
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    Wie oben geschrieben geht das update nicht.
    Anbei log Hinweis.
    iobroker	2018-07-29 08:38:02.595	info	exit 25
    iobroker	2018-07-29 08:38:02.579	info	Cannot install iobroker.discovery: 1
    iobroker	2018-07-29 08:38:02.579	info	npm ERR! code 1
    iobroker	2018-07-29 08:38:02.563	info
    iobroker	2018-07-29 08:38:02.563	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    iobroker	2018-07-29 08:38:02.563	info	WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 (node_modules\serialport):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 install: `prebuild-install || node-gyp rebuild
    iobroker	2018-07-29 08:38:02.229	info
    iobroker	2018-07-29 08:38:02.229	info	gyp ERR! not ok
    iobroker	2018-07-29 08:38:02.229	info	gyp ERR! node-gyp -v v3.4.0
    iobroker	2018-07-29 08:38:02.229	info	gyp ERR! node -v v6.9.0
    iobroker	2018-07-29 08:38:02.229	info	gyp ERR! cwd C:\ioBroker\node_modules\iobroker.discovery\node_modules\serialport
    iobroker	2018-07-29 08:38:02.229	info	gyp ERR! System Windows_NT 6.1.7601gyp ERR! command "C:\\Program Files (x86)\\nodejs\\node.exe" "C:\\Program Files (x86)\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild
    iobroker	2018-07-29 08:38:02.229	info	gyp ERR! stack at FSReqWrap.oncomplete (fs.js:123:15)
    iobroker	2018-07-29 08:38:02.229	info	gyp ERR! stack at C:\Program Files (x86)\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:404:11
    iobroker	2018-07-29 08:38:02.229	info	gyp ERR! stack at failNoPython (C:\Program Files (x86)\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:449:14)
    iobroker	2018-07-29 08:38:02.229	info	ERR! configure error gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.
    iobroker	2018-07-29 08:38:01.858	info	prebuild-install WARN install No prebuilt binaries found (target=6.9.0 runtime=node arch=ia32 platform=win32)
    iobroker	2018-07-29 08:37:57.594	info	npm install --production (System call) in "C:/ioBroker/node_modules/iobroker.discovery"
    iobroker	2018-07-29 08:37:57.578	info
    iobroker	2018-07-29 08:37:57.578	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    iobroker	2018-07-29 08:37:57.578	info	WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 (node_modules\iobroker.discovery\node_modules\serialport):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 install: `prebu
    iobroker	2018-07-29 08:37:57.286	info
    iobroker	2018-07-29 08:37:57.286	info	gyp ERR! node-gyp -v v3.4.0gyp ERR! not ok
    iobroker	2018-07-29 08:37:57.286	info	ERR! node -v v6.9.0
    iobroker	2018-07-29 08:37:57.286	info	gyp ERR! cwd C:\ioBroker\node_modules\iobroker.discovery\node_modules\serialport
    iobroker	2018-07-29 08:37:57.286	info	gyp ERR! command "C:\\Program Files (x86)\\nodejs\\node.exe" "C:\\Program Files (x86)\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
    iobroker	2018-07-29 08:37:57.286	info	gyp ERR! System Windows_NT 6.1.7601
    iobroker	2018-07-29 08:37:57.286	info	gyp ERR! stack at FSReqWrap.oncomplete (fs.js:123:15)
    iobroker	2018-07-29 08:37:57.286	info	gyp ERR! stack at C:\Program Files (x86)\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:404:11
    iobroker	2018-07-29 08:37:57.286	info	gyp ERR! stack at failNoPython (C:\Program Files (x86)\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:449:14)
    iobroker	2018-07-29 08:37:57.286	info	ERR! configure error gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.
    iobroker	2018-07-29 08:37:56.782	info	prebuild-install WARN install No prebuilt binaries found (target=6.9.0 runtime=node arch=ia32 platform=win32)
    iobroker	2018-07-29 08:37:43.275	info	npm install iobroker.discovery@1.2.1 --production --save --prefix "C:/ioBroker" (System call)
    iobroker	2018-07-29 08:37:41.989	info	NPM version: 3.10.8
    iobroker	2018-07-29 08:37:40.119	info	Update discovery from @1.1.1 to @1.2.1
    iobroker	2018-07-29 08:37:39.389	info	upgrade discovery
    vielleicht kann ja jemand damit war anfangen.
    mfg
    Danke.
    • apollon77A Offline
      Ja da steht das er Python nicht finden kann ich tippe auf Windows System.
      Google mal nach en Windows Build Tools für node und installier das mal. Dann sicherstellen das Python im Pfad ist.
      Aber Discovery geh sich so. Nur die serielle Suche geht nicht.
      Gesendet vom Handy …
        aski71
        Ich hatte gerade ein ähnliches Problem:
        Habe auf einem Ubuntu System versucht, Discovery auf 1.2.1 upzugraden.
        Der Upgradeprozess hing fest und ich hatte danach Mühe, ioBroker überhaupt wieder ans Laufen zu bringen.
        Nach einem npm install iobroker.discovery ging gar nix mehr.
        Nach iobroker start verabschiedeten sich alle Adapter und die Admin-Oberfläche zeigte auch nix mehr an.
        Ich habe es schließlich dann geschafft mittels npm install iobroker.discovery@1.2.0 wieder den alten Discovery zu installieren. Das fliegt wieder und jetzt trau mich nicht mehr … :shock:
          Sollte nicht passieren. Hast du die Ausgaben der Shell? Oder andere Logs?
