  4. Gelöst - Problem - Node Red startet nicht mehr
    1.0k
    6.1k
12 Beiträge 2 Kommentatoren 11.1k Aufrufe 2 Beobachtet
  • liv-in-skyL Offline
    liv-in-skyL Offline
    liv-in-sky
    mein node red adapter geht nicht mehr - kann mir bitte jemand helfen
    !!!wichtig wäre, die flows zu retten!!!
    mit folgender fehlermeldung
    node-red.0	2018-07-26 22:30:11.829	info	node-red exited with 1
    -----------------------		ile using your chosen key the next time you deploy a change.
    -----------------------		our settings file. Node-RED will then re-encrypt your credentials
    -----------------------		ou should set your own key using the 'credentialSecret' option in
    -----------------------		our credentials.
    -----------------------		ile will not be recoverable, you will have to delete it and re-enter
    -----------------------		f the system-generated key is lost for any reason, your credentials
    -----------------------		our flow credentials file is encrypted using a system-generated key.
    node-red.0	2018-07-26 22:30:11.165	warn	26 Jul 22:30:11 - [warn]
    node-red.0	2018-07-26 22:30:10.982	warn	26 Jul 22:30:10 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    node-red.0	2018-07-26 22:30:10.979	warn	26 Jul 22:30:10 - [warn] ------------------------------------------------------
    node-red.0	2018-07-26 22:30:10.978	warn	26 Jul 22:30:10 - [warn] [node-red/rpi-gpio] Info : Ignoring Raspberry Pi specific node
    node-red.0	2018-07-26 22:30:10.975	warn	26 Jul 22:30:10 - [warn] ------------------------------------------------------
    host.raspberry3	2018-07-26 22:30:04.917	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
    ical.0	2018-07-26 22:30:03.901	info	starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.ical, node: v8.11.2
    dwd.0	2018-07-26 22:30:03.510	info	starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v8.11.2
    host.raspberry3	2018-07-26 22:30:00.086	info	instance system.adapter.ical.0 started with pid 25398
    host.raspberry3	2018-07-26 22:30:00.031	info	instance system.adapter.dwd.0 started with pid 25393
    node-red.0	2018-07-26 22:29:57.952	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    node-red.0	2018-07-26 22:29:52.947	info	node-red exited with 1
      liv-in-skyL Offline
      liv-in-sky
      habe node-red aktualisiert - jetzt neuer fehler
      `node-red.0	2018-07-27 10:45:28.780	info	node-red exited with 1
      node-red.0	2018-07-27 10:45:28.759	debug	27 Jul 10:45:28 - Error: listen EADDRINUSE :::1825 at Object._errnoException (util.js:992:11) at _exceptionWithHostPort (util.js:1014:20) at Server.setupListenHandle [as _listen2] (net.js:
      node-red.0	2018-07-27 10:45:28.749	debug	27 Jul 10:45:28 - [red] Uncaught Exception:
      node-red.0	2018-07-27 10:45:28.735	debug	27 Jul 10:45:28 - [info] Started flows
      node-red.0	2018-07-27 10:45:28.538	debug	27 Jul 10:45:28 - [info] [join-server:96c239cd.35d408] Starting server on port 1825...
      node-red.0	2018-07-27 10:45:28.519	debug	27 Jul 10:45:28 - [info] [join-server:deb43e1d.7db4a] Starting server on port 1825...
      node-red.0	2018-07-27 10:45:28.160	debug	27 Jul 10:45:28 - [info] Starting flows
      node-red.0	2018-07-27 10:45:28.006	debug	27 Jul 10:45:28 - [info] Server now running at http://127.0.0.1:1880/
      node-red.0	2018-07-27 10:45:27.961	warn	27 Jul 10:45:27 - [info] User directory : /opt/iobroker/iobroker-data/node-red/ 27 Jul 10:45:27 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable 27 Jul 10:45:27 - [info] Fl
      node-red.0	2018-07-27 10:45:27.955	warn	27 Jul 10:45:27 - [warn] [node-red/rpi-gpio] Info : Ignoring Raspberry Pi specific node 27 Jul 10:45:27 - [warn] ------------------------------------------------------ 27 Jul 10:45:27 - [info] Setting
      node-red.0	2018-07-27 10:45:27.950	warn	27 Jul 10:45:27 - [warn] ------------------------------------------------------
      node-red.0	2018-07-27 10:45:27.021	debug	27 Jul 10:45:27 - [info] Dashboard version 2.9.6 started at /ui
      node-red.0	2018-07-27 10:45:26.820	debug	27 Jul 10:45:26 - [info] Polymer started at /polymer
      node-red.0	2018-07-27 10:45:20.706	debug	27 Jul 10:45:20 - [info] Loading palette nodes
      node-red.0	2018-07-27 10:45:19.710	debug	27 Jul 10:45:19 - [info] Node-RED version: v0.18.7 27 Jul 10:45:19 - [info] Node.js version: v8.11.2 27 Jul 10:45:19 - [info] Linux 4.9.0-4-686-pae ia32 LE
      node-red.0	2018-07-27 10:45:19.704	debug	27 Jul 10:45:19 - [info] Welcome to Node-RED ===================`
      in der zweiten zeile steht 1825 - das ist der port, den ich unter einer nachinstallierten node definiert habe - als ich dort etwas geändert hatte, begannen die probleme
      node-red-contrib-join-joaoapps  - sendet über join zu tasker (handy)
      kann ich diese node über commando-zeile deaktivieren
      suche dringend hilfe[/red]
        liv-in-skyL Offline
        liv-in-sky
        konnte problem so lösen:
        es war ein fehler von einer bestimmten node. diese node habe ich in '/iobroker/iobroker-data/node-red/config.js' disabled. danach konnte ich das webinterface zu node-red wieder öffnen. ich habe das falsche setting der node geändert bzw. gelöscht. danach node-red stop - node in config.js wieder enabled. node-red start.
        • liv-in-skyL liv-in-sky
          SpeedyBlade
          @liv-in-sky
          wie hast du die config.js disabled?
          • S SpeedyBlade
            @liv-in-sky
            liv-in-skyL Offline
            liv-in-skyL Offline
            liv-in-sky
            @SpeedyBlade ist ne zeit her - aber ich glaube - in der datei habe ich die node auf false gesetzt
              SpeedyBlade
              @liv-in-sky
              ich bin komplett neu auf dem Gebiet, da bräuchte ich mal eine step-by-step anleitung ;)
              wo bekomme ich das file her bzw. wie kann ich drauf zugreifen.
              das node red ist auf iobroker installiert
              S liv-in-skyL 2 Antworten Letzte Antwort
              • S SpeedyBlade
                @liv-in-sky
                SpeedyBlade
                schrieb am zuletzt editiert von SpeedyBlade
                @SpeedyBlade
                node-red.0 2019-09-05 16:49:00.918 info node-red exited with 1
                node-red.0 2019-09-05 16:49:00.575 info States connected to redis: 127.0.0.1:6379
                node-red.0 2019-09-05 16:49:00.379 error no connection to objects DB
                node-red.0 2019-09-05 16:49:00.107 warn 5 Sep 16:49:00 - [warn] Projekte inaktiviert: setze editorTheme.projects.enabled=true zum Aktivieren
                Es sind auch keine Objekte von node red vorhanden
                • S SpeedyBlade
                  @liv-in-sky
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  liv-in-sky
                  @SpeedyBlade
                  bist du sicher, dass es um den selben fehler geht - ich hatte damals einen programmierfehlr gemacht, de node red ein problem machte - hast du was geändert bevor der fehler kam ?
                    SpeedyBlade
                    ich habe bereits mit den flows rumgespielt und es haben auch schon ein paar funktionert
                    dann hatte ich probleme mit dem alexa flow (https://flows.nodered.org/node/node-red-contrib-alexa-local) dort ein wenig probiert und geändert und auf einmal startet nun node red nicht mehr.
                    ps.: der alexa local flow hatte tage zuvor noch funktioniert
                    • S SpeedyBlade
                      @SpeedyBlade
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      @SpeedyBlade
                      ich habe gerade nachgesehen und die datei nicht mehr gefunden - vielleicht wurde das etwas geändert - ich bin froh wenn nodered läuft und habe mittlerweile so viel wie möglich in javascript verwirklicht
                      was du probieren kannst
                      • stoppe nodered instanz in iobroker
                      • öffne console bzw terminal auf ioborkerserver mit putty oder ähnlichen
                        folgender befehl
                      nano /opt/iobroker/iobroker-data/node-red/flows.json
                      darin findest du die tabs in nodered - alle abläufe sindin diesen diesen tabs, die sich flows nennen - vorhanden
                      rote pfeile:
                      suche den namen deines flows und ersetze bei deinem flow hinter "disabled:false" das false mit true - anschliessend drücke die ALT-Taste - bleibt gedrückt und zusätzlich die x-taste - bestätige mit "j" oder "y"
                      wieder in iobroker: versuche nodered zu starten und lösche das "defekte node-module" - dann kannst du mit einem doppelklick auf dem flow-tab diesen wieder enablen
                        SpeedyBlade
                        super...genau das war es...Fehlerhafter flow...
                        vielen Dank
                        Ps.: kennst du das Problem mit dem Alexa-local flow auch?
                        zuerst ist alles online, kaum wird in der alexa web-app gesucht, geht dieser dann auf discovery und es wird nichts gefunden
                        • S SpeedyBlade
                          vielen Dank
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          @SpeedyBlade sorry - nutze ich nicht
                          habe gerade entdeckt:
                          es geht einfacher - ohne terminal/console
                          wenn du unter objecte-tab - unter der nodered instanz - den datenpunbkt flows siehst - kannst du diesen öffnen ( mit bleisift ganz rechts) - darin auf die raw ansicht wechseln und du bekommst die selbe liste - darin kannst du dann auch ändern
