  4. Homebridge-Adapter: Funktionierende Plugins und Beispiele
    6.3k
238 Beiträge 62 Kommentatoren 81.5k Aufrufe 44 Beobachtet
    @phoenixcr dann stimmt ja irgendwas in der Konfig nicht. Logfile?
    PhoenixCR
    #141
    @ilovegym habe es nochmal versucht mit deine einstellungen ...
    anbei der Log ...
    ham.0	2021-05-12 09:45:19.362	info	(83738) All NPM Modules got reinstalled/updated ... restarting ...
    ham.0	2021-05-12 09:45:19.343	info	Run `npm audit` for details.
    ham.0	2021-05-12 09:45:19.343	info	a different dependency.
    ham.0	2021-05-12 09:45:19.343	info	Some issues need review, and may require choosing
    ham.0	2021-05-12 09:45:19.343	info	npm audit fix
    ham.0	2021-05-12 09:45:19.343	info	To address issues that do not require attention, run:
    ham.0	2021-05-12 09:45:19.343	info	5 high severity vulnerabilities
    ham.0	2021-05-12 09:45:19.343	info	(83738)
    ham.0	2021-05-12 09:45:19.301	info	run `npm fund` for details
    ham.0	2021-05-12 09:45:19.301	info	(83738) 1 package is looking for funding
    ham.0	2021-05-12 09:45:19.299	info	(83738)
    ham.0	2021-05-12 09:45:19.297	info	up to date, audited 208 packages in 8s
    ham.0	2021-05-12 09:45:19.297	info	(83738)
    javascript.0	2021-05-12 09:45:19.082	info	(23009) script.js.Schrank.Server_Kühlung_PWM: PWM AUS
    ham.0	2021-05-12 09:45:10.942	info	(83738) npm install homebridge-govee --production --loglevel error (System call)
    ham.0	2021-05-12 09:45:10.940	info	(83738) Install/Update homebridge-govee
    ham.0	2021-05-12 09:45:10.939	info	(83738) Install/Update the following Libraries: homebridge-govee
    ham.0	2021-05-12 09:45:10.904	info	(83738) starting. Version 4.0.1 in /opt/iobroker/node_modules/iobroker.ham, node: v14.16.1, js-controller: 3.2.16
    host.HomeAutomation	2021-05-12 09:45:09.695	info	instance system.adapter.ham.0 started with pid 83738
    • UncleSamU Offline
      UncleSamU Offline
      UncleSam
      #142
      @PhoenixCR Jetzt gibt es glaube ich ein Durcheinander:
      • zuerst muss die Konfiguration des Adapters stimmen oder leer sein (in den Instanz-Einstellungen, nicht im Tab)
      • wenn die Konfiguration dort stimmt, sollte der Tab funktionieren
      Welche Module willst du nun installieren (unten hattest du Govee und Homesung, nun hast du homesung-tv)?
      Kannst du nochmals die gesamte Konfigurationsdatei aus der Instanz-Konfiguration zeigen (siehe unten)?
      P 1 Antwort Letzte Antwort
      • UncleSamU UncleSam
        PhoenixCR
        #143
        @unclesam
        der ist leer,
        aber über den Tab kann ich nicht der Homesung Modul installieren.
        ? 1 Antwort Letzte Antwort
        • P PhoenixCR
          @unclesam
          der ist leer,
          #144
          @phoenixcr sehe gerade, du verwendest V4.01, zieh dir mal die aktuelle 4.0.2 aus dem latest.. vielleicht hilft das.
          Und mach anschliessend n upload, sicher ist sicher...
            PhoenixCR
            #145
            @ilovegym es gibt aber keine neuere Version ...
            wie soll ich es updaten?
              PhoenixCR
              #146
              Ich habe es über terminal gemacht steht aber trotzdem 4.01 ...
              ham.0	2021-05-13 05:02:46.349	info	(164338) No additional Libraries to install ...
              ham.0	2021-05-13 05:02:46.314	info	(164338) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v14.16.1, js-controller: 3.2.16
              • P PhoenixCR
                #147
                @phoenixcr Moin, hast du danach n Upload gemacht?
                  PhoenixCR
                  #148
                  @ilovegym Moin. Nein und leider weis ich auch nicht wie ...
                  Kannst du bitte es mir erklären?
                  Danke!
                  • P PhoenixCR
                    Danke!
                    BBTownB Offline
                    BBTownB Offline
                    BBTown
                    #149
                    ioBroker auf NUC (VM debian v13 (Trixie ), node v22.22.0 npm v10.9.4, js-controller v7.2.2 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
                    • BBTownB BBTown
                      PhoenixCR
                      #150
                      @bbtown Super. Danke. Hat geklappt 😉
                      • P PhoenixCR
                        BBTownB Offline
                        BBTownB Offline
                        BBTown
                        #151
                        @phoenixcr also hast Du nun die 4.0.2.?
                        • BBTownB BBTown
                          PhoenixCR
                          schrieb am zuletzt editiert von PhoenixCR
                          #152
                          @bbtown ja hab ich ...
                          Allerdings funzt jetzt die Samsung (homesung) Modul nicht mehr ...
                          wenn ich es hier fragen darf, ist der Konfig richtig oder sieht ihr etwas das nicht stimmt?
                          Bin kein pro ... aber lerne gern ...
                            "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                            "accessories": [],
                            "platforms": [
                                "platform": "SamsungTV",
                                "devices": [
                                    "name": "[TV] Living room",
                                    "ip": "192.168.1.110",
                                    "identity": {
                                      "sessionId": "1",
                                      "aesKey": "0964262928ba5aecbadd51ec8e296088"
                                    "power": {
                                      "name": "Power TV",
                                      "key": "KEY_POWEROFF",
                                      "enableCEC": "false",
                                      "switches": [
                                          "name": "Vol Down 5",
                                          "delay": 1000,
                                          "command": "5*KEY_VOLDOWN"
                                          "name": "Channel 12",
                                          "command": [
                                            "KEY_1",
                                            "KEY_2"
                                          "name": "Play with sound",
                                          "command": [
                                            "5*KEY_VOLDOWN",
                                            "5*KEY_VOLUP"
                                          "name": "Do something",
                                          "command": {
                                            "keys": "5*KEY_VOLDOWN",
                                            "delay": 2000
                                          "name": "Do more of something",
                                          "command": {
                                            "keys": [
                                              "KEY_1",
                                              "KEY_2"
                                            "delay": 1000
                                          "name": "Launch Netflix",
                                          "command": [
                                              "keys": "KEY_CONTENTS",
                                              "delay": 2000
                                              "keys": [
                                                "3*KEY_LEFT",
                                                "KEY_ENTER"
                                              "delay": 1000
                                "name": "Govee",
                                "apiKey": "apikey",
                                "refreshTime": 30,
                                "controlInterval": 500,
                                "forceUpdates": true,
                                "debug": true,
                                "platform": "Govee"
                          • P PhoenixCR
                              "accessories": [],
                              "platforms": [
                                  "devices": [
                                      "identity": {
                                        "sessionId": "1",
                                      "power": {
                                        "name": "Power TV",
                                        "switches": [
                                            "delay": 1000,
                                            "command": [
                                              "KEY_1",
                                              "KEY_2"
                                            "command": [
                                              "5*KEY_VOLDOWN",
                                              "5*KEY_VOLUP"
                                            "command": {
                                              "delay": 2000
                                            "command": {
                                              "keys": [
                                                "KEY_1",
                                                "KEY_2"
                                              "delay": 1000
                                            "command": [
                                                "delay": 2000
                                                "keys": [
                                                  "3*KEY_LEFT",
                                                  "KEY_ENTER"
                                                "delay": 1000
                                  "name": "Govee",
                                  "apiKey": "apikey",
                                  "refreshTime": 30,
                                  "debug": true,
                                  "platform": "Govee"
                            BBTownB Offline
                            BBTownB Offline
                            BBTown
                            #153
                            @phoenixcr
                            Wenn sich das Gerät nicht geändert (neues Samsung Modell) und die Konfiguration zuvor funktioniert hat, dann würde ich als erstes prüfen ob denn der Fernseher auch tatsächlich immer unter der angegebenen IP erreichbar ist, oder ob der ggf. per DHCP immer wieder eine andere IP bekommt.
                            • BBTownB BBTown
                              @phoenixcr
                              PhoenixCR
                              #154
                              @bbtown der IP ist fix, eigentlich hat sich nichts geändert und es hat funktioniert ...
                              ich werde es noch probieren.
                              Auf jeden Fall danke für eure Hilfe!
                                @phoenixcr
                                bei mir funktioniert das alle so in der Configdatei:
                                  "accessories": [],
                                  "platforms": [
                                      "name": "Govee",
                                      "lightDevices": [
                                      "platform": "Govee",
                                      "apiKey": "blablablaapikey",
                                      "refreshTime": 30,
                                      "debug": true
                                      "name": "eWeLink",
                                      "mode": "auto",
                                      "platform": "eWeLink",
                                      "countryCode": "49",
                                      "username": "email",
                                      "password": "password"
                                      "platform": "yeelight",
                                      "name": "Yeelight"
                                Wichtig war, sonst funktioniert Govee nicht, anschliessend in der HAM Config-Seite den Schraubenschlüssel aufzurufen und dort folgendes eintragen:
                                so funktionierts hier auf jeden Fall.. :-)
                                gelberlemmyG Offline
                                gelberlemmy
                                #155
                                @ilovegym sagte in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
                                "controlInterval": 500, "forceUpdates": true, "debug": true
                                Guten Morgen, ich habe da ja wie gehabt immer noch die Problme , dass ich die Govee Geräte ein und ausschalten kann. Aber nicht die Farbe ändern, oder die Helligkeit. Hat das jemand schon geschafft ? Wie gesagt, ich kann die Änderungen sehen, wenn ich die Einstellungen über die Govee App tätige. Aber halt Ändern nicht....
                                • 6 Offline
                                  6 Offline
                                  652145
                                  #156
                                  Hallo Zusammen,
                                  Es gibt ja für die Homebrige das Plugin homebridge-gsh. (Homebridge to Google Smart Home)
                                  https://www.npmjs.com/package/homebridge-gsh
                                  Nun stelle ich mir folgendes vor.
                                  Wäre es möglich, via dem Homebridge-Adapter für den iobroker, Geräte im iobroker über den Google Assistant zu steuern?
                                  Steuerungsweg wäre wie folgt:
                                  Sprachbefehl von einem Google Assistant fähigen Gerät --> Homebridge mit dem homebridge-gsh Plugin --> iobroker Geräte
                                  Danke für die Infos.
                                  • 6 652145
                                    Hallo Zusammen,
                                    #157
                                    @652145 Ja über eigene Skripte ist das bestimmt möglich
                                    • apollon77A apollon77
                                      @EnoceanEltako sagte in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
                                      Tuya LAN Plugin
                                      Warum nimmst Du nicht den Tuya adapter?
                                      Clown007
                                      schrieb am zuletzt editiert von Clown007
                                      #158
                                      @apollon77 Ich kämpfe auch mit dem Tuya Adapter bei einer Neuinstallation. Der Adapter bleibt gelb und wird nicht grün. Leider finde ich auch keine Fehlermeldung. Weder im IoBroker log noch auf Raspi. Beim Starten des Proxy ist die Webseite auch nicht erreichbar, so dass ich das Zertifikat importieren kann. Die Ports werden auf dem Raspi auch nicht "belegt". Im Debug log sehe ich sogar ich die Geräte (Discovered encrypted device and store for later usage)
                                      Da dachte ich, dass diese Adapter mit der Nutzung der offiziellen API eine gute Lösung ist. Die Verbindung klappt auch und die grundsätzlichen Daten der Geräte (WLAN Steckdosen) werden angezeigt (Seriennummer, Hardware ....) unter Accessory Information. Leider werden aber keine Verbrauchsdaten oder der Relais Zustand angezeigt.
                                      • C Clown007
                                        #159
                                        @clown007 Naja, es gibt ja noch mehr als nur "Fehler im Log". Was sind denn die normalen Log Ausgaben? Ggf mal Debug Log aktivieren. Was steht denn da?
                                        C 1 Antwort Letzte Antwort
                                          Clown007
                                          #160
                                          @apollon77 Adapter auf debug neu gestartet:
                                          tuya.0	2021-05-31 00:50:28.894	debug	(3675) Discovered encrypted device and store for later usage: 192.168.178.120:56083 - 000055aa00000000000000130000009c00000000d09766676f3369eb10b5e9f132fd802a6387aec1416c007311d638b3c1b7936c6245e7e31f
                                          tuya.0	2021-05-31 00:50:28.446	debug	(3675) Discovered encrypted device and store for later usage: 192.168.178.117:53094 - 000055aa00000000000000130000009c00000000d09766676f3369eb10b5e9f132fd802ac988b78b3f9aff90d62f64274f6af05ae69fe60c2a
                                          tuya.0	2021-05-31 00:50:25.853	debug	(3675) connected set to false
                                          tuya.0	2021-05-31 00:50:25.702	info	(3675) Listen for encrypted local Tuya devices on port 6667
                                          tuya.0	2021-05-31 00:50:25.701	info	(3675) Listen for local Tuya devices on port 6666
                                          tuya.0	2021-05-31 00:50:25.688	info	(3675) Existing devices initialized
                                          tuya.0	2021-05-31 00:50:25.360	info	(3675) starting. Version 3.5.9 in /opt/iobroker/node_modules/iobroker.tuya, node: v12.22.1, js-controller: 3.2.16
                                          tuya.0	2021-05-31 00:50:24.085	debug	(3675) Plugin sentry Initialize Plugin (enabled=true)
                                          tuya.0	2021-05-31 00:50:09.058	info	(3271) Got terminate signal TERMINATE_YOURSELF
                                          tuya.0	2021-05-31 00:50:08.949	info	(3271) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          tuya.0	2021-05-31 00:50:08.948	debug	(3271) Plugin sentry destroyed
                                          tuya.0	2021-05-31 00:50:08.946	info	(3271) terminating
                                          tuya.0	2021-05-31 00:50:05.943	info	(3271) Got terminate signal TERMINATE_YOURSELF
                                          tuya.0	2021-05-31 00:49:45.388	debug	(3271) system.adapter.admin.0: logging true
