  4. [gelöst]Adapterkonfiguration: foobar2000.0
    6.0k
4 Beiträge 2 Kommentatoren 604 Aufrufe
  • sigi234S Online
    sigi234S Online
    sigi234
    wie muss ich das einstellen, bekomme keine Verbindung zu foobar2000.0? Adapter bleibt gelb…...
    oobar2000.0	2018-05-13 09:51:59.657	debug	stateChange foobar2000.0.info.connection {"val":false,"ack":true,"ts":1526197919651,"q":0,"from":"system.adapter.foobar2000.0","lc":1526116262594}
    foobar2000.0	2018-05-13 09:51:59.650	debug	Reconnect to 10 sec...
    foobar2000.0	2018-05-13 09:51:59.650	debug	Got error by post request Error: connect ECONNREFUSED 127.0.0.1:8888
    foobar2000.0	2018-05-13 09:51:58.630	debug	httpGet options - {"host":"127.0.0.1","port":"8888","path":"/foobar2000controller/?¶m3=info.json"}
    foobar2000.0	2018-05-13 09:51:58.630	debug	foobar2000 httpGet("¶m3=info.json - {"host":"127.0.0.1","port":"8888","path":"/foobar2000controller/?¶m3=info.json"}")
    foobar2000.0	2018-05-13 09:51:48.610	debug	stateChange foobar2000.0.info.connection {"val":false,"ack":true,"ts":1526197908611,"q":0,"from":"system.adapter.foobar2000.0","lc":1526116262594}
    foobar2000.0	2018-05-13 09:51:48.610	debug	Reconnect to 10 sec...
    foobar2000.0	2018-05-13 09:51:48.610	debug	Got error by post request Error: connect ECONNREFUSED 127.0.0.1:8888
    foobar2000.0	2018-05-13 09:51:47.590	debug	httpGet options - {"host":"127.0.0.1","port":"8888","path":"/foobar2000controller/?¶m3=info.json"}
    foobar2000.0	2018-05-13 09:51:47.590	debug	foobar2000 httpGet("¶m3=info.json - {"host":"127.0.0.1","port":"8888","path":"/foobar2000controller/?¶m3=info.json"}")
    foobar2000.0	2018-05-13 09:51:37.572	debug	stateChange foobar2000.0.info.connection {"val":false,"ack":true,"ts":1526197897571,"q":0,"from":"system.adapter.foobar2000.0","lc":1526116262594}
    foobar2000.0	2018-05-13 09:51:37.570	debug	Reconnect to 10 sec...
    Immer Daten sichern!
    • apollon77A Offline
      Sich das der Port 8888 korrekt ist? Da bekommt der Adapter keine Verbindung.
      • sigi234S Online
        sigi234S Online
        sigi234
        Gelöst:
        http://foobar2000controller.blogspot.co … start.html
          Ich habe keine Ahnung was foobar2000 überhaupt ist aber der Adapter scheint sich Ja zu irgendeinem Server verbinden zu wollen und die ip und Port davon werden gebraucht. Die musst du schon selbst kennen
