  4. Problem mit UPNP Adapter
    6.7k
7 Beiträge 4 Kommentatoren 913 Aufrufe 1 Beobachtet
  • K Offline
    Kuddel
    ich habe den UPNP Adapter installiert um u.A. meine Internet-Auslastung im VIS dazustellen.
    Leider bekomme ich direkt nach dem Starten einige Fehlermeldungen im Log:
    upnp.0	2018-03-07 12:31:21.216	info	Auto discover: true
    upnp.0	2018-03-07 12:31:21.215	info	starting. Version 0.3.7 in /opt/iobroker/node_modules/iobroker.upnp, node: v4.8.7
    upnp.0	2018-03-07 12:30:48.458	error	at Timer.listOnTimeout (timers.js:92:15)
    upnp.0	2018-03-07 12:30:48.458	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.upnp/main.js:1172:12)
    upnp.0	2018-03-07 12:30:48.458	error	at SsdpServer.start (/opt/iobroker/node_modules/iobroker.upnp/node_modules/node-ssdp/lib/server.js:33:8)
    upnp.0	2018-03-07 12:30:48.458	error	at SsdpServer.SSDP._start (/opt/iobroker/node_modules/iobroker.upnp/node_modules/node-ssdp/lib/index.js:188:13)
    upnp.0	2018-03-07 12:30:48.458	error	at Socket.bind (dgram.js:144:11)
    upnp.0	2018-03-07 12:30:48.458	error	Error: Socket is already bound
    upnp.0	2018-03-07 12:30:48.456	error	uncaught exception: Socket is already bound
    upnp.0	2018-03-07 12:30:48.249	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
    upnp.0	2018-03-07 12:30:48.249	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
    upnp.0	2018-03-07 12:30:48.249	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    upnp.0	2018-03-07 12:30:48.249	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    upnp.0	2018-03-07 12:30:48.249	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
    upnp.0	2018-03-07 12:30:48.249	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
    upnp.0	2018-03-07 12:30:48.249	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
    upnp.0	2018-03-07 12:30:48.249	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    upnp.0	2018-03-07 12:30:48.249	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
    upnp.0	2018-03-07 12:30:48.249	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:127:23)
    upnp.0	2018-03-07 12:30:48.249	error	RangeError: Maximum call stack size exceeded
    upnp.0	2018-03-07 12:30:48.237	error	uncaught exception: Maximum call stack size exceeded
    upnp.0	2018-03-07 12:30:32.858	info	Auto discover: true
    upnp.0	2018-03-07 12:30:32.843	info	starting. Version 0.3.7 in /opt/iobroker/node_modules/iobroker.upnp, node: v4.8.7
    Hat jemand eine Idee, was das Problem ist?
    • arteckA Offline
      arteckA Offline
      arteck
      steht doch da
      • K Offline
        Kuddel
        Und was genau heißt das ?
        • Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          Naja das Problem mit dem Socket ist Folge Problem.
          Das eigentlich Problem ist das der Adapter zu viele Aufrufe in zu kurzer Zeit verursacht. Das passiert nur beim Starten weil er da alle Geräte abfrägt. Allerdings hatte ich Maßnahmen ergriffen das zu verhindern.
          Warum das jetzt wieder auftritt weiss ich nicht.
          Daher gibt es auch keine wirkliche Lösung.
          Persönlicher Support
          Spenden -> paypal.me/J3YC33
          • K Offline
            Kuddel
            Ich habe den Adapter noch ein einmal deinistalliert und neu installiert.
            Jetzt kommt die Fehlermeldung nicht mehr, aber die Objekte werden alle nicht aktualisiert…
            • Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              Ob Datenpunkte beschrieben werden oder nicht hängt vom Gerät ab. Manche Daten werden Automatisch per Push an iobroker gesendet andere muss man selbst holen.
              Per push werden meiner bisherigen Beobachtung nach nur Informationen von Media Server oder Player geliefert.
              • haselchenH Offline
                haselchenH Offline
                haselchen
                Von der Idee und Mächtigkeit ist das nen klasse Adapter.
                Nur man lässt ihn irgendwie an der Leine.
                Hab ihn installiert, weil ich erhoffte ,so an die Daten des Mediaservers der Fritzbox zu kommen.
                Die Objekte meiner ganzen Geräte werden auch wunderbar aufgelistet (für mich schon zu viele :D :D ) , nur ohne Werte.
                Alle DP bleiben leer, auch die des Mediaservers.
                Da es wohl keine Doku gibt, weiss ich als Laie natürlich nicht wie ich da nun Daten reinbekomme in jeden DP.
                Eventuell magst Du als Entwickler ein wenig (ausführlicher) helfen ;)
