  4. [Frage] Iobroker auf QNAP, USB durchschleifen (für smartmeter)
    5.9k
21 Beiträge 4 Kommentatoren 4.1k Aufrufe
  • coyoteC Offline
    coyoteC Offline
    coyote
    Guten morgen,
    habe nochmals probiert, leider ohne Erfolg. Ist es richtig dass er die Ordner node-modules,iobroker-data usw. nicht im erstellten iobroker Verzeichnis installiert? Das wundert mich etwas, sollte das nicht alles unter "iobroker" liegen?
    [~] # npm config set python /share/CACHEDEV1_DATA/.qpkg/Python/src/bin/python
    [~] # cd /share/CACHEDEV1_DATA/.qpkg
    [/share/CACHEDEV1_DATA/.qpkg] # rm -r iobroker
    [/share/CACHEDEV1_DATA/.qpkg] # mkdir iobroker
    [/share/CACHEDEV1_DATA/.qpkg] # chmod 777 iobroker
    [/share/CACHEDEV1_DATA/.qpkg] # cd iobroker
    [/share/CACHEDEV1_DATA/.qpkg/iobroker] # npm install iobroker --unsafe-perm
    > unix-dgram@0.2.3 install /share/CACHEDEV1_DATA/.qpkg/node_modules/unix-dgram
    > node-gyp rebuild
    gyp ERR! build error
    gyp ERR! stack Error: not found: make
    gyp ERR! stack     at getNotFoundError (/share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/lib/node_modules/npm/node_modules/which/which.js:14:12)
    gyp ERR! stack     at F (/share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/lib/node_modules/npm/node_modules/which/which.js:69:19)
    gyp ERR! stack     at E (/share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/lib/node_modules/npm/node_modules/which/which.js:81:29)
    gyp ERR! stack     at /share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/lib/node_modules/npm/node_modules/which/which.js:90:16
    gyp ERR! stack     at /share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    gyp ERR! stack     at /share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:123:15)
    gyp ERR! System Linux 4.2.8
    gyp ERR! command "/share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/bin/node" "/share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /share/CACHEDEV1_DATA/.qpkg/node_modules/unix-dgram
    gyp ERR! node -v v6.11.1
    gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    > ursa@0.9.4 install /share/CACHEDEV1_DATA/.qpkg/node_modules/ursa
    > node-gyp rebuild
    gyp ERR! cwd /share/CACHEDEV1_DATA/.qpkg/node_modules/ursa
    gyp ERR! not ok
    > iobroker@1.0.8 install /share/CACHEDEV1_DATA/.qpkg/node_modules/iobroker
    > node lib/setup.js
    NPM version: 2.15.12
    npm install iobroker.discovery --production --save --prefix /share/CACHEDEV1_DATA/.qpkg
    npm install iobroker.admin --production --save --prefix /share/CACHEDEV1_DATA/.qpkg
    npm install iobroker.js-controller --production --save --prefix /share/CACHEDEV1_DATA/.qpkg
    Non-critical error: EISDIR: illegal operation on a directory, open '/share/CACHEDEV1_DATA/.qpkg/iobroker'
    iobroker.inst@1.0.8 /share/CACHEDEV1_DATA/.qpkg
    └── iobroker@1.0.8
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa@0.9.4 (node_modules/ursa):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa@0.9.4 install: `node-gyp rebuild`
    [/share/CACHEDEV1_DATA/.qpkg/iobroker] # ./iobroker del admin.0
    -sh: ./iobroker: No such file or directory
    [/share/CACHEDEV1_DATA/.qpkg/iobroker] # ls
    [/share/CACHEDEV1_DATA/.qpkg/iobroker] # iobroker start
    -sh: iobroker: command not found
    [/share/CACHEDEV1_DATA/.qpkg/iobroker] # cd ..
    [/share/CACHEDEV1_DATA/.qpkg] # ls
    CloudLink/          iobroker/       nodejsv6/      QDMS/         qusbcam2/             Unifi/
    container-station/  iobroker-data/  node_modules/  QJDK8/        reinstall.sh
    etc/                killall.sh      package.json   QKVM/         SurveillanceStation/
    helpdesk/           log/            Python/        QsyncServer/  ubuntu-hd/
    EDIT: Genau daran lag es, habe jetzt alles von Hand über WinSCP in das iobroker Verzeichnis verschoben und schon läuft das Ding 8-)
    EDIT2: Leider doch noch nicht so ganz, wollte gerade einen Adapter installieren. Da kommt dann auch der Error:
    iobroker	2018-02-16 11:29:34.854	info	npm install iobroker.amazon-dash --production --prefix "/share/CACHEDEV1_DATA/.qpkg/iobroker" (System call)
    iobroker	2018-02-16 11:29:34.714	info	host.NAS1C16C2 install adapter amazon-dash
    iobroker	2018-02-16 11:29:34.694	info	npm ERR! Please include the following file with any support request:npm ERR! /share/CACHEDEV1_DATA/.qpkg/npm-debug.log
    iobroker	2018-02-16 11:29:34.693	info
    iobroker	2018-02-16 11:29:34.634	info	npm ERR! There is likely additional logging output above.
    iobroker	2018-02-16 11:29:34.634	info	npm ERR! npm owner ls socketwatcher
    iobroker	2018-02-16 11:29:34.634	info	npm ERR! Or if that isn't available, you can get their info via:
    iobroker	2018-02-16 11:29:34.634	info	npm ERR! npm bugs socketwatcher
    iobroker	2018-02-16 11:29:34.634	info	npm ERR! You can get information on how to open an issue for this project with:
    iobroker	2018-02-16 11:29:34.634	info	ERR! Tell the author that this fails on your system:npm ERR! node-gyp rebuild
    iobroker	2018-02-16 11:29:34.631	info	npm
    iobroker	2018-02-16 11:29:34.631	info	npm ERR! not with npm itself.
    iobroker	2018-02-16 11:29:34.631	info	npm ERR! If you do, this is most likely a problem with the socketwatcher package,
    iobroker	2018-02-16 11:29:34.631	info	npm ERR! Make sure you have the latest version of node.js and npm installed.
    iobroker	2018-02-16 11:29:34.631	info	npm ERR! Failed at the socketwatcher@0.3.0 install script 'node-gyp rebuild'.
    iobroker	2018-02-16 11:29:34.631	info	npm ERR! Exit status 1
    iobroker	2018-02-16 11:29:34.631	info	npm ERR! socketwatcher@0.3.0 install: `node-gyp rebuild`
    iobroker	2018-02-16 11:29:34.631	info	npm ERR! code ELIFECYCLE
    iobroker	2018-02-16 11:29:34.624	info	npm ERR! npm v3.10.10
    iobroker	2018-02-16 11:29:34.624	info	npm ERR! argv "/share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/bin/node" "/usr/local/bin/npm" "install" "iobroker.amazon-dash" "--production" "--prefix" "/share/CACHEDEV1_DATA/.qpkg/iobroker"npm ERR! node
    iobroker	2018-02-16 11:29:34.623	info	npm ERR! Linux 4.2.8
    iobroker	2018-02-16 11:29:34.216	info	ERR! node-gyp -v v3.4.0gyp ERR! not ok
    iobroker	2018-02-16 11:29:34.215	info	gyp
    iobroker	2018-02-16 11:29:34.215	info	gyp ERR! node -v v6.11.1
    iobroker	2018-02-16 11:29:34.215	info	gyp ERR! cwd /share/CACHEDEV1_DATA/.qpkg/iobroker/node_modules/socketwatcher
    iobroker	2018-02-16 11:29:34.215	info	gyp ERR! System Linux 4.2.8gyp ERR! command "/share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/bin/node" "/share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js"
    iobroker	2018-02-16 11:29:34.214	info	gyp ERR! stack at FSReqWrap.oncomplete (fs.js:123:15)
    iobroker	2018-02-16 11:29:34.214	info	ERR! stack at /share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5gyp ERR! stack at /share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/li
    iobroker	2018-02-16 11:29:34.213	info	gyp
    iobroker	2018-02-16 11:29:34.213	info	gyp ERR! stack at /share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/lib/node_modules/npm/node_modules/which/which.js:90:16
    iobroker	2018-02-16 11:29:34.213	info	gyp ERR! stack at E (/share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/lib/node_modules/npm/node_modules/which/which.js:81:29)
    iobroker	2018-02-16 11:29:34.213	info	gyp ERR! stack at F (/share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/lib/node_modules/npm/node_modules/which/which.js:69:19)
    iobroker	2018-02-16 11:29:34.213	info	ERR! stack Error: not found: makegyp ERR! stack at getNotFoundError (/share/CACHEDEV1_DATA/.qpkg/nodejsv6/node/lib/node_modules/npm/node_modules/which/which.js:14:12)
    iobroker	2018-02-16 11:29:34.212	info	gyp
    iobroker	2018-02-16 11:29:34.208	info	ERR! build error
    iobroker	2018-02-16 11:29:34.207	info
    iobroker	2018-02-16 11:29:34.203	info	gyp
    iobroker	2018-02-16 11:29:32.381	info	npm WARN lifecycle iobroker.amazon-dash@0.2.8~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.8 apt-get install libpcap-dev -y || true /share/CACHEDEV1_DATA/.qpkg/iobroker
