  4. Javascript stürzt ab error log Fragen
    5.4k
22 Beiträge 7 Kommentatoren 2.6k Aufrufe 4 Beobachtet
  • B B4unty
    Danke das steht jetzt diese Information
    2023-05-30 07:14:50.828  - info: host.iobrokerCT stopInstance system.adapter.javascript.0 (force=false, process=true)
    2023-05-30 07:14:50.918  - info: host.iobrokerCT stopInstance system.adapter.javascript.0 send kill signal
    2023-05-30 07:14:51.919  - info: host.iobrokerCT stopInstance system.adapter.javascript.0 killing pid 641
    2023-05-30 07:14:53.983  - info: host.iobrokerCT instance system.adapter.javascript.0 started with pid 16532
    2023-05-30 07:14:55.137  - error: javascript.0 (16532) javascript.0 already running
    2023-05-30 07:14:55.139  - warn: javascript.0 (16532) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-05-30 07:14:55.696  - error: host.iobrokerCT instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-05-30 07:14:55.696  - info: host.iobrokerCT Restart adapter system.adapter.javascript.0 because enabled
    2023-05-30 07:15:25.678  - info: host.iobrokerCT "system.adapter.javascript.0" disabled
    2023-05-30 07:15:27.432  - error: javascript.0 (16558) adapter disabled
    2023-05-30 07:15:27.479  - warn: javascript.0 (16558) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    2023-05-30 07:15:28.038  - error: host.iobrokerCT instance system.adapter.javascript.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    2023-05-30 07:15:28.038  - info: host.iobrokerCT Do not restart adapter system.adapter.javascript.0 because disabled or deleted
    2023-05-30 07:15:29.695  - info: host.iobrokerCT "system.adapter.javascript.0" enabled
    2023-05-30 07:15:29.834  - info: host.iobrokerCT instance system.adapter.javascript.0 started with pid 16569
    2023-05-30 07:15:31.281  - info: javascript.0 (16569) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.19.1, js-controller: 4.0.24
    2023-05-30 07:15:32.063  - info: javascript.0 (16569) requesting all states
    2023-05-30 07:15:32.063  - info: javascript.0 (16569) requesting all objects
    2023-05-30 07:15:32.841  - info: javascript.0 (16569) received all objects
    2023-05-30 07:15:33.808  - info: javascript.0 (16569) received all states
    2023-05-30 07:16:19.949  - info: host.iobrokerCT instance system.adapter.javascript.0 started with pid 16601
    2023-05-30 07:16:19.962  - warn: javascript.0 (16569) Got terminate signal. Checking desired PID: 16601 vs own PID 16569
    2023-05-30 07:16:20.492  - error: host.iobrokerCT instance system.adapter.javascript.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2023-05-30 07:16:20.493  - info: host.iobrokerCT Do not restart adapter system.adapter.javascript.0 because desired by instance
    2023-05-30 07:16:21.370  - info: javascript.0 (16601) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.19.1, js-controller: 4.0.24
    2023-05-30 07:16:22.139  - info: javascript.0 (16601) requesting all states
    2023-05-30 07:16:22.139  - info: javascript.0 (16601) requesting all objects
    2023-05-30 07:16:22.779  - info: javascript.0 (16601) received all objects
    2023-05-30 07:16:23.520  - info: javascript.0 (16601) received all states
    Wenn ich das log richtig verstehe steht da nichts zu dem warum die Instanz nicht läuft. den es sind Einträge aus Script im log. Und die vorhandene Einträge müssten sein wo ich den Adapter dummer weise neu gestartet habe.
    @b4unty sagte in Javascript stürzt ab error log Fragen:
    Wie sieht die Konfiguration denn aus?
    Und bring dein nodejs auf die empfohlene Version 18.
      B4unty
      schrieb am zuletzt editiert von B4unty
      @thomas-braun Aktuell schaut es so aus Instanz rot
       iob logs | grep javascript.0
      2023-05-30 14:52:54.644  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: Auslöser Solaranpassung
      2023-05-30 14:52:54.645  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: 980 NEIN
      2023-05-30 14:52:54.645  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: 630 NEIN
      2023-05-30 14:52:54.645  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: 440 JA
      2023-05-30 14:52:54.645  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: Begrenzer 440W  26 Mittelwert: 842.3 Spannung Mittelwert: 27.2V 100%
      2023-05-30 14:54:24.933  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: Auslöser Solaranpassung
      2023-05-30 14:54:24.934  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: 980 NEIN
      2023-05-30 14:54:24.934  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: 630 NEIN
      2023-05-30 14:54:24.934  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: 440 JA
      2023-05-30 14:54:24.934  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: Begrenzer 440W  26 Mittelwert: 842.3 Spannung Mittelwert: 27.2V 100%
      2023-05-30 14:55:53.852  - info: javascript.0 (530) script.js.CCU_State.Homeoffice_: Eltern im Wlan
      2023-05-30 14:57:23.250  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: Auslöser Solaranpassung
      2023-05-30 14:57:23.250  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: 980 NEIN
      2023-05-30 14:57:23.250  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: 630 NEIN
      2023-05-30 14:57:23.250  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: 440 JA
      2023-05-30 14:57:23.250  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: Begrenzer 440W  26 Mittelwert: 842.3 Spannung Mittelwert: 27.2V 100%
      2023-05-30 15:00:24.649  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: Auslöser Solaranpassung
      2023-05-30 15:00:24.649  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: 980 NEIN
      2023-05-30 15:00:24.650  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: 630 NEIN
      2023-05-30 15:00:24.650  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: 440 JA
      2023-05-30 15:00:24.650  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: Begrenzer 440W  26 Mittelwert: 842.3 Spannung Mittelwert: 27.2V 100%
      2023-05-30 15:01:48.388  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: mqtt.0:
      2023-05-30 15:01:53.250  - info: javascript.0 (530) script.js.CCU_State.Homeoffice_: Eltern im Wlan
      2023-05-30 15:01:53.251  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Solar_Mittelwerte: Mittelwert Ladung 3 MIN 842.3 Zähler: 24
      2023-05-30 15:01:53.251  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Solar_Mittelwerte: Mittelwert Volt  27V  Zähler: 24
      2023-05-30 15:01:53.251  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Solar_Mittelwerte: Mittelwert Volt  Shunt27.4V  Zähler: 24
      2023-05-30 15:03:21.338  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: Auslöser Solaranpassung
      2023-05-30 15:03:21.338  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: Begrenzer 980W  34 Mittelwert: 730.9 Spannung Mittelwert: 27.2V 100%
      2023-05-30 15:08:05.519  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: mqtt.0:
      2023-05-30 15:08:06.614  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: Auslöser Solaranpassung
      2023-05-30 15:08:06.614  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: Begrenzer 980W  34 Mittelwert: 730.9 Spannung Mittelwert: 27.2V 100%
      2023-05-30 15:09:35.085  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: mqtt.0:
      2023-05-30 15:09:36.707  - info: javascript.0 (530) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: mqtt.0:
       which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.19.1
      v16.19.1
      9.6.5
      nodejs:
        Installiert:           16.19.1-deb-1nodesource1
        Installationskandidat: 16.20.0-deb-1nodesource1
        Versionstabelle:
           16.20.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x buster/main amd64 Packages
       *** 16.19.1-deb-1nodesource1 100
           10.24.0~dfsg-1~deb10u3 500
              500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
           10.24.0~dfsg-1~deb10u1 500
              500 http://ftp.de.debian.org/debian buster/main amd64 Packages
      • B B4unty
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.19.1
        v16.19.1
        9.6.5
        nodejs:
          Versionstabelle:
        Und wie stellt sich ein Neu-Start des javascript-Adapters im log dar? Und bitte nicht danach greppen, das schmeißt u. U. zu viel raus.
        • T TT-Tom
          @b4unty
          Hast du den mal alle Scripts angehalten und dann die Instanz gestartet? Laufen unter global den auch Scripts?
          GaspodeG Offline
          GaspodeG Offline
          Gaspode
          @tt-tom said in Javascript stürzt ab error log Fragen:
          Hast du den mal alle Scripts angehalten und dann die Instanz gestartet? Laufen unter global denn auch Scripts?
          Ich kann diese Empfehlung nur voll und ganz unterschreiben. Alle Scripte disablen, wenn der Fehler dann nicht mehr auftaucht, Scripte nach und nach wieder enablen, bis der Fehler wieder da ist.
          Ist der Fehler auch ohne enabled Scripte da, liegt es wohl an der Installtion selbst.
          • GaspodeG Gaspode
            B4unty
            Wenn ich die Instanz starte kommt dieser Eintrag, kann ich auch zwei Instanzen installieren und die Skripte einfach zwischen den host hin und her schieben? Um nach und nach die Skripte auszuschließen?
            2023-05-30 15:25:11.303  - info: host.iobrokerCT instance system.adapter.iot.0 started with pid 11485
            2023-05-30 15:25:12.363  - info: iot.0 (11485) starting. Version 1.14.2 in /opt/iobroker/node_modules/iobroker.iot, node: v18.16.0, js-controller: 4.0.24
            2023-05-30 15:25:12.409  - info: iot.0 (11485) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
            2023-05-30 15:25:12.897  - info: iot.0 (11485) Connection changed: connect
            2023-05-30 15:25:15.304  - info: host.iobrokerCT instance system.adapter.simple-api.6 started with pid 11500
            2023-05-30 15:25:16.334  - info: simple-api.6 (11500) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.16.0, js-controller: 4.0.24
            2023-05-30 15:25:16.353  - info: simple-api.6 (11500) simpleAPI server listening on port 8087
            2023-05-30 15:25:16.354  - info: simple-api.6 (11500) Allow states only when user is owner: false
            2023-05-30 15:25:16.362  - info: simple-api.6 (11500) http server listening on port 8087
            2023-05-30 15:25:16.725  - info: smartmeter.1 (10782) Received 7 values, 3 updated
            2023-05-30 15:25:18.857  - info: device-reminder.0 (11470) State value to set for "device-reminder.0.Waschmaschine.live consumption" has to be type "number" but received type "string"
            2023-05-30 15:25:18.900  - info: device-reminder.0 (11470) State value to set for "device-reminder.0.Trockner.live consumption" has to be type "number" but received type "string"
            2023-05-30 15:25:28.327  - info: smartmeter.1 (10782) Received 7 values, 3 updated
            2023-05-30 15:25:28.856  - info: device-reminder.0 (11470) State value to set for "device-reminder.0.Waschmaschine.live consumption" has to be type "number" but received type "string"
            2023-05-30 15:25:28.859  - info: device-reminder.0 (11470) State value to set for "device-reminder.0.Trockner.live consumption" has to be type "number" but received type "string"
            2023-05-30 15:25:38.798  - info: host.iobrokerCT "system.adapter.javascript.0" enabled
            2023-05-30 15:25:38.850  - info: host.iobrokerCT instance system.adapter.javascript.0 started with pid 11529
            2023-05-30 15:25:38.978  - info: device-reminder.0 (11470) State value to set for "device-reminder.0.Waschmaschine.live consumption" has to be type "number" but received type "string"
            2023-05-30 15:25:38.978  - info: device-reminder.0 (11470) State value to set for "device-reminder.0.Trockner.live consumption" has to be type "number" but received type "string"
            2023-05-30 15:25:40.258  - info: javascript.0 (11529) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.16.0, js-controller: 4.0.24
            2023-05-30 15:25:41.032  - info: javascript.0 (11529) requesting all states
            2023-05-30 15:25:41.034  - info: javascript.0 (11529) requesting all objects
            2023-05-30 15:25:41.747  - info: javascript.0 (11529) received all objects
            2023-05-30 15:25:42.121  - info: device-reminder.0 (11470) State value to set for "sayit.0.tts.volume" has to be type "string" but received type "number"
            2023-05-30 15:25:42.216  - info: smartmeter.1 (10782) Received 7 values, 3 updated
            2023-05-30 15:25:42.526  - info: javascript.0 (11529) received all states
            2023-05-30 15:25:44.120  - info: javascript.0 (11529) Start javascript script.js.Auslöser_Bilder.Bild_Tor_auf
            2023-05-30 15:25:44.146  - info: javascript.0 (11529) script.js.Auslöser_Bilder.Bild_Tor_auf: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2023-05-30 15:25:44.373  - info: javascript.0 (11529) Start javascript script.js.Auslöser_Bilder.Bild_Tor_zu
            2023-05-30 15:25:44.384  - info: javascript.0 (11529) script.js.Auslöser_Bilder.Bild_Tor_zu: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2023-05-30 15:25:44.385  - info: javascript.0 (11529) Start javascript script.js.CCU_State.CCU_to_FHEM
            2023-05-30 15:25:44.388  - info: javascript.0 (11529) script.js.CCU_State.CCU_to_FHEM: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2023-05-30 15:25:44.388  - info: javascript.0 (11529) Start javascript script.js.CCU_State.Homatik_CuxD
            2023-05-30 15:25:44.391  - info: javascript.0 (11529) script.js.CCU_State.Homatik_CuxD: registered 9 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2023-05-30 15:25:44.391  - info: javascript.0 (11529) Start javascript script.js.CCU_State.Homeoffice_
            2023-05-30 15:25:44.421  - info: javascript.0 (11529) script.js.CCU_State.Homeoffice_: registered 3 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
            2023-05-30 15:25:44.421  - info: javascript.0 (11529) Start javascript script.js.Garagentor.TorPosition
            2023-05-30 15:25:44.424  - info: javascript.0 (11529) script.js.Garagentor.TorPosition: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2023-05-30 15:25:44.424  - info: javascript.0 (11529) Start javascript script.js.Haus_Türen.Klingel
            2023-05-30 15:25:44.426  - info: javascript.0 (11529) script.js.Haus_Türen.Klingel: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2023-05-30 15:25:44.427  - info: javascript.0 (11529) Start javascript script.js.Schaltungen.Flur_Bewegung
            2023-05-30 15:25:44.429  - info: javascript.0 (11529) script.js.Schaltungen.Flur_Bewegung: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2023-05-30 15:25:44.429  - info: javascript.0 (11529) Start javascript script.js.Schaltungen.Garage_Lampen
            2023-05-30 15:25:44.439  - info: javascript.0 (11529) script.js.Schaltungen.Garage_Lampen: registered 8 subscriptions, 6 schedules, 0 messages, 0 logs and 0 file subscriptions
            2023-05-30 15:25:44.439  - info: javascript.0 (11529) Start javascript script.js.Schaltungen.PDU_Garage_ON_OFF
            2023-05-30 15:25:44.444  - info: javascript.0 (11529) script.js.Schaltungen.PDU_Garage_ON_OFF: registered 10 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
            2023-05-30 15:25:44.444  - info: javascript.0 (11529) Start javascript script.js.Schaltungen.RolladenSchaltung
            2023-05-30 15:25:44.448  - info: javascript.0 (11529) script.js.Schaltungen.RolladenSchaltung: registered 4 subscriptions, 3 schedules, 0 messages, 0 logs and 0 file subscriptions
            2023-05-30 15:25:44.448  - info: javascript.0 (11529) Start javascript script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung
            2023-05-30 15:25:44.450  - info: javascript.0 (11529) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: registered 2 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
            2023-05-30 15:25:44.451  - info: javascript.0 (11529) Start javascript script.js.Verbrauch_Solaranlage_Sonstige.Solar_Mittelwerte
            2023-05-30 15:25:44.453  - info: javascript.0 (11529) script.js.Verbrauch_Solaranlage_Sonstige.Solar_Mittelwerte: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2023-05-30 15:25:44.453  - info: javascript.0 (11529) Start javascript script.js.Verbrauch_Solaranlage_Sonstige.Wechselrichter_Ein_Aus
            2023-05-30 15:25:44.458  - info: javascript.0 (11529) script.js.Verbrauch_Solaranlage_Sonstige.Wechselrichter_Ein_Aus: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
            2023-05-30 15:25:48.858  - info: device-reminder.0 (11470) State value to set for "device-reminder.0.Waschmaschine.live consumption" has to be type "number" but received type "string"
            2023-05-30 15:25:48.858  - info: device-reminder.0 (11470) State value to set for "device-reminder.0.Trockner.live consumption" has to be type "number" but received type "string"
            2023-05-30 15:25:54.932  - info: smartmeter.1 (10782) Received 7 values, 3 updated
            2023-05-30 15:25:58.859  - info: device-reminder.0 (11470) State value to set for "device-reminder.0.Waschmaschine.live consumption" has to be type "number" but received type "string"
            2023-05-30 15:25:58.900  - info: device-reminder.0 (11470) State value to set for "device-reminder.0.Trockner.live consumption" has to be type "number" but received type "string"
            2023-05-30 15:26:00.003  - info: javascript.0 (11529) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: Auslöser Solaranpassung
            2023-05-30 15:26:00.004  - info: javascript.0 (11529) script.js.Verbrauch_Solaranlage_Sonstige.Leistung_Anpassung: Begrenzer 980W  34 Mittelwert: 875.1 Spannung Mittelwert: 27.3V 100%
            2023-05-30 15:26:00.005  - info: snmp.0 (11440) Scheduled restart.
            2023-05-30 15:26:00.055  - info: snmp.0 (11440) terminating
            2023-05-30 15:26:00.057  - info: snmp.0 (11440) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            node JS ist jetzt auf 18
            GaspodeG 1 Antwort Letzte Antwort
            • B B4unty
              GaspodeG Offline
              GaspodeG Offline
              Gaspode
              @b4unty said in Javascript stürzt ab error log Fragen:
              Ja, kannst du so machen.
              • GaspodeG Gaspode
                B4unty
                @gaspode es scheint in diesem skript zu sein den nur dieses ist auf der Instanz die dann auf Rot schaltet
                var Gew_C3_BCnschteWattLeistung;
                on({id: [].concat(['alias.0.Sensoren.SolarAnlage.BATERIE-RELAI-INVERTER']), change: "ne"}, async function (obj) {
                  var value = obj.state.val;
                  sendTo("telegram", "send", {
                      text: (['Relai Auslöser bei ',getState("0_userdata.0.Schalten.Hilfspunkte.Akku-BeideMessungen-Mitte").val,'V beide Mitte und ',getState("alias.0.Sensoren.SolarAnlage.266_State_of_charge").val,'%'].join(''))
                on({id: [].concat(['alias.0.Sensoren.SolarAnlage.BEGRENZUNG-LEISTUNG']), change: "ne"}, async function (obj) {
                  Gew_C3_BCnschteWattLeistung = ('' + getState("alias.0.Sensoren.SolarAnlage.BEGRENZUNG-LEISTUNG").val);
                  sendTo("mqtt.0", "sendMessage2Client", {
                     "topic": 'inverter/ctrl/limit_persistent_relative/0     ',
                     "message": Gew_C3_BCnschteWattLeistung
                  console.log("mqtt.0: " + "");
                schedule("*/2 * * * *", async function () {
                  if (getState("0_userdata.0.Schalten.Hilfspunkte.PV-Automatik").val == true) {
                    console.log('Auslöser Solaranpassung');
                    if (getState("0_userdata.0.Schalten.Hilfspunkte.Akku-BeideMessungen-Mitte").val >= 25.5 && getState("0_userdata.0.Schalten.Hilfspunkte.AkkuArbeit").val == true && getState("alias.0.Sensoren.Stomzähler.AKTUELLER_BEZUG").val >= -100 && (getState("alias.0.Sensoren.SolarAnlage.MittelwertLadung").val >= 600 && getState("alias.0.Sensoren.SolarAnlage.266_State_of_charge").val >= 95 || false)) {
                      console.log((['Begrenzer 980W  34 Mittelwert: ',getState("alias.0.Sensoren.SolarAnlage.MittelwertLadung").val,' Spannung Mittelwert: ',getState("0_userdata.0.Schalten.Hilfspunkte.Akku-BeideMessungen-Mitte").val,'V ',getState("alias.0.Sensoren.SolarAnlage.266_State_of_charge").val,'%'].join('')));
                      // 980 Watt
                      setState("alias.0.Sensoren.SolarAnlage.BEGRENZUNG-LEISTUNG"/*BEGRENZUNG-LEISTUNG_Alias*/, 34);
                    } else {
                      console.log('980 NEIN');
                      if (getState("0_userdata.0.Schalten.Hilfspunkte.Akku-BeideMessungen-Mitte").val >= 25.2 && getState("alias.0.Sensoren.Stomzähler.AKTUELLER_BEZUG").val >= -100 && getState("0_userdata.0.Schalten.Hilfspunkte.AkkuArbeit").val == true && getState("alias.0.Sensoren.SolarAnlage.MittelwertLadung").val >= 410 && getState("alias.0.Sensoren.SolarAnlage.266_State_of_charge").val >= 93) {
                        console.log((['Begrenzer 630W  31 Mittelwert: ',getState("alias.0.Sensoren.SolarAnlage.MittelwertLadung").val,' Spannung Mittelwert: ',getState("0_userdata.0.Schalten.Hilfspunkte.Akku-BeideMessungen-Mitte").val,'V ',getState("alias.0.Sensoren.SolarAnlage.266_State_of_charge").val,'%'].join('')));
                        setState("alias.0.Sensoren.SolarAnlage.BEGRENZUNG-LEISTUNG"/*BEGRENZUNG-LEISTUNG_Alias*/, 31);
                        // 630 Watt
                      } else {
                        console.log('630 NEIN');
                        if (getState("0_userdata.0.Schalten.Hilfspunkte.Akku-BeideMessungen-Mitte").val >= 24.7 && getState("0_userdata.0.Schalten.Hilfspunkte.AkkuArbeit").val == true && getState("alias.0.Sensoren.SolarAnlage.MittelwertLadung").val >= 220 && (compareTime('8:00', '15:00', "between", null) && getState("alias.0.Sensoren.SolarAnlage.266_State_of_charge").val >= 85 && getState("alias.0.Sensoren.SolarAnlage.MittelwertLadung").val >= 550 || getState("alias.0.Sensoren.SolarAnlage.266_State_of_charge").val >= 91)) {
                          console.log((['Begrenzer 440W  28 Mittelwert: ',getState("alias.0.Sensoren.SolarAnlage.MittelwertLadung").val,' Spannung Mittelwert: ',getState("0_userdata.0.Schalten.Hilfspunkte.Akku-BeideMessungen-Mitte").val,'V ',getState("alias.0.Sensoren.SolarAnlage.266_State_of_charge").val,'%'].join('')));
                          setState("alias.0.Sensoren.SolarAnlage.BEGRENZUNG-LEISTUNG"/*BEGRENZUNG-LEISTUNG_Alias*/, 28);
                          // 440 Watt
                        } else {
                          console.log('440 NEIN');
                          if (getState("0_userdata.0.Schalten.Hilfspunkte.Akku-BeideMessungen-Mitte").val >= 24.6 && getState("0_userdata.0.Schalten.Hilfspunkte.AkkuArbeit").val == true && getState("alias.0.Sensoren.SolarAnlage.MittelwertLadung").val >= 120 && (getState("alias.0.Sensoren.SolarAnlage.266_State_of_charge").val >= 90 || compareTime('07:00', '16:00', "between", null) && getState("alias.0.Sensoren.SolarAnlage.266_State_of_charge").val >= 83 && getState("alias.0.Sensoren.SolarAnlage.MittelwertLadung").val >= 280)) {
                            console.log((['Begrenzer 230W  15 Mittelwert: ',getState("alias.0.Sensoren.SolarAnlage.MittelwertLadung").val,' Spannung Mittelwert:',getState("0_userdata.0.Schalten.Hilfspunkte.Akku-BeideMessungen-Mitte").val,'V ',getState("alias.0.Sensoren.SolarAnlage.266_State_of_charge").val,'%'].join('')));
                            // 230 Watt
                            setState("alias.0.Sensoren.SolarAnlage.BEGRENZUNG-LEISTUNG"/*BEGRENZUNG-LEISTUNG_Alias*/, 15);
                          } else {
                            console.log('230 NEIN');
                            if (getState("0_userdata.0.Schalten.Hilfspunkte.Akku-BeideMessungen-Mitte").val >= 24.4 && getState("0_userdata.0.Schalten.Hilfspunkte.AkkuArbeit").val == true && getState("alias.0.Sensoren.SolarAnlage.266_State_of_charge").val >= 70) {
                              setState("alias.0.Sensoren.SolarAnlage.BEGRENZUNG-LEISTUNG"/*BEGRENZUNG-LEISTUNG_Alias*/, 8);
                              // 90 Watt
                              console.log((['Begrenzer 90W  8 Mittelwert: ',getState("alias.0.Sensoren.SolarAnlage.MittelwertLadung").val,' Spannung: ',getState("0_userdata.0.Schalten.Hilfspunkte.Akku-BeideMessungen-Mitte").val,' V ',getState("alias.0.Sensoren.SolarAnlage.266_State_of_charge").val,'%'].join('')));
                            } else {
                              console.log('90 NEIN');
                              setState("alias.0.Sensoren.SolarAnlage.BEGRENZUNG-LEISTUNG"/*BEGRENZUNG-LEISTUNG_Alias*/, 4);
                              console.log((['MInimum 4 Mittelwert: ',getState("alias.0.Sensoren.SolarAnlage.MittelwertLadung").val,'W  Spannung Mittelwert: ',getState("0_userdata.0.Schalten.Hilfspunkte.Akku-BeideMessungen-Mitte").val,'V ',getState("alias.0.Sensoren.SolarAnlage.266_State_of_charge").val,'%'].join('')));
                kann es sein das ein Fehler in der mqtt Kommunikation dazu führen kann?
                HomoranH T 2 Antworten Letzte Antwort
                • B B4unty
                        // 980 Watt
                      } else {
                          // 630 Watt
                        } else {
                            // 440 Watt
                          } else {
                              // 230 Watt
                            } else {
                                // 90 Watt
                              } else {
                  @b4unty hast du da Umlaute drin?
                  die ggf. nicht konform codiert sind?
                  • B B4unty
                          // 980 Watt
                        } else {
                            // 630 Watt
                          } else {
                              // 440 Watt
                            } else {
                                // 230 Watt
                              } else {
                                  // 90 Watt
                                } else {
                    TT-Tom
                    im Topic sind Leerzeichen ist das gewollt?
                    die Variable ggf. als String übergeben
                    Gruß Tom
                    Public Transport
                    NSPanel Adapter Wiki
                    • T TT-Tom
                      B4unty
                      @tt-tom Danke für den Hinweis beides mal angepasst. Schauen wir mal was Passiert
