  4. ECharts adapter keine Datenpunkte
    5.4k
echarts
16 Beiträge 5 Kommentatoren 747 Aufrufe 4 Beobachtet
  • D denjo
    @DJMarc75
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 6.1.21-v8+
    Installation:           Native
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     5
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                            /usr/bin/node           v18.16.0
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            7.8G        3.3G        3.3G        1.0M        1.2G        4.3G
    Swap:            99M          0B         99M
    Total:          7.9G        3.3G        3.4G
    Active iob-Instances:   40
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    Objects:                15455
    States:                 12460
    Size of iob-Database:
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    29M     /opt/iobroker/iobroker-data/states.jsonl
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @denjo ok und jetzt noch die Langfassung davon. :)
    Lehrling seit 1975 !!!
    • DJMarc75D DJMarc75
      denjo
      schrieb am zuletzt editiert von denjo
      @djmarc75
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       07:40:57 up  3:41,  1 user,  load average: 3.03, 3.33, 3.03
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=37.0'C
      volt=0.9460V
      *** Time and Time Zones ***
                     Local time: Sat 2023-05-27 07:40:58 CEST
                 Universal time: Sat 2023-05-27 05:40:58 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      denjo
      /home/denjo
      denjo adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.8G        3.5G        3.1G        1.0M        1.2G        4.1G
      Swap:            99M          0B         99M
      Total:          7.9G        3.5G        3.2G
               7811 M total memory
               3495 M used memory
               3663 M active memory
                831 M inactive memory
               3081 M free memory
                134 M buffer memory
               1099 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      220G  7.5G  204G   4% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
      /dev/sda1      vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      [Sat May 27 03:59:39 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1024x768M@60 smsc95xx.macaddr=DC:A6:32:E0:5D:E1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=53cd3546-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sat May 27 03:59:41 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat May 27 03:59:41 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sat May 27 03:59:43 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.1G    /var/
      484M    /var/cache
      478M    /var/cache/apt
      374M    /var/cache/apt/archives
      372M    /var/log
      Archived and active journals take up 368.1M in the file system.
      /opt/iobroker/backups:
      130M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      907M    /opt/iobroker/iobroker-data/
      566M    /opt/iobroker/iobroker-data/files
      265M    /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      72M     /opt/iobroker/iobroker-data/files/telegram.admin
      51M     /opt/iobroker/iobroker-data/states.jsonl
      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
      32M     /opt/iobroker/iobroker-data/files/vis.0/Film.gif
      27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
       *** 18.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   10
      Adapter State
      + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker                                 -  enabled
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.amazon-dash.0            : amazon-dash           : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
        system.adapter.devices.0                : devices               : iobroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.easee.0                  : easee                 : iobroker                                 - disabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
      + system.adapter.enigma2.1                : enigma2               : iobroker                                 -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.hyperion_ng.0            : hyperion_ng           : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.material.0               : material              : iobroker                                 - disabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
        system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 0.0.0.0
        system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 1324, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
      + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
        system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
      + system.adapter.ring.0                   : ring                  : iobroker                                 -  enabled
        system.adapter.samsung.0                : samsung               : iobroker                                 - disabled
        system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 - disabled, port: 8002
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 5663, bind: 0.0.0.0, run as: admin
      + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
      + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
        system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
        system.adapter.ws.0                     : ws                    : iobroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 - disabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f87fbb8463c9eb11b1448b4f1d69213e-if00-port0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "amazon-dash"  : 1.1.0    , installed 1.1.0
      Adapter    "backitup"     : 2.6.19   , installed 2.6.19
      Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "devices"      : 1.1.2    , installed 1.1.2
      Adapter    "easee"        : 1.0.7    , installed 1.0.7
      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
      Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "iot"          : 1.14.2   , installed 1.14.2
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Adapter    "material"     : 1.1.2    , installed 1.1.2
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "node-red"     : 4.0.0    , installed 4.0.0
      Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
      Adapter    "openweathermap": 0.3.3   , installed 0.3.3
      Adapter    "ring"         : 3.2.2    , installed 3.3.0
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
      Adapter    "tado"         : 0.4.8    , installed 0.4.8
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.13.1   , installed 3.13.1
      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "worx"         : 2.1.3    , installed 2.1.3
      Adapter    "yeelight-2"   : 1.1.2    , installed 1.2.1
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects:        15455
      States:         12460
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
      Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 5
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12267      566/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12280      566/iobroker.js-con
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3810       589/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       13020      904/node-red
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       17686      1276/io.harmony.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          3821       589/sshd: /usr/sbin
      tcp6       0      0 :::5663                 :::*                    LISTEN      1001       18818      1359/io.simple-api.
      tcp6       0      0 :::51989                :::*                    LISTEN      1001       17137      1652/io.nuki-extend
      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       21519      1759/io.terminal.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       17036      1408/io.socketio.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22595      2359/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12903      717/io.admin.0
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       17687      1276/io.harmony.0
      udp        0      0 0.0.0.0:33973           0.0.0.0:*                           108        14582      450/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14580      450/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       14956      1057/io.shelly.0
      udp        0      0 0.0.0.0:34774           0.0.0.0:*                           1001       15275      1199/io.broadlink2.
      udp        0      0 0.0.0.0:39096           0.0.0.0:*                           1001       15295      1199/io.broadlink2.
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       15842      1083/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       15843      1083/io.tuya.0
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       15270      1199/io.broadlink2.
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12768      793/dhcpcd
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       685151     395062/io.mihome-va
      udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       14898      1008/io.mihome-vacu
      udp        0      0 0.0.0.0:53577           0.0.0.0:*                           1001       15277      1199/io.broadlink2.
      udp6       0      0 :::546                  :::*                                0          12782      793/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        14581      450/avahi-daemon: r
      udp6       0      0 :::34842                :::*                                108        14583      450/avahi-daemon: r
      2023-05-27 07:41:35.401  - debug: vis.0 (410968) States connected to redis: 127.0.0.1:9000
      2023-05-27 07:41:38.872  - info: vis.0 (410968) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.16.0, js-controller: 4.0.24
      2023-05-27 07:41:39.765  - info: vis.0 (410968) vis license is OK.
      2023-05-27 07:41:42.350  - info: vis.0 (410968) terminating
      2023-05-27 07:41:42.353  - info: vis.0 (410968) Terminated (NO_ERROR): Without reason
      2023-05-27 07:41:43.332  - info: host.iobroker instance system.adapter.vis.0 terminated with code 0 (NO_ERROR)
      2023-05-27 07:41:43.333  - info: host.iobroker Restart adapter system.adapter.vis.0 because enabled
      2023-05-27 07:42:14.038  - info: host.iobroker instance system.adapter.vis.0 started with pid 412378
      2023-05-27 07:42:15.983  - debug: vis.0 (412378) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-05-27 07:42:16.142  - debug: vis.0 (412378) Objects client ready ... initialize now
      2023-05-27 07:42:16.230  - debug: vis.0 (412378) Objects create System PubSub Client
      2023-05-27 07:42:16.232  - debug: vis.0 (412378) Objects create User PubSub Client
      2023-05-27 07:42:16.544  - debug: vis.0 (412378) Objects client initialize lua scripts
      2023-05-27 07:42:16.624  - debug: vis.0 (412378) Objects connected to redis: 127.0.0.1:9001
      2023-05-27 07:42:16.793  - debug: vis.0 (412378) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-05-27 07:42:16.948  - debug: vis.0 (412378) States create System PubSub Client
      2023-05-27 07:42:16.951  - debug: vis.0 (412378) States create User PubSub Client
      2023-05-27 07:42:17.207  - debug: vis.0 (412378) States connected to redis: 127.0.0.1:9000
      2023-05-27 07:42:24.265  - info: vis.0 (412378) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.16.0, js-controller: 4.0.24
      2023-05-27 07:42:24.863  - info: vis.0 (412378) vis license is OK.
      2023-05-27 07:42:28.027  - info: vis.0 (412378) terminating
      2023-05-27 07:42:28.029  - info: vis.0 (412378) Terminated (NO_ERROR): Without reason
      2023-05-27 07:42:28.748  - info: vis.0 (412378) terminating with timeout
      2023-05-27 07:42:29.123  - info: host.iobroker instance system.adapter.vis.0 terminated with code 0 (NO_ERROR)
      2023-05-27 07:42:29.124  - info: host.iobroker Restart adapter system.adapter.vis.0 because enabled
      iob diag has finished.
      Press any key for a summary
      • D denjo
        @djmarc75
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=37.0'C
        volt=0.9460V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        denjo
        /home/denjo
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 7811 M total memory
                 3495 M used memory
                 3081 M free memory
                  134 M buffer memory
                 1099 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        1.1G    /var/
        484M    /var/cache
        478M    /var/cache/apt
        372M    /var/log
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        javascript:     6.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        15455
        States:         12460
        Pending Updates: 5
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @denjo
        erstmal nix problematisches zu sehen ausser vll
        @denjo sagte in ECharts adapter keine Datenpunkte:
        sind die dauerhaft so hoch ?
        Und in der VIS mal
        nach "chart" filtern schon probiert ?
        D 2 Antworten Letzte Antwort
          @denjo
          Und in der VIS mal
          denjo
          @djmarc75 load average sagt mir nichts, ja hab ich schon probiert
            @denjo
            Und in der VIS mal
            denjo
            @djmarc75 könntest du das widget nicht exportieren und mir senden, geht das???
            • D denjo
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              geht das?
              [{"tpl":"tplEchartsChart","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","echart_oid":"nothing_selected","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"465px","top":"650px"},"widgetSet":"echarts"}]
              Ob das was bringt ? Ich würde die Kiste mal neu starten, den Browsercache nochmal leeren und dann nochmal schauen.
                geht das?
                denjo
                @djmarc75 hab ich schon alles probiert
                • D denjo
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  @denjo Widget Import probiert ?
                    denjo
                    @djmarc75 ja hat geklappt danke
                    • D denjo
                      Hallo, ich habe den ECharts adapter installiert aber bekomme keine Datenpunkte angezeigt bzw kann keine auswählen. Ich habe gelesen das der History Adapter auch installiert sein muss leider lässt der sich nicht installieren code25. Hat jemand Rat??
                      Den History Adapter konnte ich nun über die Katze installieren trotzdem habe ich im ECharts Adapter keine Datenpunkte die ich auswählen kann.
                      Jetzt habe ich doch beides zum laufen bekommen, aber leider fehlt mir das widget für vis???
                      Blödsinn! das muss normal gehen.
                      Sonst hast du noch mehr Probleme!
                      hast du das mal abgearbeitet?
                      • D denjo
                        @denjo
                        iobroker update history@2.2.4 --debug
                        sagt?
