  4. Admin.0 - Alias subscription error.
    6.7k
alias
93 Beiträge 26 Kommentatoren 17.0k Aufrufe 23 Beobachtet
  • M MartyBr
    @codierknecht
    Ich bekomme auch die gleichen Meldungen im Log, wenn ich in der Seitenleiste auf Energiefluss klicke:
    	2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=wireless-mbus.0.DWZ-22271898.data.2-0-VIF_VOLUME, sourceObj={"type":"state","common":{"name":"Volume (Instantaneous value)","role":"value.volume","type":"mixed","read":true,"write":false,"unit":"m³"},"native":{"id":".data.2-0-VIF_VOLUME","StorageNumber":0,"Tariff":0},"_id":"wireless-mbus.0.DWZ-22271898.data.2-0-VIF_VOLUME","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1665748391545}
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHPLG-S#7A30E5#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false,"custom":{"iot.0":{"smartName":{"de":"Shelly4"}}}},"native":{},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1680453185545,"_id":"shelly.0.SHPLG-S#7A30E5#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHPLG-S#7A2DD3#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false,"custom":{"iot.0":{"smartName":false}}},"native":{},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1680453187136,"_id":"shelly.0.SHPLG-S#7A2DD3#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHPLG-S#79AC43#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false,"custom":{"iot.0":{"smartName":{"de":"Shelly2"}}}},"native":{},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1680453184748,"_id":"shelly.0.SHPLG-S#79AC43#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHPLG-S#04096C#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false,"custom":{"iot.0":{"smartName":{"de":"Medien","smartType":"SWITCH"}}},"smartName":{"de":"Drucker","smartType":"SWITCH"}},"native":{},"_id":"shelly.0.SHPLG-S#04096C#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1680453181316}
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHPLG-S#04096C#1.Relay0.Energy, sourceObj={"type":"state","common":{"name":"Energy","type":"number","role":"value.power.consumption","read":true,"write":false,"def":0,"unit":"Wh"},"native":{},"_id":"shelly.0.SHPLG-S#04096C#1.Relay0.Energy","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1680453165542}
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.2.00085A499BE388.7.VOLTAGE, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":409.5,"unit":"V","name":"Kuechenlampe:7.VOLTAGE","role":"value.voltage"},"native":{"MIN":0,"UNIT":"V","OPERATIONS":5,"MAX":409.5,"FLAGS":1,"ID":"VOLTAGE","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"POWERMETER_PSM.VOLTAGE"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1675442719949,"_id":"hm-rpc.2.00085A499BE388.7.VOLTAGE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.2.00085A499BE388.7.POWER, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":163830,"unit":"W","name":"Kuechenlampe:7.POWER","role":"value.power"},"native":{"MIN":0,"UNIT":"W","OPERATIONS":5,"MAX":163830,"FLAGS":1,"ID":"POWER","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"POWERMETER_PSM.POWER"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1675442719942,"_id":"hm-rpc.2.00085A499BE388.7.POWER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.2.00085A499BE388.7.FREQUENCY, sourceObj={"type":"state","common":{"def":50,"type":"number","read":true,"write":false,"min":29.52,"max":70.47,"unit":"Hz","name":"Kuechenlampe:7.FREQUENCY","role":"value.frequency"},"native":{"MIN":29.52,"UNIT":"Hz","OPERATIONS":5,"MAX":70.47,"FLAGS":1,"ID":"FREQUENCY","TYPE":"FLOAT","DEFAULT":50,"CONTROL":"POWERMETER_PSM.FREQUENCY"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1675442719937,"_id":"hm-rpc.2.00085A499BE388.7.FREQUENCY","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.2.00085A499BE388.7.CURRENT, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":65535,"unit":"mA","name":"Kuechenlampe:7.CURRENT","role":"value.current"},"native":{"MIN":0,"UNIT":"mA","OPERATIONS":5,"MAX":65535,"FLAGS":1,"ID":"CURRENT","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"POWERMETER_PSM.CURRENT"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1675442719924,"_id":"hm-rpc.2.00085A499BE388.7.CURRENT","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.2.0001DD89972BD3.6.POWER, sourceObj={"type":"state","common":{"name":"Kueche-Kuehlschrank:6.POWER","def":0,"type":"number","read":true,"write":false,"min":0,"max":163830,"unit":"W","role":"value.power"},"native":{"MIN":0,"UNIT":"W","OPERATIONS":5,"MAX":163830,"FLAGS":1,"ID":"POWER","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"POWERMETER_PSM.POWER"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1675442719119,"_id":"hm-rpc.2.0001DD89972BD3.6.POWER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.2.0001DD89AAE630.6.POWER, sourceObj={"type":"state","common":{"name":"Kueche_Ofen1:6.POWER","role":"value.power","def":0,"type":"number","read":true,"write":false,"min":0,"max":163830,"unit":"W"},"native":{"MIN":0,"UNIT":"W","OPERATIONS":5,"MAX":163830,"FLAGS":1,"ID":"POWER","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"POWERMETER_PSM.POWER"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1675442719291,"_id":"hm-rpc.2.0001DD89AAE630.6.POWER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.1.NEQ1559992.1.STATE, sourceObj={"type":"state","common":{"name":"Waschmaschine HWR:1.STATE","def":false,"type":"boolean","read":true,"write":true,"role":"switch"},"native":{"CONTROL":"SWITCH.STATE","DEFAULT":false,"FLAGS":1,"ID":"STATE","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1672927788108,"_id":"hm-rpc.1.NEQ1559992.1.STATE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.1.NEQ1559992.2.FREQUENCY, sourceObj={"type":"state","common":{"name":"Waschmaschine HWR:2.FREQUENCY","def":0,"type":"number","read":true,"write":false,"min":48.72,"max":51.27,"unit":"Hz","role":"value.frequency"},"native":{"CONTROL":"POWERMETER.FREQUENCY","DEFAULT":0,"FLAGS":1,"ID":"FREQUENCY","MAX":51.27,"MIN":48.72,"OPERATIONS":5,"TAB_ORDER":4,"TYPE":"FLOAT","UNIT":"Hz"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1672927788120,"_id":"hm-rpc.1.NEQ1559992.2.FREQUENCY","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.1.NEQ1559992.2.CURRENT, sourceObj={"type":"state","common":{"name":"Waschmaschine HWR:2.CURRENT","def":0,"type":"number","read":true,"write":false,"min":0,"max":65535,"unit":"mA","role":"value.current"},"native":{"CONTROL":"POWERMETER.CURRENT","DEFAULT":0,"FLAGS":1,"ID":"CURRENT","MAX":65535,"MIN":0,"OPERATIONS":5,"TAB_ORDER":2,"TYPE":"FLOAT","UNIT":"mA"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1672927788116,"_id":"hm-rpc.1.NEQ1559992.2.CURRENT","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.1.OEQ1973502.1.STATE, sourceObj={"type":"state","common":{"name":"Trockner HWR_Dev:1.STATE","def":false,"type":"boolean","read":true,"write":true,"role":"switch"},"native":{"CONTROL":"SWITCH.STATE","DEFAULT":false,"FLAGS":1,"ID":"STATE","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1672927788045,"_id":"hm-rpc.1.OEQ1973502.1.STATE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.1.OEQ1973502.2.FREQUENCY, sourceObj={"type":"state","common":{"name":"Trockner HWR_Dev:2.FREQUENCY","def":0,"type":"number","read":true,"write":false,"min":48.72,"max":51.27,"unit":"Hz","role":"value.frequency"},"native":{"CONTROL":"POWERMETER.FREQUENCY","DEFAULT":0,"FLAGS":1,"ID":"FREQUENCY","MAX":51.27,"MIN":48.72,"OPERATIONS":5,"TAB_ORDER":4,"TYPE":"FLOAT","UNIT":"Hz"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1672927788059,"_id":"hm-rpc.1.OEQ1973502.2.FREQUENCY","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.2.00085A499BE388.4.STATE, sourceObj={"type":"state","common":{"def":false,"type":"boolean","read":true,"write":true,"role":"switch","name":"Kuechenlampe:4.STATE"},"native":{"MIN":false,"OPERATIONS":7,"MAX":true,"FLAGS":1,"ID":"STATE","TYPE":"BOOL","DEFAULT":false,"CONTROL":"SWITCH.STATE"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1675442719759,"_id":"hm-rpc.2.00085A499BE388.4.STATE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.ccccccfffeeaa411.load_power, sourceObj={"type":"state","common":{"name":"Load power","type":"number","unit":"W","read":true,"write":false,"role":"value.power"},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1670063309195,"_id":"zigbee.0.ccccccfffeeaa411.load_power","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHPLG-S#04096C#1.Relay0.Power, sourceObj={"type":"state","common":{"name":"Power","type":"number","role":"value.power","read":true,"write":false,"def":0,"unit":"W"},"native":{},"_id":"shelly.0.SHPLG-S#04096C#1.Relay0.Power","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1680453165508}
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHPLG-S#79AC43#1.Relay0.Power, sourceObj={"type":"state","common":{"smartName":{"de":"Shelly-Plug-1","smartType":"SWITCH"},"name":"Power","type":"number","role":"value.power","read":true,"write":false,"def":0,"unit":"W","custom":{"iot.0":{"smartName":{"de":"Power","smartType":"SWITCH"}}}},"native":{},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1680453152989,"_id":"shelly.0.SHPLG-S#79AC43#1.Relay0.Power","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHPLG-S#7A2DD3#1.Relay0.Power, sourceObj={"type":"state","common":{"name":"Power","type":"number","role":"value.power","read":true,"write":false,"def":0,"unit":"W","custom":{"iot.0":{"smartName":{"de":"Power","smartType":"SWITCH"}}}},"native":{},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1680453172771,"_id":"shelly.0.SHPLG-S#7A2DD3#1.Relay0.Power","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHPLG-S#7A30E5#1.Relay0.Power, sourceObj={"type":"state","common":{"name":"Power","type":"number","role":"value.power","read":true,"write":false,"def":0,"unit":"W"},"native":{},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1680453159296,"_id":"shelly.0.SHPLG-S#7A30E5#1.Relay0.Power","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.561	error	Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.ccccccfffee1cf1b.load_power, sourceObj={"type":"state","common":{"name":"Load power","type":"number","unit":"W","read":true,"write":false,"role":"value.power"},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1670062871559,"_id":"zigbee.0.ccccccfffee1cf1b.load_power","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=smartmeter.0.1-1:2_8_0.value, sourceObj={"type":"state","common":{"name":"1-1:2_8_0.value","type":"number","read":true,"unit":"kWh","role":"value","write":false},"native":{"id":"1-1:2_8_0.value"},"_id":"smartmeter.0.1-1:2_8_0.value","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1642450859161}
    admin.0
    2023-04-04 19:44:41.559	error	Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.ccccccfffed71e1c.load_power, sourceObj={"type":"state","common":{"name":"Load power","type":"number","unit":"W","read":true,"write":false,"role":"value.power"},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1670063218320,"_id":"zigbee.0.ccccccfffed71e1c.load_power","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.559	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.CUX3506003.1.TEMPERATURE, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":-100,"max":200,"unit":"°C","role":"value.temperature","name":"Temp-WZ:1.TEMPERATURE"},"native":{"ID":"TEMPERATURE","UNIT":"°C","TAB_ORDER":0,"OPERATIONS":1,"FLAGS":1,"TYPE":"FLOAT","MIN":-100,"MAX":200,"DEFAULT":0},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1652032552687,"_id":"hm-rpc.0.CUX3506003.1.TEMPERATURE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.559	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.CUX3506001.1.TEMPERATURE, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":-100,"max":200,"unit":"°C","role":"value.temperature","name":"Temp-Kueche:1.TEMPERATURE"},"native":{"ID":"TEMPERATURE","UNIT":"°C","TAB_ORDER":0,"OPERATIONS":1,"FLAGS":1,"TYPE":"FLOAT","MIN":-100,"MAX":200,"DEFAULT":0},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1652032552508,"_id":"hm-rpc.0.CUX3506001.1.TEMPERATURE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.559	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.CUX3506006.1.TEMPERATURE, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":-100,"max":200,"unit":"°C","role":"value.temperature","name":"Temp-Gaestez:1.TEMPERATURE"},"native":{"ID":"TEMPERATURE","UNIT":"°C","TAB_ORDER":0,"OPERATIONS":1,"FLAGS":1,"TYPE":"FLOAT","MIN":-100,"MAX":200,"DEFAULT":0},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1652032552374,"_id":"hm-rpc.0.CUX3506006.1.TEMPERATURE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.1.OEQ1973502.2.ENERGY_COUNTER, sourceObj={"type":"state","common":{"name":"Trockner HWR_Dev:2.ENERGY_COUNTER","def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","role":"value.power.consumption"},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1672927788057,"_id":"hm-rpc.1.OEQ1973502.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.1.OEQ1973502.2.POWER, sourceObj={"type":"state","common":{"name":"Trockner HWR_Dev:2.POWER","def":0,"type":"number","read":true,"write":false,"min":0,"max":167772.15,"unit":"W","role":"value.power"},"native":{"CONTROL":"POWERMETER.POWER","DEFAULT":0,"FLAGS":1,"ID":"POWER","MAX":167772.15,"MIN":0,"OPERATIONS":5,"TAB_ORDER":1,"TYPE":"FLOAT","UNIT":"W"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1672927788062,"_id":"hm-rpc.1.OEQ1973502.2.POWER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.1.OEQ1973502.2.VOLTAGE, sourceObj={"type":"state","common":{"name":"Trockner HWR_Dev:2.VOLTAGE","def":0,"type":"number","read":true,"write":false,"min":0,"max":6553.5,"unit":"V","role":"value.voltage"},"native":{"CONTROL":"POWERMETER.VOLTAGE","DEFAULT":0,"FLAGS":1,"ID":"VOLTAGE","MAX":6553.5,"MIN":0,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"FLOAT","UNIT":"V"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1672927788064,"_id":"hm-rpc.1.OEQ1973502.2.VOLTAGE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.1.NEQ1559992.2.ENERGY_COUNTER, sourceObj={"type":"state","common":{"name":"Waschmaschine HWR:2.ENERGY_COUNTER","def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","role":"value.power.consumption"},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1672927788118,"_id":"hm-rpc.1.NEQ1559992.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.1.NEQ1559992.2.POWER, sourceObj={"type":"state","common":{"name":"Waschmaschine HWR:2.POWER","def":0,"type":"number","read":true,"write":false,"min":0,"max":167772.15,"unit":"W","role":"value.power"},"native":{"CONTROL":"POWERMETER.POWER","DEFAULT":0,"FLAGS":1,"ID":"POWER","MAX":167772.15,"MIN":0,"OPERATIONS":5,"TAB_ORDER":1,"TYPE":"FLOAT","UNIT":"W"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1672927788122,"_id":"hm-rpc.1.NEQ1559992.2.POWER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.1.NEQ1559992.2.VOLTAGE, sourceObj={"type":"state","common":{"name":"Waschmaschine HWR:2.VOLTAGE","def":0,"type":"number","read":true,"write":false,"min":0,"max":6553.5,"unit":"V","role":"value.voltage"},"native":{"CONTROL":"POWERMETER.VOLTAGE","DEFAULT":0,"FLAGS":1,"ID":"VOLTAGE","MAX":6553.5,"MIN":0,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"FLOAT","UNIT":"V"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1672927788124,"_id":"hm-rpc.1.NEQ1559992.2.VOLTAGE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.2.0001DD89AAE7C9.6.POWER, sourceObj={"type":"state","common":{"name":"Kueche_Ofen2:6.POWER","role":"value.power","def":0,"type":"number","read":true,"write":false,"min":0,"max":163830,"unit":"W"},"native":{"MIN":0,"UNIT":"W","OPERATIONS":5,"MAX":163830,"FLAGS":1,"ID":"POWER","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"POWERMETER_PSM.POWER"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1675442719473,"_id":"hm-rpc.2.0001DD89AAE7C9.6.POWER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.2.0001DD89A463F1.6.POWER, sourceObj={"type":"state","common":{"name":"Kueche_Spülmaschine:6.POWER","role":"value.power","def":0,"type":"number","read":true,"write":false,"min":0,"max":163830,"unit":"W"},"native":{"MIN":0,"UNIT":"W","OPERATIONS":5,"MAX":163830,"FLAGS":1,"ID":"POWER","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"POWERMETER_PSM.POWER"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1675442719650,"_id":"hm-rpc.2.0001DD89A463F1.6.POWER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.560	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.2.00085A499BE388.7.ENERGY_COUNTER, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838859.1,"unit":"Wh","name":"Kuechenlampe:7.ENERGY_COUNTER","role":"value.power.consumption"},"native":{"MIN":0,"UNIT":"Wh","OPERATIONS":5,"MAX":838859.1,"FLAGS":1,"ID":"ENERGY_COUNTER","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"POWERMETER_PSM.ENERGY_COUNTER"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1675442719932,"_id":"hm-rpc.2.00085A499BE388.7.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.559	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.CUX3506005.1.TEMPERATURE, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":-100,"max":200,"unit":"°C","role":"value.temperature","name":"Temp-Gaestebad:1.TEMPERATURE"},"native":{"ID":"TEMPERATURE","UNIT":"°C","TAB_ORDER":0,"OPERATIONS":1,"FLAGS":1,"TYPE":"FLOAT","MIN":-100,"MAX":200,"DEFAULT":0},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1652032552239,"_id":"hm-rpc.0.CUX3506005.1.TEMPERATURE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.559	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.CUX3506004.1.TEMPERATURE, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":-100,"max":200,"unit":"°C","role":"value.temperature","name":"Temp-HWR:1.TEMPERATURE"},"native":{"ID":"TEMPERATURE","UNIT":"°C","TAB_ORDER":0,"OPERATIONS":1,"FLAGS":1,"TYPE":"FLOAT","MIN":-100,"MAX":200,"DEFAULT":0},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1652032552428,"_id":"hm-rpc.0.CUX3506004.1.TEMPERATURE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.559	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.CUX3506009.1.TEMPERATURE, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":-100,"max":200,"unit":"°C","role":"value.temperature","name":"Temp-Schlafz:1.TEMPERATURE"},"native":{"ID":"TEMPERATURE","UNIT":"°C","TAB_ORDER":0,"OPERATIONS":1,"FLAGS":1,"TYPE":"FLOAT","MIN":-100,"MAX":200,"DEFAULT":0},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1652032552597,"_id":"hm-rpc.0.CUX3506009.1.TEMPERATURE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.559	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.1.NEQ1480228.1.STATE, sourceObj={"type":"state","common":{"name":"TFK Haustuer:1.STATE","def":false,"type":"boolean","read":true,"write":false,"role":"sensor.window"},"native":{"CONTROL":"DOOR_SENSOR.STATE","DEFAULT":false,"FLAGS":1,"ID":"STATE","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1672927787997,"_id":"hm-rpc.1.NEQ1480228.1.STATE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-04-04 19:44:41.559	error	Alias subscription error. Please check your alias definitions: sourceId=smartmeter.0.1-1:1_8_0.value, sourceObj={"type":"state","common":{"name":"1-1:1_8_0.value","type":"number","read":true,"unit":"kWh","role":"value","write":false},"native":{"id":"1-1:1_8_0.value"},"_id":"smartmeter.0.1-1:1_8_0.value","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1642450849387}
    Die Anzeige funktioniert sowohl in der VIS (Editor) wie auch auf dem Tablett über die Visualisierung.
    CodierknechtC Offline
    Codierknecht
    #75
    @martybr sagte in Admin.0 - Alias subscription error.:
    admin.0
    https://github.com/SKB-CGN/ioBroker.energiefluss/issues/174#issue-1654326590
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
      bishop
      #76
      Nur mal so reingeworfen... ich hatte den Energiefluss adapter noch nicht installiert aber trotzdem die Meldungen.
      • R Offline
        Rushmed
        #77
        Ich schließe mich @bishop9191 an. Hatte den Adapter Energiefluss auch nie installiert und bekomme trotzdem manchmal die Meldungen. Dieser Fred hier ist auch deutlich älter als der initial Release des Adapters.
        Meistens (oder vll. sogar immer) kommen die Meldungen während ich Blocklyscripte bearbeite.
        Also immer wenn die Meldungen auftauchen habe ich gerade irgendetwas an Scripten gemacht aber lange nicht immer wenn ich was an Scripten mache kommen die Meldungen.
        CodierknechtC D 2 Antworten Letzte Antwort
        • R Rushmed
          Codierknecht
          #78
          @rushmed
          Scheint irgendeine seltsame Wechselwirkung zu sein.
          Vor der Installation des Energiefluss-Adapters hatte ich diese Meldungen gar nicht.
          Nach der Installation nahezu sicher reproduzierbar, indem ich in der Seitenleiste die Anzeige des Adapters aufrufe.
          Nach dem Stopp der Instanz ist wieder Ruhe im Karton.
          Also iwie muss das ja schon miteinander zusammenhängen.
          • CodierknechtC Codierknecht
            @rushmed
            Codierknecht
            #79
            Gerade nochmal wieder die Instanz gestartet.
            Nach über 6 Stunden Ruhe bringt ein Klick in die Seitenleiste unmittelbar die Fehler.
            Nach meiner Erfahrung ein nahezu sicheres Zeichen für eine Wechselwirkung.
              MartyBr
              #80
              @codierknecht
              Ich kann das bestätigen. Ich habe hier das gleiche Verhalten und kann es jederzeit durch einen Klick in der Seitenleiste auf Energiefluss provozieren.
              Martin
              Homematic und Homematic IP
              • R Offline
                Rushmed
                #81
                Ok, das kann alles sein. Dann breitet sich das Problem wohl aus. Wichtig ist dass wir den Auslöser finden um den Entwicklern einen Lösungsansatz zu bieten.
                • M MartyBr
                  @codierknecht
                  Codierknecht
                  #82
                  @martybr
                  Wenn man auf die Seitenleiste verzichtet scheint's ziemlich stabil zu sein.
                  Da ich den Adapter nur für die Vis einsetze, kann ich damit leben.
                  Ich werde das aber weiter beobachten.
                    @martybr
                    MartyBr
                    #83
                    @codierknecht
                    Ich mache das genauso. Da ich die Werte nur n der VIS abrufe/anschaue, hatte ich es nicht gemeldet, da ich einen Fehler bei meinem System vermutet habe. Aber es ist ja gut, dass ich hier nicht alleine stehe.
                    Martin
                    • R Rushmed
                      danny_v1
                      #84
                      @rushmed Seit gestern habe ich den gleichen Effekt festgestellt, wenn ich was an einem Blockly ändere kommen 30-40 Fehler. Den Energiefluss Adapter habe ich nicht installiert.
                      Gibt es da jetzt schon neue Erkenntnisse wo das Problem her kommt?
                      Kann aber auch sein das bei mir einige Aliase wirklich fehlerhaft sind, die sind schon ewig alt, die hatte ich anfangs alle händisch erstellt also ohne Geräte oder Alias Manager.
                      Versuche gerade etwas Ordnung zu machen und alle Aliase mit dem Alias Manager Raum für Raum zu Bearbeiten.
                      Hat da jemand eine gute Vorgehensweise?
                      Was sehr Wünschenswert wäre wenn man sich anzeigen lassen könnte wo überall ein Datenpunkt verwendet wird. So könnte man auch schnell nicht mehr verwendete Datenpunkte löschen. (Komme aus der SPS Programmierung da ist das ein viel genutztes Werkzeug).
                      G 1 Antwort Letzte Antwort
                      • D danny_v1
                        guergen
                        #85
                        Der Threat ist zwar schon alt, aber das Problem immer noch aktuell (admin 6.9.1; js 5.0.12)!
                        • G guergen
                          Codierknecht
                          #86
                          @guergen sagte in Admin.0 - Alias subscription error.:
                          admin 6.9.1
                          Als Beta-Tester unterwegs?
                          R G 2 Antworten Letzte Antwort
                            admin 6.9.1
                            Rushmed
                            #87
                            @codierknecht Im stable existiert das Problem auch noch.
                            Admin 6.8.0; JS 7.0.3
                              admin 6.9.1
                              guergen
                              #88
                              @codierknecht Ja
                              • W Online
                                W Online
                                Wildbill
                                schrieb am zuletzt editiert von Wildbill
                                #89
                                Durch Zufall habe ich eben den Thread gefunden. Ich hatte das auch immer wieder mal, als ich noch aliase benutzt hatte. Dabei betraf es nicht immer die gleichen, sondern wild gemischt immer mal wieder andere. Aufgetreten ist es immer dann, wenn ich ein Blockly-Script gespeichert hatte. So gut wie immer kamen dann ein paar Alias-Fehler im Log. Es betraf aber nicht immer die gleichen Blockly-Scripte und teilweise trat es auch auf bei Scripten die überhaupt nicht auf einen Alias oder einen Datenpunkt, der einen Alias hat verwiesen, so dass ich damals keinen Zusammenhang sah. Erst als ich den ersten Satz von @danny_v1 eben las, fiel es mir wieder ein.
                                Leider habe ich damals dann alle Aliase wieder gelöscht und verwende wieder die direkten Datenpunkte, da mir damals der Aufwand, jedem vermeintlich fehlerhaft gemeldeten Alias nachzugehen höher war, als ab und an ein paar Scripte zu ändern, wenn ichb mal ein Gerät austausche…
                                Aber jetzt so im Nachhinein…
                                Gruss, Jürgen
                                P.S.: Ich war damals und bin es auch heute noch zu 99% auf den stable-Versionen unterwegs. Nur einen Adapter habe ich direkt aus Github (tractive) und einige wenige aus latest. Aber keine wie den admin, javascript oder sonst welche „essentiellen“ von iobroker.
                                • W Wildbill
                                  Gruss, Jürgen
                                  guergen
                                  #90
                                  @wildbill
                                  Das mit den Blockly´s kann ich auch bestätigen!
                                  • G guergen
                                    @wildbill
                                    dos1973
                                    schrieb am zuletzt editiert von dos1973
                                    #91
                                    ich habe auch den Fehler...
                                    habe heute meine ersten Aliase angelegt.
                                    und der ist auch nur in einem einzigen Blockly hinterlegt, ganz sicher. Es gibt keine fehlenden Verknüpfungen
                                    	2024-01-04 12:56:44.507	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-25#C45BBE6C2843#1.version, sourceObj={"type":"state","common":{"name":{"en":"Firmware version","de":"Firmware-Version","ru":"Версия прошивки","pt":"Versão de firmware","nl":"Firmware","fr":"Firmware version","it":"Versione firmware","es":"Versión de firmware","pl":"Okładka","uk":"Версія прошивки","zh-cn":"导 言"},"type":"string","role":"state","read":true,"write":false,"icon":"data:image/svg+xml;base64,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"},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704331083192,"_id":"shelly.1.SHSW-25#C45BBE6C2843#1.version","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                    admin.0
                                    2024-01-04 12:56:44.507	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-25#C45BBE6C2843#1.uptime, sourceObj={"type":"state","common":{"name":{"en":"Device running since","de":"Gerät läuft seit","ru":"Устройство работает с","pt":"Dispositivo em execução desde","nl":"Device vlucht sinds","fr":"Appareils fonctionnant depuis","it":"Dispositivo in esecuzione da","es":"Dispositivo funcionando desde","pl":"Device biegnie od czasu do czasu","uk":"Пристрої, що працюють з","zh-cn":"自那时以来丧失能力"},"type":"number","role":"value.interval","unit":"sec","read":true,"write":false,"icon":"data:image/svg+xml;base64,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"},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704331083221,"_id":"shelly.1.SHSW-25#C45BBE6C2843#1.uptime","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                    admin.0
                                    2024-01-04 12:56:44.507	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-25#C45BBE6C2843#1.temperatureC, sourceObj={"type":"state","common":{"name":{"en":"Temperature","de":"Temperatur","ru":"Температура","pt":"Temperatura","nl":"Temperatuur","fr":"Température","it":"Temperatura","es":"Temperatura","pl":"Temperatura","zh-cn":"模范"},"type":"number","role":"value.temperature","read":true,"write":false,"unit":"°C"},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704331083413,"_id":"shelly.1.SHSW-25#C45BBE6C2843#1.temperatureC","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                    admin.0
                                    2024-01-04 12:56:44.507	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-25#C45BBE6C2843#1.rssi, sourceObj={"type":"state","common":{"name":{"en":"Received Signal Strength Indication","de":"Empfangene Signalstärkeanzeige","ru":"Получена индикация силы сигнала","pt":"Indicação de Força de Sinal Recebida","nl":"Vervangde Signal Strength Indicatie","fr":"Indication de force de signal reçue","it":"Indicazione di forza segnale ricevuta","es":"Indicación de fuerza de la señal recibida","pl":"Received Signal Strength (ang.)","uk":"Отриманий показ сигналу","zh-cn":"接受签字国制"},"type":"number","role":"value","unit":"dBm","read":true,"write":false,"icon":"data:image/svg+xml;base64,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"},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704331083221,"_id":"shelly.1.SHSW-25#C45BBE6C2843#1.rssi","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                    was nun, ignorieren?
                                    möchte nur vermeiden dass mir später, wenn ich alle angelegt und in den scrpten verbunden habe nix mehr geht
                                    I 1 Antwort Letzte Antwort
                                    • D dos1973
                                      admin.0
                                      admin.0
                                      admin.0
                                      I Offline
                                      I Offline
                                      iobroker2001
                                      #92
                                      Hi, ich bekomme seit ein paar Tagen ebenfalls "Alias subscription error...".
                                      Aliase habe ich schon seit langer Zeit ohne Probleme. Aber jetzt vor ein paar Tagen habe ich ein neues Aliasverzeichnis mit 3 Homematic-Aliasen angelegt, die in InfluxDB2 gespeichert werden (Solltemperatur, Isttemp. und Ventilstellung eines Heizkörperthermostats.
                                      Bei allen 3 neuen Aliaswerten bekomme ich Meldungen dieser Art:
                                      Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.MEQ1873749.4.VALVE_STATE, sourceObj={"type":"state","common":{"name":"HT_Wohnzimmer_links:4.VALVE_STATE","role":"value.valve","def":0,"type":"number","read":true,"write":false,"min":0,"max":99,"unit":"%","mobile":{"admin":{"visible":true}}},"native":{"CONTROL":"NONE","DEFAULT":0,"FLAGS":1,"ID":"VALVE_STATE","MAX":99,"MIN":0,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"INTEGER","UNIT":"%"},"_id":"hm-rpc.0.MEQ1873749.4.VALVE_STATE","acl":{"object":1636,"state":1636,"file":1632,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1706028268680}
                                      Ich hatte nie den Energiefluss-Adapter installiert, mein System ist auf dem neuesten Stand, keine GitHub-Adapter installiert.
                                      Die Aliase zeigen auf bereits lange bestehende DP - nur, dass diese jetzt mit der InfluxDB geloggt werden.
                                      W 1 Antwort Letzte Antwort
                                      • I iobroker2001
                                        W Offline
                                        W Offline
                                        w00dy
                                        schrieb am zuletzt editiert von w00dy
                                        #93
                                        @Codierknecht
                                        Moin, bei mir siehts auch nicht besser aus:
                                        web.0
                                           2024-03-17 16:35:51.593	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.Wifi_SSId, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.Wifi_SSId","common":{"type":"string","role":"state","read":true,"write":false,"name":"gosund-Warmwasser-UP Wifi SSId"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877877,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.592	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.Wifi_RSSI, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.Wifi_RSSI","common":{"type":"number","role":"value.rssi","read":true,"write":false,"name":"gosund-Warmwasser-UP Wifi RSSI"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877965,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.593	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.Wifi_Signal, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.Wifi_Signal","common":{"role":"value","read":true,"write":false,"type":"number","name":"gosund-Warmwasser-UP Wifi Signal"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877993,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.592	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.Wifi_Mode, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.Wifi_Mode","common":{"type":"number","role":"value","read":true,"write":true,"name":"gosund-Warmwasser-UP Wifi Mode"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877942,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.591	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.Wifi_Downtime, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.Wifi_Downtime","common":{"type":"string","role":"state","read":true,"write":false,"name":"gosund-Warmwasser-UP Wifi Downtime"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242878056,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.591	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.Wifi_BSSId, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.Wifi_BSSId","common":{"type":"string","role":"state","read":true,"write":false,"name":"gosund-Warmwasser-UP Wifi BSSId"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877899,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.590	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.Wifi_AP, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.Wifi_AP","common":{"role":"value","read":true,"write":false,"type":"number","name":"gosund-Warmwasser-UP Wifi AP"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877850,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.590	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.Uptime, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.Uptime","common":{"type":"mixed","role":"state","read":true,"write":false,"name":"gosund-Warmwasser-UP Uptime"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877595,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.591	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.Wifi_Channel, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.Wifi_Channel","common":{"type":"number","role":"level","read":true,"write":true,"name":"gosund-Warmwasser-UP Wifi Channel"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877921,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.591	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.Wifi_LinkCount, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.Wifi_LinkCount","common":{"role":"value","read":true,"write":false,"type":"number","name":"gosund-Warmwasser-UP Wifi LinkCount"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242878034,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.589	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.Time, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.Time","common":{"type":"string","role":"state","read":true,"write":true,"name":"gosund-Warmwasser-UP Time"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877542,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.589	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.Sleep, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.Sleep","common":{"role":"value","read":true,"write":false,"type":"number","name":"gosund-Warmwasser-UP Sleep"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877775,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.590	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.UptimeSec, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.UptimeSec","common":{"role":"value","read":true,"write":false,"type":"number","name":"gosund-Warmwasser-UP UptimeSec"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877639,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.589	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.POWER, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.POWER","common":{"type":"boolean","role":"switch","read":true,"write":true,"storeMap":true,"name":"gosund-Warmwasser-UP POWER"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242874202,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.589	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.SleepMode, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.SleepMode","common":{"type":"string","role":"state","read":true,"write":false,"name":"gosund-Warmwasser-UP SleepMode"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877753,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.588	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.MqttCount, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.MqttCount","common":{"role":"value","read":true,"write":false,"type":"number","name":"gosund-Warmwasser-UP MqttCount"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877816,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.588	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.LoadAvg, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.LoadAvg","common":{"role":"value","read":true,"write":false,"type":"number","name":"gosund-Warmwasser-UP LoadAvg"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877796,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.588	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.Heap, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.Heap","common":{"role":"value","read":true,"write":false,"type":"number","name":"gosund-Warmwasser-UP Heap"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242877659,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.587	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.ENERGY_Yesterday, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.ENERGY_Yesterday","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"gosund-Warmwasser-UP ENERGY Yesterday"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242878154,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.587	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.ENERGY_Voltage, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.ENERGY_Voltage","common":{"type":"number","role":"value.voltage","read":true,"write":false,"unit":"V","name":"gosund-Warmwasser-UP ENERGY Voltage"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242878252,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.587	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.ENERGY_TotalStartTime, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.ENERGY_TotalStartTime","common":{"type":"string","role":"value","read":true,"write":false,"name":"gosund-Warmwasser-UP ENERGY TotalStartTime"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242878091,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.586	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.ENERGY_Total, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.ENERGY_Total","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"gosund-Warmwasser-UP ENERGY Total","custom":{"influxdb.0":{"enabled":true,"storageType":"","aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":"0","changesMinDelta":"0","ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":"1000"}}},"native":{},"type":"state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1705314367701}
                                        web.0
                                           2024-03-17 16:35:51.586	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.ENERGY_Today, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.ENERGY_Today","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"gosund-Warmwasser-UP ENERGY Today"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242878184,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.586	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.ENERGY_Power, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.ENERGY_Power","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"W","name":"gosund-Warmwasser-UP ENERGY Power","custom":{"influxdb.0":{"enabled":true,"storageType":"","aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":"0","changesMinDelta":"0","ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":"1000"}}},"native":{},"type":"state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1705314318785}
                                        web.0
                                           2024-03-17 16:35:51.585	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.gosund-Warmwasser-UP.ENERGY_Period, sourceObj={"_id":"sonoff.0.gosund-Warmwasser-UP.ENERGY_Period","common":{"role":"value","read":true,"write":false,"type":"number","name":"gosund-Warmwasser-UP ENERGY Period"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1705242878208,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.585	error	Alias subscription error. Please check your alias definitions: sourceId=hue.0.Wohnzimmer.xy, sourceObj={"_id":"hue.0.Wohnzimmer.xy","type":"state","common":{"type":"string","name":"Wohnzimmer.xy","read":true,"write":true,"role":"level.color.xy","def":"[0.5612,0.4042]"},"native":{"id":"2"},"from":"system.adapter.hue.0","user":"system.user.admin","ts":1710516286482,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.585	error	Alias subscription error. Please check your alias definitions: sourceId=hue.0.Wohnzimmer.sat, sourceObj={"_id":"hue.0.Wohnzimmer.sat","type":"state","common":{"type":"number","name":"Wohnzimmer.sat","read":true,"write":true,"role":"level.color.saturation","min":0,"max":254,"def":251},"native":{"id":"2"},"from":"system.adapter.hue.0","user":"system.user.admin","ts":1707901953376,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.584	error	Alias subscription error. Please check your alias definitions: sourceId=hue.0.Wohnzimmer.r, sourceObj={"_id":"hue.0.Wohnzimmer.r","type":"state","common":{"type":"number","name":"Wohnzimmer.r","read":true,"write":true,"role":"level.color.red","min":0,"max":255,"def":0},"native":{"id":"2"},"from":"system.adapter.hue.0","user":"system.user.admin","ts":1710516286659,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.584	error	Alias subscription error. Please check your alias definitions: sourceId=hue.0.Wohnzimmer.on, sourceObj={"_id":"hue.0.Wohnzimmer.on","type":"state","common":{"type":"boolean","name":"Wohnzimmer.on","read":true,"write":true,"role":"switch","def":false},"native":{"id":"2"},"from":"system.adapter.hue.0","user":"system.user.admin","ts":1710516286248,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.584	error	Alias subscription error. Please check your alias definitions: sourceId=hue.0.Wohnzimmer.level, sourceObj={"_id":"hue.0.Wohnzimmer.level","type":"state","common":{"type":"number","name":"Wohnzimmer.level","read":true,"write":true,"role":"level.dimmer","min":0,"max":100,"def":0},"native":{"id":"2"},"from":"system.adapter.hue.0","user":"system.user.admin","ts":1710516286883,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.583	error	Alias subscription error. Please check your alias definitions: sourceId=hue.0.Wohnzimmer.hue, sourceObj={"_id":"hue.0.Wohnzimmer.hue","type":"state","common":{"type":"number","name":"Wohnzimmer.hue","read":true,"write":true,"role":"level.color.hue","unit":"°","min":0,"max":360,"def":35},"native":{"id":"2"},"from":"system.adapter.hue.0","user":"system.user.admin","ts":1710516286330,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.583	error	Alias subscription error. Please check your alias definitions: sourceId=hue.0.Wohnzimmer.g, sourceObj={"_id":"hue.0.Wohnzimmer.g","type":"state","common":{"type":"number","name":"Wohnzimmer.g","read":true,"write":true,"role":"level.color.green","min":0,"max":255,"def":0},"native":{"id":"2"},"from":"system.adapter.hue.0","user":"system.user.admin","ts":1710516286704,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.582	error	Alias subscription error. Please check your alias definitions: sourceId=hue.0.Wohnzimmer.effect, sourceObj={"_id":"hue.0.Wohnzimmer.effect","type":"state","common":{"type":"string","name":"Wohnzimmer.effect","read":true,"write":true,"role":"switch","def":"none"},"native":{"id":"2"},"from":"system.adapter.hue.0","user":"system.user.admin","ts":1710516286442,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.582	error	Alias subscription error. Please check your alias definitions: sourceId=hue.0.Wohnzimmer.ct, sourceObj={"_id":"hue.0.Wohnzimmer.ct","type":"state","common":{"type":"number","name":"Wohnzimmer.ct","read":true,"write":true,"role":"level.color.temperature","unit":"°K","min":1802,"max":6536,"def":2000},"native":{"id":"2"},"from":"system.adapter.hue.0","user":"system.user.admin","ts":1710516286526,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.581	error	Alias subscription error. Please check your alias definitions: sourceId=hue.0.Wohnzimmer.command, sourceObj={"_id":"hue.0.Wohnzimmer.command","type":"state","common":{"type":"string","name":"Wohnzimmer.command","read":true,"write":true,"role":"command","def":"{}"},"native":{"id":"2"},"from":"system.adapter.hue.0","user":"system.user.admin","ts":1710516286801,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.581	error	Alias subscription error. Please check your alias definitions: sourceId=hue.0.Wohnzimmer.colormode, sourceObj={"_id":"hue.0.Wohnzimmer.colormode","type":"state","common":{"type":"string","name":"Wohnzimmer.colormode","read":true,"write":false,"role":"sensor.colormode","def":"xy"},"native":{"id":"2"},"from":"system.adapter.hue.0","user":"system.user.admin","ts":1710516286607,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.581	error	Alias subscription error. Please check your alias definitions: sourceId=hue.0.All.bri, sourceObj={"_id":"hue.0.All.bri","type":"state","common":{"type":"number","name":"All.bri","read":true,"write":true,"role":"level.dimmer","min":0,"max":254,"def":0},"native":{"id":"0"},"from":"system.adapter.hue.0","user":"system.user.admin","ts":1710516284371,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.580	error	Alias subscription error. Please check your alias definitions: sourceId=hue.0.Wohnzimmer.b, sourceObj={"_id":"hue.0.Wohnzimmer.b","type":"state","common":{"type":"number","name":"Wohnzimmer.b","read":true,"write":true,"role":"level.color.blue","min":0,"max":255,"def":0},"native":{"id":"2"},"from":"system.adapter.hue.0","user":"system.user.admin","ts":1710516286765,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.580	error	Alias subscription error. Please check your alias definitions: sourceId=hue.0.Wohnzimmer.alert, sourceObj={"_id":"hue.0.Wohnzimmer.alert","type":"state","common":{"type":"string","name":"Wohnzimmer.alert","read":true,"write":true,"role":"switch","def":"none"},"native":{"id":"2"},"from":"system.adapter.hue.0","user":"system.user.admin","ts":1710516286561,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.580	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.shellyplus1#441793a44b70#1.Mqtt.topicPrefix, sourceObj={"type":"state","common":{"name":{"en":"Topic prefix","de":"Thema Präfix","ru":"Тема префикса","pt":"Prefixo de tópico","nl":"Onderwerp voorvoegsel","fr":"Préfixe du sujet","it":"Prefisso tematico","es":"Prefijo temático","pl":"Przedrostek","uk":"Тема префікса","zh-cn":"主题前"},"type":"string","role":"state","read":true,"write":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1710516340023,"_id":"shelly.1.shellyplus1#441793a44b70#1.Mqtt.topicPrefix","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.579	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.shellyplus1#441793a44b70#1.Sys.timezone, sourceObj={"type":"state","common":{"name":{"en":"Timezone","de":"Zeitzone","ru":"Часовой пояс","pt":"Fuso horário","nl":"Tijdzone","fr":"Timezone","it":"Tempo","es":"Zona horaria","pl":"Timezone","uk":"Часовий пояс","zh-cn":"时间区"},"type":"string","role":"text","read":true,"write":true},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1710516339876,"_id":"shelly.1.shellyplus1#441793a44b70#1.Sys.timezone","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.579	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.shellyplus1#441793a44b70#1.Relay0.temperatureF, sourceObj={"type":"state","common":{"name":{"en":"Temperature","de":"Temperatur","ru":"Температура","pt":"Temperatura","nl":"Temperatuur","fr":"Température","it":"Temperatura","es":"Temperatura","pl":"Temperatura","zh-cn":"模范"},"type":"number","role":"value.temperature","read":true,"write":false,"unit":"°F"},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1710516337198,"_id":"shelly.1.shellyplus1#441793a44b70#1.Relay0.temperatureF","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.561	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.shellyplus1#441793a44b70#1.Mqtt.statusNotifications, sourceObj={"type":"state","common":{"name":{"en":"Generic status notifications enabled","de":"Generelle Statusmeldungen aktiviert","ru":"Уведомления о генерическом статусе включены","pt":"Notificações de status genéricas activadas","nl":"Generische status melding","fr":"Notifications d'état générique activé","it":"Notifiche di stato generiche abilitate","es":"Se han habilitado notificaciones de estado genérico","pl":"Statystyki genetyczne umożliwiły","uk":"Увімкнути повідомлення про статус","zh-cn":"基因身份通知使得"},"type":"boolean","role":"state","read":true,"write":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1710516340081,"_id":"shelly.1.shellyplus1#441793a44b70#1.Mqtt.statusNotifications","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.560	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.shellyplus1#441793a44b70#1.Relay0.source, sourceObj={"type":"state","common":{"name":{"en":"Source of last command","de":"Quelle des letzten Befehls","ru":"Источник последней команды","pt":"Fonte do último comando","nl":"Vertaling:","fr":"Source de la dernière commande","it":"Fonte dell'ultimo comando","es":"Fuente del último comando","pl":"Źródło ostatniego dowództwa","zh-cn":"最后一次指挥的来源"},"type":"string","role":"text","read":true,"write":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1710516337058,"_id":"shelly.1.shellyplus1#441793a44b70#1.Relay0.source","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        web.0
                                           2024-03-17 16:35:51.559	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.shellyplus1#441793a44b70#1.Sys.sntp, sourceObj={"type":"state","common":{"name":{"en":"SNTP Server","de":"SNTP Server","ru":"SNTP сервер","pt":"Servidor SNTP","nl":"SNTP","fr":"SNTP Server","it":"Server SNTP","es":"SNTP Server","pl":"SNTP Server","uk":"Статус на сервери","zh-cn":"SNTP Server"},"type":"string","role":"text.url","read":true,"write":true},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1710516339856,"_id":"shelly.1.shellyplus1#441793a44b70#1.Sys.sntp","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                        Seit ein paar Tagen flattern die Meldungen sporadisch ins Log. Der Alias-Manager ist bei mir nicht installiert.
                                        Ich nutze den Energieflußadapter schon eine Weile, aber der Fehler tritt bei mir erst seit ein paar Tagen auf, allerdings in Verbindung mit dem Web-Adapter.
                                        Viele Grüße
                                        w00dy
