  4. Test Adapter Slideshow (ehemals Diashow) v0.1.x
    6.3k
adapterbildschirmschonerdiashowslideshow
101 Beiträge 26 Kommentatoren 21.0k Aufrufe 25 Beobachtet
  • DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    #79
    Kleiner Edit von mir in der main.js im Verzeichnis
    /opt/iobroker/node_modules/iobroker.slideshow/build
    var __create = Object.create;
    var __defProp = Object.defineProperty;
    var __defProps = Object.defineProperties;
    var __getOwnPropDesc = Object.getOwnPropertyDescriptor;
    var __getOwnPropDescs = Object.getOwnPropertyDescriptors;
    var __getOwnPropNames = Object.getOwnPropertyNames;
    var __getOwnPropSymbols = Object.getOwnPropertySymbols;
    var __getProtoOf = Object.getPrototypeOf;
    var __hasOwnProp = Object.prototype.hasOwnProperty;
    var __propIsEnum = Object.prototype.propertyIsEnumerable;
    var __defNormalProp = (obj, key, value) => key in obj ? __defProp(obj, key, { enumerable: true, configurable: true, writable: true, value }) : obj[key] = value;
    var __spreadValues = (a, b) => {
     for (var prop in b || (b = {}))
       if (__hasOwnProp.call(b, prop))
         __defNormalProp(a, prop, b[prop]);
     if (__getOwnPropSymbols)
       for (var prop of __getOwnPropSymbols(b)) {
         if (__propIsEnum.call(b, prop))
     return a;
    var __spreadProps = (a, b) => __defProps(a, __getOwnPropDescs(b));
    var __markAsModule = (target) => __defProp(target, "__esModule", { value: true });
    var __reExport = (target, module2, copyDefault, desc) => {
     if (module2 && typeof module2 === "object" || typeof module2 === "function") {
       for (let key of __getOwnPropNames(module2))
         if (!__hasOwnProp.call(target, key) && (copyDefault || key !== "default"))
           __defProp(target, key, { get: () => module2[key], enumerable: !(desc = __getOwnPropDesc(module2, key)) || desc.enumerable });
     return target;
    var __toESM = (module2, isNodeMode) => {
     return __reExport(__markAsModule(__defProp(module2 != null ? __create(__getProtoOf(module2)) : {}, "default", !isNodeMode && module2 && module2.__esModule ? { get: () => module2.default, enumerable: true } : { value: module2, enumerable: true })), module2);
    var utils = __toESM(require("@iobroker/adapter-core"));
    var import_global_helper = require("./modules/global-helper");
    var slideBing = __toESM(require("./modules/slideBing"));
    var slideLocal = __toESM(require("./modules/slideLocal"));
    var slideFS = __toESM(require("./modules/slideFS"));
    var slideSyno = __toESM(require("./modules/slideSynology"));
    let Helper;
    const MsgErrUnknown = "Unknown Error";
    let UpdateRunning = false;
    class Slideshow extends utils.Adapter {
     constructor(options = {}) {
       super(__spreadProps(__spreadValues({}, options), {
       this.tUpdatePictureStoreTimeout = null;
       this.tUpdateCurrentPictureTimeout = null;
       this.on("ready", this.onReady.bind(this));
       this.on("stateChange", this.onStateChange.bind(this));
       this.on("unload", this.onUnload.bind(this));
       this.isUnloaded = false;
     async onReady() {
       try {
         Helper = new import_global_helper.GlobalHelper(this);
         await this.setObjectNotExistsAsync("updatepicturelist", {
           type: "state",
           common: {
             type: "boolean",
             role: "button",
             read: true,
             write: true,
             desc: "Update picture list",
             def: false
           native: {}
         await this.setStateAsync("updatepicturelist", false, true);
         this.subscribeStates("updatepicturelist");
         await this.updatePictureStoreTimer();
       } catch (err) {
         Helper.ReportingError(err, MsgErrUnknown, "onReady");
     async onStateChange(id, state) {
       if (state) {
         if (id === `${this.namespace}.updatepicturelist` && (state == null ? void 0 : state.val) === true && (state == null ? void 0 : state.ack) === false) {
           if (UpdateRunning === true) {
             Helper.ReportingInfo("Info", "Adapter", "Update picture list already running");
           } else {
             Helper.ReportingInfo("Info", "Adapter", "Updating picture list");
             clearTimeout(this.tUpdateCurrentPictureTimeout);
           await this.setStateAsync("updatepicturelist", false, false);
     onUnload(callback) {
       try {
         this.isUnloaded = true;
         clearTimeout(this.tUpdatePictureStoreTimeout);
         callback();
       } catch (e) {
         callback();
     async updatePictureStoreTimer() {
       UpdateRunning = true;
       let updatePictureStoreResult = { success: false, picturecount: 0 };
       Helper.ReportingInfo("Debug", "Adapter", "UpdatePictureStoreTimer occured");
       try {
         this.tUpdatePictureStoreTimeout && clearTimeout(this.tUpdatePictureStoreTimeout);
       } catch (err) {
         Helper.ReportingError(err, MsgErrUnknown, "updatePictureStoreTimer", "Clear Timer");
       try {
         switch (this.config.provider) {
           case 1:
             updatePictureStoreResult = await slideBing.updatePictureList(Helper);
             break;
           case 2:
             updatePictureStoreResult = await slideLocal.updatePictureList(Helper);
             break;
           case 3:
             updatePictureStoreResult = await slideFS.updatePictureList(Helper);
             break;
           case 4:
             updatePictureStoreResult = await slideSyno.updatePictureList(Helper);
             break;
       } catch (err) {
         Helper.ReportingError(err, MsgErrUnknown, "updatePictureStoreTimer", "Call Timer Action");
       try {
         if (this.config.update_picture_list && this.config.update_picture_list > 0 && updatePictureStoreResult.success === true) {
           Helper.ReportingInfo("Debug", "updatePictureStoreTimer", `Update every ${this.config.update_picture_list} hours, starting timer`);
           this.tUpdatePictureStoreTimeout = setTimeout(() => {
           }, this.config.update_picture_list * 36e5);
         } else if (updatePictureStoreResult.success === false) {
           }, this.config.update_interval * 3e5);
         if (updatePictureStoreResult.success === true && updatePictureStoreResult.picturecount > 0 && this.isUnloaded === false) {
           await this.setObjectNotExistsAsync("picturecount", {
             type: "state",
             common: {
               type: "number",
               role: "value",
               read: true,
               write: false,
               desc: "Pictures found"
             native: {}
           await this.setStateAsync("picturecount", { val: updatePictureStoreResult.picturecount, ack: true });
           this.updateCurrentPictureTimer();
       } catch (err) {
         Helper.ReportingError(err, MsgErrUnknown, "updatePictureStoreTimer", "Set Timer");
     async updateCurrentPictureTimer() {
       var _a;
       let CurrentPictureResult = null;
       let Provider = "";
       Helper.ReportingInfo("Debug", "Adapter", "updateCurrentPictureTimer occured");
       try {
         this.tUpdateCurrentPictureTimeout && clearTimeout(this.tUpdateCurrentPictureTimeout);
       } catch (err) {
         Helper.ReportingError(err, MsgErrUnknown, "updateCurrentPictureTimer", "Clear Timer");
       try {
           case 1:
             CurrentPictureResult = await slideBing.getPicture(Helper);
             Provider = "Bing";
             break;
           case 2:
             CurrentPictureResult = await slideLocal.getPicture(Helper);
             Provider = "Local";
             break;
           case 3:
             CurrentPictureResult = await slideFS.getPicture(Helper);
             Provider = "FileSystem";
             break;
           case 4:
             CurrentPictureResult = await slideSyno.getPicture(Helper);
             Provider = "Synology";
             break;
       } catch (err) {
         Helper.ReportingError(err, MsgErrUnknown, "updateCurrentPictureTimer", "Call Timer Action");
       try {
         if (CurrentPictureResult !== null && this.isUnloaded === false) {
           Helper.ReportingInfo("Debug", Provider, `Set picture to ${CurrentPictureResult.path}`);
           await this.setObjectNotExistsAsync("picture", {
             type: "state",
             common: {
               type: "string",
               role: "text",
               read: true,
               write: false,
               desc: "Current picture"
             native: {}
           await this.setStateAsync("picture", { val: CurrentPictureResult.url, ack: true });
           await this.setObjectNotExistsAsync("path", {
             type: "state",
             common: {
               type: "string",
               role: "text",
               read: true,
               write: false,
               desc: "Path and Name"
             native: {}
           await this.setStateAsync("path", { val: CurrentPictureResult.path, ack: true });
           await this.setObjectNotExistsAsync("info1", {
             type: "state",
             common: {
               type: "string",
               role: "text",
               read: true,
               write: false,
               desc: "Info 1 for picture"
             native: {}
           await this.setStateAsync("info1", { val: CurrentPictureResult.info1, ack: true });
           await this.setObjectNotExistsAsync("info2", {
             type: "state",
             common: {
               type: "string",
               role: "text",
               read: true,
               write: false,
               desc: "Info 2 for picture"
             native: {}
           await this.setStateAsync("info2", { val: CurrentPictureResult.info2, ack: true });
           await this.setObjectNotExistsAsync("info3", {
             type: "state",
             common: {
               type: "string",
               role: "text",
               read: true,
               write: false,
               desc: "Info 3 for picture"
             native: {}
           await this.setStateAsync("info3", { val: CurrentPictureResult.info3, ack: true });
           await this.setObjectNotExistsAsync("date", {
             type: "state",
             common: {
               type: "number",
               role: "date",
               read: true,
               write: false,
               desc: "Date of picture"
             native: {}
           await this.setStateAsync("date", { val: ((_a = CurrentPictureResult.date) == null ? void 0 : _a.getTime()) || null, ack: true });
       } catch (err) {
       try {
         this.tUpdateCurrentPictureTimeout = setTimeout(() => {
         }, this.config.update_interval * 1e3);
       } catch (err) {
         Helper.ReportingError(err, MsgErrUnknown, "updateCurrentPictureTimer", "Set Timer");
    if (module.parent) {
     module.exports = (options) => new Slideshow(options);
    } else {
     (() => new Slideshow())();
    //# sourceMappingURL=main.js.map
    Zeile 211 bis 223 von mir hinzugefügt.
    Dadurch wird ein neuer DP "path" erzeugt (Neustart des Adapters) in welchen bei jedem Bilderwechsel der aktuelle Pfad inkl. Dateiname geschrieben wird.
    Benutzung auf eigenes Risiko natürlich aber falls das jemand testen mag dann gerne.
    p.s. bei Update vom Adapter wird die main.js natürlich wieder mit der originalen überschrieben.
    Lehrling seit 1975 !!!
    • DJMarc75D DJMarc75
       return a;
       return target;
      let Helper;
       async onReady() {
         try {
             type: "state",
             common: {
               type: "boolean",
               role: "button",
               read: true,
               write: true,
               def: false
             native: {}
         } catch (err) {
         if (state) {
             } else {
         try {
           callback();
         } catch (e) {
           callback();
         try {
         } catch (err) {
         try {
             case 1:
               break;
             case 2:
               break;
             case 3:
               break;
             case 4:
               break;
         } catch (err) {
         try {
               type: "state",
               common: {
                 type: "number",
                 role: "value",
                 read: true,
                 write: false,
               native: {}
         } catch (err) {
         var _a;
         let Provider = "";
         try {
         } catch (err) {
         try {
             case 1:
               Provider = "Bing";
               break;
             case 2:
               Provider = "Local";
               break;
             case 3:
               break;
             case 4:
               break;
         } catch (err) {
         try {
               type: "state",
               common: {
                 type: "string",
                 role: "text",
                 read: true,
                 write: false,
               native: {}
               type: "state",
               common: {
                 type: "string",
                 role: "text",
                 read: true,
                 write: false,
               native: {}
               type: "state",
               common: {
                 type: "string",
                 role: "text",
                 read: true,
                 write: false,
               native: {}
               type: "state",
               common: {
                 type: "string",
                 role: "text",
                 read: true,
                 write: false,
               native: {}
               type: "state",
               common: {
                 type: "string",
                 role: "text",
                 read: true,
                 write: false,
               native: {}
               type: "state",
               common: {
                 type: "number",
                 role: "date",
                 read: true,
                 write: false,
               native: {}
         } catch (err) {
         try {
         } catch (err) {
      } else {
      #80
      @djmarc75
      super, gute Idee, danke dir! Zu beachten, wer in der Shell an den Dateien rumfummelt, sollte mit den richtigen Rechten arbeiten, also entweder als user iobroker oder anschliessend mit chown die Rechte wieder auf iobroker:iobroker setzen, sonst schiesst ihr euch unter Umstaenden was..
      Ich habs so gemacht, geht bestimmt auch anders, wenn man sudo -u iobroker macht :)
      ilovegym@iobrokerS:/opt/iobroker/node_modules/iobroker.slideshow/build$ sudo cp main.js main.js-old
      ilovegym@iobrokerS:/opt/iobroker/node_modules/iobroker.slideshow/build$ ls
      lib  main.js  main.js-old  modules
      ilovegym@iobrokerS:/opt/iobroker/node_modules/iobroker.slideshow/build$ sudo rm main.js
      ilovegym@iobrokerS:/opt/iobroker/node_modules/iobroker.slideshow/build$ sudo nano main.js
      ilovegym@iobrokerS:/opt/iobroker/node_modules/iobroker.slideshow/build$ ls -la
      total 40
      drwxrwxr-x+ 4 iobroker iobroker  4096 Dec 15 07:20 .
      drwxrwxr-x+ 7 iobroker iobroker  4096 Dec 10 13:10 ..
      drwxrwxr-x+ 2 iobroker iobroker  4096 Dec 10 13:10 lib
      -rw-rw-r--+ 1 root     root     10815 Dec 15 07:20 main.js
      -rw-rw-r--+ 1 root     root     10676 Dec 15 07:20 main.js-old
      drwxrwxr-x+ 2 iobroker iobroker  4096 Dec 10 13:10 modules
      ilovegym@iobrokerS:/opt/iobroker/node_modules/iobroker.slideshow/build$ sudo chown iobroker:iobroker main.js
      total 40
      -rw-rw-r--+ 1 iobroker iobroker 10815 Dec 15 07:20 main.js
      • Attila PergeA Offline
        Attila Perge
        #81
        Hallo Ralf,
        super Adapter, Danke!
        Habe die Tage installiert und getestet.
        Auf mein Laptop funktioniert es auch.
        Auf ein Android Tablet unter Firefox und Chrom funktioniert es auch.
        Habe jetzt noch auf einen älteren IPad getestet, dort scheint es aber nicht zu funktionieren.
        Sollte später aber darüber laufen.
        Hast du eine Idee, was ich unter IOS anders machen muss, damit es dort auch funktioniert?
        Ich habe es auch in der ioBroker App versucht, dort scheint es leider auch nicht zu funktionieren.
        Hat es jemand unter IOS zum laufen bekommen?
        VG Attila
        • W Offline
          W Offline
          Wiesel 0
          #82
          (Hoffe hier richtig zu sein, da dies mein erster Beitrag in diesem Forum ist.)
          zunächst mal: super Adapter, der hat mir wirklich noch gefehlt!
          ich habe die Slideshow seit kurzem auf einem Android Outkitel RT1 und auf einem kleinen NUC über Windows in VIS 1.4.16. am laufen.
          Ich habe leider das Problem, dass sowohl beim Tablet als auch im Windows-Browser nach einigen Stunden der Speicher voll läuft und die View abstürzt.
          Ich habe es dann auf dem Tablet mit der App IOBroker Visu probiert, was leider auch keine Besserung brachte.
          Im Browser steht nur Fehlercode: Out of Memory und die Visu App friert einfach ein.
          Ich habe leider im Forum zu dem Problem nichts gefunden.
          Hat jemand eine Idee, wie ich das Problem in den Griff bekomme?
          Vielen Dank schonmal für eure Hilfe.!
          Ro75R DJMarc75D 2 Antworten Letzte Antwort
          • W Wiesel 0
            Ro75R Offline
            Ro75R Offline
            Ro75
            #83
            @wiesel-0 Aller 20 Sekunden werden neue Bilder geladen und ggfs. im Speicher (Cache) gehalten. Irgendwann läuft der halt voll.
            • W Wiesel 0
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              #84
              @wiesel-0 sagte in Test Adapter Slideshow (ehemals Diashow) v0.1.x:
              Ja, das ist bei mir auch so und eigentlich auch "normal". Erklärung dazu: Je mehr verschiedene Bilder (Summe in MB aller Bilder) Du in deinem Verzeichnis hast, desto mehr wird im jeweiligen Browser in den Cache geschrieben und irgendwann ist der dann übervoll und zwingt den Browser in die Knie.
              Teste es mal mit den BING Bildern und Du wirst sehen dass der Browser nicht abstürzt.
              Eine Lösung diesbezüglich seitens des Adapters oder ioBroker kann und wird es daher nicht geben. :)
              EDIT:
              Ich nutze den Fullybrowser auf einem FireTV Stick - falls der Fully dann mal abschmieren sollte, startet dieser eben automatisch wieder neu :)
              • W Offline
                W Offline
                Wiesel 0
                #85
                Hallo DJMarc75,
                danke für die schnelle Hilfe!
                Tatsächlich kannte ich den Fully Browser noch nicht!
                Der hat es voll gebracht und hat genau die Einstellungen (Auto-Relaoad, Delete Cache on Auto-Reload und Delete Webstorage), die ich gesucht habe!
                Vielen Dank für diesen Tip!
                • J Online
                  J Online
                  jensven
                  #86
                  habe mir die slideshow jetzt auch mal installiert und funktionier soweit auch ganz gut
                  Verstehe ich das so richtig:
                  Ich erstelle eine View in der ich dann das Widget über den ganzen Bildschirm lege. Dann muss ich ein Script erstelle mit dem ich dann nach einer vorgegeben inaktiviät in das View von der slideshow wechsle?
                  • J jensven
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    #87
                    @jensven sagte in Test Adapter Slideshow (ehemals Diashow) v0.1.x:
                    super 👍
                    Das kommt ja darauf an was Du wie genau umsetzen willst, aber das sollte nicht in diesem Beitrag behandelt werden da dies nichts mit dem Adapter zu tun hat sondern eine allgemeine Frage zum Thema "Visualisierung" ist. :)
                      super 👍
                      J Online
                      J Online
                      jensven
                      #88
                      @djmarc75
                      da gebe ich dir insofern recht dass das mit der Thematik VIS zu tun hat.
                      Aber die grundsätzliche Aufgabe dieses Adapters ist es ja eine Diashow für die VIS zu sein anstatt das abschalten des Bildschirms o. ä.
                      Deswegen die Frage ob ich das so wie ich es beschrieben habe richtig verstanden habe oder ob es einen anderen Weg dafür gibt.
                      • J jensven
                        @djmarc75
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        #89
                        Ja genau und dieser Adapter und das zugehörige Widget macht auch absolut nichts anderes.
                        Es gibt da keinerlei Funktionen wie das Display zu schalten oder Sonstiges.
                        Dazu sind andere Adapter, Skripte, Browser, usw anzuwenden.
                          TripleX
                          #90
                          @AggroRalf
                          Habe gerade deinen Adapter installiert.
                          Ordner und Bilder habe ich über den Dateimanager angelegt und das Widget auf eine extra Seite gepackt.
                          Nur startet die Diashow bei mir nicht.
                          Laut Protokoll ist alles ok.
                          Habe das Timeout auf 1 gesetzt.
                          Gehe mal davon aus, dass damit Minuten gemeint sind.
                          Kann es evtl. daran liegen, dass ich auf jeder Seite ein animiertes gif laufen habe oder wird sowas ignoriert?
                          Wäre es evtl. auch möglich den Adapter auf einer geteilten View (links Diashow / rechts z.B. Kalender) zu nutzen?
                          • T TripleX
                            @AggroRalf
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            #91
                            @triplex zeig mal bitte einen Screenshot von Deinen Einstellungen.
                              TripleX
                              #92
                              @djmarc75 said in Test Adapter Slideshow (ehemals Diashow) v0.1.x:
                              • T TripleX
                                J Online
                                J Online
                                jensven
                                #93
                                @triplex
                                die Bilder hast du auch so hochgeladen wie es dort steht ?
                                Bilder aus dem lokalen Ordner iobroker/iobroker-data/files/vis.0/slideshow
                                Bitte mit VIS-Dateimanager Ordner erstellen und Bilder hochladen
                                Hast du mal den Button "updatepicturelist" während der adapter läuft gedrückt ? Vllt. wird dadurch das Problem gelöst.
                                Ansonsten würde ich mal nur normale Bilder ausprobieren. Dann merkst du sofort ob es an den animierten GIF liegt
                                • J jensven
                                  @triplex
                                  TripleX
                                  #94
                                  @jensven said in Test Adapter Slideshow (ehemals Diashow) v0.1.x:
                                  @triplex
                                  Bilder habe ich wie beschrieben hochgeladen.
                                  Im Datenpunkt picturecount werden auch die Anzahl der Fotos angezeigt.
                                  Das mit dem GIF hast du falsch verstanden.
                                  Ich habe keine GIFs in der Diashow sondern auf den einzelnen Seiten.
                                  Könnte es evtl. daran liegen, dass die Diashow nicht startet, da sich immer was auf der View bewegt?
                                  T J 2 Antworten Letzte Antwort
                                  • T TripleX
                                    @triplex
                                    TripleX
                                    #95
                                    Hallo zusammen!
                                    Noch jemand ne Idee warum die Diashow nicht startet?
                                    manuxiM 1 Antwort Letzte Antwort
                                    • T TripleX
                                      Hallo zusammen!
                                      manuxiM Offline
                                      manuxiM Offline
                                      manuxi
                                      #96
                                      Ich wollte eigentlich letztens schon hier reingeschrieben haben, aber irgendwie ist das untergegangen.
                                      Ich bekomme leider Synology Photos nicht eingebunden. Wir sharen hier ziemlich viele Alben, daher wäre das klasse, das hinzubekommen.
                                      Ich habe einen User mit Upload-Rechten ausgestattet und versucht, die Slideshow damit zum Laufen zu bekommen. Leider ohne Erfolg.
                                      Mit dem User kann ich mich über den Browser anmelden und in SynoPhotos das eine freigegebene Album anschauen. Das klappt also generell.
                                      Im Slideshow-Log steht aber leider:
                                      slideshow.0
                                      2024-02-15 01:19:09.203	error	Error occured: No pictures found in Synology(updatePictureList)
                                      slideshow.0
                                      2024-02-15 01:19:09.202	error	Error occured: Error getting folders from Synology in Synology(synoGetFolders)
                                      Dazu habe ich in der Doku nichts finden können. Hat jemand einen Tipp für mich?
                                      • T TripleX
                                        @triplex
                                        J Online
                                        J Online
                                        jensven
                                        #97
                                        @triplex
                                        Daran kann es nicht liegen, ich habe auch GIFs bei mir am laufen und es funktioniert.
                                        Dumme Frage aber kann die Lösung sein:
                                        Du weisst das du dir nen blockly bzw. nen script schreiben musst mit dem du auf die slideshow view wechselst?
                                        Das macht der Adapter ja nicht selbst.
                                        T 2 Antworten Letzte Antwort
                                        • J jensven
                                          @triplex
                                          TripleX
                                          #98
                                          @triplex
                                          Das mit dem blockly wusste ich nicht...stand das irgendwo?
                                          Wenn ja, dann habe ich das wohl überlesen.
                                          Wäre es denn auch möglich die Diashow nur auf einer Hälfte der View laufen zu lassen und auf der anderen Hälfte was anderes?
                                          Könntest mir das Blockly mal zur Verfügung stellen?
