  4. [Adapter] Sonoff- Tasmota
    6.8k
720 Beiträge 75 Kommentatoren 337.9k Aufrufe 8 Beobachtet
    knopers1
    Hi, will ich mal testen. Habe den ganzen Arschvoll von den Dingern mit Tasmota hier im Haus.
    Beim installieren bekomme ich ein paar Fehler:
    root@orangepiplus2e:~# cd /opt/iobroker
    root@orangepiplus2e:/opt/iobroker# npm i https://github.com/ioBroker/ioBroker.sonoff/tarball/master --production
    iobroker@1.0.0 /opt/iobroker
    └─┬ iobroker.sonoff@1.3.2
      └─┬ mqtt@2.13.0
        ├─┬ readable-stream@2.3.3
        │ ├── safe-buffer@5.1.1
        │ └── string_decoder@1.0.3
        └─┬ websocket-stream@5.0.1
          └─┬ ws@3.2.0
            └── async-limiter@1.0.0
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/greenlock/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/jszip/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/mdns/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/stk500/package.json'
    root@orangepiplus2e:/opt/iobroker# iobroker a sonoff
    host.orangepiplus2e install adapter sonoff
    got /opt/iobroker/node_modules/iobroker.sonoff/admin
    upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
    upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
    host.orangepiplus2e object system.adapter.sonoff created
    host.orangepiplus2e create instance sonoff
    host.orangepiplus2e object sonoff.0.info created
    host.orangepiplus2e object system.adapter.sonoff.0.outputCount created
    host.orangepiplus2e object system.adapter.sonoff.0.inputCount created
    host.orangepiplus2e object system.adapter.sonoff.0.uptime created
    host.orangepiplus2e object system.adapter.sonoff.0.memRss created
    host.orangepiplus2e object system.adapter.sonoff.0.memHeapTotal created
    host.orangepiplus2e object system.adapter.sonoff.0.memHeapUsed created
    host.orangepiplus2e object system.adapter.sonoff.0.connected created
    host.orangepiplus2e object system.adapter.sonoff.0.alive created
    host.orangepiplus2e object system.adapter.sonoff.0 created
    • kmxakK Offline
      kmxakK Offline
      kmxak
      der adapter scheint aber dennoch installiert worden zu sein oder?
      Gruß Alex
        knopers1
        ja, es ist was neues da!
        die Frage ist, wie binde ich den Sonoff jetzt ein?
          @knopers1:
          Beim installieren bekomme ich ein paar Fehler: `
          Ich sehe keine Fehler!
          dort sind höchstens ein paar WARNungen
          also alles im grünen Bereich.
          • kmxakK Offline
            kmxakK Offline
            kmxak
            Deine IP und Port sowie User und PW eintragen und auf geht es. Client ID ist der Name vom Sonoff. So wird er im ioBroker angezeigt.
            Änder aber bitte den Port da der Port vom MQTT Adapter schon genutzt wird.
            Alles speichern fertig.
            Gruß Alex
              stephan61
              Hallo Knoppers die warnmeldungen hatte ich beim update vom Host auch
              habe mit
              sudo npm install greenlock –production
              sudo npm install jszip --production
              und so weiter
              die fehlenden Dateien installiert keine Ahnung was da passiert war
              Gruß Stephan
                knopers1
                ok,
                es geht jetzt! Schalten geht auch. Super!
                Jetzt möchte ich einen zweiten Tasmota einbinden. Kann ich den gleichen Port sowie Benutzername und Passwort nehmen?
                Muß ich eine neue Instanz des Adapters installieren?
                • kmxakK Offline
                  kmxakK Offline
                  kmxak
                  Auf jedem Sonoff die gleichen Daten eingeben. Ein Adapter. Aber immer eine andere Client ID vergeben.
                  Gruß Alex
                  • chucky666C Online
                    chucky666C Online
                    chucky666
                    Hallo
                    Der sonoff Th10 wird noch nicht unterstützt?
                    • kmxakK Offline
                      kmxakK Offline
                      kmxak
                      Ich denke Bluefox hat die Geräte nicht alle selber daher bat er uns Debugs zu schicken.
                      Aktivier mal bitte Debug bei dem Adapter und schau mal ob der Sonoff Daten sendet. Schick das ganze mal Bluefox oder füg es hier an dann kann er das im Adapter aufnehmen.
                      Gruß Alex
                      • chucky666C Online
                        chucky666C Online
                        chucky666
                        Weiß nicht ob das richtig ist
                        mqtt.0	2017-10-03 14:49:50.648	info	publishOnSubscribe send all known states
                        mqtt.0	2017-10-03 14:49:50.648	info	Client [DVES_0736F2] subscribes on "cmnd.DVES_0736F2.#" with regex /^mqtt\.0\.cmnd\.DVES_0736F2\..*/
                        mqtt.0	2017-10-03 14:49:50.647	info	Client [DVES_0736F2] subscribes on "cmnd.DVES_0736F2.#" with regex /^cmnd\.DVES_0736F2\..*/
                        mqtt.0	2017-10-03 14:49:50.407	info	publishOnSubscribe send all known states
                        mqtt.0	2017-10-03 14:49:50.407	info	Client [DVES_0736F2] subscribes on "cmnd.sonoffs.#" with regex /^mqtt\.0\.cmnd\.sonoffs\..*/
                        mqtt.0	2017-10-03 14:49:50.406	info	Client [DVES_0736F2] subscribes on "cmnd.sonoffs.#" with regex /^cmnd\.sonoffs\..*/
                        mqtt.0	2017-10-03 14:49:50.274	info	publishOnSubscribe send all known states
                        mqtt.0	2017-10-03 14:49:50.274	info	Client [DVES_0736F2] subscribes on "cmnd.sonoff5.#" with regex /^mqtt\.0\.cmnd\.sonoff5\..*/
                        mqtt.0	2017-10-03 14:49:50.273	info	Client [DVES_0736F2] subscribes on "cmnd.sonoff5.#" with regex /^cmnd\.sonoff5\..*/
                        Gesendet von iPad mit Tapatalk Pro
                        geändert: Code in Code-Tags; Homoran (Mod)
                        • kmxakK Offline
                          kmxakK Offline
                          kmxak
                          du hast den mqtt adapter geloggt xD
                          Hast du unter Instanzen den Adapter auf Debug gesetzt? (Expertenansicht aktivieren)
                          Nimm lieber den Sonoff und benutze die```
                          <code>[code]hier den code einfügen[/code]</code>
                          Gruß Alex
                          • chucky666C Online
                            chucky666C Online
                            chucky666
                            sonoff.0 2017-10-03 15:03:08.830 debug Client [DVES_0736F2] pingreq
                            sonoff.0 2017-10-03 15:03:08.340 debug Client [DVES_42009A] pingreq
                            sonoff.0 2017-10-03 15:03:05.018 debug Client [DVES_41ECEC] pingreq
                            sonoff.0 2017-10-03 15:02:53.830 debug Client [DVES_0736F2] pingreq
                            sonoff.0 2017-10-03 15:02:53.340 debug Client [DVES_42009A] pingreq
                            sonoff.0 2017-10-03 15:02:50.017 debug Client [DVES_41ECEC] pingreq
                            sonoff.0 2017-10-03 15:02:38.829 debug Client [DVES_0736F2] pingreq
                            sonoff.0 2017-10-03 15:02:38.340 debug Client [DVES_42009A] pingreq
                            sonoff.0 2017-10-03 15:02:34.968 debug [DVES_41ECEC] Received: cmnd/sonoff2/POWER =
                            sonoff.0 2017-10-03 15:02:34.940 debug stateChange sonoff.0.DVES_41ECEC.alive: {"val":true,"ack":true,"ts":1507035754933,"q":0,"from":"system.adapter.sonoff.0","lc":1507035754933}
                            sonoff.0 2017-10-03 15:02:34.938 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_41ECEC.alive {"val":true,"ack":true,"ts":1507035754933,"q":0,"from":"system.adapter.sonoff.0","lc":1507035754933}
                            sonoff.0 2017-10-03 15:02:34.929 debug stateChange sonoff.0.info.connection: {"val":"DVES_42009A,DVES_0736F2,DVES_41ECEC","ack":true,"ts":1507035754925,"q":0,"from":"system.adapter.sonoff.0","lc":1507035754925}
                            sonoff.0 2017-10-03 15:02:34.928 debug redis pmessage io.sonoff.0.* io.sonoff.0.info.connection {"val":"DVES_42009A,DVES_0736F2,DVES_41ECEC","ack":true,"ts":1507035754925,"q":0,"from":"system.adapter.sonoff.0","lc":1507035754925}
                            sonoff.0 2017-10-03 15:02:34.924 info Client [DVES_41ECEC] connected
                            sonoff.0 2017-10-03 15:02:25.972 debug [DVES_0736F2] Received: tele/sonoff5/SENSOR = {"Time":"2017-10-03T14:02:25", "AM2301-14":{"Temperature":21.6, "Humidity":54.7}, "TempUnit":"C"}
                            sonoff.0 2017-10-03 15:02:25.910 debug stateChange sonoff.0.DVES_0736F2.POWER: {"val":false,"ack":true,"ts":1507035745898,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745898}
                            sonoff.0 2017-10-03 15:02:25.907 debug stateChange sonoff.0.DVES_0736F2.RSSI: {"val":84,"ack":true,"ts":1507035745897,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745897}
                            sonoff.0 2017-10-03 15:02:25.906 debug stateChange sonoff.0.DVES_0736F2.Vcc: {"val":3.177,"ack":true,"ts":1507035745896,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745896}
                            sonoff.0 2017-10-03 15:02:25.906 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.POWER {"val":false,"ack":true,"ts":1507035745898,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745898}
                            sonoff.0 2017-10-03 15:02:25.905 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.RSSI {"val":84,"ack":true,"ts":1507035745897,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745897}
                            sonoff.0 2017-10-03 15:02:25.904 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.Vcc {"val":3.177,"ack":true,"ts":1507035745896,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745896}
                            sonoff.0 2017-10-03 15:02:25.886 debug [DVES_0736F2] Received: tele/sonoff5/STATE = {"Time":"2017-10-03T14:02:25", "Uptime":16, "Vcc":3.177, "POWER":"OFF", "Wifi":{"AP":1, "SSId":"Chucky", "RSSI":84, "APMac":"CC:CE:1E:A3:6C:D3"}}
                            sonoff.0 2017-10-03 15:02:23.693 debug [DVES_0736F2] Received: cmnd/sonoff5/POWER =
                            sonoff.0 2017-10-03 15:02:23.666 debug stateChange sonoff.0.DVES_0736F2.alive: {"val":true,"ack":true,"ts":1507035743661,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743661}
                            sonoff.0 2017-10-03 15:02:23.663 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.alive {"val":true,"ack":true,"ts":1507035743661,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743661}
                            sonoff.0 2017-10-03 15:02:23.659 debug stateChange sonoff.0.info.connection: {"val":"DVES_42009A,DVES_0736F2","ack":true,"ts":1507035743648,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743648}
                            sonoff.0 2017-10-03 15:02:23.655 debug redis pmessage io.sonoff.0.* io.sonoff.0.info.connection {"val":"DVES_42009A,DVES_0736F2","ack":true,"ts":1507035743648,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743648}
                            sonoff.0 2017-10-03 15:02:23.645 info Client [DVES_0736F2] connected
                            sonoff.0 2017-10-03 15:02:23.348 debug stateChange sonoff.0.DVES_42009A.alive: {"val":true,"ack":true,"ts":1507035743342,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743342}
                            sonoff.0 2017-10-03 15:02:23.347 debug stateChange sonoff.0.DVES_42009A.alive: {"val":true,"ack":true,"ts":1507035743341,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743341}
                            sonoff.0 2017-10-03 15:02:23.347 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_42009A.alive {"val":true,"ack":true,"ts":1507035743342,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743342}
                            sonoff.0 2017-10-03 15:02:23.346 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_42009A.alive {"val":true,"ack":true,"ts":1507035743341,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743341}
                            sonoff.0 2017-10-03 15:02:23.328 debug [DVES_42009A] Received: cmnd/sonoff3/POWER =
                            sonoff.0 2017-10-03 15:02:23.258 debug stateChange sonoff.0.info.connection: {"val":"DVES_42009A","ack":true,"ts":1507035743241,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743241}
                            sonoff.0 2017-10-03 15:02:23.254 debug redis pmessage io.sonoff.0.* io.sonoff.0.info.connection {"val":"DVES_42009A","ack":true,"ts":1507035743241,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743241}
                            sonoff.0 2017-10-03 15:02:23.239 debug stateChange sonoff.0.DVES_41ECEC.alive: {"val":false,"ack":true,"ts":1507035743194,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409102}
                            sonoff.0 2017-10-03 15:02:23.239 debug stateChange sonoff.0.DVES_42009A.alive: {"val":false,"ack":true,"ts":1507035743193,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409099}
                            sonoff.0 2017-10-03 15:02:23.238 debug stateChange sonoff.0.DVES_0736F2.alive: {"val":false,"ack":true,"ts":1507035743193,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409098}
                            sonoff.0 2017-10-03 15:02:23.237 debug stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1507035743192,"q":0,"from":"system.adapter.sonoff.0","lc":1506975964976}
                            sonoff.0 2017-10-03 15:02:23.222 info Client [DVES_42009A] connected
                            sonoff.0 2017-10-03 15:02:23.206 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_41ECEC.alive {"val":false,"ack":true,"ts":1507035743194,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409102}
                            sonoff.0 2017-10-03 15:02:23.204 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_42009A.alive {"val":false,"ack":true,"ts":1507035743193,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409099}
                            sonoff.0 2017-10-03 15:02:23.203 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.alive {"val":false,"ack":true,"ts":1507035743193,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409098}
                            sonoff.0 2017-10-03 15:02:23.197 debug redis pmessage io.sonoff.0.* io.sonoff.0.info.connection {"val":"","ack":true,"ts":1507035743192,"q":0,"from":"system.adapter.sonoff.0","lc":1506975964976}
                            sonoff.0 2017-10-03 15:02:23.121 info Starting MQTT authenticated server on port 1883
                            ****geändert: Code in Code-Tags und spoiler; Homoran (Mod)****
                              knopers1
                              habe vorerst 4 Stück an den Sonoff Adapter gekoppelt. Bis jetzt nichts negatives zu berichten.
                              Die hue Instanzen wurden gelöscht, dadurch um die 100MB RAM frei geworden. Geil, darauf habe ich gewartet.
                              • N Offline
                                N Offline
                                noxx
                                läuft, trotz fehler beim installieren
                                https://pastebin.com/raw/5AyQYApp
                                Aber, wieso bekomme ich die Temperatur nicht angezeigt im iobroker?
                                Tasmota-console:
                                17:40:55 MQTT: cmnd/sonoff/POWER =
                                17:40:56 UPnP: Multicast (re)joined
                                17:41:33 MQTT: stat/sonoff/RESULT = {"POWER1":"ON"}
                                17:41:33 MQTT: stat/sonoff/POWER1 = ON
                                17:41:34 MQTT: stat/sonoff/RESULT = {"POWER2":"ON"}
                                17:41:34 MQTT: stat/sonoff/POWER2 = ON
                                17:41:35 MQTT: stat/sonoff/RESULT = {"POWER3":"ON"}
                                17:41:35 MQTT: stat/sonoff/POWER3 = ON
                                17:41:40 MQTT: stat/sonoff/RESULT = {"POWER4":"ON"}
                                17:41:40 MQTT: stat/sonoff/POWER4 = ON
                                17:41:43 MQTT: stat/sonoff/RESULT = {"POWER2":"OFF"}
                                17:41:43 MQTT: stat/sonoff/POWER2 = OFF
                                17:41:44 MQTT: stat/sonoff/RESULT = {"POWER3":"OFF"}
                                17:41:44 MQTT: stat/sonoff/POWER3 = OFF
                                17:41:45 MQTT: stat/sonoff/RESULT = {"POWER4":"OFF"}
                                17:41:45 MQTT: stat/sonoff/POWER4 = OFF
                                17:41:46 MQTT: stat/sonoff/RESULT = {"POWER1":"OFF"}
                                17:41:46 MQTT: stat/sonoff/POWER1 = OFF
                                17:43:19 MQTT: tele/sonoff/STATE = {"Time":"2017-10-05T17:43:19", "Uptime":21, "Vcc":3.249, "POWER1":"OFF", "POWER2":"OFF", "POWER3":"OFF", "POWER4":"OFF", "Wifi":{"AP":2, "SSID":"myhome2_AP", "RSSI":52, "APMac":"F8:1A:67:3D:F2:81"}}
                                17:43:19 MQTT: tele/sonoff/SENSOR = {"Time":"2017-10-05T17:43:19", "DS18x20":{"DS1":{"Type":"DS18B20", "Address":"28FF9ABC7115022A", "Temperature":12.2}}, "TempUnit":"C"}
                                [2880_01.png](/assets/uploads/files/2880_01.png)
                                [2880_02.png](/assets/uploads/files/2880_02.png)
                                • kmxakK Offline
                                  kmxakK Offline
                                  kmxak
                                  Die Daten werden schon mal gesendet. Es wird nicht angezeigt weil es aktuell noch nicht eingefügt ist.
                                  Bluefox schreibt in seinem letzten Satz: > Ich habe nur DH28xx angebunden. Für weitere Sensoren brauche ich debug outputs. Am besten per PR :) Mit PR meint er wohl PN
                                  Gruß Alex
                                  • BluefoxB Offline
                                    BluefoxB Offline
                                    Es gibt updates. 0.2.0
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      @kmxak:
                                      Bluefox schreibt in seinem letzten Satz: > Ich habe nur DH28xx angebunden. Für weitere Sensoren brauche ich debug outputs. Am besten per PR :) Mit PR meint er wohl PN `
                                      Mit PR meine ich Pull Request auf dem Github :)
                                      • chucky666C Online
                                        chucky666C Online
                                        chucky666
                                        Danke für den Adapter
                                        Wäre schön wenn du den Sonoff Th10 mit Temperatur Sensor einbinden könntest.
                                        sonoff.0	2017-10-05 21:10:39.820	debug	stateChange sonoff.0.info.connection: {"val":"DVES_0736F2","ack":true,"ts":1507230639811,"q":0,"from":"system.adapter.sonoff.0","lc":1507230639811}
                                        sonoff.0	2017-10-05 21:10:39.818	debug	redis pmessage io.sonoff.0.* io.sonoff.0.info.connection {"val":"DVES_0736F2","ack":true,"ts":1507230639811,"q":0,"from":"system.adapter.sonoff.0","lc":1507230639811}
                                        sonoff.0	2017-10-05 21:10:39.599	info	Client [DVES_0736F2] connected
                                        • kmxakK Offline
                                          kmxakK Offline
                                          kmxak
                                          @Bluefox:
                                          Mit PR meine ich Pull Request auf dem Github :) `
                                          Ok beim nächsten mal. Muss erstmal herausbekommen wie das geht :lol:
                                          Rückmeldung zum POW Sonoff: Energy läuft. Danke TOP
                                          Gruß Alex
