  4. Täglicher Absturz ioBroker + Zugriff auf Raspi [gelöst]
    5.4k
340 Beiträge 5 Kommentatoren 82.1k Aufrufe 4 Beobachtet
  • GlasfaserG Glasfaser
    @searcher57
    Bitte über die Konsole
    iobroker upgrade iobroker.vis@1.4.0
    searcher57
    @glasfaser
    pi@raspberrypi:~ $ iobroker upgrade iobroker.vis@1.4.0
    Cannot upgrade: /opt/iobroker/node_modules/iobroker.vis/io-package.json: Unexpected end of JSON input
    • S searcher57
      GlasfaserG Offline
      GlasfaserG Offline
      @searcher57
      iobroker install iobroker.vis@1.4.0
      • S searcher57
        @glasfaser said in Täglicher Absturz ioBroker + Zugriff auf Raspi:
        iob diag
        Hier die Full Ausgabe, die jetzt auch funktioniert!
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Architecture    : aarch64
        Docker          : false
        Virtualization  : none
        Distributor ID: Debian
        Description:    Debian GNU/Linux 11 (bullseye)
        Release:        11
        Codename:       bullseye
        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
        NAME="Debian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        Systemuptime and Load:
         18:36:54 up  1:24,  1 user,  load average: 0.18, 0.19, 0.17
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=47.2'C
        volt=0.9360V
        *** Time and Time Zones ***
                       Local time: Mon 2023-05-15 18:36:54 CEST
                   Universal time: Mon 2023-05-15 16:36:54 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp        io i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            1.8G        1.4G        162M        1.0M        307M        405M
        Swap:            99M          0B         99M
        Total:          1.9G        1.4G        262M
                 1849 M total memory
                 1380 M used memory
                 1424 M active memory
                  155 M inactive memory
                  161 M free memory
                   38 M buffer memory
                  268 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4       29G  3.7G   25G  14% /
        devtmpfs       devtmpfs  667M     0  667M   0% /dev
        tmpfs          tmpfs     925M     0  925M   0% /dev/shm
        tmpfs          tmpfs     370M  1.1M  369M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        /dev/sda1      exfat      29G  2.1G   27G   7% /mnt/usb0
        tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
        [Mon May 15 17:12:09 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:15:C8:D1 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=ae9ac4e2-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Mon May 15 17:12:10 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on reado        nly filesystem
        [Mon May 15 17:12:10 2023] EXT4-fs (mmcblk0p2): write access will be enabled dur        ing recovery
        [Mon May 15 17:12:11 2023] EXT4-fs (mmcblk0p2): recovery complete
        [Mon May 15 17:12:11 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
        [Mon May 15 17:12:11 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
        [Mon May 15 17:12:13 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET      SOURCE         FSTYPE OPTIONS
        /           /dev/mmcblk0p2 ext4   rw,noatime
        |-/boot     /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437        ,iocharset=ascii,shortname=mixed,errors=remount-ro
        `-/mnt/usb0 /dev/sda1      exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dma        sk=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
        /var:
        540M    /var/
        180M    /var/cache
        175M    /var/cache/apt
        155M    /var/lib
        130M    /var/lib/apt/lists
        Archived and active journals take up 104.0M in the file system.
        /opt/iobroker/backups:
        11M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        321M    /opt/iobroker/iobroker-data/
        276M    /opt/iobroker/iobroker-data/files
        61M     /opt/iobroker/iobroker-data/files/vis-2-beta
        51M     /opt/iobroker/iobroker-data/files/javascript.admin
        48M     /opt/iobroker/iobroker-data/files/telegram.admin
        36M     /opt/iobroker/iobroker-data/objects.jsonl
        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.m        ap
        15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors        -node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modu        les_io-1d9f06.44fe4a3f.chunk.js.map
        10M     /opt/iobroker/iobroker-data/states.jsonl
        9.7M    /opt/iobroker/iobroker-data/files/vis-2-beta/material-icons/knx-uf.json
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.16.0
        /usr/bin/node           v18.16.0
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Installed: 18.16.0-deb-1nodesource1
          Candidate: 18.16.0-deb-1nodesource1
          Version table:
         *** 18.16.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://security.debian.org/debian-security bullseye-security/main ar        m64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.3.5
        javascript:     6.1.4
        Adapters from github:   0
        Adapter State
          system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
        + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
        + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
          system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/../node_modules/iobroker.vis/io-package.json: /opt/iobroker/node_modules/iobroker.vis/io-package.json: Unexpected end of JSON input
        Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
        Adapter    "alias-manager": 1.2.4    , installed 1.2.4
        Adapter    "backitup"     : 2.6.19   , installed 2.6.19
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "echarts"      : 1.0.12   , installed 1.0.12
        Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
        Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
        Adapter    "iot"          : 1.14.2   , installed 1.14.2
        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
        Adapter    "shelly"       : 6.3.1    , installed 6.3.1
        Adapter    "socketio"     : 4.2.0    , installed 6.3.1
        Adapter    "telegram"     : 1.15.2   , installed 1.15.2
        Adapter    "text2command" : 2.3.0    , installed 2.3.0
        Adapter    "web"          : 4.3.0    , installed 5.3.1
        Adapter    "ws"           : 1.3.0    , installed 2.3.1
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Objects and States
        Objects:        8636
        States:         7351
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       1853       1014/io.hm-rpc.0
        tcp        0      0 192.168.178.38:2001     0.0.0.0:*               LISTEN      1001       15373      1040/io.hm-rpc.1
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14817      485/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14810      485/iobroker.js-con
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14005      510/sshd: /usr/sbin
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       15569      1163/io.simple-api.
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3955       887/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25273      1401/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14007      510/sshd: /usr/sbin
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15415      1066/io.shelly.0
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       2000       1133/io.broadlink2.
        udp        0      0 0.0.0.0:48160           0.0.0.0:*                           108        14723      352/avahi-daemon: r
        udp        0      0 0.0.0.0:35874           0.0.0.0:*                           1001       2029       1133/io.broadlink2.
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1487       720/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14721      352/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          14038      720/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        14722      352/avahi-daemon: r
        udp6       0      0 :::34081                :::*                                108        14724      352/avahi-daemon: r
        2023-05-15 17:46:14.532  - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
        2023-05-15 17:46:14.826  - info: admin.0 (887) <== Disconnect system.user.admin from ::ffff:192.168.178.30 web
        2023-05-15 17:46:15.055  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-05-15 17:46:17.598  - info: host.raspberrypi instance system.adapter.web.0 started with pid 1401
        2023-05-15 17:46:21.371  - info: web.0 (1401) starting. Version 5.3.1 in /opt/iobroker/node_modules/iobroker.web, node: v18.16.0, js-controller: 4.0.24
        2023-05-15 17:46:21.907  - info: web.0 (1401) socket.io server listening on port 8082
        2023-05-15 17:46:21.920  - info: web.0 (1401) simpleAPI server listening on port 8082
        2023-05-15 17:46:21.922  - info: web.0 (1401) Allow states only when user is owner: false
        2023-05-15 17:46:21.938  - info: web.0 (1401) http server listening on port 8082
        2023-05-15 17:46:28.981  - error: host.raspberrypi startInstance vis.0: Cannot read and parse "/opt/iobroker/node_modules/iobroker.vis/package.json"
        2023-05-15 17:46:29.180  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
        2023-05-15 17:46:38.900  - info: host.raspberrypi "system.adapter.vis.0" disabled
        2023-05-15 17:46:50.059  - info: host.raspberrypi "system.adapter.vis.0" enabled
        2023-05-15 17:46:50.163  - error: host.raspberrypi startInstance vis.0: Cannot read and parse "/opt/iobroker/node_modules/iobroker.vis/package.json"
        2023-05-15 17:46:50.348  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
        2023-05-15 17:47:02.106  - info: admin.0 (887) ==> Connected system.user.admin from ::ffff:192.168.178.30
        2023-05-15 17:48:01.632  - info: admin.0 (887) <== Disconnect system.user.admin from ::ffff:192.168.178.30
        2023-05-15 17:49:49.333  - info: admin.0 (887) ==> Connected system.user.admin from ::ffff:192.168.178.30
        2023-05-15 17:50:24.172  - info: admin.0 (887) ==> Connected system.user.admin from ::ffff:192.168.178.36
        2023-05-15 17:52:34.771  - info: admin.0 (887) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin
        2023-05-15 18:00:00.023  - info: javascript.0 (921) script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 7 | Reboots korrigiert: 0 | Unveränderte Werte: 5
        2023-05-15 18:15:00.066  - info: javascript.0 (921) script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 7 | Reboots korrigiert: 0 | Unveränderte Werte: 5
        2023-05-15 18:30:00.051  - info: javascript.0 (921) script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 4 | Reboots korrigiert: 0 | Unveränderte Werte: 8
        2023-05-15 18:35:00.106  - info: host.raspberrypi instance system.adapter.yr.0 started with pid 1618
        2023-05-15 18:35:36.650  - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=47.2'C
        volt=0.9360V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 1849 M total memory
                 1380 M used memory
                  161 M free memory
                   38 M buffer memory
                  268 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        540M    /var/
        180M    /var/cache
        175M    /var/cache/apt
        155M    /var/lib
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        javascript:     6.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        8636
        States:         7351
        Pending Updates: 0
        GlasfaserG Offline
        GlasfaserG Offline
        @searcher57 sagte in Täglicher Absturz ioBroker + Zugriff auf Raspi:
        @Thomas-Braun
        ich kenne mich nicht mit SD aus , was heißt das bei Ihm .
        Ich dachte er hat es neu aufgesetzt !?
          @searcher57
          searcher57
          pi@raspberrypi:~ $ iobroker install iobroker.vis@1.4.0
          adapter "vis" already installed. Use "upgrade" to upgrade to a newer version.
          • S searcher57
            GlasfaserG Offline
            GlasfaserG Offline
            Jipp ,, dann in der Admin Oberfläche upgraden ... wird auch angezeigt !
              @Thomas-Braun
              @glasfaser
              Das bedeutet, das die Wiederherstellung des Dateisystems abgeschlossen wurde. Das heißt aber noch lange nicht, dass alle Einschußlöcher auch gestopft werden konnten. Daher fährt man die Kisten ja auch immer sauber herunter, dann werden die Dateien geschlossen und du hast keine Fragmente im Dateisystem, wie es offenbar hier der Fall ist.
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                Danke ..
                OT ...
                Zu 100 % frage ich immer nach der Full Ausgabe von iob diag , da für mich die Summary nicht viel wiedergibt , sollte man es nicht bei der Full belassen !?
                • S searcher57
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @searcher57
                  Hallo ... bist du noch da
                  oder ziehst du gerade den Stecker wieder von der Raspberry ;)
                    searcher57
                    #66
                    @glasfaser
                    Sorry,
                    nein, aber das Problem ist nicht behoben! Ich bekomme keine neue Installation des Adapters hin und die Instanz habe ich ja gelöscht. Wie soll ich denn jetzt weiter vorgehen? Bitte immer dran denken: Rentner und Laie!!
                    HomoranH GlasfaserG 3 Antworten Letzte Antwort
                      @searcher57
                      searcher57
                      #67
                      @glasfaser
                      Versprochen! Der Anschiss hat gesessen!!😠 😥
                      • S searcher57
                        @glasfaser
                        Sorry,
                        #68
                        was ist daran ein Problem?
                        sind hier fast alle
                        • S searcher57
                          @glasfaser
                          Sorry,
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #69
                          Hiermit hinzufügen :
                          S GlasfaserG 2 Antworten Letzte Antwort
                            searcher57
                            #70
                            @glasfaser
                            Und genau dann kommt das!
                            $ iobroker add vis --host raspberrypi
                            Could not read io-package.json: /opt/iobroker/node_modules/iobroker.vis/io-package.json: Unexpected end of JSON input
                            host.raspberrypi error: reading io-package.json /opt/iobroker/node_modules/iobroker.vis/io-package.json: Unexpected end of JSON input
                            ERROR: Process exited with code 27
                            • S searcher57
                              @glasfaser
                              #71
                              @searcher57
                              iob update
                              iob upgrade
                                @searcher57
                                iob update
                                iob upgrade
                                searcher57
                                #72
                                @thomas-braun said in Täglicher Absturz ioBroker + Zugriff auf Raspi:
                                iob upgrade
                                pi@raspberrypi:~ $ iob upgrade
                                • S searcher57
                                  iob upgrade
                                  #73
                                  @searcher57 Die Ausgabe von
                                  iob update
                                  ist geheim?
                                    iob update
                                    ist geheim?
                                    searcher57
                                    #74
                                    pi@raspberrypi:~ $ iob update
                                    GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                    • S searcher57
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      #75
                                      @Thomas-Braun
                                      wäre ... !?
                                      rm /opt/iobroker/node_modules/iobroker.vis/io-package.json
                                      iob upload all
                                      • S searcher57
                                        #76
                                        @searcher57
                                        cd /opt/iobroker
                                        npm install iobroker.vis --force --debug
                                        HomoranH S 2 Antworten Letzte Antwort
                                          @searcher57
                                          cd /opt/iobroker
                                          #77
                                          @thomas-braun was war denn jetzt wieder der Vorteil von --force gegenüber --production?
