  4. Täglicher Absturz ioBroker + Zugriff auf Raspi [gelöst]
    5.4k
340 Beiträge 5 Kommentatoren 82.2k Aufrufe 4 Beobachtet
  • GlasfaserG Glasfaser
    @searcher57
    Bitte über die Konsole
    iobroker upgrade iobroker.vis@1.4.0
    searcher57
    pi@raspberrypi:~ $ iobroker upgrade iobroker.vis@1.4.0
    Cannot upgrade: /opt/iobroker/node_modules/iobroker.vis/io-package.json: Unexpected end of JSON input
      @searcher57
      searcher57
      @glasfaser
      • S searcher57
        GlasfaserG Offline
        GlasfaserG Offline
        @searcher57
        iobroker install iobroker.vis@1.4.0
        • S searcher57
          @glasfaser said in Täglicher Absturz ioBroker + Zugriff auf Raspi:
          iob diag
          Hier die Full Ausgabe, die jetzt auch funktioniert!
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Architecture    : aarch64
          Docker          : false
          Virtualization  : none
          Distributor ID: Debian
          Description:    Debian GNU/Linux 11 (bullseye)
          Release:        11
          Codename:       bullseye
          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
          NAME="Debian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          Systemuptime and Load:
           18:36:54 up  1:24,  1 user,  load average: 0.18, 0.19, 0.17
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          Other values than 0x0 hint to temperature/voltage problems
          temp=47.2'C
          volt=0.9360V
          *** Time and Time Zones ***
                         Local time: Mon 2023-05-15 18:36:54 CEST
                     Universal time: Mon 2023-05-15 16:36:54 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp        io i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            1.8G        1.4G        162M        1.0M        307M        405M
          Swap:            99M          0B         99M
          Total:          1.9G        1.4G        262M
                   1849 M total memory
                   1380 M used memory
                   1424 M active memory
                    155 M inactive memory
                    161 M free memory
                     38 M buffer memory
                    268 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4       29G  3.7G   25G  14% /
          devtmpfs       devtmpfs  667M     0  667M   0% /dev
          tmpfs          tmpfs     925M     0  925M   0% /dev/shm
          tmpfs          tmpfs     370M  1.1M  369M   1% /run
          /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
          /dev/sda1      exfat      29G  2.1G   27G   7% /mnt/usb0
          tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
          [Mon May 15 17:12:09 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:15:C8:D1 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=ae9ac4e2-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Mon May 15 17:12:10 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on reado        nly filesystem
          [Mon May 15 17:12:10 2023] EXT4-fs (mmcblk0p2): write access will be enabled dur        ing recovery
          [Mon May 15 17:12:11 2023] EXT4-fs (mmcblk0p2): recovery complete
          [Mon May 15 17:12:11 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
          [Mon May 15 17:12:11 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
          [Mon May 15 17:12:13 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET      SOURCE         FSTYPE OPTIONS
          /           /dev/mmcblk0p2 ext4   rw,noatime
          |-/boot     /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437        ,iocharset=ascii,shortname=mixed,errors=remount-ro
          `-/mnt/usb0 /dev/sda1      exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dma        sk=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
          /var:
          540M    /var/
          180M    /var/cache
          175M    /var/cache/apt
          155M    /var/lib
          130M    /var/lib/apt/lists
          Archived and active journals take up 104.0M in the file system.
          /opt/iobroker/backups:
          11M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          321M    /opt/iobroker/iobroker-data/
          276M    /opt/iobroker/iobroker-data/files
          61M     /opt/iobroker/iobroker-data/files/vis-2-beta
          51M     /opt/iobroker/iobroker-data/files/javascript.admin
          48M     /opt/iobroker/iobroker-data/files/telegram.admin
          36M     /opt/iobroker/iobroker-data/objects.jsonl
          19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.m        ap
          15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors        -node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modu        les_io-1d9f06.44fe4a3f.chunk.js.map
          10M     /opt/iobroker/iobroker-data/states.jsonl
          9.7M    /opt/iobroker/iobroker-data/files/vis-2-beta/material-icons/knx-uf.json
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.16.0
          /usr/bin/node           v18.16.0
          /usr/bin/npm            9.5.1
          /usr/bin/npx            9.5.1
          nodejs:
            Installed: 18.16.0-deb-1nodesource1
            Candidate: 18.16.0-deb-1nodesource1
            Version table:
           *** 18.16.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
               12.22.12~dfsg-1~deb11u4 500
                  500 http://security.debian.org/debian-security bullseye-security/main ar        m64 Packages
               12.22.12~dfsg-1~deb11u3 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.3.5
          javascript:     6.1.4
          Adapters from github:   0
          Adapter State
            system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
          + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
          + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
            system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/../node_modules/iobroker.vis/io-package.json: /opt/iobroker/node_modules/iobroker.vis/io-package.json: Unexpected end of JSON input
          Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
          Adapter    "alias-manager": 1.2.4    , installed 1.2.4
          Adapter    "backitup"     : 2.6.19   , installed 2.6.19
          Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
          Adapter    "echarts"      : 1.0.12   , installed 1.0.12
          Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
          Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
          Adapter    "iot"          : 1.14.2   , installed 1.14.2
          Adapter    "javascript"   : 6.1.4    , installed 6.1.4
          Adapter    "shelly"       : 6.3.1    , installed 6.3.1
          Adapter    "socketio"     : 4.2.0    , installed 6.3.1
          Adapter    "telegram"     : 1.15.2   , installed 1.15.2
          Adapter    "text2command" : 2.3.0    , installed 2.3.0
          Adapter    "web"          : 4.3.0    , installed 5.3.1
          Adapter    "ws"           : 1.3.0    , installed 2.3.1
          Adapter    "yr"           : 5.3.0    , installed 5.3.0
          Objects and States
          Objects:        8636
          States:         7351
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       1853       1014/io.hm-rpc.0
          tcp        0      0 192.168.178.38:2001     0.0.0.0:*               LISTEN      1001       15373      1040/io.hm-rpc.1
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14817      485/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14810      485/iobroker.js-con
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14005      510/sshd: /usr/sbin
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       15569      1163/io.simple-api.
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3955       887/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25273      1401/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14007      510/sshd: /usr/sbin
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15415      1066/io.shelly.0
          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       2000       1133/io.broadlink2.
          udp        0      0 0.0.0.0:48160           0.0.0.0:*                           108        14723      352/avahi-daemon: r
          udp        0      0 0.0.0.0:35874           0.0.0.0:*                           1001       2029       1133/io.broadlink2.
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1487       720/dhcpcd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14721      352/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          14038      720/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        14722      352/avahi-daemon: r
          udp6       0      0 :::34081                :::*                                108        14724      352/avahi-daemon: r
          2023-05-15 17:46:14.532  - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
          2023-05-15 17:46:14.826  - info: admin.0 (887) <== Disconnect system.user.admin from ::ffff:192.168.178.30 web
          2023-05-15 17:46:15.055  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-05-15 17:46:17.598  - info: host.raspberrypi instance system.adapter.web.0 started with pid 1401
          2023-05-15 17:46:21.371  - info: web.0 (1401) starting. Version 5.3.1 in /opt/iobroker/node_modules/iobroker.web, node: v18.16.0, js-controller: 4.0.24
          2023-05-15 17:46:21.907  - info: web.0 (1401) socket.io server listening on port 8082
          2023-05-15 17:46:21.920  - info: web.0 (1401) simpleAPI server listening on port 8082
          2023-05-15 17:46:21.922  - info: web.0 (1401) Allow states only when user is owner: false
          2023-05-15 17:46:21.938  - info: web.0 (1401) http server listening on port 8082
          2023-05-15 17:46:28.981  - error: host.raspberrypi startInstance vis.0: Cannot read and parse "/opt/iobroker/node_modules/iobroker.vis/package.json"
          2023-05-15 17:46:29.180  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
          2023-05-15 17:46:38.900  - info: host.raspberrypi "system.adapter.vis.0" disabled
          2023-05-15 17:46:50.059  - info: host.raspberrypi "system.adapter.vis.0" enabled
          2023-05-15 17:46:50.163  - error: host.raspberrypi startInstance vis.0: Cannot read and parse "/opt/iobroker/node_modules/iobroker.vis/package.json"
          2023-05-15 17:46:50.348  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
          2023-05-15 17:47:02.106  - info: admin.0 (887) ==> Connected system.user.admin from ::ffff:192.168.178.30
          2023-05-15 17:48:01.632  - info: admin.0 (887) <== Disconnect system.user.admin from ::ffff:192.168.178.30
          2023-05-15 17:49:49.333  - info: admin.0 (887) ==> Connected system.user.admin from ::ffff:192.168.178.30
          2023-05-15 17:50:24.172  - info: admin.0 (887) ==> Connected system.user.admin from ::ffff:192.168.178.36
          2023-05-15 17:52:34.771  - info: admin.0 (887) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin
          2023-05-15 18:00:00.023  - info: javascript.0 (921) script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 7 | Reboots korrigiert: 0 | Unveränderte Werte: 5
          2023-05-15 18:15:00.066  - info: javascript.0 (921) script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 7 | Reboots korrigiert: 0 | Unveränderte Werte: 5
          2023-05-15 18:30:00.051  - info: javascript.0 (921) script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 4 | Reboots korrigiert: 0 | Unveränderte Werte: 8
          2023-05-15 18:35:00.106  - info: host.raspberrypi instance system.adapter.yr.0 started with pid 1618
          2023-05-15 18:35:36.650  - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=debian
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          temp=47.2'C
          volt=0.9360V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   1849 M total memory
                   1380 M used memory
                    161 M free memory
                     38 M buffer memory
                    268 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          540M    /var/
          180M    /var/cache
          175M    /var/cache/apt
          155M    /var/lib
          /usr/bin/npm            9.5.1
          /usr/bin/npx            9.5.1
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        8636
          States:         7351
          Pending Updates: 0
          GlasfaserG Offline
          GlasfaserG Offline
          @searcher57 sagte in Täglicher Absturz ioBroker + Zugriff auf Raspi:
          @Thomas-Braun
          ich kenne mich nicht mit SD aus , was heißt das bei Ihm .
          Ich dachte er hat es neu aufgesetzt !?
            @searcher57
            searcher57
            pi@raspberrypi:~ $ iobroker install iobroker.vis@1.4.0
            adapter "vis" already installed. Use "upgrade" to upgrade to a newer version.
            • S searcher57
              GlasfaserG Offline
              GlasfaserG Offline
              Jipp ,, dann in der Admin Oberfläche upgraden ... wird auch angezeigt !
                @Thomas-Braun
                @glasfaser
                Das bedeutet, das die Wiederherstellung des Dateisystems abgeschlossen wurde. Das heißt aber noch lange nicht, dass alle Einschußlöcher auch gestopft werden konnten. Daher fährt man die Kisten ja auch immer sauber herunter, dann werden die Dateien geschlossen und du hast keine Fragmente im Dateisystem, wie es offenbar hier der Fall ist.
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Danke ..
                  OT ...
                  Zu 100 % frage ich immer nach der Full Ausgabe von iob diag , da für mich die Summary nicht viel wiedergibt , sollte man es nicht bei der Full belassen !?
                  • S searcher57
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @searcher57
                    Hallo ... bist du noch da
                    oder ziehst du gerade den Stecker wieder von der Raspberry ;)
                      searcher57
                      #66
                      @glasfaser
                      Sorry,
                      nein, aber das Problem ist nicht behoben! Ich bekomme keine neue Installation des Adapters hin und die Instanz habe ich ja gelöscht. Wie soll ich denn jetzt weiter vorgehen? Bitte immer dran denken: Rentner und Laie!!
                      HomoranH GlasfaserG 3 Antworten Letzte Antwort
                        @searcher57
                        searcher57
                        #67
                        @glasfaser
                        Versprochen! Der Anschiss hat gesessen!!😠 😥
                        • S searcher57
                          @glasfaser
                          Sorry,
                          #68
                          was ist daran ein Problem?
                          sind hier fast alle
                          • S searcher57
                            @glasfaser
                            Sorry,
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #69
                            Hiermit hinzufügen :
                            S GlasfaserG 2 Antworten Letzte Antwort
                              searcher57
                              #70
                              @glasfaser
                              Und genau dann kommt das!
                              $ iobroker add vis --host raspberrypi
                              Could not read io-package.json: /opt/iobroker/node_modules/iobroker.vis/io-package.json: Unexpected end of JSON input
                              host.raspberrypi error: reading io-package.json /opt/iobroker/node_modules/iobroker.vis/io-package.json: Unexpected end of JSON input
                              ERROR: Process exited with code 27
                              • S searcher57
                                @glasfaser
                                #71
                                @searcher57
                                iob update
                                iob upgrade
                                  @searcher57
                                  iob update
                                  iob upgrade
                                  searcher57
                                  #72
                                  @thomas-braun said in Täglicher Absturz ioBroker + Zugriff auf Raspi:
                                  iob upgrade
                                  pi@raspberrypi:~ $ iob upgrade
                                  • S searcher57
                                    iob upgrade
                                    #73
                                    @searcher57 Die Ausgabe von
                                    iob update
                                    ist geheim?
                                      iob update
                                      ist geheim?
                                      searcher57
                                      #74
                                      pi@raspberrypi:~ $ iob update
                                      GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                      • S searcher57
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        #75
                                        @Thomas-Braun
                                        wäre ... !?
                                        rm /opt/iobroker/node_modules/iobroker.vis/io-package.json
                                        iob upload all
                                        • S searcher57
                                          #76
                                          @searcher57
                                          cd /opt/iobroker
                                          npm install iobroker.vis --force --debug
                                          HomoranH S 2 Antworten Letzte Antwort
