  4. Täglicher Absturz ioBroker + Zugriff auf Raspi [gelöst]
    5.4k
340 Beiträge 5 Kommentatoren 82.1k Aufrufe 4 Beobachtet
  • S searcher57
    Sorry, wie kann ich Dir die Langfassung kopieren?
    @searcher57
    Genauso wie Zusammenfassung.
      @searcher57
      searcher57
      Ich hoffe das meinst Du!
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       20:18:56 up  2:11,  1 user,  load average: 0.61, 0.63, 0.46
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=47.7'C
      volt=0.9360V
      *** Time and Time Zones ***
                     Local time: Sun 2023-05-14 20:18:56 CEST
                 Universal time: Sun 2023-05-14 18:18:56 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            1.8G        1.3G        155M        0.0K        357M        439M
      Swap:            99M         99M        0.0K
      Total:          1.9G        1.4G        155M
               1849 M total memory
               1336 M used memory
                351 M active memory
               1219 M inactive memory
                155 M free memory
                 22 M buffer memory
                335 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       29G  5.8G   23G  21% /
      devtmpfs       devtmpfs  667M     0  667M   0% /dev
      tmpfs          tmpfs     925M     0  925M   0% /dev/shm
      tmpfs          tmpfs     370M  1.1M  369M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      /dev/sda1      exfat      29G 1023M   28G   4% /mnt/usb0
      tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
      [Sun May 14 18:07:11 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:15:C8:D1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c4978b94-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun May 14 18:07:12 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Sun May 14 18:07:12 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Sun May 14 18:07:12 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      [Sun May 14 18:07:12 2023] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
      [Sun May 14 18:07:12 2023] EXT4-fs (mmcblk0p2): recovery complete
      [Sun May 14 18:07:12 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun May 14 18:07:12 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun May 14 18:07:14 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET      SOURCE         FSTYPE OPTIONS
      /           /dev/mmcblk0p2 ext4   rw,noatime
      |-/boot     /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      `-/mnt/usb0 /dev/sda1      exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
      /var:
      1.2G    /var/
      721M    /var/log
      697M    /var/log/journal/5348baed3ac54f7a91359e7c297fe9a9
      179M    /var/cache
      Archived and active journals take up 696.1M in the file system.
      /opt/iobroker/backups:
      1.4G    /opt/iobroker/backups/
      4.0K    /opt/iobroker/backups/redistmp
      /opt/iobroker/iobroker-data:
      434M    /opt/iobroker/iobroker-data/
      266M    /opt/iobroker/iobroker-data/files
      71M     /opt/iobroker/iobroker-data/history
      68M     /opt/iobroker/iobroker-data/backup-objects
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
      23M     /opt/iobroker/iobroker-data/objects.jsonl
      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.0
      /usr/bin/node           v18.16.0
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
       *** 18.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   0
      Adapter State
        system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
        system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
        system.adapter.doorbird.0               : doorbird              : raspberrypi                              - disabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
        system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.6.19   , installed 2.6.19
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "devices"      : 1.1.2    , installed 1.1.2
      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
      Adapter    "iot"          : 1.14.2   , installed 1.14.2
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Adapter    "sbfspot"      : 4.1.4    , installed 4.1.4
      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
      Adapter    "socketio"     : 4.2.0    , installed 6.3.1
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "text2command" : 2.3.0    , installed 2.3.0
      Adapter    "web"          : 4.3.0    , installed 5.3.1
      Adapter    "ws"           : 1.3.0    , installed 2.3.1
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Objects and States
      Objects:        8696
      • S searcher57
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=47.7'C
        volt=0.9360V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M         99M        0.0K
                 1849 M total memory
                 1336 M used memory
                  351 M active memory
                  155 M free memory
                   22 M buffer memory
                  335 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        1.2G    /var/
        721M    /var/log
        179M    /var/cache
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        javascript:     6.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        8696
        @searcher57
        Das ist nicht die vollständige Ausgabe.
          @searcher57
          searcher57
          Bitte sag mir, mit welchem Befehl ich an die Langfassung komme. Ich muss es sonst an irgend einem Punkt unterbrechen.
          • Thomas BraunT Online
            @searcher57
            Es gibt eine Kopie davon in /home/iobroker
            Aber man kann das auch direkt aus dem Terminalprogramm kopieren. Aus gescheiten jedenfalls.
              @searcher57
              searcher57
              Also, ich gehe mit Putty auf den Raspi. Beim letzten Versuch dir die vollständige Ausgabe zu kopieren, ist er schon wieder abgestürzt. Soll ich ihn wieder reseten? Wenn ich den Befehl iob diag ausführe, dann läuft das bis zur Zusammenfassung automatisch durch. Wann soll ich das unterbrechen?
              • S searcher57
                @searcher57 sagte in Täglicher Absturz ioBroker + Zugriff auf Raspi:
                Das ist natürlich alles andere als normal.
                Auch das ist nicht normal. Das Skript erwartet zwei Bestätigungen per Tastatur fortzufahren. Vor der zweiten Bestätigung kann man die Langfassung aus dem Terminal kopieren.
                S 2 Antworten Letzte Antwort
                  searcher57
                  Eben! Und jetzt??
                  • S searcher57
                    Eben! Und jetzt??
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @searcher57
                    Bist du immer noch als Beta Tester unterwegs !?
                    nicht lang her :
                    https://forum.iobroker.net/post/978802
                      searcher57
                      Soll ich einen Neustart durchführen??
                      • GlasfaserG Glasfaser
                        @searcher57
                        nicht lang her :
                        @glasfaser
                        Nope:
                        • S searcher57
                          @searcher57
                          Schau mal in das Journal zu den Absturzzeiten rein
                            @searcher57
                            nicht lang her :
                            @glasfaser
                            Wenn das immer noch das gleiche Speichermedium war damals ist, wird das mittlerweile komplett durch sein.
                              @glasfaser
                              searcher57
                              Ich verstehe dich nicht.
                              • S searcher57
                                @searcher57
                                Was verstehst du nicht?
                                  @searcher57
                                  searcher57
                                  Ich bin nicht mehr als Beta-Tester unterwegs. Ausser dem Doorbird-Adapter bin ich nicht im Beta gewesen. Ich habe alles nach Matthias Kleine aufgebaut. Leider kann mir niemand helfen. Vielleicht muss ich mit dem Problem leben. Wäre schön, wenn du mir sagst, ob ich einen Reset machen soll und wie ich dann an die Langfassung komme?
                                  • S searcher57
                                    Hab ich dir doch schon gesagt.
                                    Hast du das Speichermedium seit April ausgetauscht?
                                    Das war ja damals schon wurmstichig.
                                      searcher57
                                      Ja, ich habe die SD Karte kopiert und im Einsatz. Soll ich die Original- Karte wieder einsetzen?
                                      • S searcher57
                                        @searcher57
                                        Kopien sind natürlich von defekten Medien aus sinnfrei, du kopierst den kaputten Kram ja dann auf das frische Medium.
                                          @searcher57
                                          searcher57
                                          Das heisst, das Ganze von Null an wieder aufrollen??
                                          GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
