  4. Probleme mit Octoprint Adapter
    5.4k
14 Beiträge 4 Kommentatoren 1.3k Aufrufe 3 Beobachtet
  • DJMarc75D DJMarc75
    @draexler zeig mal
    iob diag
    bitte
    draexlerD Offline
    draexlerD Offline
    draexler
    @djmarc75 sagte in Probleme mit Octoprint Adapter:
    iob diag
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : kvm
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     12:41:04 up 1 day, 18:05,  1 user,  load average: 2.36, 1.28, 0.77
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Sun 2023-05-14 12:41:04 CEST
               Universal time: Sun 2023-05-14 10:41:04 UTC
                     RTC time: Sun 2023-05-14 10:41:05
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    peter
    /home/peter
    peter cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        5.1G        1.2G        0.0K        1.7G        2.6G
    Swap:           974M        0.0K        974M
    Total:          8.9G        5.1G        2.2G
             7945 M total memory
             5070 M used memory
             1181 M active memory
             5215 M inactive memory
             1184 M free memory
              283 M buffer memory
             1406 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     795M  488K  795M   1% /run
    /dev/sda1      ext4       48G   13G   34G  27% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     795M     0  795M   0% /run/user/1000
    [Fri May 12 18:35:37 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Fri May 12 18:35:38 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    4.1G    /var/
    3.7G    /var/log
    3.6G    /var/log/journal/a9beaafc6f754bc5ab03f2e4fc074e63
    189M    /var/cache
    Archived and active journals take up 144.0M in the file system.
    /opt/iobroker/backups:
    244M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-oben/.piolibdeps/zentralflur-infodisplay-oben/AsyncMqttClient-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-oben/.piolibdeps/zentralflur-infodisplay-oben/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-oben/.piolibdeps/zentralflur-infodisplay-oben/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-oben/.piolibdeps/zentralflur-infodisplay-oben/AsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-unten/.piolibdeps/zentralflur-infodisplay-unten/AsyncMqttClient-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-unten/.piolibdeps/zentralflur-infodisplay-unten/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-unten/.piolibdeps/zentralflur-infodisplay-unten/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-unten/.piolibdeps/zentralflur-infodisplay-unten/AsyncTCP-esphome': Permission denied
    1.3G    /opt/iobroker/iobroker-data/
    699M    /opt/iobroker/iobroker-data/esphome.0
    698M    /opt/iobroker/iobroker-data/esphome.0/.esphome
    651M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
    349M    /opt/iobroker/iobroker-data/files
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-oben/.piolibdeps/zentralflur-infodisplay-oben/AsyncMqttClient-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-oben/.piolibdeps/zentralflur-infodisplay-oben/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-oben/.piolibdeps/zentralflur-infodisplay-oben/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-oben/.piolibdeps/zentralflur-infodisplay-oben/AsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-unten/.piolibdeps/zentralflur-infodisplay-unten/AsyncMqttClient-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-unten/.piolibdeps/zentralflur-infodisplay-unten/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-unten/.piolibdeps/zentralflur-infodisplay-unten/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-unten/.piolibdeps/zentralflur-infodisplay-unten/AsyncTCP-esphome': Permission denied
    46M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    26M     /opt/iobroker/iobroker-data/states.jsonl
    21M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/zentralflur-infodisplay-unten/.pioenvs/zentralflur-infodisplay-unten/firmware.elf
    21M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/holzlager-infodisplay/.pioenvs/holzlager-infodisplay/firmware.elf
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 -  enabled
    + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.drag-indicator.0         : drag-indicator        : iobroker                                 -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
    + system.adapter.gigaset-elements.0       : gigaset-elements      : iobroker                                 -  enabled
    + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
    + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
    + system.adapter.hue.1                    : hue                   : iobroker                                 -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
      system.adapter.meteoalarm.0             : meteoalarm            : iobroker                                 -  enabled
      system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
    + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
      system.adapter.oilfox.0                 : oilfox                : iobroker                                 -  enabled
    + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.plenticore.0             : plenticore            : iobroker                                 -  enabled, port: 80
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
    + system.adapter.pushover.2               : pushover              : iobroker                                 -  enabled
    + system.adapter.pushover.3               : pushover              : iobroker                                 -  enabled
    + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
    + system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tvprogram.0              : tvprogram             : iobroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
      system.adapter.vcard.0                  : vcard                 : iobroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.wolf.0                   : wolf                  : iobroker                                 - disabled, port: 12004, bind: 0.0.0.0
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
    + system.adapter.yahka.1                  : yahka                 : iobroker                                 -  enabled
    + system.adapter.yahka.2                  : yahka                 : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "bosch-ebike"  : 0.0.3    , installed 0.0.3
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "drag-indicator": 2.1.0   , installed 2.1.0
    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
    Adapter    "email"        : 1.1.4    , installed 1.1.4
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "linux-control": 1.1.3    , installed 1.1.3
    Adapter    "meteoalarm"   : 2.3.5    , installed 2.3.5
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "oilfox"       : 4.1.2    , installed 4.1.2
    Adapter    "parcel"       : 0.0.27   , installed 0.0.27
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
    Adapter    "unifi"        : 0.5.10   , installed 0.5.10
    Adapter    "vcard"        : 0.0.9    , installed 0.0.9
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "wolf"         : 1.5.0    , installed 1.5.0
    Adapter    "yahka"        : 0.17.0   , installed 0.17.0
    Objects and States
    Objects:        25656
    States:         20237
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:38023         0.0.0.0:*               LISTEN      1001       1358958    55108/io.yahka.2
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13540      382/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13533      382/iobroker.js-con
    tcp        0      0 0.0.0.0:38539           0.0.0.0:*               LISTEN      1001       1358231    55108/io.yahka.2
    tcp        0      0 192.168.1.30:9292       0.0.0.0:*               LISTEN      1001       14360      660/io.hm-rpc.1
    tcp        0      0 127.0.0.1:35887         0.0.0.0:*               LISTEN      1001       1460989    55081/io.yahka.0
    tcp        0      0 0.0.0.0:40911           0.0.0.0:*               LISTEN      1001       1358232    55108/io.yahka.2
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11550      1/init
    tcp        0      0 127.0.0.1:40625         0.0.0.0:*               LISTEN      1001       1358237    55108/io.yahka.2
    tcp        0      0 192.168.1.30:2001       0.0.0.0:*               LISTEN      1001       13289      645/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13494      411/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:40183         0.0.0.0:*               LISTEN      1001       1358216    55100/io.yahka.1
    tcp        0      0 127.0.0.1:40153         0.0.0.0:*               LISTEN      1001       1358966    55108/io.yahka.2
    tcp        0      0 192.168.1.30:2010       0.0.0.0:*               LISTEN      1001       14407      675/io.hm-rpc.2
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14654      765/io.mqtt.0
    tcp        0      0 0.0.0.0:44157           0.0.0.0:*               LISTEN      1001       1358194    55100/io.yahka.1
    tcp        0      0 0.0.0.0:39325           0.0.0.0:*               LISTEN      1001       1357954    55081/io.yahka.0
    tcp        0      0 0.0.0.0:34079           0.0.0.0:*               LISTEN      1001       1358233    55108/io.yahka.2
    tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       939470     39865/python3
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       16196      1015/io.harmony.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          11554      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13617      440/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19954      1702/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13496      411/sshd: /usr/sbin
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       19762      1638/io.terminal.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12667      353/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11551      1/init
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       16197      1015/io.harmony.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1358235    55108/io.yahka.2
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1358234    55108/io.yahka.2
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1358196    55100/io.yahka.1
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1358195    55100/io.yahka.1
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1357956    55081/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1357955    55081/io.yahka.0
    udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       938550     39865/python3
    udp        0      0 192.168.1.30:5353       0.0.0.0:*                           1001       938549     39865/python3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       938543     39865/python3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       939457     39824/io.esphome.0
    udp6       0      0 :::111                  :::*                                0          11557      1/init
    2023-05-14 12:00:39.218  - error: octoprint.0 (1524) (printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
    2023-05-14 12:00:39.241  - error: octoprint.0 (1524) (printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
    2023-05-14 12:00:39.313  - error: octoprint.0 (1524) (printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
    2023-05-14 12:00:42.308  - error: octoprint.0 (1524) (printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
    2023-05-14 12:25:21.193  - error: octoprint.0 (1524) (printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
    2023-05-14 12:25:21.258  - error: octoprint.0 (1524) (printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
    2023-05-14 12:25:21.373  - error: octoprint.0 (1524) (printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
    2023-05-14 12:25:24.280  - error: octoprint.0 (1524) (printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
    2023-05-14 12:37:58.462  - error: octoprint.0 (1524) (printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
    2023-05-14 12:37:58.479  - error: octoprint.0 (1524) (printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
    2023-05-14 12:37:58.495  - error: octoprint.0 (1524) (printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
    2023-05-14 12:38:01.246  - error: octoprint.0 (1524) (printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
    iob diag has finished.
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 5.10.0-22-amd64
    Installation:           kvm
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     1
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            7.9G        5.3G        993M        0.0K        1.7G        2.4G
    Total:          8.9G        5.3G        2.0G
    Active iob-Instances:   54
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                24724
    States:                 19511
    Size of iob-Database:
    45M     /opt/iobroker/iobroker-data/objects.jsonl
    23M     /opt/iobroker/iobroker-data/states.jsonl
    • draexlerD draexler
      iob diag
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      peter
      /home/peter
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               7945 M total memory
               5070 M used memory
               1184 M free memory
                283 M buffer memory
               1406 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      /var:
      4.1G    /var/
      3.7G    /var/log
      189M    /var/cache
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        25656
      States:         20237
      Pending Updates: 1
                           v.2023-04-16
      Installation:           kvm
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      MEMORY:
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                24724
      States:                 19511
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @draexler was läuft denn da noch drauf, ausser iobroker ?
      Lehrling seit 1975 !!!
      draexlerD 1 Antwort Letzte Antwort
        draexlerD Offline
        draexlerD Offline
        draexler
        @djmarc75 Nö, der ioBroker läuft auf einer VM in Proxmox und der OctoPrint auf einem Pi400.
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @draexler sagte in Probleme mit Octoprint Adapter:
          aha.. also iob und octoprint getrennt....
          und was ist nun dein Anliegen ?
            draexlerD Offline
            draexlerD Offline
            draexler
            @djmarc75 ähh… siehe Eingangspost. Fehlermeldung im Log und die Frage was der Grund sein kann?! Denn laufen tut die ganze Sache ja.
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              aha...da war ersichtlich dass iob und octo getrennt laufen 😂
              Natürlich entschuldige ich mich hiermit 🤥
              da_WoodyD draexlerD 2 Antworten Letzte Antwort
                da_WoodyD Online
                da_WoodyD Online
                @djmarc75 ich denk mal, da hast du was verwechselt...
                normal hängt ein PI vor dem drucker im netzwerk mit octoprint.
                z.b.
                dann gibts im ioB den octoprint adapter. der siht bei mir in iQontrol so aus:
                woher der fehler kommt ist mir allerdings noch immer ein rätsel...
                mein ender ist im moment aufgedreht, druckt nicht, aber keine meldungen.
                • da_WoodyD da_Woody
                  z.b.
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  @da_woody sagte in Probleme mit Octoprint Adapter:
                  ? Ich ?
                  was verwechsel ich ? 😂
                    draexlerD Offline
                    draexlerD Offline
                    draexler
                    Können wir uns wieder dem Problem widmen?
                    Ich fasse jetzt alles nochmal zusammen:
                    ioBroker läuft auf eine VM in Proxmox -> Alles UptoDate -> Node.js: v18.16.0 NPM: 9.5.1 (siehe auch Log "iob Diag" weiter oben)
                    Octoprint läuft auf einen Pi400 -> Alles UptoDate -> Octoprint: OctoPrint 1.8.7 Python 3.7.3 OctoPi 0.18.0
                    Adapter in ioBroker -> UptoDate -> v4.0.0
                    Beim Drucken (und nur während des Drucks) erscheinen die im Eingangspost erwähnten Fehlermeldungen.
                    Es wurde schon alles neu gestartet, iobFix ausgeführt etc.
                    Netzwerkprobleme sind nicht ersichtlich -> Unifi zeigt keine Verbindungsabbrüche etc.
                      immer wenn ich etwas mit Octoprint Drucke habe ich das im Log:
                      	2023-05-12 13:00:13.773	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 13:00:11.095	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 13:00:11.015	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 13:00:10.956	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:47:36.783	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:47:34.045	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:47:34.025	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:47:33.990	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:35:15.855	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:35:13.069	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:35:13.034	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:35:12.970	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:22:54.805	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:22:52.078	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:22:52.040	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:22:51.984	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:10:17.986	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:10:15.069	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:10:15.026	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 12:10:14.981	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 11:45:15.785	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 11:45:13.109	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 11:45:12.991	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 11:45:12.967	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 11:32:39.756	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 11:32:37.038	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 11:32:36.994	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 11:32:36.947	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 11:20:27.774	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 11:20:25.059	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      octoprint.0
                      2023-05-12 11:20:24.979	error	(printer/printhead) status 409: {"error":"Printer is not operational or currently printing"}
                      Was könnte die Ursache sein? Was der Text sagt ist mir klar. Octoprint selbst ist aber wunderbar erreichbar.
                      FredFF Online
                      FredFF Online
                      FredF
                      Most Active Forum Testing
                      @draexler
                      Vielleicht liegt es ein dem kleinen Wörtchen "or" in der Fehlermeldung und es ist ganz normal das diese Meldung beim Drucken kommt?
                      Nur so eine Idee, ich nutze den Adapter nicht.
