  4. Easee Wallbox mit iobroker
    6.4k
easeewallboxadapter
529 Beiträge 61 Kommentatoren 194.3k Aufrufe 54 Beobachtet
    kaffeschluerfer
    #432
    Guten Morgen zusammen!
    da scheint tatsächlich "gewartet" worden - so dass der Adapter nun nihct mehr läuft. Steht bzw. springt nach neustart auf rot...
    easee.0
    	2023-05-10 08:21:33.146	error	DB closed
    easee.0
    	2023-05-10 08:21:33.145	warn	get state error: Connection is closed.
    easee.0
    	2023-05-10 08:21:33.000	info	undefined is not a valid state value for id "easee.0.EH7J4CYM.status.latestFirmware"
    easee.0
    	2023-05-10 08:21:32.642	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    easee.0
    	2023-05-10 08:21:32.641	info	terminating
    easee.0
    	2023-05-10 08:21:32.640	info	Adaptor easee cleaned up everything...
    easee.0
    	2023-05-10 08:21:32.637	error	Gone
    easee.0
    	2023-05-10 08:21:32.637	error	Error: Gone at new HttpError (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/Errors.js:27:24) at FetchHttpClient.<anonymous> (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:154:35) at step (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:52:23) at Object.next (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:33:53) at fulfilled (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:24:58) at processTicksAndRejections (node:internal/process/task_queues:96:5)
    easee.0
    	2023-05-10 08:21:32.636	error	unhandled promise rejection: Gone
    easee.0
    	2023-05-10 08:21:32.636	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    easee.0
    	2023-05-10 08:21:32.279	info	Starting SignalR
    easee.0
    	2023-05-10 08:21:32.022	info	Easee Api Login successful
    easee.0
    	2023-05-10 08:21:31.693	info	starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.easee, node: v16.19.1, js-controller: 4.0.24
    stiwy18S 1 Antwort Letzte Antwort
    • K kaffeschluerfer
      easee.0
      easee.0
      easee.0
      easee.0
      easee.0
      easee.0
      easee.0
      easee.0
      easee.0
      easee.0
      easee.0
      easee.0
      easee.0
      stiwy18S Offline
      stiwy18S Offline
      stiwy18
      #433
      @kaffeschluerfer Als Workaround kannst du SignalR deaktivieren, dann läuft der Adapter wird, oder die URL selbst übergangsweise in deinem iOBroker anpassen, dann läuft er auch wieder.
      K NewanN 2 Antworten Letzte Antwort
      • stiwy18S stiwy18
        kaffeschluerfer
        #434
        @stiwy18 Danke - hat geholfen. Läuft wieder ohne SignalIR. Meine Wallbox hat übrigens FW v310
        • stiwy18S stiwy18
          NewanN Offline
          NewanN Offline
          Newan
          #435
          @stiwy18 Ist das so das die URL angepasst und es geht. Wäre ja nen einfacherer fix.
          Bin aber bis zum WE leider unterwegs
          • NewanN Newan
            stiwy18S Offline
            stiwy18S Offline
            stiwy18
            #436
            @newan Korrekt, hab nur in Zeile 46 die URL von https://api.easee.cloud/hubs/chargers auf https://streams.easee.com/hubs/chargers geändert, dann lief der Adapter wird mit SignalR
            W 1 Antwort Letzte Antwort
            • stiwy18S stiwy18
              W Offline
              W Offline
              warp-it
              #437
              @stiwy18 said in Easee Wallbox mit iobroker:
              Zeile 46 von was?
              NewanN 1 Antwort Letzte Antwort
              • W warp-it
                Zeile 46 von was?
                NewanN Offline
                NewanN Offline
                Newan
                #438
                @warp-it Ist ein neuer commit online.. Mal testen dann mach ich ne Version
                K W 2 Antworten Letzte Antwort
                • NewanN Newan
                  kaffeschluerfer
                  #439
                  @newan hab gerade aus Github installiert und getestet - leider immernoch dasselbe Problem. Ohne SignalIR gehts aber.
                  easee.0
                  	2023-05-10 17:01:03.759	info	starting. Version 1.0.7 (non-npm: Newan/ioBroker.easee) in /opt/iobroker/node_modules/iobroker.easee, node: v16.19.1, js-controller: 4.0.24
                  easee.0
                  	2023-05-10 17:00:39.847	warn	get state error: Connection is closed.
                  easee.0
                  	2023-05-10 17:00:39.846	warn	Could not perform strict object check of state easee.0.EH7J4CYM.name: DB closed
                  easee.0
                  	2023-05-10 17:00:39.335	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                  easee.0
                  	2023-05-10 17:00:39.335	info	terminating
                  easee.0
                  	2023-05-10 17:00:39.334	info	Adaptor easee cleaned up everything...
                  easee.0
                  	2023-05-10 17:00:39.302	error	Failed to complete negotiation with the server: TypeError: Cannot read properties of undefined (reading 'secure')
                  easee.0
                  	2023-05-10 17:00:39.302	error	Error: Failed to complete negotiation with the server: TypeError: Cannot read properties of undefined (reading 'secure') at HttpConnection._getNegotiationResponse (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/HttpConnection.js:256:35) at async HttpConnection._startInternal (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/HttpConnection.js:172:41) at async HttpConnection.start (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/HttpConnection.js:75:9) at async HubConnection._startInternal (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/HubConnection.js:132:9) at async HubConnection._startWithStateTransitions (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/HubConnection.js:109:13)
                  easee.0
                  	2023-05-10 17:00:39.301	error	unhandled promise rejection: Failed to complete negotiation with the server: TypeError: Cannot read properties of undefined (reading 'secure')
                  easee.0
                  	2023-05-10 17:00:39.300	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  easee.0
                  	2023-05-10 17:00:39.225	info	Starting SignalR
                  easee.0
                  	2023-05-10 17:00:38.965	info	Easee Api Login successful
                  easee.0
                  	2023-05-10 17:00:38.634	info	starting. Version 1.0.7 (non-npm: Newan/ioBroker.easee) in /opt/iobroker/node_modules/iobroker.easee, node: v16.19.1, js-controller: 4.0.24
                  • K kaffeschluerfer
                    easee.0
                    easee.0
                    easee.0
                    easee.0
                    easee.0
                    easee.0
                    easee.0
                    easee.0
                    easee.0
                    easee.0
                    easee.0
                    easee.0
                    easee.0
                    #440
                    @kaffeschluerfer sagte in Easee Wallbox mit iobroker:
                    node: v16.19.1
                    Versuch es mit der aktuellen Empfehlung nodejs@18.
                      kaffeschluerfer
                      #441
                      @thomas-braun said in Easee Wallbox mit iobroker:
                      jap, das war's. Funktioniert wieder mit SignalIR. Hatte übersehen dass ich nodejs aktualisieren sollte... Danke!
                      • K kaffeschluerfer
                        Smokey
                        #442
                        Ich habe leider immer noch ein Problem:
                        easee.0 2023-05-15 10:03:50.813 error Easee API error on charger session - stop refresh
                        easee.0 2023-05-15 10:03:50.812 error Error: Request failed with status code 403
                        Da ich mein System ohnehin am WE neu aufsetzen musste, habe ich soweit alles auf dem letzten Stand. Ob SignalIR an oder aus macht keinen Unterschied. Aufgefallen ist mir, dass mein Adapter die Version 1.07 hat. Auf Git sehe ich allerdings nur eine 1.04 als aktuelle.
                        Noch irgendwelche Ideen?
                        • S Smokey
                          K_o_bold
                          #443
                          @smokey sagte in Easee Wallbox mit iobroker:
                          Kommt bei mir auch öfters und heute früh bei mir auch. Ich glaube nicht, dass das am Adapter liegt. Bei Easee seint es mal wieder Probleme gegeben zu haben.
                          Seit 11:25 Uhr sind die errors weg.
                          • K K_o_bold
                            Smokey
                            #444
                            @k_o_bold sagte in Easee Wallbox mit iobroker:
                            stimmt... genau 11:25. Und jetzt 13:28 hatte ich sie noch mal.... ok, dann kann ich die lokale Fehlersuche aufgeben :) Danke!
                            • NewanN Newan
                              W Offline
                              W Offline
                              warp-it
                              #445
                              @newan said in Easee Wallbox mit iobroker:
                              Ich habe den easee Adpter 1.07 installiert. Wenn ich SignalR aktiviere, startet der Adaapter nicht mehr.
                              Unter Adapters wird mir kein Update angeboten.
                              Falls eine neuere Version existiert, so ist mir nicht klar, wie ich das Update anstoßen kann.
                              • W warp-it
                                k_b
                                #446
                                @warp-it sagte in Easee Wallbox mit iobroker:
                                Die aktuelle Version bekommst Du, wenn Du den Master von iobroker.easee installierst.
                                Das machst Du, indem Du im Expertenmodus bei Adapter auf die Katze gehst.
                                Dann mittleren Reiter "von Github" auswählen und easee als Stichwort eingeben.
                                "easee [newman]" auswählen. Dann hast Du noch keine Instanz. Die musst Du unter Adapter "easee" mit Hilfe des "+" hinzufügen.
                                Vorher natürlich die 1.0.7 löschen (Instanz und Adapter).
                                • K k_b
                                  W Offline
                                  W Offline
                                  warp-it
                                  #447
                                  @k_b
                                  Hmmm,
                                  habe Instanz und Adapter gelöscht, und von Github neu installiert.
                                  Versionsnummer ist noch immer 1.07 und mit SignalR stratet die Instanz nach wie vor nicht.
                                  Ohne SignalR startet sie.
                                  Was ist zu tun?
                                  • W warp-it
                                    @k_b
                                    Hmmm,
                                    Was ist zu tun?
                                    NewanN Offline
                                    NewanN Offline
                                    Newan
                                    #448
                                    @warp-it mal ein debug log posten ob man was sieht.
                                    Kann Adapter sein oder der eassee Server
                                    • NewanN Newan
                                      W Offline
                                      W Offline
                                      warp-it
                                      #449
                                      @newan @k_b Sorry,
                                      habe hoch gescrollt und nodejs von 16 auf 18 aktualisiert, und jetzt funktioniert auch SignalR.
                                      Vielen Dank für Eure Unterstützung.
                                        MHeymann
                                        schrieb am zuletzt editiert von MHeymann
                                        #450
                                        Hallo Zusammen,
                                        mein Logfile wird seit einiger Zeit alle zwei Minuten mit dem Fehler "undefined is not a valid state value" zu gespammt. Habe die Easee Box und denn Adapter jeweils neu gestartet. Aber leider keine Veränderung.
                                        Adapter Version: 1.0.7
                                        Wallbox Version: 310
                                        Weis jemand woran das liegen könnte bzw. wie ich die Fehlermeldung weg bekomme?
                                        LG Marko
                                        easee.0
                                        2023-06-27 19:43:55.901	error	undefined is not a valid state value
                                        easee.0
                                        2023-06-27 19:43:55.876	debug	{"isEnabled":true,"lockCablePermanently":true,"authorizationRequired":false,"remoteStartRequired":null,"smartButtonEnabled":false,"wiFiSSID":"XXX","detectedPowerGridType":1,"offlineChargingMode":null,"circuitMaxCurrentP1":16,"circuitMaxCurrentP2":16,"circuitMaxCurrentP3":16,"enableIdleCurrent":true,"limitToSinglePhaseCharging":null,"phaseMode":2,"localNodeType":1,"localAuthorizationRequired":false,"localRadioChannel":0,"localShortAddress":0,"localParentAddrOrNumOfNodes":0,"localPreAuthorizeEnabled":false,"localAuthorizeOfflineEnabled":true,"allowOfflineTxForUnknownId":true,"maxChargerCurrent":16,"ledStripBrightness":25,"chargingSchedule":""}
                                        easee.0
                                        2023-06-27 19:43:55.876	debug	Charger config ausgelesen mit id:
                                        easee.0
                                        2023-06-27 19:43:55.740	debug	{"smartCharging":true,"cableLocked":true,"chargerOpMode":2,"totalPower":0,"sessionEnergy":0,"energyPerHour":0,"wiFiRSSI":-58,"cellRSSI":-65,"localRSSI":null,"outputPhase":0,"dynamicCircuitCurrentP1":16,"dynamicCircuitCurrentP2":0,"dynamicCircuitCurrentP3":0,"chargerFirmware":310,"chargerRAT":1,"lockCablePermanently":true,"inCurrentT2":0,"inCurrentT3":0.007000000216066837,"inCurrentT4":0.008999999612569809,"inCurrentT5":0.007000000216066837,"outputCurrent":0,"inVoltageT1T2":null,"inVoltageT1T3":null,"inVoltageT1T4":null,"inVoltageT1T5":null,"inVoltageT2T3":220.14199829101562,"inVoltageT2T4":223.1719970703125,"inVoltageT2T5":222.67999267578125,"inVoltageT3T4":null,"inVoltageT3T5":null,"inVoltageT4T5":null,"ledMode":21,"cableRating":20,"dynamicChargerCurrent":0,"circuitTotalAllocatedPhaseConductorCurrentL1":0,"circuitTotalAllocatedPhaseConductorCurrentL2":0,"circuitTotalAllocatedPhaseConductorCurrentL3":0,"circuitTotalPhaseConductorCurrentL1":0.007000000216066837,"circuitTotalPhaseConductorCurrentL2":0.008999999612569809,"circuitTotalPhaseConductorCurrentL3":0.007000000216066837,"reasonForNoCurrent":52,"wiFiAPEnabled":false,"lifetimeEnergy":2700.030728333338,"offlineMaxCircuitCurrentP1":16,"offlineMaxCircuitCurrentP2":16,"offlineMaxCircuitCurrentP3":16,"errorCode":0,"fatalErrorCode":0,"eqAvailableCurrentP1":null,"eqAvailableCurrentP2":null,"eqAvailableCurrentP3":null,"deratedCurrent":null,"deratingActive":false,"connectedToCloud":true,"isOnline":true,"voltage":220.14199829101562,"latestPulse":"2023-06-27T17:40:47.983Z","errors":[]}
                                        easee.0
                                        2023-06-27 19:43:55.740	debug	Charger status ausgelesen mit id:
                                        easee.0
                                        2023-06-27 19:43:55.622	debug	Hole Energiedaten: 2
                                        easee.0
                                        2023-06-27 19:43:55.618	debug	{"id":"","name":"Wall","color":5,"createdOn":"2021-06-01T08:38:44.618192","updatedOn":"2022-05-22T11:24:52.667486","levelOfAccess":1,"productCode":1}
                                        easee.0
                                        2023-06-27 19:43:55.618	debug	Charger found
                                        easee.0
                                        2023-06-27 19:43:55.618	debug	[{"id":"","name":"Wall E","color":5,"createdOn":"2021-06-01T08:38:44.618192","updatedOn":"2022-05-22T11:24:52.667486","levelOfAccess":1,"productCode":1}]
                                        easee.0
                                        2023-06-27 19:43:55.618	debug	Chargers ausgelesen
                                        easee.0
                                        2023-06-27 19:43:55.508	debug	read new states from the API
                                        • M MHeymann
                                          Hallo Zusammen,
                                          LG Marko
                                          easee.0
                                          easee.0
                                          easee.0
                                          easee.0
                                          easee.0
                                          easee.0
                                          easee.0
                                          easee.0
                                          easee.0
                                          easee.0
                                          easee.0
                                          K_o_bold
                                          #451
                                          bin der einzige bei dem der Eassee Adaper folgende errors hat?
                                          Es passiert seit heute und ich habe nichts verändert.
                                          Die Eassee App läuft Problemlos
                                          easee.0
                                          2023-08-03 21:09:01.640	error	Request failed with status code 429
                                          easee.0
                                          2023-08-03 21:09:01.637	error	Api login error - check Username and password
