  4. Adapter Status Anzeige HOST und SLAVE unterschiedlich
20 Beiträge 3 Kommentatoren 2.1k Aufrufe
  • wendy2702W Online
    wendy2702W Online
    Hm,
    komisch. Wo liegt denn dann der Fehler?
    Muss ja dann etwas im iobroker.json sein wenn ich das richtig verstehe.
    Hier mal die beiden files:
    HOST:
    ! { "network": { "IPv4": true, "IPv6": true, "bindAddress": null, "useSystemNpm": true }, "objects": { "type": "file", "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].", "host": "0.0.0.0", "port": 9001, "user": "", "pass": "", "noFileCache": true, "connectTimeout": 2000 }, "states": { "type": "file", "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].", "host": "0.0.0.0", "port": 9000, "options": { "auth_pass": null, "retry_max_delay": 15000 } }, "log": { "level": "info", "maxDays": 7, "transport": { "file1": { "type": "file", "enabled": true, "filename": "log/iobroker", "fileext": ".log", "maxsize": null, "maxFiles": null } } }, "dataDirComment": "Always relative to iobroker.js-controller/", "dataDir": "../../iobroker-data/" } !
    Slave:
    ! cat iobroker.json { "system": { "memoryLimitMB": 0, "hostname": "" }, "network": { "IPv4": true, "IPv6": true, "bindAddress": null, "useSystemNpm": true }, "objects": { "type": "file", "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].", "host": "192.168.178.18", "port": 9001, "user": "", "pass": "", "noFileCache": false, "connectTimeout": 2000 }, "states": { "type": "file", "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].", "host": "192.168.178.18", "port": 9000, "maxQueue": 1000, "options": { "auth_pass": null, "retry_max_delay": 15000 } }, "log": { "level": "info", "maxDays": 7, "noStdout": true, "transport": { "file1": { "type": "file", "enabled": true, "filename": "log/iobroker", "fileext": ".log", "maxsize": null, "maxFiles": null }, "syslog1": { "type": "syslog", "enabled": false, "host": "localhost", "host_comment": "The host running syslogd, defaults to localhost.", "port_comment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).", "protocol": "udp4", "protocol_comment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).", "path_comment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).", "facility_comment": "Syslog facility to use (Default: local0).", "localhost": "iobroker", "localhost_comment": "Host to indicate that log messages are coming from (Default: localhost).", "sysLogType_comment": "The type of the syslog protocol to use (Default: BSD).", "app_name_comment": "The name of the application (Default: process.title).", "eol_comment": "The end of line character to be added to the end of the message (Default: Message without modifications)." } } }, "dataDirComment": "Always relative to iobroker.js-controller/", "dataDir": "../../iobroker-data/" }pi@pi-iobroker:/opt/iobroker/iobroker-data $ !
    REDIS ist doch kein "muss" oder? Kann mich nicht daran erinnern das damals konfiguriert zu haben.
      Sieht von der Konfig korrekt aus.
      @wendy2702:
      REDIS ist doch kein "muss" oder? Kann mich nicht daran erinnern das damals konfiguriert zu haben. `
      Nein ist kein muss, und selbst wenn du es konfiguriert hättest; mit den Werten, die du in iobroker setup custom eingegeben hast wäre es nicht benutzt.
      Welche Versionen js-controller hast du?
      • eric2905E Offline
        eric2905E Offline
        eric2905
        Der Admin auf dem Slave läuft doch gar nicht.
        Kannst Du ihn trotzdem mit <ip-slave>:8081 erreichen (nicht 192.168.178.18)?
        Gruß,
        Eric
        Von unterwegs getippert</ip-slave>
          @eric:
          in den Screenshots sind die IP-Adressen zu sehen.
          Erklär mir das mal ;-)
          • wendy2702W Online
            wendy2702W Online
            @eric2905:
            Gruß,
            Eric
            Von unterwegs getippert</ip-slave> `
            Auf dem Slave läuft der Admin.1
            Admin.0 läuft auf dem Host.
            • wendy2702W Online
              wendy2702W Online
              @Homoran:
              @wendy2702:
              Rainer `
              ~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201710 ... cc2274.jpg">https://uploads.tapatalk-cdn.com/20171001/342ea597ddebf19754ff1b997acc2274.jpg</link_text>" />
              Gesendet von iPhone mit Tapatalk Pro~~
              • eric2905E Offline
                eric2905E Offline
                eric2905
                @wendy2702:
                Auf dem Slave läuft der Admin.1 `
                Nein, er läuft nicht - siehe roter „Play-Button“.
                Mach mal bitte einen breiteren Screenshot vom Reiter Instanzen, wo man den Admin des Slaves sieht und welchem Host er zugewiesen ist.
                Wie hast Du denn den Multihost aufgesetzt?
                Nackte ioBroker-Installation an den Master gekoppelt, oder ein bereits benutztes System (weitere Instanzen aktiv, Daten vorhanden, usw.)?
                Gruß,
                Eric
                  @eric2905:
                  @wendy2702:
                  Auf dem Slave läuft der Admin.1 Nein, er läuft nicht - siehe roter „Play-Button“.
                  Doch, der Admin.1 ist grün.
                  warum hast du da zwei admins drauf.
                  damit kannst du natürlich (evtl.??) das gesamte System aushebeln.
                  @eric2905:
                  Nackte ioBroker-Installation an den Master gekoppelt, oder ein bereits benutztes System (weitere Instanzen aktiv, Daten vorhanden, usw.)? `
                  Das ist natürlich interessant!
                  • eric2905E Offline
                    eric2905E Offline
                    eric2905
                    Deswegen wollte ich den Breiteren Screenshot haben, wo man die Host-Zuordnung sieht.
                    • wendy2702W Online
                      wendy2702W Online
                      Ähem… jetzt gerade zurück vom Gassi gehen und auf beiden Systemen ist der Status jetzt gleich.
                      Hier erstmal die Screenshots:
                      Host:
                      Slave:
                      Wie habe ich das System aufgesetzt:
                      iobroker Host läuft schon länger, dann ende 2016 einen PI3 als Slave nach der damaligen Anleitung dazu konfiguriert.
                        @wendy2702:
                        dann ende 2016 einen PI3 als Slave nach der damaligen Anleitung dazu konfiguriert. `
                        … und dann erst über den Master die Instanzen auf dem Slave erzeugt?
                        • wendy2702W Online
                          wendy2702W Online
                          @Homoran:
                          @wendy2702:
                          Rainer `
                          Wenn ich mich richtig erinnere ja.
                            Dann bleibt nur noch die Frage warum da zwei admin-Adapter sind.
                            • wendy2702W Online
                              wendy2702W Online
                              Kann ich den denn auf dem Slave "einfach" löschen?
                              Oder sollte ich den lieber neu aufsetzen?
                                Jetzt verläßt mich mein Wissen.
                                Fakt ist:
                                • Der Slave bekommt offline (= ohne Bindung an den Master) seine eigene ioBroker Installation. Diese enthält u.a. einen admin.
                                • dann erst wird der Slave per iobroker setup custom an den Master gebunden
                                • der admin des Slave taucht nicht mehr auf
                                Ich habe keine Ahnung was mit den Adaptern auf dem Maste passiert, wenn du den Slave neu aufbaust und die dortigen Instanzen auf einmal weg sind
                                  • na gut habe ich auch schon mal gemacht, ich glaube die werden anschließend "hot pluggable" wieder auf dem Slave installiert.
                                Aber bei dir werden nach abmelden des Slaves trotzdem beide admin weiterhin auf dem Master zu sehen sein.
                                ICH würde folgendermaßen Vorgehen:
                                • Backup des MAsters über die Konsole (sudo iobroker backup)
                                • Löschen des admin.1
                                  • sehen was dann ist.
                                • wendy2702W Online
                                  wendy2702W Online
                                  Ok. Werde ich die Tage mal versuchen
