  3. Einsteigerfragen
  4. MQTT Server sendet nur einmal
    5.5k
7 Beiträge 2 Kommentatoren 386 Aufrufe 2 Beobachtet
  • Y Offline
    Y Offline
    YARD2
    Ich habe ein kleines Problem mit dem MQTT Server.
    Er sendet den geänderten Zustand nicht an die Clients.
    Beim Verbinden sendet er 1x (MQTTX) oder 3x (mqttExplorer, aber einen alten Wert, dann nie wieder.
    Egal ob ich nur das Topic oder alles (#) subscribe.
    Habe den IObroker auch neu installiert (Windows Version 6.3.5 mit Installer 2.2.1).
    Ne Idee woran das liegen könnte ?
    mqttExplorer
    _______________________
    2023-05-06 19:02:30.086 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] connected with secret 1683392550080_6810
    2023-05-06 19:02:30.088 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] with keepalive 60 set timeout to 90 seconds
    2023-05-06 19:02:30.098 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] received subscribe package {"cmd":"subscribe","retain":false,"qos":1,"dup":false,"length":6,"topic":null,"payload":null,"subscriptions":[{"topic":"#","qos":0}],"messageId":24694}
    2023-05-06 19:02:30.099 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] Handle subscribe: {"topic":"#","qos":0}
    2023-05-06 19:02:30.101 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] subscribes on "#" with regex /.*/
    2023-05-06 19:02:30.102 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] subscribes on "#" with regex /^mqtt\.0(\..*)?/
    2023-05-06 19:02:30.105 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] received subscribe package {"cmd":"subscribe","retain":false,"qos":1,"dup":false,"length":11,"topic":null,"payload":null,"subscriptions":[{"topic":"$SYS/#","qos":0}],"messageId":24695}
    2023-05-06 19:02:30.106 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] Handle subscribe: {"topic":"$SYS/#","qos":0}
    2023-05-06 19:02:30.107 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] subscribes on "$SYS/#" with regex /^\$SYS(\..*)?/
    2023-05-06 19:02:30.108 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] subscribes on "$SYS/#" with regex /^mqtt\.0\.\$SYS(\..*)?/
    2023-05-06 19:02:30.128 - debug: mqtt.0 (5032) stateChange mqtt.0.info.connection: {"val":"mqtt.mqtt.0,mqtt-explorer-9f9587cc","ack":true,"ts":1683392550120,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1683392550120}
    2023-05-06 19:02:30.313 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] publishOnSubscribe send all known states
    2023-05-06 19:02:30.315 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] send to this client "info/connection": mqtt.mqtt.0
    2023-05-06 19:02:30.317 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] send to this client "smartmeter/0/1-0:16_7_0__255/value": 396
    2023-05-06 19:02:30.319 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] publishOnSubscribe send all known states
    2023-05-06 19:02:30.321 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] send to this client "info/connection": mqtt.mqtt.0
    2023-05-06 19:02:30.322 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] send to this client "smartmeter/0/1-0:16_7_0__255/value": 396
    2023-05-06 19:02:31.073 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":405,"ack":true,"ts":1683392551060,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683392551060}
    2023-05-06 19:02:32.098 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] send to this client "info/connection": mqtt.mqtt.0
    2023-05-06 19:02:32.113 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] send to this client "smartmeter/0/1-0:16_7_0__255/value": 396
    2023-05-06 19:02:34.031 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":406,"ack":true,"ts":1683392554018,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683392554018}
    2023-05-06 19:02:37.022 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":394,"ack":true,"ts":1683392557010,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683392557010}
    2023-05-06 19:02:38.393 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] connection closed: disconnected
    2023-05-06 19:02:38.411 - debug: mqtt.0 (5032) stateChange mqtt.0.info.connection: {"val":"mqtt.mqtt.0","ack":true,"ts":1683392558403,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1683392558403}
    2023-05-06 19:02:40.017 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":397,"ack":true,"ts":1683392560004,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683392560004}
    2023-05-06 19:02:43.016 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":380,"ack":true,"ts":1683392563004,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683392563004}
    2023-05-06 19:02:46.017 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":375,"ack":true,"ts":1683392566005,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683392566005}
    2023-05-06 19:02:49.013 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":386,"ack":true,"ts":1683392569001,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683392569001}
    MQTTX
    ________________________________
    2023-05-06 19:16:57.999 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3216,"ack":true,"ts":1683393417995,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393417995}
    2023-05-06 19:17:01.000 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3223,"ack":true,"ts":1683393420995,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393420995}
    2023-05-06 19:17:03.995 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3230,"ack":true,"ts":1683393423991,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393423991}
    2023-05-06 19:17:06.984 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":1463,"ack":true,"ts":1683393426980,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393426980}
    2023-05-06 19:17:09.985 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2373,"ack":true,"ts":1683393429980,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393429980}
    2023-05-06 19:17:12.392 - info: mqtt.0 (5032) Client [mqttx_e52458bc] connected with secret 1683393432390_1044
    2023-05-06 19:17:12.395 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] with keepalive 60 set timeout to 90 seconds
    2023-05-06 19:17:12.409 - debug: mqtt.0 (5032) stateChange mqtt.0.info.connection: {"val":"mqtt.mqtt.0,mqttx_e52458bc","ack":true,"ts":1683393432403,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1683393432403}
    2023-05-06 19:17:12.435 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] received subscribe package {"cmd":"subscribe","retain":false,"qos":1,"dup":false,"length":6,"topic":null,"payload":null,"subscriptions":[{"topic":"#","qos":0}],"messageId":19888}
    2023-05-06 19:17:12.437 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] Handle subscribe: {"topic":"#","qos":0}
    2023-05-06 19:17:12.438 - info: mqtt.0 (5032) Client [mqttx_e52458bc] subscribes on "#" with regex /.*/
    2023-05-06 19:17:12.439 - info: mqtt.0 (5032) Client [mqttx_e52458bc] subscribes on "#" with regex /^mqtt\.0(\..*)?/
    2023-05-06 19:17:12.640 - info: mqtt.0 (5032) Client [mqttx_e52458bc] publishOnSubscribe send all known states
    2023-05-06 19:17:12.642 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] send to this client "info/connection": mqtt.mqtt.0
    2023-05-06 19:17:12.643 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] send to this client "smartmeter/0/1-0:16_7_0__255/value": 396
    2023-05-06 19:17:13.015 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2562,"ack":true,"ts":1683393433010,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393433010}
    2023-05-06 19:17:14.395 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] send to this client "info/connection": mqtt.mqtt.0
    2023-05-06 19:17:14.406 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] send to this client "smartmeter/0/1-0:16_7_0__255/value": 396
    2023-05-06 19:17:16.002 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2578,"ack":true,"ts":1683393435997,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393435997}
    2023-05-06 19:17:19.000 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2577,"ack":true,"ts":1683393438995,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393438995}
    2023-05-06 19:17:21.999 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2583,"ack":true,"ts":1683393441994,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393441994}
    2023-05-06 19:17:24.985 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2576,"ack":true,"ts":1683393444980,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393444980}
    2023-05-06 19:17:27.985 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2553,"ack":true,"ts":1683393447980,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393447980}
    2023-05-06 19:17:31.045 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2542,"ack":true,"ts":1683393451040,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393451040}
    2023-05-06 19:17:34.012 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2554,"ack":true,"ts":1683393454006,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393454006}
    2023-05-06 19:17:36.993 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2557,"ack":true,"ts":1683393456988,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393456988}
    2023-05-06 19:17:39.987 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2554,"ack":true,"ts":1683393459982,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393459982}
    2023-05-06 19:17:42.992 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2562,"ack":true,"ts":1683393462986,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393462986}
    2023-05-06 19:17:45.985 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":1463,"ack":true,"ts":1683393465980,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393465980}
    2023-05-06 19:17:48.999 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3193,"ack":true,"ts":1683393468994,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393468994}
    2023-05-06 19:17:52.012 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3197,"ack":true,"ts":1683393472007,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393472007}
    2023-05-06 19:17:54.988 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3206,"ack":true,"ts":1683393474980,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393474980}
    2023-05-06 19:17:57.986 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3205,"ack":true,"ts":1683393477981,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393477981}
    2023-05-06 19:18:00.206 - debug: mqtt.0 (5032) Client [mqtt.mqtt.0] pingreq
    2023-05-06 19:18:01.005 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3199,"ack":true,"ts":1683393481000,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393481000}
    2023-05-06 19:18:04.050 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3202,"ack":true,"ts":1683393484044,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393484044}
    2023-05-06 19:18:06.983 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3178,"ack":true,"ts":1683393486978,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393486978}
    2023-05-06 19:18:09.986 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3183,"ack":true,"ts":1683393489981,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393489981}
    2023-05-06 19:18:12.984 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":1483,"ack":true,"ts":1683393492979,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393492979}
    2023-05-06 19:18:13.436 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] pingreq
    2023-05-06 19:18:15.988 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":1510,"ack":true,"ts":1683393495983,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393495983}
    • Y YARD2
      mqttExplorer
      MQTTX
      Marc BergM Offline
      Marc BergM Offline
      Marc Berg
      @yard2 zeig mal die Einstellungen der Instanz "mqtt.0"
      • Y Offline
        Y Offline
        YARD2
        Hab schon einige settings probiert.
        • Y YARD2
          Marc BergM Offline
          Marc BergM Offline
          Marc Berg
          @yard2 Da deine Datenpunkte mit "ack" geändert werden.
          müsste das hier aktiviert werden:
          Y 1 Antwort Letzte Antwort
          • Marc BergM Marc Berg
            Y Offline
            Y Offline
            YARD2
            schrieb am zuletzt editiert von YARD2
            @marc-berg
            Oh Mann. Danke das wars.
            Die Option hatte ich nicht ausprobiert ;-)
            Nur warum steht da ack drin. Macht evtl der Smartmeter.
            • Y YARD2
              @marc-berg
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              @yard2 sagte in MQTT Server sendet nur einmal:
              Gibt's dazu nicht einen Adapter oder wer schreibt dort Werte?
                Y Offline
                Y Offline
                YARD2
                @marc-berg
                Ich nutze den SmartMeter Adapter
