  3. Einsteigerfragen
  4. Fehler im ioBroker
    5.9k
    1.5k
Fehler im ioBroker
43 Beiträge 3 Kommentatoren 18.5k Aufrufe 3 Beobachtet
    Tomme
    moin moin Jungs und Mädels!
    ich bin Frischling und hab da mal ne Frage ...
    ich habe folgende Fehler in meiner iobroker Installation und weiß nicht ob die problematisch sind ... kann jemand dazu was sagen? kann ich das so lassen oder muß ich irgendwas neu installieren?
    pi@ioBrokerPi:/opt/iobroker $ npm prune
    npm WARN skipping integrity check for git dependency ssh://git@github.com/motuditli/ioBroker.solarwetter.git
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    removed 863 packages, and changed 71 packages in 4m
    145 packages are looking for funding
      run `npm fund` for details
    pi@ioBrokerPi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
    npm ERR! invalid: iobroker.solarwetter@1.0.2 /opt/iobroker/node_modules/iobroker.solarwetter
    npm ERR! extraneous: is-nan@1.3.2 /opt/iobroker/node_modules/is-nan
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
    npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    ├── iobroker.reolink@0.1.1 (git+ssh://git@github.com/aendue/ioBroker.reolink.git#b78aab6744cdb81b360fd947a9c6e2fd6808bab1)
    ├── iobroker.solarwetter@1.0.2 invalid: "github:motuditli/ioBroker.solarwetter#c5d340e2b3e021951a88c44a89f6219624c97a15" from the root project
    npm ERR!     /home/iobroker/.npm/_logs/2023-04-27T19_10_17_300Z-debug-0.log
    Ich hoffe ich muß ihn nicht neu installieren ... für eure Bemühungen vielen Dank!
    es grüßt der Tomme!
    T CodierknechtC 2 Antworten Letzte Antwort
    • T Tomme
      es grüßt der Tomme!
      Tomme
      und das kommt bei npm audit dazu
      pi@ioBrokerPi:/opt/iobroker $ npm audit fix --force
      npm WARN using --force Recommended protections disabled.
      npm WARN audit Updating iobroker.js-controller to 1.3.0, which is a SemVer major change.
      npm WARN audit No fix available for iobroker.javascript@*
      npm WARN audit Updating iobroker.backitup to 0.2.7, which is a SemVer major change.
      npm WARN audit No fix available for iobroker.nina@*
      npm WARN audit No fix available for iobroker.solarwetter@*
      npm WARN audit Updating iobroker.cloud to 4.0.10, which is a SemVer major change.
      npm WARN audit Updating iobroker.discovery to 0.4.0, which is a SemVer major change.
      npm WARN audit Updating iobroker.loxone to 2.2.3, which is a SemVer major change.
      npm WARN audit Updating iobroker.node-red to 1.2.0, which is a SemVer major change.
      npm WARN audit Updating iobroker.samsung to 0.2.9, which is a SemVer major change.
      npm WARN audit Updating iobroker.yahka to 0.16.0, which is a SemVer major change.
      removed 863 packages, changed 61 packages, and audited 1450 packages in 3m
      # npm audit report
      axios  <=0.21.1
      Severity: high
      Axios vulnerable to Server-Side Request Forgery - https://github.com/advisories/GHSA-4w2v-q235-vp99
      axios Inefficient Regular Expression Complexity vulnerability - https://github.com/advisories/GHSA-cph5-m8f7-6c5x
      Depends on vulnerable versions of follow-redirects
      fix available via `npm audit fix --force`
      Will install iobroker.loxone@2.2.3, which is a breaking change
      node_modules/lxcommunicator/node_modules/axios
        lxcommunicator  *
        Depends on vulnerable versions of axios
          iobroker.loxone  >=3.0.0
          Depends on vulnerable versions of lxcommunicator
          node_modules/iobroker.loxone
      debug  <=2.6.8
      Severity: high
      debug Inefficient Regular Expression Complexity vulnerability - https://github.com/advisories/GHSA-9vvw-cc9w-f27h
      Regular Expression Denial of Service in debug - https://github.com/advisories/GHSA-gxpj-cx7g-858c
      Depends on vulnerable versions of ms
      Will install iobroker.discovery@0.4.0, which is a breaking change
      node_modules/engine.io-client/node_modules/debug
      node_modules/engine.io/node_modules/debug
      node_modules/mdns-discovery/node_modules/debug
      node_modules/socket.io-adapter/node_modules/debug
      node_modules/socket.io-client/node_modules/debug
      node_modules/socket.io-parser/node_modules/debug
      node_modules/socket.io/node_modules/debug
        engine.io  <=3.6.0
        Depends on vulnerable versions of debug
          socket.io  <=2.4.1
          Depends on vulnerable versions of engine.io
          Depends on vulnerable versions of socket.io-adapter
          Depends on vulnerable versions of socket.io-client
          Depends on vulnerable versions of socket.io-parser
            node-red-contrib-polymer  *
            node_modules/node-red-contrib-polymer
              iobroker.node-red  >=1.4.0
              Depends on vulnerable versions of node-red
              Depends on vulnerable versions of node-red-contrib-polymer
              Depends on vulnerable versions of node-red-node-feedparser
              Depends on vulnerable versions of node-red-node-twitter
              node_modules/iobroker.node-red
        engine.io-client  <=3.1.1
        Depends on vulnerable versions of parsejson
          socket.io-client  1.0.0-pre - 2.1.1
          Depends on vulnerable versions of engine.io-client
            iobroker.cloud  <=2.4.6 || 2.8.0 - 3.0.2 || >=4.0.11
            node_modules/iobroker.cloud
        mdns-discovery  >=0.1.1
          iobroker.discovery  >=0.4.4
          Depends on vulnerable versions of mdns-discovery
          node_modules/iobroker.discovery
        socket.io-adapter  <=1.1.0
        socket.io-parser  <=3.3.2
      follow-redirects  <=1.14.7
      Severity: high
      Exposure of Sensitive Information to an Unauthorized Actor in follow-redirects - https://github.com/advisories/GHSA-pw2r-vq6v-hr8c
      Exposure of sensitive information in follow-redirects - https://github.com/advisories/GHSA-74fj-2j2h-c42q
      node_modules/lxcommunicator/node_modules/follow-redirects
      jsonwebtoken  <=8.5.1
      Severity: moderate
      jsonwebtoken unrestricted key type could lead to legacy keys usage  - https://github.com/advisories/GHSA-8cf7-32gw-wr33
      jsonwebtoken's insecure implementation of key retrieval function could lead to Forgeable Public/Private Tokens from RSA to HMAC - https://github.com/advisories/GHSA-hjrf-2m68-5959
      jsonwebtoken vulnerable to signature validation bypass due to insecure default algorithm in jwt.verify() - https://github.com/advisories/GHSA-qwph-4952-7xr6
      No fix available
      node_modules/jsonwebtoken
        @iobroker/js-controller-adapter  <=5.0.0-alpha.0-20221230-c7ef56a8
        Depends on vulnerable versions of @iobroker/db-objects-file
        Depends on vulnerable versions of @iobroker/db-objects-jsonl
        Depends on vulnerable versions of @iobroker/db-objects-redis
        Depends on vulnerable versions of @iobroker/db-states-file
        Depends on vulnerable versions of @iobroker/db-states-jsonl
        Depends on vulnerable versions of @iobroker/db-states-redis
        Depends on vulnerable versions of @iobroker/js-controller-common
        Depends on vulnerable versions of jsonwebtoken
        node_modules/@iobroker/js-controller-adapter
          iobroker.js-controller  *
          Depends on vulnerable versions of @iobroker/js-controller-adapter
          Depends on vulnerable versions of @iobroker/js-controller-cli
          Depends on vulnerable versions of @iobroker/js-controller-common-db
          Depends on vulnerable versions of le-acme-core
          Depends on vulnerable versions of request
          node_modules/iobroker.js-controller
        @iobroker/js-controller-common  <=5.0.0-alpha.0-20221230-c7ef56a8
        node_modules/@iobroker/js-controller-common
          @iobroker/db-base  4.0.0-alpha.1-20210830-d9828cd3 - 4.1.0-alpha.3-20220302-91ae5b6c
          node_modules/@iobroker/db-base
            @iobroker/db-objects-file  4.0.0-alpha.1-20210830-d9828cd3 - 4.1.0-alpha.3-20220302-91ae5b6c
            Depends on vulnerable versions of @iobroker/db-base
            node_modules/@iobroker/db-objects-file
            @iobroker/db-objects-jsonl  4.0.0-alpha.1-20210830-d9828cd3 - 4.1.0-alpha.3-20220302-91ae5b6c
            node_modules/@iobroker/db-objects-jsonl
            @iobroker/db-objects-redis  4.0.0-alpha.1-20210830-d9828cd3 - 4.1.0-alpha.3-20220302-91ae5b6c
            node_modules/@iobroker/db-objects-redis
            @iobroker/db-states-file  4.0.0-alpha.1-20210830-d9828cd3 - 4.1.0-alpha.3-20220302-91ae5b6c
            node_modules/@iobroker/db-states-file
            @iobroker/db-states-jsonl  4.0.0-alpha.1-20210830-d9828cd3 - 4.1.0-alpha.3-20220302-91ae5b6c
            node_modules/@iobroker/db-states-jsonl
            @iobroker/db-states-redis  4.0.0-alpha.1-20210830-d9828cd3 - 4.1.0-alpha.3-20220302-91ae5b6c
            node_modules/@iobroker/db-states-redis
          @iobroker/js-controller-cli  <=4.1.0-alpha.3-20220302-91ae5b6c
          node_modules/@iobroker/js-controller-cli
          @iobroker/js-controller-common-db  <=4.1.0-alpha.3-20220302-91ae5b6c
          node_modules/@iobroker/js-controller-common-db
      moment-timezone  0.1.0 - 0.5.34
      Severity: moderate
      Command Injection in moment-timezone - https://github.com/advisories/GHSA-56x4-j7p9-fcf9
      Cleartext Transmission of Sensitive Information in moment-timezone - https://github.com/advisories/GHSA-v78c-4p63-2j6c
      Will install iobroker.node-red@1.10.1, which is a breaking change
      node_modules/moment-timezone
        @node-red/util  1.2.4 - 3.0.2
        Depends on vulnerable versions of moment-timezone
        node_modules/@node-red/util
          @node-red/editor-api  1.2.4 - 3.0.2
          Depends on vulnerable versions of @node-red/util
          node_modules/@node-red/editor-api
          @node-red/registry  1.2.4 - 3.0.2
          node_modules/@node-red/registry
          @node-red/runtime  1.2.4 - 3.0.2
          Depends on vulnerable versions of @node-red/registry
          node_modules/@node-red/runtime
          node-red  >=0.20.0-beta.2
          Depends on vulnerable versions of @node-red/editor-api
          Depends on vulnerable versions of @node-red/nodes
          Depends on vulnerable versions of @node-red/runtime
      ms  <2.0.0
      Severity: moderate
      Vercel ms Inefficient Regular Expression Complexity vulnerability - https://github.com/advisories/GHSA-w9mr-4mfr-499f
      node_modules/engine.io-client/node_modules/ms
      node_modules/engine.io/node_modules/ms
      node_modules/mdns-discovery/node_modules/ms
      node_modules/socket.io-adapter/node_modules/ms
      node_modules/socket.io-client/node_modules/ms
      node_modules/socket.io-parser/node_modules/ms
      node_modules/socket.io/node_modules/ms
      node-forge  <=1.2.1
      Severity: high
      Prototype Pollution in node-forge debug API. - https://github.com/advisories/GHSA-5rrq-pxf6-6jx5
      Prototype Pollution in node-forge util.setPath API - https://github.com/advisories/GHSA-wxgw-qj99-44c2
      URL parsing in node-forge could lead to undesired behavior. - https://github.com/advisories/GHSA-gf8q-jrpm-jvxq
      Improper Verification of Cryptographic Signature in `node-forge` - https://github.com/advisories/GHSA-2r2c-g63r-vccr
      Open Redirect in node-forge - https://github.com/advisories/GHSA-8fr3-hfg3-gpgp
      Improper Verification of Cryptographic Signature in node-forge - https://github.com/advisories/GHSA-cfm4-qjh2-4765
      Improper Verification of Cryptographic Signature in node-forge - https://github.com/advisories/GHSA-x4jg-mjrx-434g
      Prototype Pollution in node-forge - https://github.com/advisories/GHSA-92xj-mqp7-vmcj
      fix available via `npm audit fix`
      node_modules/rsa-compat/node_modules/node-forge
        rsa-compat  <=1.9.4
        Depends on vulnerable versions of node-forge
      parsejson  *
      Severity: high
      Regular Expression Denial of Service in parsejson - https://github.com/advisories/GHSA-q75g-2496-mxpp
      Will install iobroker.cloud@4.0.10, which is a breaking change
      node_modules/parsejson
      request  *
      Severity: moderate
      Server-Side Request Forgery in Request - https://github.com/advisories/GHSA-p8p7-x288-28g6
      No fix available
      node_modules/request
        dropbox-v2-api  *
        node_modules/dropbox-v2-api
        iobroker.backitup  >=0.3.0
        Depends on vulnerable versions of dropbox-v2-api
        node_modules/iobroker.backitup
        iobroker.javascript  *
        node_modules/iobroker.javascript
        iobroker.nina  *
        node_modules/iobroker.nina
        iobroker.solarwetter  *
        le-acme-core  *
        Depends on vulnerable versions of rsa-compat
        node_modules/le-acme-core
        node-red-node-feedparser  *
        node_modules/node-red-node-feedparser
        node-red-node-twitter  >=0.0.4
        node_modules/node-red-node-twitter
        request-promise  >=0.0.2
        Depends on vulnerable versions of request-promise-core
        node_modules/request-promise
          samsungtv
          node_modules/samsungtv
            iobroker.samsung  >=0.5.1
            Depends on vulnerable versions of samsungtv
            node_modules/iobroker.samsung
        request-promise-core  *
        node_modules/request-promise-core
      xml2js  <0.5.0
      Severity: moderate
      xml2js is vulnerable to prototype pollution  - https://github.com/advisories/GHSA-776f-qx25-q3cc
      Will install iobroker.yahka@0.16.0, which is a breaking change
      node_modules/xml2js
        @homebridge/dbus-native  *
        Depends on vulnerable versions of xml2js
        node_modules/@homebridge/dbus-native
          hap-nodejs  >=0.10.0-beta.0
          Depends on vulnerable versions of @homebridge/dbus-native
          node_modules/hap-nodejs
            iobroker.yahka  0.15.0 || >=0.17.0
            Depends on vulnerable versions of hap-nodejs
            node_modules/iobroker.yahka
        @node-red/nodes  *
        node_modules/@node-red/nodes
      57 vulnerabilities (5 low, 38 moderate, 13 high, 1 critical)
      To address issues that do not require attention, run:
        npm audit fix
      To address all issues possible (including breaking changes), run:
      Some issues need review, and may require choosing
      a different dependency.
      *** Fehlercode: 1 ***
      • T Tomme
        es grüßt der Tomme!
        CodierknechtC Offline
        Codierknecht
        @tomme sagte in Fehler im ioBroker:
        Wie hast Du den denn installiert?
        Das sieht mir schon äußerst suspekt aus.
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
        T Thomas BraunT 3 Antworten Letzte Antwort
        • CodierknechtC Codierknecht
          Tomme
          schrieb am zuletzt editiert von Tomme
          @codierknecht
          ich habe bei dieser xten Version in der ich alles neu aufgesetzt habe nur das skript geladen und ausgeführt lief bisher optisch alles fehlerfrei durch auch die adapterinstallationen ... der Großteil läuft auch ...
          # node installieren für iobroker
          sudo apt-get update && sudo apt-get upgrade
          cd
          curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash - # Ungerade Node.js Versionen dürfen nicht verwendet werden.
          sudo apt-get install -y nodejs
          sudo apt-get install npm
          cd
          . .bashrc # liest die user bashrc in der geöffneten Konsole neu ein
          sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null # listet die Verzeichnisse auf
          uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          sudo apt-get update && sudo apt-get upgrade && sudo apt-get full-upgrade && sudo npm audit fix --force
          curl -sLf https://iobroker.net/install.sh | bash - # ioBroker Installationsskript
          cd
            Tomme
            @codierknecht
            und dann die adapter installiert mit ihren instanzen und davor gab es keine Fehler npm audit ist ohne Fehler durch gelaufen
            pi@ioBrokerPi:/opt/iobroker $ iob update
            Used repository: stable
            Adapter    "alarm"        : 3.3.9    , installed 3.3.9
            Adapter    "backitup"     : 2.6.19   , installed 2.6.19
            Adapter    "bmw"          : 2.5.7    , installed 2.5.7
            Adapter    "cloud"        : 4.3.0    , installed 4.4.1
            Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
            Adapter    "geofency"     : 1.2.4    , installed 1.2.4
            Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
            Adapter    "homekit-controller": 0.5.8, installed 0.5.8
            Adapter    "javascript"   : 6.1.4    , installed 6.1.4
            Adapter    "landroid"     : 1.0.3    , installed 1.0.3
            Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
            Adapter    "loxone"       : 3.0.1    , installed 3.0.1
            Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
            Adapter    "nina"         : 0.0.25   , installed 0.0.25
            Adapter    "node-red"     : 4.0.0    , installed 4.0.3
            Adapter    "samsung"      : 0.5.11   , installed 0.5.11
            Adapter    "solarwetter"  : 1.0.0    , installed 1.0.2
            Adapter    "weatherunderground": 3.4.2, installed 3.4.2
            Adapter    "worx"         : 2.1.3    , installed 2.1.3
            Adapter    "yahka"        : 0.17.0   , installed 0.17.0
            • T Tomme
              @codierknecht
              Codierknecht
              @tomme
              Was sagt denn
              iob diag
                @tomme
                Was sagt denn
                iob diag
                Tomme
                @codierknecht said in Fehler im ioBroker:
                iob diag
                Teil 1
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Model           : Raspberry Pi 4 Model B Rev 1.5
                Architecture    : aarch64
                Docker          : false
                Virtualization  : none
                Distributor ID: Debian
                Description:    Debian GNU/Linux 11 (bullseye)
                Release:        11
                Codename:       bullseye
                PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                NAME="Debian GNU/Linux"
                VERSION_ID="11"
                VERSION="11 (bullseye)"
                VERSION_CODENAME=bullseye
                ID=debian
                HOME_URL="https://www.debian.org/"
                SUPPORT_URL="https://www.debian.org/support"
                BUG_REPORT_URL="https://bugs.debian.org/"
                Systemuptime and Load:
                 21:58:49 up 1 day, 20:28,  4 users,  load average: 0.46, 0.33, 0.34
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                Other values than 0x0 hint to temperature/voltage problems
                temp=54.0'C
                volt=0.9260V
                *** Time and Time Zones ***
                               Local time: Thu 2023-04-27 21:58:50 CEST
                           Universal time: Thu 2023-04-27 19:58:50 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server:       true
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            7.8G        2.5G        1.5G         78M        3.7G        5.0G
                Swap:           3.7G          0B        3.7G
                Total:           11G        2.5G        5.2G
                         7811 M total memory
                         2550 M used memory
                         3142 M active memory
                         2003 M inactive memory
                         1513 M free memory
                          328 M buffer memory
                         3418 M swap cache
                         3683 M total swap
                            0 M used swap
                         3683 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                Filesystem               Type      Size  Used Avail Use% Mounted on
                /dev/root                ext4       24G  8.1G   15G  36% /
                devtmpfs                 devtmpfs  3.6G     0  3.6G   0% /dev
                tmpfs                    tmpfs     3.9G     0  3.9G   0% /dev/shm
                tmpfs                    tmpfs     1.6G  1.4M  1.6G   1% /run
                tmpfs                    tmpfs     5.0M  4.0K  5.0M   1% /run/lock
                /dev/sda1                vfat      255M   31M  225M  13% /boot
                tmpfs                    tmpfs     782M   36K  782M   1% /run/user/1000
                /dev/sda4                fuseblk  1000M  321M  680M  33% /media/pi/Austausch-USB
                /dev/mmcblk0p4           ext4       12G  312M   11G   3% /media/pi/Austausch-SD
                /dev/mmcblk0p2           ext4       14G   11G  2.1G  84% /media/pi/writable
                /dev/mmcblk0p1           vfat      253M  120M  133M  48% /media/pi/system-boot
                //192.168.7.1/BackItUp   cifs      238G  183G   55G  77% /opt/iobroker/backups
                //192.168.7.1/BackItUp/  cifs      238G  183G   55G  77% /opt/iobroker/backups
                //192.168.7.1/ioBrokerPi cifs      238G  183G   55G  77% /mnt/LaptopIoBrokerPi
                [Wed Apr 26 01:30:03 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0A:D6:44 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=ee423409-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                [Wed Apr 26 01:30:06 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                [Wed Apr 26 01:30:06 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                [Wed Apr 26 01:30:08 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                [Wed Apr 26 01:30:33 2023] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Quota mode: none.
                [Wed Apr 26 01:30:34 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                TARGET                    SOURCE                   FSTYPE  OPTIONS
                /                         /dev/sda2                ext4    rw,noatime
                |-/boot                   /dev/sda1                vfat    rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                |-/mnt/LaptopIoBrokerPi   //192.168.7.1/ioBrokerPi cifs    rw,relatime,vers=2.1,cache=strict,username=Tomme,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.7.1,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                |-/media/pi/Austausch-USB /dev/sda4                fuseblk rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096
                |-/media/pi/Austausch-SD  /dev/mmcblk0p4           ext4    rw,nosuid,nodev,relatime,errors=remount-ro
                |-/media/pi/writable      /dev/mmcblk0p2           ext4    rw,nosuid,nodev,relatime,errors=remount-ro
                |-/media/pi/system-boot   /dev/mmcblk0p1           vfat    rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro
                `-/opt/iobroker/backups   //192.168.7.1/BackItUp   cifs    rw,relatime,vers=2.1,cache=strict,username=Tomme,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.7.1,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                  `-/opt/iobroker/backups //192.168.7.1/BackItUp/  cifs    rw,relatime,vers=2.0,cache=strict,username=Tomme,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.7.1,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                /var:
                1.2G    /var/
                491M    /var/cache
                482M    /var/cache/apt
                381M    /var/cache/apt/archives
                326M    /var/log
                Archived and active journals take up 304.1M in the file system.
                /opt/iobroker/backups:
                6.2M    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                269M    /opt/iobroker/iobroker-data/
                132M    /opt/iobroker/iobroker-data/node-red/node_modules
                91M     /opt/iobroker/iobroker-data/files
                51M     /opt/iobroker/iobroker-data/files/javascript.admin
                14M     /opt/iobroker/iobroker-data/objects.jsonl
                11M     /opt/iobroker/iobroker-data/states.jsonl
                7.8M    /opt/iobroker/iobroker-data/files/homekit-controller.admin/static/js/main.52e68e8c.js
                6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v18.16.0
                /usr/bin/node           v18.16.0
                /usr/bin/npm            9.5.1
                /usr/bin/npx            9.5.1
                nodejs:
                  Installed: 18.16.0-deb-1nodesource1
                  Candidate: 18.16.0-deb-1nodesource1
                  Version table:
                 *** 18.16.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                     12.22.12~dfsg-1~deb11u3 500
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                     12.22.5~dfsg-2~11u1 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                No problems detected
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  4.0.24
                admin:          6.3.5
                javascript:     6.1.4
                Adapters from github:   2
                Adapter State
                + system.adapter.admin.0                  : admin                 : ioBrokerPi                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alarm.0                  : alarm                 : ioBrokerPi                               -  enabled
                + system.adapter.backitup.0               : backitup              : ioBrokerPi                               -  enabled
                + system.adapter.bmw.0                    : bmw                   : ioBrokerPi                               -  enabled
                + system.adapter.cloud.0                  : cloud                 : ioBrokerPi                               -  enabled
                  system.adapter.daswetter.0              : daswetter             : ioBrokerPi                               -  enabled
                + system.adapter.discovery.0              : discovery             : ioBrokerPi                               -  enabled
                  system.adapter.dwd.0                    : dwd                   : ioBrokerPi                               -  enabled
                + system.adapter.geofency.0               : geofency              : ioBrokerPi                               -  enabled, port: 7999, bind: 0.0.0.0
                + system.adapter.homeconnect.0            : homeconnect           : ioBrokerPi                               -  enabled
                + system.adapter.homekit-controller.0     : homekit-controller    : ioBrokerPi                               -  enabled
                + system.adapter.javascript.0             : javascript            : ioBrokerPi                               -  enabled
                  system.adapter.landroid.0               : landroid              : ioBrokerPi                               - disabled
                + system.adapter.lg-thinq.0               : lg-thinq              : ioBrokerPi                               -  enabled
                + system.adapter.loxone.0                 : loxone                : ioBrokerPi                               -  enabled, port: 80
                + system.adapter.net-tools.0              : net-tools             : ioBrokerPi                               -  enabled
                + system.adapter.nina.0                   : nina                  : ioBrokerPi                               -  enabled
                + system.adapter.node-red.0               : node-red              : ioBrokerPi                               -  enabled, port: 1880, bind: 0.0.0.0
                + system.adapter.ping.0                   : ping                  : ioBrokerPi                               -  enabled
                  system.adapter.reolink.0                : reolink               : ioBrokerPi                               - disabled
                + system.adapter.reolink.1                : reolink               : ioBrokerPi                               - disabled
                + system.adapter.reolink.2                : reolink               : ioBrokerPi                               -  enabled
                  system.adapter.reolink.3                : reolink               : ioBrokerPi                               - disabled
                  system.adapter.reolink.4                : reolink               : ioBrokerPi                               - disabled
                  system.adapter.reolink.5                : reolink               : ioBrokerPi                               - disabled
                + system.adapter.samsung.0                : samsung               : ioBrokerPi                               -  enabled
                + system.adapter.simple-api.0             : simple-api            : ioBrokerPi                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  system.adapter.solarwetter.0            : solarwetter           : ioBrokerPi                               -  enabled
                  system.adapter.weatherunderground.0     : weatherunderground    : ioBrokerPi                               -  enabled
                  system.adapter.weatherunderground.1     : weatherunderground    : ioBrokerPi                               -  enabled
                + system.adapter.worx.0                   : worx                  : ioBrokerPi                               -  enabled
                + system.adapter.yahka.0                  : yahka                 : ioBrokerPi                               -  enabled
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Objects and States
                Objects:        10450
                States:         8419
                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:2 http://deb.debian.org/debian bullseye InRelease
                Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:5 https://linux.teamviewer.com/deb stable InRelease
                Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
                Hit:7 https://repo.homebridge.io stable InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:39619         0.0.0.0:*               LISTEN      116        1027712    218340/homebridge:
                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       612208     218206/node-red
                tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          734        623/vncserver-x11-c
                tcp        0      0 0.0.0.0:5938            0.0.0.0:*               LISTEN      0          1017263    406348/teamviewerd
                tcp        0      0 127.0.0.1:44549         0.0.0.0:*               LISTEN      1001       616532     218875/io.yahka.0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          638        656/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:40435         0.0.0.0:*               LISTEN      116        612338     218278/homebridge
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       610697     216843/iobroker.js-
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       612593     216843/iobroker.js-
                tcp        0      0 0.0.0.0:44083           0.0.0.0:*               LISTEN      1001       614202     218875/io.yahka.0
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15354      921/exim4
                tcp        0      0 127.0.0.1:36971         0.0.0.0:*               LISTEN      116        1025518    218278/homebridge
                tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          1017265    406348/teamviewerd
                tcp        0      0 127.0.0.1:6011          0.0.0.0:*               LISTEN      1000       1356322    608524/sshd: pi@pts
                tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       1356914    608219/sshd: pi@pts
                tcp        0      0 127.0.0.1:46197         0.0.0.0:*               LISTEN      116        1026919    218278/homebridge
                tcp6       0      0 :::54900                :::*                    LISTEN      116        612034     218346/homebridge:
                tcp6       0      0 :::5900                 :::*                    LISTEN      0          733        623/vncserver-x11-c
                tcp6       0      0 :::5938                 :::*                    LISTEN      0          1017261    406348/teamviewerd
                tcp6       0      0 :::34623                :::*                    LISTEN      116        612084     218340/homebridge:
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15355      921/exim4
                tcp6       0      0 ::1:6011                :::*                    LISTEN      1000       1356321    608524/sshd: pi@pts
                tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       1356913    608219/sshd: pi@pts
                tcp6       0      0 :::22                   :::*                    LISTEN      0          640        656/sshd: /usr/sbin
                tcp6       0      0 :::41095                :::*                    LISTEN      116        611079     218339/homebridge:
                tcp6       0      0 :::8581                 :::*                    LISTEN      116        613689     216910/hb-service
                tcp6       0      0 :::40463                :::*                    LISTEN      116        613864     218358/homebridge:
                tcp6       0      0 :::7999                 :::*                    LISTEN      1001       611931     218198/io.geofency.
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       616493     218783/io.simple-ap
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       611773     216947/io.admin.0
                tcp6       0      0 :::56771                :::*                    LISTEN      116        611115     218347/homebridge:
                tcp6       0      0 :::51619                :::*                    LISTEN      116        613763     218278/homebridge
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16458      520/dhcpcd
                udp        0      0 0.0.0.0:58508           0.0.0.0:*                           108        15402      442/avahi-daemon: r
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       614207     218875/io.yahka.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       614206     218875/io.yahka.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       615470     218634/io.homekit-c
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       613242     218206/node-red
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        613686     216910/hb-service
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15400      442/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                108        15401      442/avahi-daemon: r
                udp6       0      0 :::59619                :::*                                108        15403      442/avahi-daemon: r
                2023-04-27 21:40:24.303  - info: bmw.0 (413780) Found 1 bmw vehicles
                2023-04-27 21:42:58.735  - info: worx.0 (218834) No payload found
                2023-04-27 21:45:00.055  - info: host.ioBrokerPi instance system.adapter.dwd.0 started with pid 620555
                2023-04-27 21:45:02.739  - info: dwd.0 (620555) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
                2023-04-27 21:45:04.095  - info: host.ioBrokerPi instance system.adapter.daswetter.0 started with pid 620582
                2023-04-27 21:45:04.828  - info: dwd.0 (620555) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-04-27 21:45:05.383  - info: host.ioBrokerPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-04-27 21:45:06.599  - info: daswetter.0 (620582) starting. Version 3.1.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.16.0, js-controller: 4.0.24
                2023-04-27 21:45:07.765  - info: daswetter.0 (620582) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                2023-04-27 21:45:08.284  - info: daswetter.0 (620582) cleaned everything up...
                2023-04-27 21:45:08.303  - info: host.ioBrokerPi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-04-27 21:45:25.456  - info: bmw.0 (413780) Found 1 bmw vehicles
                2023-04-27 21:50:00.046  - info: host.ioBrokerPi instance system.adapter.dwd.0 started with pid 621711
                2023-04-27 21:50:02.542  - info: dwd.0 (621711) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
                2023-04-27 21:50:04.536  - info: dwd.0 (621711) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-04-27 21:50:05.121  - info: host.ioBrokerPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-04-27 21:50:24.777  - info: bmw.0 (413780) Found 1 bmw vehicles
                2023-04-27 21:50:36.029  - info: homekit-controller.0 (218634) IP-7A:0C:6C:53:B1:DF (Bungalow) found without known pairing data and already paired: ignoring
                2023-04-27 21:52:46.685  - info: admin.0 (216947) ==> Connected system.user.admin from ::ffff:192.168.7.1
                2023-04-27 21:52:58.784  - info: worx.0 (218834) No payload found
                2023-04-27 21:55:00.047  - info: host.ioBrokerPi instance system.adapter.dwd.0 started with pid 623022
                2023-04-27 21:55:02.716  - info: dwd.0 (623022) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
                2023-04-27 21:55:04.411  - info: dwd.0 (623022) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-04-27 21:55:05.000  - info: host.ioBrokerPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-04-27 21:55:24.661  - info: bmw.0 (413780) Found 1 bmw vehicles
                iob diag has finished.
                Press any key for a summary
                  @tomme
                  Was sagt denn
                  iob diag
                  Tomme
                  @codierknecht
                  Copy text starting here:
                                       v.2023-04-16
                  Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                  Kernel:                 6.1.21-v8+
                  Installation:           Native
                  User-ID:                1000
                  X-Server:               true
                  Pending OS-Updates:     0
                  Pending iob updates:    0
                  Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                          /usr/bin/npm            9.5.1
                                          /usr/bin/npx            9.5.1
                  Recommended versions are nodejs 18.x.y and npm 9.x.y
                  MEMORY:
                  Mem:            7.8G        2.5G        1.5G         78M        3.8G        5.0G
                  Swap:           3.7G          0B        3.7G
                  Active iob-Instances:   23
                  ioBroker Core:          js-controller           4.0.24
                                          admin                   6.3.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                10450
                  States:                 8419
                  Size of iob-Database:
                  12M     /opt/iobroker/iobroker-data/states.jsonl
                    @tomme
                    Was sagt denn
                    iob diag
                    Tomme
                    @codierknecht
                    iwi fehlt da immer der reolink adapter ... davon habe ich 6 instanzen ... aber wird nicht angezeigt ich schau mal ob die gelöscht sind ;/
                    ... sind noch da
                    • CodierknechtC Offline
                      Codierknecht
                      @tomme
                      Da läuft ein Desktop. Der hat auf 'nem Server nix verloren.
                      Und das Boot-Target sollte dann auch gleich auf multi-user.target umgestellt werden.
                      T 2 Antworten Letzte Antwort
                        @tomme
                        Tomme
                        @codierknecht
                        den desktop schalte ich aus wenn alles läuft
                        und von dem anderen habe ich keine ahnung ... leider
                          @tomme
                          Tomme
                          @codierknecht
                          hab ich jetzt was falsch gemacht?
                          pi@ioBrokerPi:/opt/iobroker $ iob setup
                          Successfully migrated 10450 objects to Redis Sets
                          object 0_userdata.0.example_state yet exists
                          object 0_userdata.0 yet exists
                          object alias.0 yet exists
                          object system.certificates yet exists
                          object system.licenses yet exists
                          object system.repositories yet exists
                          object system.config yet exists
                          object enum.functions yet exists
                          object enum.rooms yet exists
                          object system.group.user yet exists
                          object system.group.administrator yet exists
                          object _design/system updated
                          • T Tomme
                            @codierknecht
                            Codierknecht
                            Wenn Du den nur ausschaltest, schleppst Du den Kram ja trotzdem weiterhin mit.
                            Nur damit da keine falsche Hoffnung aufkommt: Ich auch nicht wirklich - ich nutze an der Ecke einen fertigen Container.
                            Vielleicht kann ja mal @Thomas-Braun hier drüberschauen?
                              Tomme
                              woher weißt du wie ich heiße??? ist ja witzig 👍
                                Tomme
                                @codierknecht
                                an docker habe ich mich noch nicht ran getraut ... wollte erstmal hiermit klar kommen
                                • T Tomme
                                  @codierknecht
                                  @tomme
                                  Finger weg von
                                  Das zieht dir ggfls. unwiederbringlich die Installation auf Links.
                                  Und ein Desktop inkl. Teamviewer hat auf einem Server nic verloren.
                                  Installier es neu, diesmal gescheit.
                                    @tomme
                                    Finger weg von
                                    Tomme
                                    moin,
                                    alles neu?
                                    kriegen wir wenigstens das backup vorher zum laufen???
                                    teamviewer ist schnell gelöscht
                                    • T Tomme
                                      moin,
                                      alles neu?
                                      @tomme
                                      Hast du etwa keins von vor dem Blödsinn?
                                        @tomme
                                        Tomme
                                        na nee darum bin ich ja hier ... 🤕
                                          @tomme
                                          Tomme
                                          du heißt übrigens genau wie ich ... das ist sehr löblich ;)
                                          32.7k
                                          82.6k
